E-Tuners / Custom Hardparts
Notices
Like Tree53Likes
 Old 07-17-2012, 02:39 PM   #361
Posts: 9,587   (View Stats)
Originally Posted by himurax13 View Post
Too bad there isn't a core exchange program due to the limited amount. Maybe once these are in production that might be a possibility. Probably an extra charge since the unit that is coming is in better shape than the one being swapped.
Except for the LED light issue (which isn't a problem for me since I haven't routed it through the firewall yet) I haven't had any issues with the VTA software thus far. My Turbosmart and Forge V1 sound and act the same as if they were in recirc mode. If I had a complaint, it would be that. I was hoping for more noise.
Lex if we were to log our shifts, what would we be looking for to see if everything is working properly? How should the logs be taken?
If you want to compare - log the following:
1. A shift with valve in recirc and VTA feature off
2. A shift with valve in VTA and VTA feature off
3. A shift with valve in VTA and VTA feature on
I would do the 3 above in 3 scenarios:
1. A shift
2. Letting off the gas and not shifting after boosting
3. Idle
I've already done this during development but if you want to see how things look take a look at AFRs.
Lex is online now   Reply With Quote
 Old 07-17-2012, 02:43 PM   #362
himurax13's Avatar
Posts: 2,184   (View Stats)
Groans: 34
1. A shift
3. Idle
Oh OK, so its just a matter of AFR since the whole point of this feature is to reduce the rich condition that VTA causes. With my "Informal" field testing, I couldn't tell the difference between VTA or Recirc, which I believe was the goal.
I wish I had a decibel meter to measure if the the BOV's are louder in VTA mode. Maybe I should keep lightening the spring pressure?
Ohnononono pinoyboi.
Listen my adobo cooking friend. You will move to NJ. I shall take you under my wing. You will void that warranty. Your wife will be very upset with you that you spend every Tuesday night with us, and you use all your extra monies to buy all the parts I shall find for you. You will sushi roll and ffs up and down the GSP with us. You will end up on YouTube and in the street racing videos. And last, but not least, you will allow us access to employee pricing on all parts thru your dealership.
Are you sure you still want to come to NJ? We go hard here.....be warned.
I too once was a naive ayshun with a stock pu. Then I met these fuckers. My wife hates me now Tuesday nights. My neighbors hate my car for the uber cool cold start. My garage is a fucking mess. My warranty went out the window. My life has not been the same since April. I should have bought a Mazda2.
himurax13 is online now   Reply With Quote
 Old 07-17-2012, 10:13 PM   #363
himurax13's Avatar
Groans: 34
Did some more informal field testing. Lowering the spring pressure on the Turbosmart Dual Port is definitely making it louder. I got some pedestrians from a few hundred feet away to turn around with only 13 lbs of boost.
Lex (07-22-2012)
 Old 07-21-2012, 04:38 PM   #364
Dmurray06's Avatar
Posts: 2,578   (View Stats)
Groans: 121
Groaned at 49 Times in 15 Posts
Got my Guardian Angel installed today, god damn that thing is badass!
And I left a review on your site Lex
Thanks!
2010 Mazdaspeed 3 Black Mica w/ Tech Package
Insalled: Corksport SRI/TIP // Cobb AccessPort// Autotech Internals // Corksport LED Kit // Corksport Stubby Antenna // Forge v2 BPV // JBR SSP// JBR 80a RMM // JBR Weighted Shift Knob // ETS TMIC // Corksport Catless Downpipe // Corksport RacePipe // Denso itv22 // Stratified Guardian Angel // block8head Defrost Pod // Prosport Boost Gauge // Zoom Boom Box
Awaiting Install: HTP 3" TIP // HTP Battery Tray // Sure 3" MAF // Stratified Boost Dial
Dmurray06 is online now   Reply With Quote
The Following User Says Thank You to Dmurray06 For This Useful Post:
Lex (07-22-2012)
 Old 07-21-2012, 04:50 PM   #365
IMASA's Avatar
Posts: 118   (View Stats)
IMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond reputeIMASA has a reputation beyond repute
Are there any issues if I'm running my Forge as a BPV but I have the GA with VTA enabled?
