 Old 06-18-2012, 05:54 PM   #241
CaptainCrunch's Avatar
Posts: 83   (View Stats)
CaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the worldCaptainCrunch is the leader of the world
I did the Motorcraft XT-M5-QS this last weekend on my MS6 (not a fun job, try and find a 24mm offset closed-end wrench and remove the intake). It wasn't that different at first, but after 600 miles, there is a REAL difference. Before it could sometimes feel like metal on metal through the shifter, and that is gone.
I got it for $19 at a local dealer.
CaptainCrunch is offline
 Old 06-19-2012, 04:06 PM   #242
Cataphract_40's Avatar
Posts: 1,730   (View Stats)
Groans: 30
I truly hope you mean $19 per quart...otherwise you got the best deal on the planet on that stuff...
2008 GT MS3 - 307 WHP/338 WTQ
1995 Miata
Cataphract_40 is offline
 Old 06-24-2012, 07:17 PM   #243
Sweet baby jesus, if I had got it for $6.33 a quart I would have bought a thousand of them. The 3 actually came to $57 altogether.
 Old 06-24-2012, 07:46 PM   #244
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
It takes about 2k miles for it to break in.
Past Mazdas & Speeds
Neverlift is offline
 Old 06-26-2012, 10:04 PM   #245
CW42's Avatar
Posts: 216   (View Stats)
CW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant futureCW42 has a brilliant future
When it's cold and windy here, I get a very slight grinding feel. Now that it's summer it goes into 2nd fairly easily (takes a bit more force than the other gears) if you do it quickly, but I notice that if you hover between the gears too much (1 going down to 2) and try to ease it in, you can feel the gears bumping and then grind if you hover there too long. This only happens when the car is moving. When the car is stopped, no grinding or bumpiness is noticed while playing with the shifter in any way. I actually had this problem a bit with the 97 V6 Camaro I had after I got them to replace my clutch. Gears would not engage easily when the car was in motion and 3rd would grind in winter and was always harder to get into. Is this resistance to go into gear when a car is in motion normal? I drove the Camaro for 5 years that way and it never seemed to hurt anything or ever get any worse.
CW42 is offline
 Old 06-27-2012, 07:50 AM   #246
babypetit's Avatar
Posts: 18   (View Stats)
babypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant futurebabypetit has a brilliant future
subbed
babypetit is offline
 Old 07-03-2012, 02:42 PM   #247
Lexx3D's Avatar
Posts: 4   (View Stats)
Lexx3D is an unknown quantity at this point
Can anybody link me to a How-to on transmission oil change please?
Thanks
Lexx3D is offline
 Old 07-04-2012, 12:21 PM   #248
Groans: 30
This one's not bad, I used it when I changed out my transmission fluid to XT-M5-QS...
HOW TO: Transmission fluid change on MS3 *updated with some new info 11-15-07*
1995 Miata
 Old 07-21-2012, 08:58 AM   #249
Mid_Life_Crisis's Avatar
Posts: 137   (View Stats)
Mid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the worldMid_Life_Crisis is the leader of the world
Groaned at 14 Times in 4 Posts
I did it a few weeks ago. Nice improvement. It isn't a miracle cure that suddenly makes the tranny become a joy to drive, but it is better than it was. Weird thing is that after a few days I had to adjust the shifter. Once the new stuff displaced the old it started getting notchy, whereas before it was just stubborn. Adjustment cleared that up.
Mid_Life_Crisis is offline
 Old 09-19-2012, 01:08 PM   #250
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: Transmission Cured
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HTML code is On
*Only* the transmission Ingle Mazdaspeed3/6 General Discussion 10 07-30-2018 07:39 AM
Transmission Cured FreeFlyFreak MazdaSpeed 3 - Engine, Transmission & Driveline 305 11-08-2017 07:36 AM
Rattle Not Cured TRex MazdaSpeed 3 - Engine, Transmission & Driveline 35 09-16-2011 06:20 AM
Page generated in 0.31862 seconds with 28 queries
