Like Tree2Likes
  • 1 Post By Jesse MS3GT
  • 1 Post By yang_jackson
 Old 03-10-2008, 09:52 AM   #1
Jesse MS3GT's Avatar
Posts: 356   (View Stats)
Jesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the worldJesse MS3GT is the leader of the world
Default TSB's and Recalls for MS3
If possible please sticky! Also feel free to move this if you feel it is better suited elsewhere.
***NEW*** TSB thanks to Dadasracecar (added 4/8/08)
Click link below for Cam Driven Fuel Pump TSB
NHTSA Recall Campaign Number: 07V295000
Component: ENGINE AND ENGINE COOLING
Details: ON CERTAIN PASSENGER VEHICLES, THE NO. 4 LEFT SIDE ENGINE MOUNT BOLT MAY LOOSEN IF A SUDDEN RAPID ACCELERATION IS REPEATEDLY PERFORMED.
Consequence: IF THE VEHICLE IS CONTINUOUSLY DRIVEN UNDER SUCH CONDITION, THE NO. 4 ENGINE MOUNT BOLT MAY LOOSEN AND PULL OUT OR BREAK, ALLOWING THE TRANSMISSION TO BE OUT OF POSITION. IN EXTREME CASES, THE DRIVE SHAFT MAY BECOME DETACHED. IF THIS OCCURS THE VEHICLE WILL LOSE POWER AND WILL COME TO A STOP, INCREASING THE RISK OF A CRASH.
Corrective Action: DEALERS WILL INSPECT AND REPLACE THE NO. 4 ENGINE MOUNT BOLT WITH A MODIFIED ONE, AND, IF NECESSARY, REPLACE THE NO. 4 ENGINE MOUNT RUBBER AND BRACKET WITH NEW ONES FREE OF CHARGE. THE RECALLBEGAN ON JULY 13, 2007. OWNERS MAY CONTACT MAZDA AT 800-222-5500 .
Units Potentially Affected: 5700
Recall Initiated By: ODI
Date added to NHTSA datbase: 07/10/2007
NHTSA Recall Campaign Number: 07V052000
Component: EQUIPMENT
Details: ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH OPTIONAL ACCESSORY ALL WEATHER FLOOR MATS, THERE IS INSUFFICIENT CLEARANCE BETWEEN THE FLOOR MAT AND ACCELERATOR PEDAL.
Consequence: IN THIS SITUATION IT IS POSSIBLE THAT THE ACCELERATOR PEDAL MIGHT GET STUCK BEHIND THE FLOOR MAT, WHICH MAY PREVENT THE VEHICLE FROM PROPERLY DECELERATING WHEN THE ACCELERATOR IS RELEASED INCREASING THE RISK OF A CRASH.
Corrective Action: OWNERS WILL BE INSTRUCTED TO RETURN THE FLOOR MATS TO DEALERS AND WILL BE SHIPPED A NEW FLOOR MAT FREE OF CHARGE. THE RECALL BEGAN ON MARCH 7, 2007. OWNERS MAY CONTACT MAZDA AT 1-800-222-5500.
Units Potentially Affected: 1700
Recall Initiated By: MFR
Date added to NHTSA datbase: 02/15/2007
SERVICE BULLETIN:09012007 NHTSA ITEM NUMBER:10023192
MFG Bulletin Date: 20070901
Component: ELECTRICAL SYSTEM:WIRING:INTERIOR/UNDER DASH
Bulletin Summary: MIL ILLUMINATION (DTC P2006) VOLUNTARY EMISSION RECALL CAMPAIGN 4807H AND OBD-II COMPLIANCE VOLUNTARY EMISSION RECALL CAMPAIGN 4907H. *NJ
Date added to datbase: 20071101
SERVICE BULLETIN:0101007 NHTSA ITEM NUMBER:10021521
MFG Bulletin Date: 20070301
Component: ENGINE AND ENGINE COOLING:ENGINE
Bulletin Summary: MIL COMES ON WITH DTC P2006 (VARIABLE SWIRL CONTROL SYSTEM SHUTTER VALVE STUCK CLOSED). *KB
Date added to datbase: 20070514
SERVICE BULLETIN:0102206 NHTSA ITEM NUMBER:10023313
MFG Bulletin Date: 20070907
Component: SUSPENSION:FRONT
Bulletin Summary: FRONT CRANKSHAFT BOLT SERVICE WARNING. *NJ
Date added to datbase: 20071114
MTOL - 5636 Dealer Repair Information
Symptom and Conditions
Some customers may experience a chattering noise when passing over bumps
and/or driving on a rough roads,that may be confused as a dash rattle
at the base of the windshield.
