 Old 12-21-2011, 06:17 AM   #601
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Originally Posted by wolly6973 View Post
Yes it is true. When you add an intake and remove one of the cats you need a fp.
This^.
rfinkle2 is offline
 Old 12-21-2011, 02:48 PM   #602
LakeSTLMS3's Avatar
Posts: 281   (View Stats)
LakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the worldLakeSTLMS3 is the leader of the world
Originally Posted by babyjake View Post
im thinking of getting the corksport cbe and test pipe and a k&n sri, people are saying i need a different fuel pump for this, is that true? or will it be fine?
Wolly and finkle are right, you should upgrade your pump. However, many of us have run these mods before w/o internals or a new pump and have had no problems. If I were you, I would hold off on the cbe and get an AP. Then you can log your fuel pressure and see if you need to upgrade your pump or not. Just my .02
2011 Black Mica Genpu
COBB AP / Corksport SRI & TIP - LED fog kit - exhaust hangers / StreetUnit testpipe / OBX CBE / Ultimate Racing catted DP / CP-e TMIC - tow plate / Eibach Pro kit / KMD internals / Turbosmart dualport bov / ITV22 denso plugs / TRZ dogbone RMM / JBR 80duro TMM - 80duro PMM - heavy shift knob - SSP - shifter bushings - mud flaps - RSB - 5mm spacers - EGR block off - TB TIG and coolant bypass / RX-8 wheels 18x8 / 245/40/18 Pirelli's / Aeroforce gauges
Stratified!........
E85 tuned - VD 348whp/396tq
Future Mods:
Koni yellows - OCC - BNR S3 - FMIC - JBR big intake - Cobb 3port - Bosch 3 bar - GA - retune from Lex
LakeSTLMS3 is offline
 Old 12-26-2011, 11:50 AM   #603
Scoobs's Avatar
Posts: 750   (View Stats)
Scoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the worldScoobs is the leader of the world
This^.
Yep, FP upgrade. This is why I'm getting mine at the same time as my SRI/TIP, I will have all the room to do it all at once.
Accessport is worth it, and needed. So I know what I'm getting for my B-day this March.
The rest comes in this summer, no point jumping steps and killing the MS3. Do it right the first time.
Sold
2010 Speed3 Black Mica tech pack, JBR RMM 80 duro, Cobb SRI, stupid horn fixed with low tone add on.
New
2012 Mazda2 GS Aluminum Metallic Mica, Corksport rear torsion bar, Corksport H11 Led fog bulbs, Piaa H4 x-treme white bulbs, AWR rmm 70duro....more to come
Wife's car
2011 Mazda2 True Red GS (Touring in the US), wifes car, no mods so far but she want a Corksport CBE, Corksport SRI and a drop in the futur. <-----
Scoobs is offline
 Old 01-02-2012, 06:34 PM   #604
davinspeed3's Avatar
Posts: 252   (View Stats)
davinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the worlddavinspeed3 is the leader of the world
Groans: 28
Originally Posted by Scoobs View Post
Any vids with Cobb down pipe with OEM CBE untouched, (or CP-E catted on untouched CBE) well you get the picture....getting to stage 2 is more important to me than sound right now. But I would like to ear what it would sound like. Later I'll add a CBE for a good low sound...but first more powar!
i actually just installed my cp-e catted downpipe yesterday morning. power is amazing. as far as noise goes, it gave it a little deeper sounds( and is a little louder ), but it did also increase drone on acceleration and decel. it sounded decent but not enough for me, so this morning i went to local muffler shop and had the resonator taken out. WOW!! now it sounds much better and for only $30. i probably will get the cp-e cbe eventually ( like to keep tbe all one company) but this will get me by for a while. i'll try to get a video up asap but it will probably be a iphone vid so dont know how the quality will be. just fyi, with this setup it is fairly quite/stock sounding cruising along but once you accelerate it sounds mean. and oddly enough the drone seems less after deleting the res.
