 Old 07-12-2012, 09:45 AM   #1
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Default The Official Short Shifter Thread
***** The Official Mazdaspeed Forums Short Shifter Thread *****
DISCLAIMER: This is an informative thread and a resource for gathering information on which form of shifter you may want (Short Shift Plate, Full Replacement, or just a simple stem). All-in-all it is up to you to decide on which form to go with.
So you've decided that the factory shifting assembly is not up to your standard of performance. The following information will give you insight into what aftermarket parts you can buy for your specific model vehicle to transform the feel and performance of your shifter assembly. The Mazdaspeed platform has many different ways to adjust the height, distance of throw, and feel of the transmission while driving. We'll start at a very simple install and work up to the hardest level.
For additional Information Please See The Following Contacts List For The Specific Vendor You Have In Mind:
For CorkSport Performance Contact:
@CorkSport
CorkSport Mazda Performance Website
Mazdaspeed Forums Vendor Area - Corksport
For James Barone Racing Contact:
@jbarone
James Barone Racing Website
Mazdaspeed Forums Vendor Area - JAMES BARONE RACING
For TWM Performance Contact:
@TWM Performance
TWM Performance Website
Mazdaspeed Forums Vendor Area - TWM Performance
For COBB Tuning Contact:
@Cobb Tuning
@Evan@COBB
@David@COBB
COBB Tuning Website
Mazdaspeed Forums Vendor Area - COBB Tuning
***** First Generation Mazdaspeed3 *****
Short Shift Plates
The first way of adjusting the distance of the gear change (see: the "throw") is to add a SSP, an abbreviation for Short Shift Plate. The name is almost an exact description of the piece. A solid piece of metal with 4 holes in it that sits on top of the transmission housing connecting the linkage.
There are currently 3 Companies who manufacture Short Shift Plates for the First Gen Mazdaspeed3.
1. James Barone Racing
Price: $80.00
The Stage 1 Kit From Jamie Includes both the Plate AND a counterweight. A stage 2 kit can be ordered which includes base bushings for $95.00
3. Corksport Mazda Performance
Price: $69.00
The SSP from CorkSport includes a Counterweight
Base Bushings
At the base of every First Gen MS3 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears.
Price: $25.00
3. CorkSport Mazda Performance
Price: $39.00
4. TWM Performance
Price: $34.95
Shift Counterweights
At the opposite end of the gear linkage lies the counterweight. A counterweight provides a balance at each end of the linkage and also provides improved shift response while also ensuring the transmission stays in gear during aggressive driving.
Price: $20.00
Color options include Red, Blue, and the pictured Black below
3. TWM Performance
Price: $49.95
While pricey, the TWM Counterweight is the only weight on the market which can be adjusted to personal preference.
4. COBB Tuning
Price: $25.00
The simplest design and only one option to choose from.
Replacement Stems
The gear lever itself within the cabin is capable of being shortened. A 30% reduction in the distance of the throw can be seen when adding an actual short shifter. Two companies currently manufacture a short shifter for the platform.
1. COBB Tuning
Price: $275.00
COBB's Shifter Features double adjustments for both Shift knob height and Throw Length
To view how to install your COBB Tuning Double Adjustable Short Throw Shifter Please See This Thread: COBB Tuning Mazdaspeed3 STS Install
1. TWM Performance
Price: $249.95
The TWM features no adjustment in throw or knob height, it is one size only.
To view how to install your TWM Performance Short Shifter Please See This Tutorial courtesy of Krystm's Garage
Tutorial: Short Throw Shifter Install
Full Replacement Systems
If you're feeling an overhaul of your complete shifting package, TWM Performance is currently the only company for our platform who manufactures a direct replacement system.
1. TWM Performance
Price: $449.95
The Full Replacement System from TWM includes everything except a Counterweight and Shorter Shift Plate
***** Mazdaspeed6 *****
Short Shift Plates
Price: $80.00
Base Bushings
At the base of every Mazdaspeed6 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears.
These are the bushing locations:
Price: $25.00
Price: $20.00
3. COBB Tuning
Price: $25.00
Replacement Stems
The gear lever itself within the cabin is capable of being shortened. A 33% reduction in the distance of the throw can be seen when adding an actual short shifter. Unfortunately, only 1 company currently manufactures a short shifter for the Speed6 platform.
1. TWM Performance
Price: $139.95 for a Stage 1, Add $50 for a Stage 2
The TWM features no adjustment in throw or knob height, it is one size only. (Stage 2 Shown)
Unfortunately, no full replacement system is currently offered for the MazdaSpeed6 platform as the shifter assembly is much more complex compared to that of the Speed3.
