 Old 12-31-2009, 01:51 PM   #41
darth vader's Avatar
Posts: 665   (View Stats)
Overfilling is a recipe for blown seals, leaks and internal damage. Remember, there's an expected air volume inside the case and there's a bunch of whirling gears pumping fluid and air around. If you overfill with an essentially incompressible fluid, something's gotta give.
darth vader is offline
 Old 12-31-2009, 02:11 PM   #42
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
Originally Posted by darth vader View Post
Any Ford technician/parts guy will know exactly what I am talking about. It's a little 4 oz bottle and it's is called "friction modifier". It is used in alot of ford's Trak Lok diffs from millions of cars in the 70s, 80s and 90s. Basically it makes gear lube a touch more slippery than usual, to reduce LSD chatter. It's called fish oil because it reeks like rotting fish. Costs a couple bucks, no more.
Ford Racing Performance Parts []
Ok , I gots the Ford friction modifier. Seriously, this is the stinkiest stuff on the planet.
Be careful using it, as even a tiny bit spilled stinks real bad.
Couldn't really tell a difference yet but my tranny was already warm when I added it. I'll report back after a few cold starts.
ps. picked it up at the ford dealer for $5
Originally Posted by FreeFlyFreak View Post
Been hearing that a lot. Seems strange, OM says 2.6, Service manuall says 2.6 buy you guys are getting 3+ in it..... You are level right? not jacked up or anything?
yea 2.6 qts. if the car is flat, prolly holds more is the car is jacked off, careful not to overfill.
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline
 Old 12-31-2009, 03:38 PM   #43
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Well I went ahead and got the Ford stuff xt m5 qs, a 24mm wrench, and a hand pump.
Put the fluid in and will go for a drive later.
The fluid that came out didnt look bad at all, I am wondering now if they changed the fluid when they replaced my drive shaft a couple of months ago.
If they did, who knows what they used.
The dealer is a combo Subaru Mazda dealer, they could easily have put some Subie GL-5 stuff in there!!
EDIT:
I just read the service manual and it calls for draining the fluid when changing the shaft.
No wonder things went down hill recently tranny wise, glad I caught it so soon, 2600miles on whatever they put in there, didnt notice a difference at first, but it has deteriorated rapidly over the past Month or so (shaft was changed mid October).
I am almost positive this is where my recent notchy hard shifting came from.
Cost me $80 for the oil and tools to fix what I think was caused by some dealer SNAFU.
If I had thought that might have been the reason earlier I would have taken it in and had them fix the problem, would have been useful to document it in case of future problems.
Anyway I'll let you know, if it gets better.
Never had any complaint about the tranny till the last Month or so.
Suspension:
FreeFlyFreak is offline
 Old 12-31-2009, 03:41 PM   #44
08cosmic3's Avatar
Posts: 2,920   (View Stats)
08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world08cosmic3 is the leader of the world
Groaned at 54 Times in 43 Posts
Originally Posted by felt View Post
Did you buy 3 or 20? Because on their site I see "There is a limit of 20 quarts per order due to shipping limitations"
That means you can't order MORE than 30 quarts. I ordered 3 and you will only need 2.7 quarts.
I used the how to and filled using gravity and a long tube. I guess if you pump it in from above or have the front end jacked up then it will hold more than 2.7
EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14
____________________________________________Dragon Slayer _________________________________________________
08cosmic3 is offline
 Old 12-31-2009, 05:11 PM   #45
ilusch's Avatar
Posts: 48   (View Stats)
ilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to beholdilusch is a splendid one to behold
Originally Posted by ms3077 View Post
So all these cars have the same transmission as the MS3?? I think this is for the regular 3 not the Speed3 unless of course it's a modified version. Wow, the 911 Carrera uses a transmission made by this company; SP6
Avensis
Corolla
Verso
Camry
Scion tC
RAV4
Mazda Motor Corporation
Mazda6
Mazda5
Mazda3
CX-7
Mitsubishi Motors Corporation
Eclipse
Grandis
Outlander
Rancer
Chrysler LLC
Dodge Caliber
Dodge Avenger
Jeep Compass
Jeep Patriot
Chrysler Sebring
The diesel cars are using the bg6! Sometimes they make more torque as the speed 3 !