2011 BLACK MICA MAZDASPEED 3
25% E-85 Dizzy Tuned
CP-E SRI // CP-E TIP // CP-E DP // CP-E FMIC // CP-E TURBO MANIFOLD // COBB AP // COBB XLE BPV // SURE SHORTCUT & COUNTERWEIGHT // SURE ANCHORS // JBR DOGBONE RMM // TWM DESERT EAGLE KNOB // DENSO ITV 22's // AUTOTECH INTERNALS // RESONATOR DELETE // MD OCC // SWIFT SPRINGS
davinspeed3 is offline
 Old 01-05-2012, 10:12 PM   #605
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
specvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the worldspecvspeedfreak is the leader of the world
Groaned at 54 Times in 27 Posts
Short interior clip (driver window cracked open). Don't mind the crappy HID's, need to replace them.
2011 Mazdaspeed 3 Ultimate Racing cbe interior - YouTube
*COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite
specvspeedfreak is offline
 Old 01-06-2012, 06:40 PM   #606
Boost Addict's Avatar
Posts: 1,327   (View Stats)
2 new shitty vids of 2nd gear pull, Gen1 CNT 3" catted downpipe to OBX 3" cat back
FREEKTUNE
Boost Addict is offline
 Old 01-10-2012, 05:40 PM   #607
Groans: 28
@Scoobs dont know if you saw my other thread i made but here is my car with the cp-e catted dp and the resonator deleted on the stock exhaust. video actually doesnt do it justice, it sounds mean, almost straight pipe sounding. oh and video is from my iphone so..
 Old 01-11-2012, 06:04 AM   #608
Scoobs's Avatar
11 mazdaspeed 3 cp-e downpipe & resonator delete on stock exhaust - YouTube
Fuck yeah! Thanks man, sound good. You said you have less drone too with the resonator out, I beleive that, the oem exhaust has a lot of drone, the res delete would help. I love UR, CS and Magnaflow CBE but spending $800 for noise and larger tip drive me nuts. I want more HP/torque, for a little price the MS3 becomes a monster and I like that.
Stealthy with stock tips is a good thing too, cops are going nuts these days about aftermarket exhaust. Well its all because of Civics with fart-cans but they are cracking down.
Thanks for the vid!
Sold
New
Wife's car
Scoobs is offline
 Old 01-17-2012, 06:25 PM   #609
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
Mods in sig.
OEM Mani
Part Throttle
Part Throttle with a little more juice
2015 Mazda 6
IshiKage is offline
 Old 02-08-2012, 07:26 PM   #610
dantes5823's Avatar
Posts: 6,576   (View Stats)
Here an update vid..
First is an edited vid with a Cp-e catted downpipe then its an ebay catless with OBX CBE for both.
Then a few with launch control at 4500...just for kicks really.
And then just messing around the reservation.
dantes5823 is offline
 Old 02-08-2012, 07:35 PM   #611
myslow1's Avatar
Posts: 355   (View Stats)
myslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the worldmyslow1 is the leader of the world
sounds great!!!!!!!
Daily - 2007 True Red Mazdaspeed3 GT.
Jack Stand Race Car - 1991 Aquamarine Pearl MR2.
myslow1 is offline
 Old 02-08-2012, 07:36 PM   #612
dantes5823's Avatar
Originally Posted by myslow1 View Post
sounds great!!!!!!!
Thanks man. I think thats the last of updates lol. Might record a few proper clips with the camera on the bumper and actually get a few good WOT pulls.
 Old 02-25-2012, 07:51 AM   #613
chintastic's Avatar
Posts: 299   (View Stats)
chintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the worldchintastic is the leader of the world
gen 2 ms3 magnaflow cbe, cnt catless downpipe - YouTube this is my CNT catless downpipe with magnaflow catback
2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps,
chintastic is offline
 Old 02-27-2012, 08:17 PM   #614
mikede5's Avatar
Posts: 82   (View Stats)
mikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant futuremikede5 has a brilliant future
Here is the cheap ebay exhaust I just put on. No mods on this car besides the Speed Daddy exhaust. It sounds even deeper in person. Embed doesn't seem to work well on here.
mikede5 is offline
 Old 02-28-2012, 01:22 AM   #615
FightaX's Avatar
Posts: 1,221   (View Stats)
FightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the worldFightaX is the leader of the world
Groans: 32
When weather gets better, I will post one with corksport dp, corksport testpipe & HKS catback exhaust w/resonator delete.