thanks
2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb RSB | CP-E SRI Nano | CP-E RMM | CP-E TIH | CP-E HPFP | H&R Springs | Koni Yellows | TWM STS | OCC | Dashhawk | 273hp/311ft lbs
IMASA is offline   Reply With Quote
The Following User Says Thank You to IMASA For This Useful Post:
Lex (07-22-2012)
 Old 07-21-2012, 05:01 PM   #366
Dmurray06's Avatar
Groans: 121
thanks
Ummm...not sure, but if your using it as a BPV just toggle the VTA feature off, then your good.
Lex (07-22-2012)
 Old 07-21-2012, 06:04 PM   #367
speed_freak91's Avatar
Posts: 695   (View Stats)
speed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the worldspeed_freak91 is the leader of the world
How the hell did I miss this thread until now?
Lex I see your out of the GA's on your website. When might you be getting more in?
2008.5 CWP MazdaSpeed 3:
--Cobb SRI--Cobb TIH--Cobb AP--Cobb V2 Piping--Treadstone TR8 Core
--Autotech HPFP Internals----Grimmspeed EBC--NGK LTR7IX-11--JBR SSP+Bushings--
--JBR Trilogy Mounts--JBR RSB--JBR AP mount--JBR 5mm Wheel Spacers--
--M3 Endlinks--KW V2--Advan RZ 18x8.5+45--Dunlop Star Spec 235/40-18--
--Corksport Camber Plates--SPC Camber Arms--MD OCC V1--
speed_freak91 is offline   Reply With Quote
The Following User Says Thank You to speed_freak91 For This Useful Post:
Lex (07-22-2012)
 Old 07-21-2012, 06:53 PM   #368
Dmurray06's Avatar
Groans: 121
Target is before the end of this month. I will post in here once they come in.
There you go
Lex (07-22-2012)
 Old 07-22-2012, 12:11 AM   #369
himurax13's Avatar
Groans: 34
thanks
I didn't have any issues running the Turbosmart Dualport or my Forge V1 in recirc with the VTA software installed. However, I didn't take any logs either.
The Following 2 Users Say Thank You to himurax13 For This Useful Post:
IMASA (07-22-2012), Lex (07-22-2012)
 Old 07-22-2012, 06:53 AM   #370
Mistersix's Avatar
Posts: 1,958   (View Stats)
It should work just fine. All the GA is doing is holding the valve closed at idle. And forcing it closed faster in between shifts.
However, i've been running my GA with the VTA feature engaged on the stock valve and it flutters like crazy. But its not the valve.
Me and a friend got a flash light and looked in it and watched as i mashed the throttle. It closes tight and seals, then the fluttering sound follows. I believe the sound to be the air being chopped up by the impeller in the compressor side.
Can this eventually damage the turbo?
Cobb ap,sf,inlet//Custom fmic TR-8//Cp-e dp//3bar map//fp internals//Stratified GA//GFB respons//MD OCC//AWR mounts//TT diff mount//H&R springs//235's on RX-8's
The Following User Says Thank You to Mistersix For This Useful Post:
Lex (07-22-2012)
 Old 07-22-2012, 10:10 AM   #371
You're getting a bit of compressor surge. The oem valve is fast with a very stiff spring so it tends to cause more surge than other valves. In my testing it was minimal and non damaging. There has to be a compromise between drive ability and surge. The later you keep the valve open the poorer the drive ability and the earlier you close it the more potential for surge so after quite a bit of testing I struck what felt like the best balance. Mild flutter at low boost pressures should not cause any damage. Valves like the hks allow for some flutter as well to improve boost holding and drive ability.
