GA with VTA mode released. Read all about it including updated instructions on my site here: http://www.stratifiedauto.com/index....roducts_id=217 I've got 5 units available ATM and 100 more being built. I kept the $179 price for these next 5, but they will go up to 199 when the new batch arrives due to new functionality being added. We're also on facebook: http://www.facebook.com/StratifiedAutomotiveControls And for those of you that dislike facebook, check out the blog: http://www.stratifiedauto.com/blog/ The last article I wrote in there about the mod path should be a good read. @Mistersix @himurax13 Thanks for all the support everyone! |
so quick question @Lex what would i have to do to run VTA with the HKS SSQV3? Just toying with the idea |
Can't wait to get mine. Thanks Lex! Sent from my DROID RAZR using Tapatalk 2 |
Lex, when are you going to send me an invoice? ;) |
@Lex I dont wanna make an account. I just want your device. can you send me an invoice and i will pay you in the morning. or a paypal. |
So with the VTA feature would I be better off running a BOV instead of a BPV? Sent from my DROID RAZR using Tapatalk 2 |
@Lex I sent you a pm for an invoice but never heard from ya with the holiday and all. I'm feeling less lazy than before and made an account and am placing my order. Ha, just checked my email and there it is. DUH!!! |
Order placed and paid. Send that puppy aht! |
And for those of you asking how the Forge sounds VTA, it's in this video I made. For those of you that don't want to sit through the explanation of how it works just to 1:45. http://www.youtube.com/watch?feature...&v=vsyLnHch9Do |
@Lex Will the GA come with VTA on as the default or do we have to do the blue wire dealie? Sent from my DROID RAZR using Tapatalk 2 |
@Lex any idea what a good temporary plug for the recirc hose would be til i get the JBR intake without the recirc fitting? |
Or over the recirc port on the intake? If your fine with just sticking a plug into the recirc hose and having it dangle around in the engine bay, then go to lowes or home depot and buy a pvc plug for 75 cents. It works just fine but looks bad. |
@Lex So if I were to run the GA with VTA mode on, how would the car react if I had a 50/50 re-circulation? Put in my order last night and just trying to gauge all setup options. Thanks. |
It couldn't hurt to have some of the air recirc'd with the GA since it only effects the bpv actuation. could be an effective solution. @Lex |
Lex how does the Turbosmart Dual Port in 50/50 hybrid mode work with the VTA software? |
Some one should lend @Lex they're dual port valve for testing. |
Please forgive my noobish tl;dr question, is the Cobb XLE BPV a "push" style valve? and to what if any disadvantage do I face should I purchase said guardian angel and run full VTA? |
I can see no disadvantage running the gaurdian angle. It protects your motor from over boosting by releasing excessive boost threw the valve instead of cutting fuel or some other abrupt way. It also keeps the valve closed during idle and close's faster in between shifts while using the VTA feature. |
@Lex Ive got 2 questions at once. Im thinking of adding a Snow performance safe injection unit to trigger the GA in the case of loss of flow in my meth set up. Your instructions for the GA say to use a trigger of 5v or higher, the Snow unit has a 12v trigger signal, just want to make sure this is fine since it is double your given value. Second part of the question is if I go this route, with the impliment of the VTA software, should the trigger activate, will the 12v signal from the meth injection unit trigger the on/off vta option? I gues what im getting at is since it uses the same blue wire, will the GA know the difference of me putting the 12v to switch the vta on/off from it recieving the 12v from an external trigger to activate and "blow off" |
1. The trigger signal should be 5V or higher. So 12V or battery voltage will trigger the GA just fine. 2. The VTA toggle only works for the second or 2 when the GA turns on. This is why you have to hold the trigger wire to 12V when you just start it up. After the startup, the trigger will just act as a trigger for the failsafe. |
@Lex Ok so last good question. For those of us that have the GA version 1 w/o the updated software, what is the address to send it back to you, how much, and do you need all the wireing as well (kind of a bitch to have to rip it all out so Im hoping the answer is no) |
Lexster, I just looked at your install instructions and have a good idea of how the unit works now. Question: Running GA in VTA mode and having an overboost condition will cause excess pressure to VTA. This is likely to cause a sudden rich condition (depending on amount of air exhausted), correct? Obviously, a correctly tuned car is preferred and the overboost rich condition would only be a case if something went wrong. I was about to buy but they are out of stock again. Looks like Ill be on the next shipment buy. Tried out a HKS (which has.... issues) and am not really liking it. |
Got my GA installed and dialed in today. Works like a champ. Idle is good and stoich. shifts are much better and the boost protection is top notch. A much better way than fuel cut. there are two issues however. The stock valve i'm currently running does flutter a bit. At part throttle and WOT. Whatever, i need and adjustable valve. But, once the VTA function is enabled the red light stays on??? This is terribly annoying. And that little fucker is bright. I dug the fact that it comes on when it see's over boost but on all the time other than high load? So at this point i'm basically gonna make sure its dialed in and then bury the red light somewhere. I'm pretty bummed about this to be honest. |
| All times are GMT -7. The time now is 01:57 AM. |