The Toyota diesel have about 300 lb/ft!!!
ilusch is offline
 Old 12-31-2009, 07:57 PM   #46
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
I bought this some of this stuff today, too. I actually posted this in the M3F topic in the OP. My factory tranny fluid is draining overnight as I type this, I'm going to put the XT-M5-QS in tomorrow morning and report back on impressions.
wassup, thanks for the recommendation. I don't know if you remember this, but you actually suggested XT-M5-QS to me way back in July when we were at Ken's taking the front bumper off my MS3 so he could look at the FMIC.
Well i am happy to say that everything went off without a hitch - shifts are smooth and click-clickity now! I have to say that this XT-M5-QS stuff is a QUALITY product!
Cataphract_40 is offline
 Old 01-01-2010, 01:51 PM   #47
shpankey's Avatar
Posts: 496   (View Stats)
Yea, perfectly level. Even put a level on the battery. I spilt some, so I would guess it took right at 3 quarts, maybe a hair less. I filled it over a bit then let it drain for 30 minutes until it didn't come out while being level. My pinky in the hole, the fluid was right there level with the bottom of the hole. I am not worried at all about being overfilled b/c I know I had it level.
shpankey is offline
 Old 01-01-2010, 04:07 PM   #48
The Kamikaze King!
Groans: 754
Yeah me too, I was level and took almost 3. My guess is 2.8 quarts
Suspension:
 Old 01-23-2010, 01:19 AM   #49
bf360's Avatar
Posts: 2,069   (View Stats)
Can over filling damage your transmission at all?
Originally Posted by DCLXVI View Post
your car is possessed by satan, so i dunno whats goin on with that LOL vta's shootin fire some crazy ass extra fluid lines. secret boost control settings haha ninja, or your demon spawn gas pedal not taking no for an answer lololol but your shit rips it.
bf360 is offline
 Old 01-23-2010, 09:39 AM   #50
The Kamikaze King!
Groans: 754
Yes........... if it were possible.
If the car is level it is not possible to overfill, unless you are a fool, that is why the fill hole is on the side.
Any excess will drain out.
The top of the fill hole is the "High full" and one cm below the fill hole is "Low full"
Per the service manual.
I am thinking the quantity given in the owners manual, is more of a guide of how much to buy, or how much to expect to have to put in there before it begins dribbling back out.
The acceptable full quantity is a range.
Also, by way of an update, my car tranny is back to normal now after putting this stuff in, in fact I would say better than normal in terms of shifting.
I am now 100% convinced that the Mazda/Subaru dealer put some incorrect fluid in there, the tranny got progressively worse over 2500 miles until I could take it no longer, and then realized there must be a problem.
The only thing I do notice is a little noise from the LSD when the car is cold, and making a sharp turn.
I don't remember hearing that when the car had the original OEM fluid in it........ but there again I wasn't listening either.
Shifts way better though.
Suspension:
 Old 01-24-2010, 01:28 PM   #51
wildfrisco's Avatar
Posts: 22   (View Stats)
wildfrisco is on a distinguished road
On another forum someone said the 6-speed is actually a Getrag 6MTT450:
GETRAG Corporate Group - 6MTT450 TRANSMISSION
wildfrisco is offline
 Old 01-24-2010, 01:37 PM   #52
The Kamikaze King!
Groans: 754
I have heard both stories, but I trust wassup61 so I am going with his.
Suspension:
 Old 01-24-2010, 02:41 PM   #53
nue
nue's Avatar
Posts: 110   (View Stats)
nue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud ofnue has much to be proud of
So, that's why we don't have transmission dipsticks.
nue is offline
 Old 01-24-2010, 02:52 PM   #54
Tcman2006's Avatar
Posts: 165   (View Stats)
Tcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to allTcman2006 is a name known to all
anyone know how much the average dealer charges to change fluid
Tcman2006 is offline
 Old 01-24-2010, 03:30 PM   #55
nyghtryder's Avatar
Posts: 1,903   (View Stats)
nyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the worldnyghtryder is the leader of the world
too much, if you can change your oil you can do this.
A Kabar is just a paper weight until it's in the hand of a Marine.
If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground.
COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS
NATOR PA
nyghtryder is offline
 Old 01-24-2010, 03:35 PM   #56
Tcman2006's Avatar
my dealership kinda has this deal going..they do all the service and then give me a lifetime powertrain warranty
 Old 01-24-2010, 03:49 PM   #57
The Kamikaze King!
Groans: 754
Tranny fluid is not required to be changed according to the Mazda Maintenance schedule.
Therefore do it yourself, how will they know?
Suspension:
 Old 01-24-2010, 03:53 PM   #58
Tcman2006's Avatar
oooh ok good to know thanks....is there a how to on this?
 Old 01-24-2010, 04:05 PM   #59
The Kamikaze King!
Groans: 754
Link to a "how to" in post # 6 of the thread linked below:
Synthetic transmission oil suggestion
Suspension:
 Old 01-26-2010, 03:14 PM   #60
Mudpie's Avatar
Posts: 7   (View Stats)
Mudpie will become famous soon enough
If you are in the Marietta/Atlanta GA area, they carry the Motorcraft stuff at Original Equipment Marketing (340 Franklin Road, Marietta GA, 770-919-2515). The invoice from last May shows a retail price of $17.94/qt, they sold it at $13.12/qt. The big thing is have the Motorcraft part number ( XT-M5-QS ) with you when you go to any of the dealers. A number of people on miata.net have commented how the parts guys keep trying the sell the 75W140 smutz for diffys and claim it replaces the 75W90 stuff. WRONG ANSWER! Even at Original Equipment marketing, they pulled the diffy smutz and I had to show them the right stuff in the Motorcraft catalog, see screen shot below. Also note that Original does not take checks from individuals.
If you want directions involving "you go to the Big Chicken and...," send me a PM indicating where you will be coming from and directions will be supplied. Note, directions may involve mention of Waffle House or street with Peachtree somewhere in the name as well.
Mudpie is offline
 Old 01-28-2010, 01:24 PM   #61
Hank3's Avatar
Posts: 514   (View Stats)
Hank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the worldHank3 is the leader of the world
Thought about ordering this Ford fluid since I'm at 26K now, but I have had complaints with the stock fluid. Haven't had any grinds. Only thing I've experienced is when we had the cold snap in FL a few weeks back and it was somewhat hard to shift into 2nd in the mornings.
Where can you purchase the stock fluid at?
5% off Redline leather goodies HERE. Pics of them installed in my Speed3 HERE.
Hank3 is offline
 Old 02-02-2010, 12:20 PM   #62
hnda etr's Avatar
Posts: 4,173   (View Stats)
Groans: 90
Uhhh.... Dealership?
hnda etr is offline
 Old 02-02-2010, 12:54 PM   #63
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
My dealer does it for $79.95, but since I'm supplying the fluid they're only charging me $50... Not too bad at all.
They're doing it on Friday so I'm pumped to feel the difference over the stock gunk.
Alpha is offline
 Old 02-02-2010, 02:30 PM   #64
Groans: 30
have you considered doing it yourself?
I mean, you'll save $50...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
 Old 02-02-2010, 02:44 PM   #65
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
I in-fact changed my trans fluid last night. I put in the Motorcraft XT-M5-QS, as recommended by Jeff (wassup61). Don't pay a dealer to do it, unless you have no tools or means to lift the car. It's really easy to do yourself, with some tubing a funnel and a BIG-ASS 24mm wrench. I actually did it w/o lifting the car.
I also put in my stock RMM, cause the vibes from my cp-e RMM were getting annoying. I'll put the cp-e back in, come my next track day.
Anyways, my car now shifts as smooth as glass. I was having 2nd gear engagement issues, that now seem to be completely gone, thanks to the Motorcraft fluid.
Current Fail:
MATT DAMOND is offline
 Old 02-02-2010, 03:33 PM   #66
Groans: 30
good shit, isn't it?
1995 Miata
 Old 02-02-2010, 05:13 PM   #67
Frequentflyer's Avatar
Posts: 1,949   (View Stats)
I got it for a pretty good price off Ebay. $32.49 for 3 quarts + $13 for shipping.