If you have an aftermarket valve you can soften the spring to get it just right but the oem is not adjustable. With the oem however you can try plugging the small hole at the bottom of the valve and see how it reacts. That hole is for the second chamber of the valve.
thanks
No issues. Some report better shifting so if you like it better you can run it this way without problems.
Last edited by Lex; 07-22-2012 at 10:10 AM. Reason: MSF Database - Automerged Doublepost
IMASA (07-22-2012), Mistersix (07-22-2012)
 Old 07-22-2012, 10:16 AM   #372
Mistersix's Avatar
Just as i assumed. The whole point is for it to close fast in an attempt to some air in. which helps with the afr's.
An adjustable valve is next on my list.
Lex (07-22-2012)
 Old 07-22-2012, 10:33 AM   #373
IMASA's Avatar
Great thanks! I ordered a VTA plug from Edge. I was going to install the GA today, but wanted to have the VTA mode enabled while running recirc until the plug comes. I plan on trying to do a clean install so all wires will be wraped/tucked away.
Lex (07-22-2012)
 Old 07-22-2012, 11:33 AM   #374
Dmurray06's Avatar
Groans: 121
The home depot plumbing department solved my problems lol.
The Following 5 Users Say Thank You to Dmurray06 For This Useful Post:
IMASA (07-22-2012), Lex (07-22-2012), m249saw (07-22-2012), Mistersix (07-22-2012), rfinkle2 (01-30-2013)
 Old 07-22-2012, 11:45 AM   #375
Firemedic/Arms Dealer
m249saw's Avatar
Posts: 718   (View Stats)
m249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the worldm249saw is the leader of the world
Groaned at 7 Times in 6 Posts
and
1/2 inch threaded cap and threaded slip fitting
Threaded together and slip right in the recirc hose with plenty of area to clamp it down tight
2012 Subaru STi Wagon, Dark Grey Metallic. Stock as fuck.
m249saw is online now   Reply With Quote
The Following 2 Users Say Thank You to m249saw For This Useful Post:
 Old 07-22-2012, 11:50 AM   #376
Thanks!
Thank you for the very kind words. I will have another decal for you in the mail
Dmurray06 (07-22-2012)
 Old 07-22-2012, 12:20 PM   #377
Dmurray06's Avatar
Groans: 121
Sweet deal, thanks a lot Alex!
Lex (07-22-2012)
 Old 07-22-2012, 06:29 PM   #378
IMASA's Avatar
Thanks for the tip. I ran out to HD and picked up a 3/4" plug that worked fine.
I installed this today and it was easier than I expected.
After driving around for a few kms, I noticed that on rare occasions, at very light throttle, the car hesitates/studders a bit. My LTFT's are no more than ~+/- 4. I should put a softer spring in my Forge V1 and see if it helps.
Overall I'm quite impressed with this product. Everything from the quick shipping, packaging, excellent build quality and obviously the way the GA performs, is top notch. The added VTA feature is a nice bonus.
Thanks Lex!!!
The Following 2 Users Say Thank You to IMASA For This Useful Post:
Dmurray06 (07-22-2012), Lex (07-23-2012)
 Old 07-22-2012, 07:11 PM   #379
m249saw's Avatar
Mine did the same thing under light throttle though has gone away. Give it some time to let your LTFTs settle, a softer spring will allow the valve to open more at partial throttle.
Sent telepathetically to my Razr Maxx
IMASA (07-22-2012), Lex (07-23-2012)
 Old 07-23-2012, 12:48 AM   #380
The slight hesitation will be more pronounced when the car is cold and the ECU commands a richer mixture. It should smooth out after a couple of minutes as it warms up.
 Old 07-23-2012, 10:07 AM   #381
himurax13's Avatar
Groans: 34
With the Turbosmart Dual Port, it will definately get a compressor surge if the spring tension is too high. When I lowered the spring tension, the compressor surge went away and the BOV sound got much louder. I am running mine 2.5 turns from unscrewing the cap and it works great. If the Guardian Angel overboost protection engages, it sounds like a loud whoosh to let you know that you are overboosting. At this point, just let off the throttle a little and keep on trucking. I feel all warm and squishy inside knowing that I wont be hitting 30+ PSI anymore.