***** Second Generation Mazdaspeed3 *****
Short Shift Plates
There are currently 3 Companies who manufacture Short Shift Plates for the Second Gen Mazdaspeed3.
Price: $80.00
Price: $69.00
Base Bushings
At the base of every Second Gen MS3 gear lever there are 4 rubber grommets that hold the shifter cage to the floor board. These bushings give the side-to-side movement of the shifter a very soft feel. Upgrading to solid aluminum Base Bushings improves the feel of the shifter when navigating throughout the gears.
Price: $25.00
Price: $39.00
4. TWM Performance
Price: $34.95
Price: $20.00
3. TWM Performance
Price: $49.95
4. COBB Tuning
Price: $25.00
Replacement Stems
Unfortunately, no company currently offers just a Stem Replacement for the Second Generation Mazdaspeed3.
1. TWM Performance
Price: $449.95
I Think I got Everything.......If you spot anything wrong with this thread please bring it to my attention.
Thanks,
Dump
______________________
Built By NATOR
Tons of Ricer Mods
09Speed3Z is offline
The Following User Says Thank You to 09Speed3Z For This Useful Post:
08.5MS3 (10-03-2012)
 Old 07-12-2012, 09:51 AM   #2
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
Don't forget maperformance, etc.
Taking shape, subbing for progress and will send $$$ when done!
Raider is offline
 Old 07-12-2012, 10:03 AM   #3
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Groans: 261
Did I see that Matt Damond has one now as well?
breakfstincluded is offline
 Old 07-12-2012, 02:09 PM   #4
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
I'm sure there are spelling mistakes and the like in there somewhere if someone can find them and point them out I'd appreciate it.
@Raider
Built By NATOR
Tons of Ricer Mods
 Old 07-12-2012, 05:57 PM   #5
Raider's Avatar
Groans: 856
@Raider
E4P makes a shifter, I run it too. Let me hop on the computer tomorrow, I'll send you $.
Bumping for input about any possible missing options...
Raider is offline
 Old 07-12-2012, 06:48 PM   #6
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
This forum has quite the history with E4 Performance.
If it's in the forums best interest, I'll be glad to throw that in tomorrow.
Built By NATOR
Tons of Ricer Mods
 Old 07-12-2012, 06:56 PM   #7
Raider's Avatar
Groans: 856
I know, but people still buy it. I've got 40,000 miles on mine....
Raider is offline
 Old 07-12-2012, 07:00 PM   #8
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Fair enough
It's on the add list for tomorrow.
Built By NATOR
Tons of Ricer Mods
 Old 07-12-2012, 07:05 PM   #9
missing the limited production superskater short shifters!!!!!!!
GI: Custom MS6 Short Shift Plate
superskaterxes is offline
 Old 07-12-2012, 07:09 PM   #10
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Not an authorized MSF Member and frankly one that doesn't return goddamn phone calls!!!!!! Lol
Built By NATOR
Tons of Ricer Mods
 Old 07-12-2012, 07:12 PM   #11
Mortose's Avatar
Posts: 2,441   (View Stats)
Mortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the worldMortose is the leader of the world
Groans: 39
I vote sticky.
+1 for the TWM STS and JBR SSP. In combo, i have about a 3 inch throw now. I LOVE IT.
2008.5 Metropolitan Grey Mica: Sold
99 miata: sold
2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel
TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat"
Mortose is offline
 Old 07-13-2012, 05:43 PM   #12
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
@Raider
I looked on E4's website. There STS isn't listed anymore so I'd be a little skeptical about listing it if you can't find it.
They have their counterweight shown so I'll add that to the list in the counterweight section.
Built By NATOR
Tons of Ricer Mods
 Old 07-14-2012, 10:18 AM   #13
Raider's Avatar
Groans: 856
I got mine through pg- Protege Garage - E4P Short Shifter - Mazdaspeed3
But if op does not want to post it, I'm ok since pg is banned. I only said them because ive had one with no problems,
Raider is offline
 Old 07-23-2012, 03:16 PM   #14
JLee1469's Avatar
Posts: 1,195   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Just installed @MATT DAMOND 's piece. Very nice.
JLee1469 is offline
 Old 09-19-2012, 01:10 PM   #15
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: The Official Short Shifter Thread
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HTML code is On
The Official Short Shifter Thread 09Speed3Z MazdaSpeed 3 - Engine, Transmission & Driveline 34 04-28-2018 01:42 PM
OFFICIAL Broken Shifter NHTSA Reports Thread Mizzle MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 12-20-2012 06:48 AM
OFFICIAL Broken Shifter NHTSA Reports Thread Mizzle MSF KB - Mazdaspeed 3/6 - Troubleshooting 6 08-02-2012 08:01 PM
Page generated in 0.44823 seconds with 27 queries
