![]() | ![]() | #41 | ![]() |
![]() ![]() Join Date: Jun 2009 Location: PDX
Rep Power: 5703 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,677
Groans: 90
__________________ ![]() [SIGPIC][/SIGPIC] |
![]() | ![]() | #42 | ![]() |
![]() Join Date: Dec 2009 Location: Middle Earth
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
| ![]() ![]() ![]() Thanks! I know this was to him. But I'm kind of lost on this whole issue. I checked my stockers (FoMoCo) and they were dead on at .028 gap from the factory. So I'm guessing I am in one measurement and others are using the other?
__________________ 09 Speed 3 GT |
![]() | ![]() | #43 | ![]() |
Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| ![]() ![]() ![]() nah, you're fine. stock gap is recommended to be within .028-.032 ngk 6510's come pregapped at like .042 or some shit like that so they need to be regapped to be in spec. i think that guy was also confused about his stock plugs. |
![]() | ![]() | #44 | ![]() |
| ![]() ![]() ![]() Cool thanks. I found the stock heat range part number. Heat range 6. NGK 3787 just in case anyone needs those too. 1 step colder is Heat range 7, but I know most of you already knew that. My only question is, do I need 1 step colder? I tried the Denso's 1 step colder and they fouled out quickly. I don't think I've added over 75 chp yet (?).
![]() | ![]() | #45 | ![]() |
Groans: 1,940
| ![]() ![]() ![]() idk man. there are people who will say that when you raise boost, you should go one step colder. there are people that go one step colder with an intake and upgraded ic i think. so i'm really not too sure. i've been running step colder plugs for a while. but idk how "necessary" they are. |
![]() | ![]() | #46 | ![]() |
![]() Join Date: Apr 2010 Location: atlanta ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
| ![]() ![]() ![]() that last post helped me out alot thanks |
![]() | ![]() | #47 | ![]() |
Lurkers
Posts: n/a
| ![]() Ok, at what point do you need 2 step colder plugs??? |
![]() | ![]() | #48 | ![]() |
![]() Join Date: Jan 2009 Location: ME, Kittery
Rep Power: 1806 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,848
Groans: 105
| ![]() ![]() ![]() Good question. I should prolly replace my spark plugs soon.
__________________ 2012 WRX HB w/mudflaps yo! |
![]() | ![]() | #49 | ![]() |
![]() Join Date: Aug 2008 Location: Shamong, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 624
| ![]() ![]() ![]() Update to this thread. Autolite makes Iridium plugs now. Plug numbers are XP5364 (Heat Range 4 - stock heat range) and XP5263 (Heat Range 3 - 1 step colder). I know most will turn their nose up to Autolite compared to NGK's and Denso's, but I don't think they're a bad plug. They're $6.49 each at Autozone and I just picked up a set to try out. They are supposedly gapped at .051. I'll have to confirm this, but if so, you'll have to tighten them up a bit. From what I can see, they look like they can be tightened up without bending them too much since they almost have a negative bend to them. EDIT: The good thing about these is that it seems most Autozones and Advance Auto Parts stock them regularly whereas the NGK's and Denso's are usually special order through these places and cost more unless you get them online. You may want to spend a few bucks more per plug to get the NGK's or Denso's, but if you're in a pinch, run to Autozone and pick a set of these up. Besides, Autolite is an official NASCAR sponsor buddy.... yeeehaaw. EDIT #2: I've been running these plugs for a few thousand miles now and the car runs just fine on them. I'll pull them out in a month or two and see how they look.
__________________ 08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny! |
![]() | ![]() | #50 | ![]() |
Banned ![]() Join Date: Jul 2009 Location: Fremont, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 257
| ![]() ![]() ![]() Why does the Denso plugs foul up so easily? Are the NGK for durable? |
![]() | ![]() | #51 | ![]() |
Rep Power: 0 ![]() ![]() Thanks: 23
Have you pulled them to see how they look? I have had Denso ITV22's in for 15k miles now and need to pull them and see how they look. | |
![]() | ![]() | #52 | ![]() |
| ![]() ![]() ![]() Nope. I ordered a Corksport topmount intercooler, so when I get it in March, I'll probably pull the plugs. They're working fine with no misfires running 19 psi, so if it's not broken, I don't fix it. I was kinda pissed a few weeks ago when I put a new downpipe in and had the TMIC pulled off, but forgot to pull the plugs to look at the them while I had it off.
![]() | ![]() | #53 | ![]() |
![]() Join Date: Jul 2010 Location: Bear, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
| ![]() ![]() ![]() Getting ready to change my spark plugs in the next couple of days. I recall reading that it might be neccesary to stretch the coil from the wire that connects to the spark plug. hHas any else ever heard of this?