The valve does flutter a little during shifts if the boost is really low. It shifts great, no backfiring noises, and I get the ridiculous ricer sound that most people expect when driving a Turbo car.
For plugging the recirc hose, I went to Lowe's and I bought a #7 (Maybe a #8) Rubber stopper, shoved it into the recirc hose, and clamped her down. I think the part was like $2.
Lex (07-23-2012)
 Old 07-27-2012, 06:11 PM   #382
FistPump20fo7's Avatar
Posts: 43   (View Stats)
FistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond reputeFistPump20fo7 has a reputation beyond repute
I switched to a softer spring on my turbosmart dual port and there isnt any flutter, even at partial throttle let-off. It is holding my requested boost as well. I'm prob eventually going to switch back to recirc in the future since the sound might get annoying after awhile... Great product Lex
Also submitted a review!
-Calvin
2011 VR Non-tech Speed3 : TORQ STR
e30 Stratified tuned
93 octane 314whp/353wtq 47amb -130'elevation
FistPump20fo7 is online now   Reply With Quote
The Following 2 Users Say Thank You to FistPump20fo7 For This Useful Post:
Dmurray06 (07-27-2012), Lex (07-27-2012)
 Old 08-01-2012, 04:38 AM   #383
Mistersix's Avatar
So i've been doing some tuning and the car runs great. However, part throttle and WOT gives a lean condition but only when shifting. If i just do single gear WOT datalog, afr's are spot on. If i do multiple gear pulls, afr's go into the mid 12's.
Is this because VTA?
 Old 08-01-2012, 05:36 AM   #384
InFeXIoN's Avatar
Posts: 1,173   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
dantes5823
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is online now   Reply With Quote
 Old 08-01-2012, 06:23 AM   #385
dantes5823's Avatar
Posts: 6,674   (View Stats)
If anything you should go rich. But going into the 12's is better than 9's to me.
Lex (08-01-2012)
 Old 08-01-2012, 08:54 AM   #386
Nope, if the BPV was opening you would go rich as you would be blowing out boosted/metered air. Going lean is from something else. Check that your recirc. tube is well sealed.
 Old 08-01-2012, 05:43 PM   #387
Mistersix's Avatar
Ya i gotta look at that thing again. as it gave me problems once. But its weird that it only does it when i lift shift. Single gear WOT pulls nail afr's.
 Old 08-05-2012, 09:23 PM   #388
vrspeed10's Avatar
Posts: 977   (View Stats)
vrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the worldvrspeed10 is the leader of the world
Groaned at 25 Times in 10 Posts
I have been hearing about this thread. Subbing for some kick ass work by one of msf finest!!
If your not first your last.
03 Speed Protege.. SOLD
10 Speed3 Bolted and getting Dizzy!!
vrspeed10 is offline   Reply With Quote
The Following User Says Thank You to vrspeed10 For This Useful Post:
Lex (08-05-2012)
 Old 08-06-2012, 04:40 AM   #389
Mistersix's Avatar
That recirc tube is plugged air tight. I dunno. The only time afr's go wonky is during multiple gear runs.
This is the latest log i took. 1st threw 3rd gear. Look at row 23.
 Old 08-06-2012, 10:04 PM   #390
That's normal post spool behavior. You can help it with reducing timers and adjusting the tables but the WBO2 readings will read a little lean post spool. Nothing to worry about in regards to that.
