 Old 07-16-2012, 10:52 PM   #1
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Default Spark Plug Database - Gen2
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.026 - 0.032 | Preferred gap is between 0.026 to 0.028
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
BKR7E
Haltech is offline
 Old 07-17-2012, 06:15 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
General Specs
14mm Thread Size,
25.4mm (1") Reach,
5/8" (16mm) Hex Size,
Tapered Seat,
Resistor
tightening torque: 8.0 - 10.3 ft/lbf, (10 - 14 N/m, 1.1-1.4 kgf/m)
anti-seize on threads recommended
What's this whole "Heat Range" thing about, and why do I care?
AutoliteSparkplugs.com
>It's believed that the MZR is damn near ready for one step colder from the factory.
>Colder plugs are an integral part of KR management
Pics of screwed up spark plugs, and what they mean
Spark Plug Diagnosis
As a general theory, your ceramic should wear to a nice coffee with lots of cream color. Bright white ceramic means you should try a colder plug. Dark needs hotter. Beyond that, if your plugs ever end up looking like anything in these pics, well, you've got much bigger problems than this post is going to help with...
Just what the heck do those numbers mean anyway?
Reference Charts:
NGK - NGK spark plugs symbol code
Autolite - http://www.autolitesparkplugs.com/im...0numbering.jpg
Denso - Untitled Document
Champion - Untitled Document
Just how long can I expect my fancy new plugs to last?
Both Cobb and Denso have written on the subject. Denso has a generic note that indicates a lifespan of about 30K miles, but Cobb is even more conservative and notes the hell that is a DISI Motor will see the benefits dropping off after only 15K miles:
Per the Cobb MS3-MS6 Service Bulletin v1.03:
"...operating the car with higher than stock boost levels or with the calibrations that are on the AccessPORT, require that a spark plug gap of .026” - .028” (6.6 – 7.1mm) be used on a 1-step colder temperature plug. Denso currently offers this spark plug as part # ITV22 (please be sure to verify each plug is properly gapped before installing them). Our experience has shown that operating your turbo-charged engine at higher than stock boost levels requires that your spark plugs be replaced at around 15,000 mile intervals."
Colder Heat Ranges
generally accepted gap, where adjustable, .026 (range .025 to .028)
>Autolite Single Platinum Spark Plug
Part No. AP5263
$2.50
>Autolite Double Platinum Spark Plug
Part No. APP5263
$4.00
>Autolite Xp (Xtreme Performance) Iridium Enhanced Fine Wire Spark Plug
**Cross-references the Denso ITV-22**
Part No. XP5263
$6.50
>NGK IX Iridium
Part No. LTR71X-11
$8.00 ea.
>Denso Iridium Spark Plugs
Part No. ITV22 - one step colder
$11.99 (streetunit price)
Part No. ITV24 - two steps colder
Factory Heat Range
generally accepted gap, where adjustable, .032 (range .028 to .032)
Part No. APP5364
$3.99
>Champion Double Platinum Spark Plug
Part No. 7437
$4.29
>Motorcraft Original Equipment Finewire Single Platinum Spark Plug
Part No. SP432
$4.69
>Motorcraft Original Equipment Finewire Double Platinum Spark Plug
Part No. SP478
$4.69
>Bosch Platinum+2 Spark Plug
Part No. 4315
$4.99
>Bosch Platinum Ir Fusion
Part No. 4515
$5.71
>Bosch Platinum+4 Spark Plug
Part No. 4488
$5.99
>Pulstar Platinum Pulse Plug
Part No. EF1P
$9.99
>ACDelco Professional Platinum Spark Plug
Part No. 41-814
$6.49
>Champion Iridium
Part No. 9901
$5.74
>NGK Premium Iridium
Part No. ILTR6A8G
$9.94
Part No. XP5364
$6.59
>Pulstar Iridium Pulse Plug
Part No. EF1I
$12.99
>E3 Premium Special Electrode Automotive Spark Plug
**no reports of this plug working worth a crap in the MZR engine**
Part No. E3.66
$5.99
340hp / 371tq
TiGraySpeed6 is offline
jracer (01-30-2013), razortechrs (07-22-2014)
 Old 09-19-2012, 01:48 PM   #3
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Spark Plug Database - Gen2
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HTML code is On
Spark Plug Database - Gen2 Haltech 2010 MS3 - Engine, Transmission & Driveline 23 09-27-2017 04:09 PM
Spark Plug Database - Gen2 Haltech 2010 MS3 - ECU Computer Tuning 3 02-27-2016 03:53 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 05:52 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 73 08-04-2014 02:47 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 95 09-19-2012 01:11 PM
Page generated in 0.27210 seconds with 22 queries
