 Old 01-23-2011, 10:56 AM   #161
Mchart's Avatar
Posts: 980   (View Stats)
Mchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the worldMchart is the leader of the world
Groans: 54
Groaned at 42 Times in 32 Posts
Originally Posted by Monotonous ONE View Post
battery removal is not necessary in the least
It is if you don't have a short enough wrench and small enough hands to be able to reach into that space.
Mchart is offline
 Old 01-23-2011, 12:51 PM   #162
Mchart's Avatar
Groans: 54
Well.. Results are in the KMD internals seem to be doing the job. Pump holds well above 1700 PSI throughout the entire band now. Hits 1900 PSI from time to time as well.
This upgraded pump seems to be a bit more noisy then the stock one.. But I would assume that is due to the increased size of the internals.
Thanks for the help Joe.
Mchart is offline
 Old 01-23-2011, 01:18 PM   #163
ebnash's Avatar
Posts: 244   (View Stats)
ebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond reputeebnash has a reputation beyond repute
I have the hands of a Giant! I am certainly going to try and avoid removing bat. box and intake, but it really doesn't take more than 10 mins or so after you've done it a few times.
Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
ebnash is offline
 Old 01-24-2011, 02:14 PM   #164
JTMS3's Avatar
Posts: 2,306   (View Stats)
JTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the worldJTMS3 is the leader of the world
Groaned at 21 Times in 15 Posts
The guy who installed my internals pulled the pump in about 10 mins and just removed the lines and IC cover. No battery or intake was hurt during the installation of these internals.
Mazdaspeed 3 2010 w/ tech package - Celestial Blah Blah Blah
4/15/12 dynojet results: 305whp / 355 tq
JTMS3 is offline
 Old 01-26-2011, 08:18 PM   #165
DONOTBUGME's Avatar
Posts: 2,631   (View Stats)
DONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the worldDONOTBUGME is the leader of the world
Groans: 266
Groaned at 83 Times in 60 Posts
So using the ultragauge i checked my fuel pressure and it never dropped below 1650 during wot, saw it get up to 1700. I figure it has to be right cause it is hooked in to the obd II thing. not bad for the mods I have I guess
Blk 2010 MS3\\ Cobb AP Perm Tuned\ Autotech hpfp internals\ COBB intake \ Cobb Turbo Inlet \ Forge Bpv \ Cp-e DP \ Actual 3inch Magnaflow Exhaust \ Cp-e RMM \ JBR PMM \ ETS 3.5" TMIC \ Denso Iridium Power ITV22 \ JBR SSP and Bushings \ TWM Flat Black Piston Shift Knob\ Menzari Inferno Blk Wheels\ Eibach Pro-Kit Springs\ Koni Yellows \ Custom Painted Tanabe Strut Tower \ Red Corksport Boost Tubes and Bypass Valve Hose\ Black Badges \ DDM 5K HID, Fogs 3K yellow \ Shark Fin \\Audio \ Pioneer DD Touch Screen x920BT4 \ Alpine Type R 6.5" Components and 5x10 Speakers Powered by a 4 Channel 1600 Watt Avionxx Digital Amp \ 10" JLW3 Sub Powered by a 1 Channel 1000 watt Avionxx Digital Amp \ Prosport Prem. Boost and Oil Pressure Gauges \ Blockhead Dual Gauge Pod \\ Im thinking meth next.
DONOTBUGME is offline
 Old 01-26-2011, 08:24 PM   #166
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
The problem is that it may be dipping so fast you don't see it on the gauge. Unless that gauge can data log too. If you see other peoples logs, it will dip for a second and then be right on target.
wolly6973 is offline
 Old 01-26-2011, 08:27 PM   #167
DONOTBUGME's Avatar
Groans: 266
I see hmmm, well i have ordered the KMD internals anyways. Have to wait two fucken weeks aleast for them.
 Old 01-26-2011, 08:31 PM   #168
wolly6973's Avatar
Groans: 386
"The Great Fuel Pump Shortage of 2011" strikes again
just as well for me, can't afford one now anyway...
 Old 01-27-2011, 11:12 AM   #169
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
i feel your pain. i've been waiting for my cp-e pump since mid December and it still has yet to ship.
rfinkle2 is offline
 Old 01-31-2011, 11:59 AM   #170
Special--k's Avatar
Posts: 611   (View Stats)
Special--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the worldSpecial--k is the leader of the world
Dont feel like reading 5-6 pages... can someone link info on KDM internals in the OP or maybe make a new sticky since its going to be one of the biggest topics in the GenPu forum.
Special--k is offline
 Old 01-31-2011, 03:14 PM   #171
Nataphen's Avatar
Posts: 2,704   (View Stats)
Groans: 31
Well, God forbid you read a thread in it's entirety.
I'm just fuckin with ya. I know that you already got the link that you were looking for on the Cobb AP thread.
06 BM MS6=stock (totaled)
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 01-31-2011, 03:19 PM   #172
Special--k's Avatar
Whats with the No thanks Wolly... you dont think that it might be benificial for a GenPu forum to have a sticky about the most important tuning information (Fuel pump) for the plateform.
I sure think so, someone should make it eazy for us to figure out what to buy / where to buy / and how to install.
 Old 01-31-2011, 03:39 PM   #173
wolly6973's Avatar
Groans: 386
Nata was in a good mood and used sarcasm...
I just groaned, didn't feel like typing out a response.
The info is everywhere, just search.
Also, what makes you so much better than everyone else that you don't have to read?
