Like Tree2Likes
 Old 07-23-2012, 06:19 AM   #81
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
What do you recommend on a stock motor? Would I see any benefits running a 1 step colder plug or should I just stick with OEM specs?
3Gee Tee is offline
 Old 07-23-2012, 06:54 AM   #82
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
If you are running boost levels>stock, you may benefit, otherwise stick with the factory heat range.
rfinkle2 is offline
 Old 07-23-2012, 06:56 AM   #83
3Gee Tee's Avatar
10-4, thanks for the input.
Followup question: Which brand? I hear good things on this forum about NGK and Denso so I assume they're both comparable?
3Gee Tee is offline
 Old 07-23-2012, 07:05 AM   #84
rfinkle2's Avatar
Groans: 298
It looks as if people are slowly moving to NGK because of some recent findings of cracked porcelain on the Denso's.
The NGK will need to be regapped because the out of the box gap is a bit large for the ms3.
rfinkle2 is offline
 Old 07-24-2012, 07:47 PM   #85
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
I hate to say it rob, but the matte black wrap you have on your car looks DOPE..... how much did it end up costing you?
2008 MS3 gt
470hp/463tq on GT35r at 29psi
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned
burn813 is offline
 Old 07-24-2012, 07:59 PM   #86
BudUMfan's Avatar
Posts: 1,204   (View Stats)
BudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the worldBudUMfan is the leader of the world
Groaned at 9 Times in 7 Posts
I am running stock boost...for now with step colder NKG's...no issues
BudUMfan is offline
 Old 07-25-2012, 02:43 AM   #87
3Gee Tee's Avatar
What brand and did you have to regap them?
3Gee Tee is offline
 Old 07-25-2012, 07:13 AM   #88
BudUMfan's Avatar
I have NKG and gapped to .030, I will be running 19.5lbs when I retune.
BudUMfan is offline
 Old 07-25-2012, 11:39 AM   #89
lulz @Raider
burn813's Avatar
@rfinkle2 answer my question mang
2008 MS3 gt
burn813 is offline
 Old 07-25-2012, 12:15 PM   #90
Only use plug gapper tools to open up the plug gap; not to actually measure the gap. Use a set of feeler gauges to measure gap properly.
silvapain is offline
 Old 08-15-2012, 12:09 PM   #91
speed0450's Avatar
Posts: 22   (View Stats)
speed0450 is a jewel in the roughspeed0450 is a jewel in the roughspeed0450 is a jewel in the rough
From reading the thread, since I currently only have a cobb sri and I am running stock boost levels should I go 1 step colder or just stick with the stock heat range. Also have the denso problems been worked out? Thanks
speed0450 is offline
 Old 08-15-2012, 12:15 PM   #92
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
if you had read the thread, you would have read, a whole bunch of times, that stock boost=stock heat range plugs.
maybe it is time to work on the comprehension part of reading?
tddvrrn is offline
 Old 08-15-2012, 01:06 PM   #93
speed0450's Avatar
thanks for your input. but also some of the people that are on stock boost are running one step colder and was hoping to hear from them on there opinions of how the car is running with them. i do comprehend reading thru posts and searching before I post. that is the reason that i donated to help the forum stay up and running for me to gain knowledge as everyone else. fyi... ..has never been in my system.
 Old 08-15-2012, 01:21 PM   #94
theurgy's Avatar
Posts: 2,580   (View Stats)
I'm currently running ITV-22's while I'm in between tuning solutions at the moment.
I am currently still on stock tune and boost and it runs fine.
BNR s3, CoolingMist CMGS Meth, Damond TB Plate, JBR FMIC Undermount w/ TR8, JBR 3" Fullpath, Steedspeed EM, Cobb AP v3, Stratified Tuned, Autotech HPFP Internals, CP-e Catted Downpipe, Port and Polished IM with VTCS & Full EGR Delete, Grimmspeed EBCS, 3 BAR MAP Sensor, Turbosmart Dual-port BPV, Koni Sport Yellows, Eibach Prokits, SPC Camber Arms, Cobb FSB and RSB, AWR Front Endlinks, JBR Trilogy Mounts 70a Duro, KX-F3 Full Chassis Braces, Denso Iridium ITV-22, CP-e Safe Seals, SURE TIG IM and TB, Cobb Shift Weight, TWM SS w/Bushings and Specter Hybrid knob.
To be installed: SS Brake Lines.
theurgy is offline
 Old 08-15-2012, 03:10 PM   #95
smoogs12's Avatar
Posts: 7,731   (View Stats)
Groans: 423
@speed0450 you want to run the hottest plug you can without pre-ignition.
Tapa
-Pat
2008 True Red MS3
GT3071R 'n Stuff
SOLD
1999 Jeep XJ
1996 Jeep XJ
1994 Miata
smoogs12 is offline
The Following User Says Thank You to smoogs12 For This Useful Post:
Truguy86 (04-03-2017)
 Old 09-19-2012, 01:11 PM   #96
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: http://www.mazdaspeedforums.org/foru...ge-1-2-a-5692/
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HTML code is On
Spark Plug Database - Gen2 Haltech 2010 MS3 - Engine, Transmission & Driveline 23 09-27-2017 04:09 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 07:49 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - ECU Computer Tuning 3 02-27-2016 03:53 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 05:52 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 73 08-04-2014 02:47 PM
Page generated in 0.36246 seconds with 29 queries