08.5 CWP MS3 - Cobb AP *Stage 2* ATR tweaked - Cobb SRI w/AEM dry flow filter - RPMC Inlet - Corksport TMIC - Corksport Downpipe (w/OE midpipe) - PTP HPFP - Stock BPV - TWM SS w/bushings - CP-e RMM - Bilstein Sports w/OE springs - Rota 18x8.5 48+ SVN Black/w Red Lip - Bridgestone Potenza RE760 - Cobb RSB - Prosport Boost Gauge/Mearcat pod - Motorcraft XT-M5-QS in the tranny!
Frequentflyer is offline
 Old 02-02-2010, 05:18 PM   #68
madvillain's Avatar
Posts: 4,160   (View Stats)
Groans: 78
I think I'm going to go ahead and jump on this bandwagon..
madvillain is offline
 Old 02-02-2010, 07:40 PM   #69
Alpha's Avatar
Groans: 24
Hmm... You've got me thinking now.
I might just it then. I mean, $50 is $50.
Alpha is offline
 Old 02-03-2010, 03:38 AM   #70
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Takes less than an hour. So unless making $50/hr is not interesting to you then go for it.
If you need to buy a tool or two? So what, you will still come out $30 ahead and with useful tools.
cld12pk2go is offline
 Old 02-03-2010, 08:23 AM   #71
The Kamikaze King!
Groans: 754
That is the way I always look at it........ it is like the dealership buying me tools.
Suspension:
 Old 02-03-2010, 10:10 AM   #72
Alpha's Avatar
Groans: 24
Haha! SOLD!
Alpha is offline
 Old 02-03-2010, 11:06 AM   #73
Fagwagon's Avatar
Posts: 2,090   (View Stats)
Fagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the worldFagwagon is the leader of the world
Groans: 75
Groaned at 57 Times in 37 Posts
just ordered mine!
Fagwagon is offline
 Old 02-03-2010, 08:57 PM   #74
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ur a bitch! I sent them a message and asked them for a 3qt auction lmao.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 02-13-2010, 06:05 PM   #75
bani's Avatar
Posts: 335   (View Stats)
bani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond reputebani has a reputation beyond repute
Groans: 35
Groaned at 35 Times in 17 Posts
Isnt our tranny a Getrag? think I remember reading that somewhere.
no. our trans is an Aisin BG6.
bani is offline
 Old 02-13-2010, 06:31 PM   #76
The Kamikaze King!
Groans: 754
That was cleared up in posts #4 #7 and #11......
Maybe read the thread next time.
Suspension:
 Old 02-14-2010, 09:18 AM   #77
FULLBLOWN's Avatar
Posts: 78   (View Stats)
FULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to beholdFULLBLOWN is a splendid one to behold
So this is probably a long shot but from what I read in here, by only one person, would amsoil be a better way to go even if its more expensive?
FULLBLOWN is offline
 Old 02-14-2010, 10:17 AM   #78
Groans: 30
Buy the XT-M5-QS. It is the lube of the Gods. It flows in a giant, slippery river from its source on top of Mount Olympus, spreading smooth shifts to mortals throughout the land
1995 Miata
 Old 02-14-2010, 11:26 AM   #79
banditscout's Avatar
Posts: 783   (View Stats)
banditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the worldbanditscout is the leader of the world
Groans: 50
It is truly outstanding. I put this stuff in last week, and it really does make quite a difference in shift smoothness. The shifter seems much less reluctant to push through the gates. I also installed my solid shifter base bushings, and shifter weight a few days ago, which further pleases my right hand. IMHO these are the first 3 things you should do to this car. It really makes it quite a bit more enjoyable to drive. For under $100 bucks total for those 3 mods, you can't go wrong. DO IT.
banditscout is offline
 Old 02-17-2010, 11:58 AM   #80
I put this XT-M5-QS shit in today. I haven't driven it very much since, but from what I can tell, it's smooth as butter already.
HTML code is On
*Only* the transmission Ingle Mazdaspeed3/6 General Discussion 10 07-30-2018 07:39 AM
Transmission Cured FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 305 11-08-2017 07:36 AM
Rattle Not Cured TRex MazdaSpeed 3 - Engine, Transmission & Driveline 35 09-16-2011 06:20 AM
Page generated in 0.60126 seconds with 45 queries