Mistersix (08-07-2012)
 Old 10-12-2012, 10:35 PM   #391
XerocX's Avatar
Posts: 455   (View Stats)
XerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond reputeXerocX has a reputation beyond repute
Originally Posted by FistPump20fo7 View Post
I switched to a softer spring on my turbosmart dual port and there isn't any flutter, even at partial throttle let-off. It is holding my requested boost as well. I'm prob eventually going to switch back to recirc in the future since the sound might get annoying after awhile... Great product Lex
-Calvin
Where exactly do you order a softer spring from? I went on the Turbosmart website but I can't seem to find them, any help appreciated. Thanks FistPump20fo7
2009 CWP MS3
COBB Accessport, COBB SRI, HTP TIP, PG FMIC, Autotech internals, Guardian Angel, TurboSmart Dualport BOV (VTA), CNT Catless DP + CBE, JBR Dogbone rmm, JBR RSB, Sure Shortcut, H&R Springs, CPE tow plate, MRR GT-1 18x8.5+ 35
XerocX is offline   Reply With Quote
 Old 11-02-2012, 07:31 AM   #392
This is what I have:
Turbosmart Blow-Off Valve Springs TS-0205-3102 - SummitRacing.com
As per turbosmarts instructions, remember to oil it with some machine oil. I do once every couple months.
 Old 11-02-2012, 02:25 PM   #393
XerocX's Avatar
Thank you good sir! I see that it is rated at 10-17 in. HG. I'm running 19.5 psi as of now, I wonder if this would be a problem? Thanks
2009 CWP MS3
 Old 11-05-2012, 07:38 PM   #394
I'm running 18.5psi spiking at 19psi with no issue and I have a decent amount of adjustment space left to tighten the valve more.
 Old 11-05-2012, 08:36 PM   #395
XerocX's Avatar
Ah! That's great! Thank you sir! Ordering ASAP!!
2009 CWP MS3
 Old 01-27-2013, 06:47 PM   #396
jdub0802's Avatar
Posts: 120   (View Stats)
jdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond reputejdub0802 has a reputation beyond repute
Is anybody running the GFB in full VTA mode with the GA? I will be trading my Cobb XLE for a GFB BPV this coming week. If so how tight/loose are you running the spring to get the best performance.
2011 Speed 3 - Mica Black - Non Tech
Mods Installed: JBR SSR Level 2 with Big Knob/ JBR Motor Mounts / Cobb AP / Cobb TIP + SRI / GFB BPV / CS Race Pipe / Autotech Internals / Denso IVT-22 / JBR Throttle Body Gasket & Bypass / JBR EGR Block Off / JBR TIG / JBR RSB / GA
Apperance: DDM 6000k HID / JBR Mud Flaps / Windows Tinted
Tuning with Boost_Creep in Progress! Working towards Corn.
jdub0802 is offline   Reply With Quote
 Old 01-30-2013, 04:22 AM   #397
Mistersix's Avatar
I run the stock valve and get just a little bit of flutter after the valve blows off. This is the GA closing the valve quickly. So you want a little flutter. Adjust till you get a little flutter but a majority of the air gets released.
Are you gonna run It full VTA or dual ported?
The Following 2 Users Say Thank You to Mistersix For This Useful Post:
jdub0802 (01-31-2013), Lex (01-30-2013)
 Old 01-30-2013, 09:33 AM   #398
If the valve is adjustable you will easily be able to get it to very sweet spot where the car will run like stock but in full VTA. The OEM valve was one of the toughest ones to tune using the GA.
 Old 01-31-2013, 06:11 AM   #399
jdub0802's Avatar
Mistersix; I am running full VTA and loving it. Got the GFB valve yesterday and took her out for a test drive. Loosed the spring a little bit and it got even better. I am amazed at the difference between the Cobb and GFB valves and how they behave. For VTA the GFB is so much better.
The Following 2 Users Say Thank You to jdub0802 For This Useful Post:
Koke382 (01-31-2013), Lex (01-31-2013)
 Old 02-01-2013, 05:19 PM   #400
Mistersix's Avatar
I need a good adjustable valve. Though my stocker works pretty good as far as drive-ability and sound goes. Lex; Curious, what adjustable valve would you suggest?
Page generated in 0.61648 seconds with 32 queries