__________________ Silver 08 MS3- Purple Drank Racing Tune l CXRACING FMI l DO Methanol Injection l JBR 3.5 intake l Turbo XS DP, TP l ProSport Boost Gauge l HKS TT l Cobb AP l Cobb RMM l H&R Springs l Turbo Smart BPV l WOT Box l JBR side mounts l KMD internals l BNR Stage 1 turbo l Protegegarage SS l VTCS Delete | TB Spacer | CPE Injector Seals l BSD l 3 port EBC l Bosch 3bar MAP. [SIGPIC][/SIGPIC] |
![]() | ![]() | #54 | ![]() |
Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 3987 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
| ![]() ![]() ![]() Very old info, but stretching the springs a little on both ends helps with some peoples problems. Stretching the middle doesn't do anything because the spring holder is shaped for it and compresses it back.
__________________ ![]() |
![]() | ![]() | #55 | ![]() |
| ![]() ![]() ![]() Thanks jmhinkle.
![]() | ![]() | #56 | ![]() |
![]() Join Date: Jan 2010 Location: Killeen, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 44
| ![]() ![]() ![]() I got the 6510's...some shops say .22, some .28 for gap. My gapper shows stockers at a gap of .24-.25...so which is it? I assume .28 will be fine...I have the auto gapper that shops use so it wont break the electrode or the tip...and also creates a perfect level tip to electrode which is supposed to prevent hot spots in the piston area when firing...any help appreciated. |
![]() | ![]() | #57 | ![]() |
| ![]() ![]() ![]() Keeping stock taking 6510's back, after reading only use if making over 100HP more than stock...no need for me...not gonna risk it. |
![]() | ![]() | #58 | ![]() |
![]() Join Date: Feb 2011 Location: From Cincinnati, Stationed at Ft Campbell KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| ![]() ![]() ![]() So from what I've read and also talked to a lot of mechanics, you should try to keep your plugs as cold as possible without them fouling out, the plugs clean themselves with heat, (like self cleaning ovens, or propane grills) now going too hot on a plug will cause the fuel/air to detonate premature, causing knock and power loss, even at extreme sometimes melt. higher pressure(boost) or compression lowers the detonation point of the fuel/air. so if you dont mind changing plugs, go cold, then step it up a heat range till you find the plug best for YOUR car. |
![]() | ![]() | #59 | ![]() |
Groans: 162
| ![]() ![]() ![]() It never hurts to go 1 step colder from factory even with a stock car. Never go hotter.
![]() | ![]() | #60 | ![]() |
![]() Join Date: Nov 2010 Location: DIAMOND BAR
Rep Power: 0 ![]() Thanks: 0
| ![]() ![]() ![]() just ordered my spark plus got them for 7.89 a plug got the ngk 6510 can't wait to install these.. |
![]() | ![]() | #61 | ![]() |
![]() Join Date: May 2011 Location: Pooler, GA
Rep Power: 374 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 979
also, what did you end up gapping them at? let me know
__________________ 2008 MS3: MAISONVI PISTON SHIFT KNOB - AUTOTECH INTERNALS SURE COUNTERSHIFT - SURE SHORTCUT - SURE ANCHORS JBR TRILOGY - JBR RSB - JBR TUBING - JBR TIP - JBR SRI - JBR EGR DELETE HYPNOTIC TUNED | |
![]() | ![]() | #62 | ![]() |
lulz @Raider ![]() Join Date: Jun 2010 Location: St Louis Mo
Rep Power: 3766 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,132
| ![]() ![]() ![]() Bump
__________________ 2008 MS3 gt 470hp/463tq on GT35r at 29psi Wiseco Pistons/Molar Rods/ACT 6 Puck/ARP Head Studs/TurboXS FMIC DP and RP/TurboSmart BOV/Tial 38mm EWG/PERM 5th/6th port injectors HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned ![]() |
![]() | ![]() | #63 | ![]() |
Groans: 162
| ![]() ![]() ![]() I can tell you from personal experience that the Autolite plugs have to bent a lot and not just your regular bending. The are gapped HUGE! You actually need to carefully pull the groundstrap back and then compress it down so the angle is decent. Make sure those strange dots they have on the ground strap line up with the electrode as well. If you are in a bind which a local guy definitely was, they will do ok, but they really aren't much cheaper than a plug that works properly if you don't need them immediately.
![]() | ![]() | #64 | ![]() |
i took a look online and i think they are gapped at .051 which really threw me off. i might just go with the ngk's since that seems to be standard for most people here. i dont know how comfortable i feel having to bend a plug that much - doesn't seem natural.
![]() | ![]() | #65 | ![]() |
| ![]() ![]() ![]() I've been running the Autolite plugs for over 30k miles with no issues. Of course, when I replace them, I'll probably go with the Denso's again.
![]() | ![]() | #66 | ![]() |
![]() Join Date: Aug 2011 Location: Allen, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 20 Times in 7 Posts
| ![]() ![]() ![]() Sorry to revive the dead but what's the best practice for ungapping the plugs? I just got NGK 6510 and they are set around .040 I was going to set them at .031 but I can't get the metal to bend down.. I'm afraid to give it to much an breaking it
__________________ 2007 TRUE RED MS3 GT RX-8 WHEELS/DRILLED & SLOTTED ROTORS KONI YELLOW/COBB SPRINGS/JBR RSB/HOTCHKIS FSB COBB OTS STAGE 2 MAP RMM/COBB INTAKE/COBB TIH/ETS TMIC OBX TEST PIPE/AUTOTECH INTERNALS/FORGE BPV V2 |
![]() | ![]() | #67 | ![]() |
![]() Join Date: Jul 2008 Location: Ottawa, ON Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,005
| ![]() ![]() ![]() Just lightly tap it against a table.
