 Old 06-11-2013, 03:33 AM   #41
NICKELL666's Avatar
Posts: 566   (View Stats)
NICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the worldNICKELL666 is the leader of the world
I'll probably be doing this soon. For you guys that did it yourself, about how long did it take? I don't really want to pay the dealer to touch my car
Sent from my SCH-I535 using Tapatalk 2
09 MS3: Cobb AP; Autotech HPFP; HTP 3" Intake; CP-E TMIC; GFB Respons; NGK Iridium IX; M2 Catless DP; TurboXS cbe; JBR 88a; JBR SSP; Ralco RZ STS; Aeroforce Interceptor; Defi Red Racer; Racelands v2(until I have issues); SPC camber arms; 18x8.75 +35; 215/40/18; Freek Tune; 50/50 Corn
NICKELL666 is offline
 Old 06-11-2013, 03:57 AM   #42
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
There is a how to by @Rokusek;. It's pretty in depth. Cams are not marked for timing so many shops have bent valves trying to do it.
Raider is offline
 Old 06-11-2013, 04:41 AM   #43
Rokusek's Avatar
Posts: 5,551   (View Stats)
The tools listed in my OP where made by a guy in NC, he had them to me in 3 days after i ordered them. this is an easy job but its very in depth.
Thanks for the Mention @Raider;
HOW-TO VVT
Rokusek is offline
 Old 09-09-2013, 04:00 PM   #44
iamintown's Avatar
Posts: 8   (View Stats)
iamintown is an unknown quantity at this point
Default VVT-TimingChain Install Mazdaspeed6
I just order VVT, timingchain kit from Ebay and chain tensioner from streetunit.com, looking for good mechanic in Southern California to install it.
Mazda Variable Valve Timing Kit for MAZDASPEED3 MAZDASPEED6 and CX 7 | eBay
does anybody know good Mazda mechanic in Southern California.
iamintown is offline
 Old 09-09-2013, 04:02 PM   #45
Raider's Avatar
Groans: 856
If you have purchased from Street Unit, you missed the threads about them being shitstains.
Take it to the dealer. This is not a shade-tree job.
Raider is offline
 Old 09-10-2013, 03:02 PM   #46
iamintown's Avatar
anybody in Southern California has replaced the VVT/timing chain, I just the got the kit, looking for mechanic.
 Old 01-01-2014, 03:59 PM   #47
ericrapp0507@gmail.com's Avatar
Posts: 281   (View Stats)
ericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the worldericrapp0507@gmail.com is the leader of the world
the dealer is a bad idea.
i had 74000 and the vvt had failed.
No warranty. sposed to be 70k.
2600.
yea i know
i coulda done this myself
2/07 build date. 5/07 arrival date
88750. tracked before broken in.
Broken and broken again. been hit 4 times
235/40 fr 225/40 rear. Direzza / NT 555 /Tenzo dc-5 br 18x8.5 / DBA 4000xs/ EBC Reds /Goodridge SS lines /motul rbf/Moog control arms / axles upgraded/ Hotchkis sway fr / Whiteline adj links and tower brace/ REAR -mazdaspeed camber arms/ Tripoint anti sway/ Laura's GTspec trunk cage brace./ KSport RR. w/front camber plate w/ nasty spring rate/TopSpeed PMM Solid RMM/ sure TMM/Corksport parts =TBE w/RP or hf cat depending-Turbo- Injector seals -Fuel pump internals-Pulleys / PG v2 exh mani /HTP 3.5/ bosch 3 bar map/ new injectors/ Grimmspeed ebcs/ JMF intake /Perm Tuned vent plate/Damond Motorsports full EGR delete/DM dual CC/ Forge BPV/CP-e FMIC/Cobb v3
Samco preformed rad hose/ + Mishimoto and goodyear hoses/lines/ Braille 17/ custom tray/
Koyo Rad filled w/ Mishimoto Chill/ RPurple motor blood
ericrapp0507@gmail.com is offline
 Old 01-01-2014, 09:00 PM   #48
Raider's Avatar
Groans: 856
2600.
yea i know
Oh you could? Got the timing tools? Know the cams are not marked for timing? We do have the how to posted, but even experienced mechanics have mis-timed these engine.VVT is no more than $1200 via dealer. 70001 miles or 84 months and 1 day from sale date-out of warranty.
Raider is offline
 Old 01-07-2014, 09:32 PM   #49
redneck4Christ's Avatar
Posts: 1,803   (View Stats)
redneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the worldredneck4Christ is the leader of the world
Groans: 24
@Rokusek's write up is gold! Good stuff. Thanks again!