2007 MS3 GT - Mazdaspeed CAI, Corksport Downpipe, Corksport Testpipe, HKS-CBE w/resonator delete, CP-E 75 RMM, Koni Yellows, H&R Springs, Greddy Type S Bov, Denso ITV 22s, Autotech Internals, Accessport Tuned (Thanks Phate!) ^^ - RIP 5/29/13, You will be missed <3
2013 MS3 - Mazdaspeed Intake, Turbo XS DP & TP, Ultimate Racing CBE, Greddy Type S Bov, Autotech Internals, AP OTS MAP ( Awaiting Tune )
FightaX is offline
 Old 02-28-2012, 01:26 PM   #616
mzr23's Avatar
Posts: 54   (View Stats)
mzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond reputemzr23 has a reputation beyond repute
In case anyone is interested.
Autoplicity.com. Magnaflow 15557 - 15557
Once you add it to the cart, you'll see the price is $452.71. That's the cheapest I've seen anywhere.
Also, they only have a generic magnaflow pic for some reason. I called them and they confirmed it was split exit for gen2.
mzr23 is offline
 Old 03-06-2012, 11:55 PM   #617
Mikedubs's Avatar
Posts: 16   (View Stats)
Mikedubs is a glorious beacon of lightMikedubs is a glorious beacon of lightMikedubs is a glorious beacon of lightMikedubs is a glorious beacon of lightMikedubs is a glorious beacon of light
I'm really tempted to buy it at 450, but it's a bit sketchy since they are the only ones at 450.
Mikedubs is offline
 Old 03-08-2012, 05:14 AM   #618
MS3G35's Avatar
Posts: 1,536   (View Stats)
MS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the worldMS3G35 is the leader of the world
Groans: 80
Has anyone seen this?
MazdaSPEED3 Gen2 Triton
Sound clip
http://youtu.be/MDDr3HLWCdI
CS SRI, TIP, SBT & BPH, BPV, SECBE/CP-e RMM, Catted-DP, TMIC/JBR SSP s2, RSB, TMM/AT Internals/Cobb AP/H&R springs/NGK plugs/SPC camber arms/MB Weapon rims/Pending install: Sure TIGS
285whp/321wtq-93
E85 tune in progress
MS3G35 is offline
 Old 03-08-2012, 05:58 AM   #619
Sig_Nasty's Avatar
Posts: 272   (View Stats)
Sig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the worldSig_Nasty is the leader of the world
Groaned at 4 Times in 1 Post
cant find the OBX cbe for the gen2 anywhere now..not even listed on their website
Sig_Nasty is offline
 Old 03-08-2012, 12:57 PM   #620
Mikedubs's Avatar
Sound clip
That is a really good note. CP-E does the best work in my opinion, but you pay for it.
Mikedubs is offline
 Old 03-08-2012, 05:24 PM   #621
LakeSTLMS3's Avatar
Get in touch with @ERZperformance, they sell them. They may be out of stock right now though....
Stratified!........
Future Mods:
 Old 03-13-2012, 05:46 PM   #622
Ray Danger 2020's Avatar
Posts: 768   (View Stats)
Ray Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the worldRay Danger 2020 is the leader of the world
Groaned at 18 Times in 4 Posts
Has anyone got any advide for me? I've heard that when you do a TBE, you don't have any problems doing a CBE, but when you replace the TP and DP upgrading the fuel pump is an absolute must, and that your car will overboost? Going for the Ultimate Racing Ceramic Catted DP, Straight TP, and then the CBE without the resonator.