__________________ 2008 Cosmic Blue Mica Mazdaspeed 3. BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob. To be installed: SS Brake Lines. |
![]() | ![]() | #68 | ![]() |
Groans: 162
| ![]() ![]() ![]() That would not be ungapping, that would be gapping. You need to aim for .028 anyway. Use a bench vise for the most precise compression, or carefully push them against soft wood. Never tap them against anything. You would be risking cracking either ceramic piece.
![]() | ![]() | #69 | ![]() |
![]() Join Date: Apr 2010 Location: Des Plaines, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 234
Groaned at 53 Times in 17 Posts
| ![]() ![]() ![]() From reading all the post I am in a big delema between the NGKs and Densos and dono which ones to get. I know that Densos the spring has to be stretched. How about the NGKs? BTW, nice thread! |
![]() | ![]() | #70 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,116
Groans: 549
Sent from my LG-MS690 using Tapatalk 2
__________________ it's fun to do bad things | |
![]() | ![]() | #71 | ![]() |
Groans: 298
| ![]() ![]() ![]() I'm not disagreeing with JMhinkle or Bronco in the least, but I can see where people would get the idea to tap the strap down to regap. NGK.com |
![]() | ![]() | #72 | ![]() |
![]() | ![]() | #73 | ![]() |
Groans: 549
![]() | ![]() | #74 | ![]() |
Groans: 162
| ![]() ![]() ![]() Because we are already gapping below the recommended distance causing the arm to lean in and be angled towards the electrode. I have found that when you use a vise the arm stays more true. Also, those gapping tools suck ass. The .99 disc type that has a hole to open with works better IMHO
![]() | ![]() | #75 | ![]() |
Groans: 549
![]() | ![]() | #76 | ![]() |
Groans: 298
| ![]() ![]() ![]() This is getting more technical than I think it was intended, but gathering all of this info I think I would: -use a feeler gauge -close the gap with a vise to be sure the strap and its orientation to the electrode is consistent -open the gap (if necessary with a plug specific gapping tool) The tool that you posted Bronco sometimes are hard to find with a measure ring that is <.030. I would like to have one of those because feelers are hard to use sometimes, but I need to find one with a gap as low as .026. |
The Following User Says Thank You to rfinkle2 For This Useful Post: | Truguy86 (04-03-2017) |
![]() | ![]() | #77 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,169
Groans: 423
It had always been my understanding that using anything besides a wire style gauge was bad for precious metal plugs. true false?
__________________ -Pat 2008 True Red MS3 GT3071R 'n Stuff SOLD 1999 Jeep XJ 6.5" Lift | Armor | 33" Tires | Bumpers 1996 Jeep XJ 3.5" Lift | 31" GY Duratracs | Bumpers 1994 Miata 15x8's w/NT05's | KYB AGX | Hardog Roll Bar | 70D Engine Mounts | |
![]() | ![]() | #78 | ![]() |
Groans: 298
I guess it depends on the source. Denso says not to gap their plugs (iridium) due to the efficiency of iridium being able to overcome any gap error and NGK would have you tapping the strap. HAHA!!! I know that using a traditonal slide around copper plug gapper is a definite no - no. I would think that the picture posted of the guage above and a feeler gauge would be safe as long as we are not reckless / rough on the electrode. | |
![]() | ![]() | #79 | ![]() |
| ![]() ![]() ![]() I tapped mine down to .28 and used a standard gapper...no issues, but lately I have started feeling a smal miss after 5,000 miles and I am thinking its time to check for fouling. Will also get one of those wire ones if I can find one with the smaller gap like the last guy stated. |
![]() | ![]() | #80 | ![]() |
Eatin' Your Tuna ![]() Join Date: Feb 2008 Location: Nator HQ - San Diego, CA
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,600
Groans: 244
(Thread Starter) | ![]() Bump. Updated. If you have other plugs to be listed, reply here. Thanks
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | |
Display Modes | |
Spark Plug Database - Gen2 | Haltech | 2010 MS3 - Engine, Transmission & Driveline | 23 | 09-27-2017 05:09 PM |
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 6 - Engine, Transmission & Driveline | 41 | 05-05-2016 08:49 AM |
Spark Plug Database - Gen2 | Haltech | 2010 MS3 - ECU Computer Tuning | 3 | 02-27-2016 04:53 PM |
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3 - Engine, Transmission & Driveline | 205 | 09-22-2015 06:52 PM |
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) | Haltech | MazdaSpeed 3/6 - ECU Computer Tuning | 73 | 08-04-2014 03:47 PM |