Condition may be the result of a stick slips noise that occurs between
the cowl grill and the windshield.
Repair Procedure
When you encounter a customer with this concern replace the insulator
pads on the 8 hooks of the cowl grill with improved part as listed.
Part No. L206-50-794 Qty. 8 (4 per side)
Boosted_Speed3 likes this.
There will always be someone faster than you, smarter than you, or better than you in some way. They key is to maintain a presence beside those lesser than you to appear superior
35psi, super cams, ported head, titanium valve springs, titanium rods/pistons, flux capacitor, 88mph mod, cryogenic tranny with welded differential
Jesse MS3GT is offline
 Old 03-25-2008, 09:39 PM   #2
HiggyMS3's Avatar
Posts: 357   (View Stats)
HiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the worldHiggyMS3 is the leader of the world
Default New Recall
Got a call this afternoon from my dealer about a recall. Something to do with Door latch/lock re-enforcement??? Going in tomorow afternoon to get it done. I'll post more info after the work has been done.
2010 Victory Red HHR SS
2008 CPW MS3 (SOLD)
2004 Black SRT-4 (SOLD)
HiggyMS3 is offline
 Old 03-25-2008, 09:41 PM   #3
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
hmmmmmmmmmmmm
NYpest is offline
 Old 03-25-2008, 09:45 PM   #4
HiggyMS3's Avatar
They said it should take about an hour to complete and the "parts" just came in today. So I'm not sure if they are going to replace somehting or what but they wanted me in their ASAP to get it done.
2008 CPW MS3 (SOLD)
HiggyMS3 is offline
 Old 03-25-2008, 09:51 PM   #5
NYpest's Avatar
Merged:
keep us updated!!!!!
NYpest is offline
 Old 03-26-2008, 02:12 PM   #6
HiggyMS3's Avatar
Yeah so I'm not sure what the dealership was smoking. I get there and ask exactly what the recall is.......its for the locks. Its the whole If someone kicks your doors the right way they will unlock thing. I was like ok get it fixed than. They take my car into the bay and come out 5 mins later and say yeah your vehicle does not need the recall. Not a happy camper right now about them wasting my time along with having to leave work early to bring my car in.
2008 CPW MS3 (SOLD)
HiggyMS3 is offline
 Old 03-26-2008, 02:17 PM   #7
BlackMS3's Avatar
Posts: 1,078   (View Stats)
BlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the worldBlackMS3 is the leader of the world
I thought they fixed that with the older models..... sucks you had to waste your time.
Dealers are morons.
BlackMS3 is offline
 Old 12-08-2008, 12:04 PM   #8
AG.
AG.'s Avatar
Posts: 659   (View Stats)
AG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the worldAG. is the leader of the world
mitchells also works very well
2008 Sunlight Silver GT - Cobb SRI, HKS BOV Recirc, SU Test Pipe, TWM Shifter Bushings, 35%/5% Tint, Parrot Bluetooth Unit, Decals | To Come - Boost Gauge, Springs+Sways, CBExhaust, Wheels
AG. is offline
 Old 12-30-2008, 06:29 PM   #9
Speedy3's Avatar
Posts: 298   (View Stats)
Speedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the worldSpeedy3 is the leader of the world
Missing the VVT and CDFP TSB here.