Ray Danger 2020 is offline
 Old 03-14-2012, 06:42 AM   #623
Onelovesoccer's Avatar
Posts: 1,364   (View Stats)
Onelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the worldOnelovesoccer is the leader of the world
Groans: 116
Groaned at 13 Times in 7 Posts
i guarantee you that your question has been answered in this thread. and if not, a search would get you a million threads on this topic.
2010 Liquid Silver w/ Tech Package
270whp/324wtq corrected Dynojet 3/24/12 (93 FREEKPerm)
Cobb AP (91 RichTune) | CS SRI/TIP | cp-e S2 RMM | SURE Shifter Bushings | JBR SSP/Counterweight | UR TP | UR CBE | AT Internals | Denso ITV22s | 35% tint | Sonic Tuning HIDs | MD OCC | JBR TIGs | TSW Nurburgring 18x8.5+45 245/40/18 v12 evo2
Onelovesoccer is offline
 Old 03-18-2012, 09:58 PM   #624
lovmyrx7's Avatar
Posts: 11   (View Stats)
lovmyrx7 will become famous soon enoughlovmyrx7 will become famous soon enough
Sound clip
Sounds really good to me. Say's he had the catted DP as well. Anybody else have some footage?
lovmyrx7 is offline
 Old 03-18-2012, 10:18 PM   #625
COOL STORY BRO
Hamilton69's Avatar
Posts: 2,418   (View Stats)
Hamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the worldHamilton69 is the leader of the world
Groans: 179
Groaned at 179 Times in 30 Posts
you should be fine with the test pipe being replaced, but you MUST MUST MUST upgrade the cam driven fuel pump internals if you are replacing your downpipe, no questions asked, you have to... jp@edgeautosport will have everything you need, get in touch with them
edgeautosport.com
JBR 3.5" WHALE PENIS-su tmic- sure track urethane rmm- corksport catless 3" downpipe- ultimate racing tp-OBX 3" cat back -rally armor urethane flaps-Cobb Accessport FINKLE TUNED-sure shift anchors-autotech hpfp internals-HKS BOV VTA -jbr heavy shift knob- 245-40-r18 Falken 329's-paint matched uber smiley
ZOOM ZOOM BOOM
Hamilton69 is offline
 Old 03-19-2012, 03:41 AM   #626
See thats the thing. Idk if i'm not searcing for the right thing or if i'm not being specisic enough in my search but it's not giving me any answers i'm looking for.
 Old 03-19-2012, 06:19 AM   #627
Groans: 116
have you tried using the Google Custom Search under the "Search" tab? It works a lot better than the standard search or advanced search.
 Old 03-19-2012, 05:26 PM   #628
myslow1's Avatar
This thread is for exhaust sound clips and videos.
search or make your own thread.
myslow1 is offline
 Old 03-19-2012, 05:35 PM   #629
Scoobs's Avatar
We need more sound clips for that new CP-E Triton CBE. Looks crazy, and from the little clip sound.
Sold
New
Wife's car
Scoobs is offline
 Old 03-19-2012, 07:00 PM   #630
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
i dont like how far the tips stick out on the cpe triton
also dont like the price but whatever
Monotonous ONE is offline
 Old 03-20-2012, 12:28 AM   #631
Scoobs's Avatar
Yeah, I went back to the vid and it sticks way out...Too bad, look pretty cool on their site.
As for the price it's $50 more than CS and UR, not that bad. But again, why those tips being out so far
Sold
New
Wife's car
Scoobs is offline
 Old 03-23-2012, 11:17 AM   #632
Oliverms3's Avatar
Posts: 1,632   (View Stats)
Oliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the worldOliverms3 is the leader of the world
i forgot all about this... here's the ARK exhaust
http://www.arkperformance.com/Produc...01-0207D]10-ON Mazdaspeed 3 ARK DT-S Exhaust System
Originally Posted by Oliverms3 View Post
I have these ARK Performance Pre-production exhausts. They used my car for test fit.