I got my kit from @EdgeAutosport.com.
Good guys, both!
redneck4Christ is offline
 Old 03-03-2014, 02:22 PM   #50
Jeff23spl's Avatar
Posts: 2,009   (View Stats)
should we always replace the VVT actuator along with the chain and tensionner or is there a way to know if there is any issue with it ?
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Jeff23spl is offline
 Old 03-03-2014, 03:05 PM   #51
Raider's Avatar
Groans: 856
Since in there, yeah.
Raider is offline
 Old 04-11-2014, 12:35 AM   #52
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
In regards to upgraded parts, is there a complete list? I happened across a thread that mentioned the DCR VVT and that's definitely something I'm gonna look into, now that I wanna piece together a kit. I've only started looking into this after giving serious thought to the fact that my engine has over 120k on it. I don't wanna miss a thing!
season_of_ages is offline
 Old 04-30-2014, 06:53 PM   #53
Mfinlay04's Avatar
Posts: 826   (View Stats)
Mfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the world
If anyone is wanting the complete list with Mazda part #'s
VVT (new version) - L3K9124X0C9U
Timing chain - L3K912201A
Cam friction washer - L3K912429
Timing chain tensioner - L3K912500A
Crank pully friction washers x3 - L3H511407
Crank pully bolt - LF0111406
Front oil seal - L3G610602
Timing chain guide (tensioner side) - L3K912671
Timing chain guide - L3K912614
Valve cover gasket (inner and outer) - L3K910230
Since onlinemazda is going under new ownership. I bought all mine from Mazdawholesaleparts.com and got a good deal. I should be receiving next week. With free shipping if you buy everything directly from them it's 361.21
2006 MS6 Titanium Grey
BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3
Tuned with
Mfinlay04 is offline
 Old 04-30-2014, 07:46 PM   #54
jeffdevo's Avatar
Posts: 394   (View Stats)
jeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond reputejeffdevo has a reputation beyond repute
Does the Gen Pu VVT Chain also need to be replaced at 60k?
-Low Beam/ Fog HIDS - Lamin-X Yellow Tint on Fog Lights - TSW Mallory Wheels - Thule Bike Rack with 598 Criterium Bike Mount - GX-65 with Blendmount - Corksport RMM - Corksport Mudflaps - Corksport SRI - Corksport Rear Sway Bar - GX-65 radar laser detector - TRS Angel Eyes - Rear bumper LED Light - H&R Springs - Koni Yellow Struts - JBR Camber Arms - AP v2 -Autotech internals - Tork Motorsports Tuned - Halos - Strips - D2 Xenon Lights - SST brake lines - Stoptech Sport brake and rotors w/ sst Brake lines
[/I][/SIZE][/FONT]
jeffdevo is offline
 Old 04-30-2014, 08:14 PM   #55
The new version VVT, would that be as good or better than the DCR VVT?
Sent from my SM-N900T using Tapatalk
 Old 05-01-2014, 12:37 AM   #56
Mfinlay04's Avatar
Idk if the pu's have the same issue. I would assume that they would not be affected. I believe the recall for this came out before the pu was release. But don't take my word for it. The chain is not normally a service item. Should be good for life of motor.
Sent from my SCH-I605 using Tapatalk
Tuned with
 Old 05-01-2014, 12:42 AM   #57
Mfinlay04's Avatar
I haven't read of any failures of the new design VVT from Mazda that we installed correctly. I don't remember the time frame exactly but I believe the DCR was released before the new VVT was released. I know a handful of guys got on and bought the DCR and to my knowledge none have failed.
I emailed DCR yesterday to see if they still give a credit if we send in a new core. If they do I'll send the one I ordered in and have it "upgraded" just for peace of mind.
If they do not offer the discount I may just run the new Mazda version. Idk if 250 dollars more is justifiable.
Edit. So DCR emailed me back and they no longer offer the credit for new VVT core. If you send in a new core the price is 200. If you elect to have them supply the core its 250.
Tuned with
HTML code is On
Timing chain/VVT replacement parts list chuckms6 Mazdaspeed3/6 General Discussion 103 05-16-2019 04:38 PM
Timing Chain Replacement FluffySheepBoy MazdaSpeed 6 - Engine, Transmission & Driveline 2 01-26-2014 07:00 PM
timing chain and vvt replacement mikecrpntr MazdaSpeed 3 - Engine, Transmission & Driveline 2 11-15-2013 03:21 PM
Page generated in 0.37398 seconds with 30 queries