2007 MAZDASPEED 3, MS CAI, MS CBE.
Speedy3 is offline
 Old 02-10-2009, 08:16 PM   #10
ctbadley's Avatar
Posts: 62   (View Stats)
ctbadley is a jewel in the roughctbadley is a jewel in the roughctbadley is a jewel in the rough
How serious is the motor mount loosening? Does this happen very often?
ctbadley is offline
 Old 04-13-2009, 09:46 PM   #11
dimitry's Avatar
Posts: 24   (View Stats)
dimitry will become famous soon enoughdimitry will become famous soon enough
Im going in to a dealer cross state to look at an MS3. Would they know which recalls have been fixed in the car? It's an Acura dealer, so they don't sell Mazdas often.
dimitry is offline
 Old 05-03-2009, 01:40 PM   #12
spool's Avatar
Posts: 28   (View Stats)
spool is an unknown quantity at this point
I'm glad the recall 07V2295000 is on here because my 07 Speed 3 for some odd reason never had this reall performed before I bought it, and low and behold last night the bolt snaps, of course it has to be Sat night when it breaks so now I have to tow the car in tomorrow morning but I'm going to raise hell for the fact it was a certified used car through mazda without having the recall performed. I am not a happy camper but thanks to you guys I can seriously talk to my dealer about some lingering questions I now have about their service work / certification there.
spool is offline
 Old 05-03-2009, 02:03 PM   #13
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
axle clicking tsb..............anyone????
rodrigo is offline
 Old 06-07-2009, 09:37 PM   #14
suby killer MS3's Avatar
Posts: 2   (View Stats)
suby killer MS3 is an unknown quantity at this point
I just bought a 2008 MS3 and i was wondering after reading this thread if your in cali area if you could suggest a dealer to get the recalls checked and or fixed
suby killer MS3 is offline
 Old 07-07-2009, 04:05 PM   #15
The Frush's Avatar
Posts: 25   (View Stats)
The Frush will become famous soon enough
hmmm, seeing all this and reading the thread about how everyone is having there motor blowing up is kinda making me think twice about getting one....
Some say he urinates 98 RON petrol, and that he can smell corners. No one knows when he was born, or how. But we do know why he was placed upon the Earth. To drive quickly. He has a penchant for prog rock, and rumour has it, likes his eggs sunny side up.......
All we know is he's called The STIG!!
The Frush is offline
 Old 07-07-2009, 05:33 PM   #16
yang_jackson's Avatar
Posts: 432   (View Stats)
yang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the worldyang_jackson is the leader of the world
Groans: 29
Groaned at 56 Times in 24 Posts
maybe you should get a Yaris.... i heard they are very dependable....
chief moped rider..... i just never let my friends see the moped. mopeds are great. they will do anything!
yang_jackson is offline
 Old 07-07-2009, 09:43 PM   #17
The Frush's Avatar
i should get one of those... then i can save money and buy a real turbo car... like a supra evo, or sti... yeah thanks for the idea... ass, I'm new on the site ans still have to read more about the ms3, so if i read more good then bad then i will get one. so far the stuff im reading is making me want to learn more about the ms3
 Old 07-11-2009, 02:11 AM   #18
Groans: 29
i dont get it.... why is this stuff youre reading make you wanna learn more about the ms3 if it isnt a 'real turbo car... like a supra evo (sic), or sti....'?
some unsolicited advice: if you are going for easy big power, choose a dif platform. if you want the best/fastest daily driver, the ms3 is for you. even though my car will never be 400+hp, its still fast as fuck and i couldnt be happier.
 Old 07-23-2009, 07:03 PM   #19
The Frush's Avatar
I'm not going for big easy power. i have driven 2 ms3 and liked them and there's no way in hell i would want a fwd car to have 400+ hp, it would lose all it's fun. i had a focus that had a bunch of cosworth stuff and had 228 wph on a mild tune and it was good enough for me but i was t boned and decided i would look into a turbo car that's fun to drive. the only reason i said "real turbo cars" was due to the reason that they have been around longer than the speed3. i'm not intentionally putting the speed3 down it's a good step forward in to the turbo game for the 5 door car. i was just in a bad mood, im currently looking at a silver speed3 bone stock except or some wheels. not sure what kind has no center cap's
 Old 10-29-2009, 01:10 PM   #20
bergj1986's Avatar
Posts: 143   (View Stats)
bergj1986 is a name known to allbergj1986 is a name known to allbergj1986 is a name known to allbergj1986 is a name known to allbergj1986 is a name known to allbergj1986 is a name known to all
Groaned at 5 Times in 1 Post
I just brought my car in for some warranty work. My driver's side seatbelt latch was squeaking when I went over bumps, apparently there's a TSB for this. When I drop the car off again to get the work done I'll get more info about the TSB.