w/ DP
http://www.youtube.com/watch?v=8Iqfoh2egyA
http://www.youtube.com/watch?v=D_fMa...layer_embedded
2010 BM MS3 - Cobb AP||3gal corn||Autotech Internals||ETS TMIC||Forge BPV||Denso Iridium ITV22||TurboXS DP||ARK exhaust||CP-E Nano SRI||PG TIP||JBR RMM||JBR PMM||TRZ TMM||NRG ETD||DDM 55w 5000k HIDs and DDM 35w 3000k HID fogs||JB Heavy Knob||JB SSP||ST Coilovers w/ Eibach rear Camber Kit(made by SPC)||17x9 +28 Drag DR31 (track) RPF1 18x8 +35 (DD)||HKS TT Type 0||Clarion EQ||MB Quarts speakers||Pioneer amps and 10" Competition Sub.
346hp 392lbs of sexyness
Oliverms3 is offline
 Old 03-23-2012, 11:28 AM   #633
MS3G35's Avatar
Groans: 80
From ARK's website-Special Price $951.30
http://www.arkperformance.com/Produc...e=SM1001-0207D
Holy hell that's a lot of bones.
285whp/321wtq-93
MS3G35 is offline
 Old 03-23-2012, 11:32 AM   #634
Oliverms3's Avatar
yah I know.... Idk why they're asking for that much... but heck.. it sounds great thoe
 Old 03-24-2012, 12:45 AM   #635
Illusion's Avatar
Posts: 123   (View Stats)
Illusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant futureIllusion has a brilliant future
Groaned at 34 Times in 12 Posts
was going to go with UR bu after hearing and seeing and reading up on the ARK im sold
cobb DP+ ARK cbe FTW!
Illusion is offline
 Old 03-24-2012, 01:43 AM   #636
dhsieh911018's Avatar
Posts: 530   (View Stats)
dhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the worlddhsieh911018 is the leader of the world
Groaned at 55 Times in 35 Posts
does it still show 450 in your cart? tried it today it shows 663
dhsieh911018 is offline
 Old 03-25-2012, 07:43 AM   #637
mzr23's Avatar
Sale must be over
Sent from my SAMSUNG-SGH-I727 using Tapatalk
JBR Dogbone - CS SRI - CS TIP - COBB AP - SURE Shorcut - SURE CounterShift - DDM 6k
mzr23 is offline
 Old 03-25-2012, 01:42 PM   #638
f-castrillo's Avatar
Posts: 1,342   (View Stats)
Has anyone with a full turbo-back system experienced a ticking noise after shutting the car off? Every time I park, it sounds like someone is tossing a pebble at the exhaust piping in 3-second intervals. I checked under the car one day, and I did notice some water/condensation pooling under around where the DP meets the CBE.
It's not a huge issue, and I've never seen any problems in past datalogs that would indicate anything wrong. It's just that the click is kind of irritating sometimes.
This happened before I put the donut gasket between the CBE and DP (I ran without the gasket for a few months), as well as after getting the gasket and CNT adapter (to hold it in place) between them.
f-castrillo is offline
 Old 03-25-2012, 02:17 PM   #639
myslow1's Avatar
hotexhaust.com has the magnaflow... If you use "veedub" in the coupon section it makes it 497.
myslow1 is offline
 Old 03-27-2012, 07:50 PM   #640
kpacker51's Avatar
Posts: 1,522   (View Stats)
kpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the worldkpacker51 is the leader of the world
Groans: 59
According to the seller, this ebay listing is for a Magnaflow.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
-Abraham Lincoln
kpacker51 is offline
HTML code is On
Definitive Exhaust Thread myslow1 2010 MS3 - Engine, Transmission & Driveline 1040 02-02-2018 08:12 PM
MS6 Exhaust Thread RhoadBlock MazdaSpeed 6 - Engine, Transmission & Driveline 86 04-05-2017 04:42 PM
My exhaust manifold thread!! spiker98 MazdaSpeed 3 - Engine, Transmission & Driveline 56 09-11-2009 07:28 PM
Page generated in 0.92765 seconds with 46 queries