There's also a TSB for Bose radio's eating CD's. My dealer said not to use MP3 CD's in my MP3-capable Bose CD-Changer because "they get stuck." Sounds like BS to me. I told him whenever I'm playing a burned CD, I can't change discs, even though the lights illuminate, nothing happens. However, the CDs will change if using a store-bought CD.
I'll keep everyone posted on what I find.
bergj1986 is offline
 Old 11-22-2009, 10:44 PM   #21
erod550's Avatar
Posts: 467   (View Stats)
erod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the worlderod550 is the leader of the world
What year is yours? I have an '09 and I have used a burned MP3 CD in my Bose CD Changer with no problems.
erod550 is offline
 Old 12-04-2009, 07:08 PM   #22
Dismember
KaiserSoze's Avatar
Posts: 611   (View Stats)
KaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the worldKaiserSoze is the leader of the world
Groaned at 27 Times in 13 Posts
Here's a list of bulletins
Finish Line / Rosenthal Mazda Parts & Accessories—::—Mazda3 Bulletins
2012 Nissan Titan 4x4
KaiserSoze is offline
 Old 12-14-2009, 05:12 PM   #23
DISITRB's Avatar
Posts: 144   (View Stats)
DISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud ofDISITRB has much to be proud of
Default Drive shaft TSB
Hey the Drive shaft TSB seems to be only for the regular mazda3 but I think that is occurring with my mazdaspeed3 did any one get this done on their MS3. I would like to know thanks
DISITRB is offline
 Old 12-14-2009, 05:16 PM   #24
The Kamikaze King!
FreeFlyFreak's Avatar
Posts: 4,155   (View Stats)
Groans: 754
Mine was clicking, they replaced the entire shaft about a month ago MS3.
Suspension:
FreeFlyFreak is offline
 Old 12-14-2009, 05:34 PM   #25
IshiKage's Avatar
Posts: 6,231   (View Stats)
Groans: 278
mine is clicking too
2015 Mazda 6
IshiKage is offline
 Old 12-14-2009, 05:51 PM   #26
07SP33D3's Avatar
Posts: 47   (View Stats)
07SP33D3 is just really nice07SP33D3 is just really nice07SP33D3 is just really nice07SP33D3 is just really nice
whats it sound like if its clicking? and how do you know? my car has like a clicking sound coming from the back of the car like everytime i go over bumps and shit.
07SP33D3 is offline
 Old 12-14-2009, 05:56 PM   #27
The Kamikaze King!
Groans: 754
click, click, click .........
you hear it.
You shit in your car going over bumps?
You need a Proctologist not a Mechanic!
Suspension:
 Old 12-14-2009, 08:08 PM   #28
IshiKage's Avatar
Groans: 278
you began to hear it on the cars initial move fwd (click) or in reverse (click)
thats how many started atleast
2015 Mazda 6
IshiKage is offline
 Old 12-14-2009, 08:31 PM   #29
07SP33D3's Avatar
you hear it.
i really appreciate the douchebag answer...
07SP33D3 is offline
 Old 12-14-2009, 10:23 PM   #30
DISITRB's Avatar
Thanks. this will the first time taking my car in. I have TT front mount, catch can, forge bpv cobb sri, bc coils and rims. do you think this will be a problem for recall service.
that exactly right. If I go reverse and forward I can repeat all the time. I have check all my suspension, sway bar and endlinks and I can't find nothing odd. it has to be it.
thanks for the help guys.
I schedule it for service on friday will see how it goes.
DISITRB is offline
 Old 12-14-2009, 10:53 PM   #31
phantom3's Avatar
Posts: 1,223   (View Stats)
phantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the worldphantom3 is the leader of the world
Groans: 190
Groaned at 53 Times in 32 Posts
I'm starting to get it... Only once as I move either forward or backward.
My mission is to go fast.
Currently Designing:
The golden girdle of the gods
The CF "fuck your face" IM
phantom3 is offline
 Old 12-15-2009, 09:49 AM   #32
DISITRB's Avatar
One more thing. What do say to the dealer as far the service bulletin? They are telling me that there isn't a service bulletin like that for the MS3 I knew they were going to give shit I have not even show up there and its already problem. Is this something you pay for?
DISITRB is offline
 Old 12-15-2009, 10:18 AM   #33
The Kamikaze King!
Groans: 754
I didnt mention the bulletin, it doesn't apply to MS3 and would just confuse the issue.
Just told them there was clicking from drivers side front during load changes, that I could only hear it with the window down, and that it sounded like a bad CV joint.
They checked it out, ordered a new axle.
Replaced under warranty.
Suspension:
 Old 12-15-2009, 06:48 PM   #34
DISITRB's Avatar
Nice to hear. What a your mods and do you think I will pass by with mine.
Thanks for the help.
DISITRB is offline
 Old 12-15-2009, 07:31 PM   #35
The Kamikaze King!
Groans: 754
My mods, Koni FSD shocks, and Cobb SRI
As far as the dealer is concerned........
In other words everything else is removed for visits, and I would remove the SRI too if I was going in for any warranty work engine related.
You have........
LOL... good luck, depends on your dealer really, I would consult the Good dealer and Bad dealer lists on the forum to see if there is a "good" dealer in your area.
Suspension:
 Old 12-22-2009, 12:35 PM   #36
shpankey's Avatar
Posts: 496   (View Stats)
you hear it.
Dude, thank you for your post. This had me fricken ROLLING here at work. People lookin all funny at me now. lol
shpankey is offline
 Old 12-26-2009, 01:40 PM   #37
The Kamikaze King!
Groans: 754
Glad you liked it.... LOL
Suspension:
 Old 04-18-2010, 07:39 PM   #38
Mikey95hd's Avatar
Posts: 10   (View Stats)
Mikey95hd can only hope to improve
Groaned at 16 Times in 8 Posts
The STIG is Michael Schumacher.
Santa Clarita Galpin, Steve is the top mechanic in the country on these cars...
I think a LEAF would be better
Since you had a Focus, get the Focus RS 500...only 500 will be made
Mikey95hd is offline
 Old 04-23-2010, 09:43 PM   #39
usmc_adams's Avatar
Posts: 186   (View Stats)
usmc_adams is a jewel in the roughusmc_adams is a jewel in the roughusmc_adams is a jewel in the rough
so if i take my car to the mazda dealer and tell them these are the recalls can you fix them even if nothing wrong that i know of can they charge you for this? and or does ne of these recalls must be screwing with my car before they will fix it?
98 Honda Accord V6 (R.I.P.)
03 VW Jetta GLI VR6 6SPD- APR Stage 2 (93 Octane Program), APR Carbon Fiber Carbonio CAI, Neuspeed Coilovers, Neuspeed F&R Rotors, BBS 18', APR Performance Exhaust (R.I.P.)
08 Mazdaspeed3 Mica Black-PG Torque damper, CP-e Xcel Nano SRI w/ pre-filter, Forged BPV V2, 4000 watt lanzar, 2 12' kickers at 2000 each
usmc_adams is offline
 Old 09-19-2012, 01:58 PM   #40
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Discuss Here: http://www.mazdaspeedforums.org/foru...speed-3-a-151/
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
CWP_MS3 is offline
HTML code is On
TSB's and Recalls for MS3 Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 41 06-19-2015 07:12 PM
GM recalls 13,780 vehicles after fire reports; Chrysler recalls 16,000 Jeep Libertys Haltech Automotive News 0 11-11-2010 10:10 PM
GM recalls over 126,000 Hummer H3s Haltech Automotive News 0 05-05-2010 11:30 AM
Page generated in 0.60961 seconds with 44 queries