Especially on such an important topic, you will learn much more from reading through some threads on your own than just getting a readers digest version from someone who may be mis-interpreting things.
 Old 01-31-2011, 03:44 PM   #174
Special--k's Avatar
i was at work. Sorry, either way i got my link from someone
 Old 01-31-2011, 03:48 PM   #175
wolly6973's Avatar
Groans: 386
If you are at work then you should be reading everything!
What better way to pass some time?
What do you think I do all night at work? lol
 Old 02-01-2011, 06:41 AM   #176
ebnash's Avatar
Noboy knows how to use Google/Yahoo to search for shit on the internet???
Reading is fundamental...
ebnash is offline
 Old 02-01-2011, 07:17 AM   #177
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
lol at faggots not wanting to read
theres a wealth of information here. soak it in.
Monotonous ONE is offline
 Old 02-04-2011, 04:34 AM   #178
getcrazykid's Avatar
Posts: 34   (View Stats)
getcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud ofgetcrazykid has much to be proud of
Im skimming through most of the last 2 pages, I did read the first 3 entirely but what I'm looking for in info - not about the pump, it has obviously been well explained and I thank you all for that - But not too much info has been covered about what can monitor the Fuel pressure's for sure. I read questions but not to many answeres.
Im looking at both the Dashdaq and the ultragauge. I look at there paramiters and nothing say the that it monitors specifically the HPFP but they are along to lines, saying fuel pressure absolute blah blah. But does anyone know for sure which one of these does monitor the HPFP's pressure? I dont wanna buy then say shit, I dont see it.
The dashhawk is just so small of a screen IMO like and old school Apexi S-AFC.
getcrazykid is offline
 Old 02-04-2011, 05:41 AM   #179
Nataphen's Avatar
Groans: 31
I would recommend getting a Cobb Accessport. It logs, tunes, clears CELs, etc., etc. The gen 2 software hasn't come out yet. PM me for info.
13 5.0
Wife's 13 Focus ST
Nataphen is offline
 Old 02-04-2011, 02:50 PM   #180
Thats not really what I was asking for. I'm pretty interested in the Ultragauge since they have it onsale for 60$
UltraGauge Automotive Information Center and OBDII Scan Tool
Does anyone at all know for sure that this monitors the high pressure fuel pressure?
 Old 02-04-2011, 07:37 PM   #181
DONOTBUGME's Avatar
Groans: 266
Yes it does, I have it.
example
 Old 02-04-2011, 07:44 PM   #182
MS33SM's Avatar
Posts: 1,821   (View Stats)
MS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the worldMS33SM is the leader of the world
Groans: 132
Groaned at 166 Times in 92 Posts
Efff an Ultragauge, use Torque
MS33SM is offline
 Old 02-04-2011, 07:53 PM   #183
DONOTBUGME's Avatar
Groans: 266
Looks nice but i dont have a droid
 Old 02-07-2011, 12:48 PM   #184
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
@MS33SM
sounds interesting. Where can i get the Mazdaspeed PID´s? Just ordered an EM327 OBDII Bluetooth Modul from Ebay :-)
MPS_Fan is offline
 Old 02-07-2011, 01:26 PM   #185
MS33SM's Avatar
Groans: 132
Originally Posted by MPS_Fan View Post
@MS33SM
All questions are answered in the VIP
MS33SM is offline
 Old 02-09-2011, 01:18 AM   #186
nuttzzy's Avatar
Posts: 102   (View Stats)
nuttzzy is a glorious beacon of lightnuttzzy is a glorious beacon of lightnuttzzy is a glorious beacon of lightnuttzzy is a glorious beacon of lightnuttzzy is a glorious beacon of lightnuttzzy is a glorious beacon of light
Groaned at 5 Times in 2 Posts
waiting on my parts to upgrade as well
2010 Mazdaspeed 3
nuttzzy is offline
 Old 02-09-2011, 08:14 AM   #187
rfinkle2's Avatar
Groans: 298
i have just about all of the how to's subscribed to, but remember someone recommending a particular tool for the hpfp install...
can someone remember off of the top of their head the tool recommended (besides a crowsfoot) for the 19mm nut on the bottom of the pump?
rfinkle2 is offline
 Old 02-09-2011, 08:20 AM   #188
Groans: 819
The nut on the bottom requires an open ended wrench...and adjustable will not fit
The pump itself is held in by 3 E8 inverted (female) torx bolts. I recommend using an extension to get in there.
Thats basically it.
And be prepared to get sprayed in the face with gasoline...its lots of fun
 Old 02-09-2011, 08:24 AM   #189
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
The stock fuel pump = bad
aftermarket fuel pump = good
Amazon is offline
 Old 02-09-2011, 08:24 AM   #190
MS33SM's Avatar
Groans: 132
MS33SM is offline
 Old 02-09-2011, 08:26 AM   #191
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Groans: 112
we need a fuel pump god to appear and solve the shortage problem.
that is all.
860whp/677wtq
2.7 V6 Ecoboost
PapaSmurf is offline
 Old 02-09-2011, 08:48 AM   #192
rfinkle2's Avatar
Groans: 298
thanks! that was what i remembered reading e8 inverted torx bolts (female).
i'll be sure to wear some goggles.
THANKS AGAIN.
rfinkle2 is offline
 Old 02-16-2011, 06:54 PM   #193
rawazchico's Avatar
Posts: 28   (View Stats)
rawazchico will become famous soon enoughrawazchico will become famous soon enough
Groaned at 9 Times in 4 Posts
Default Make this simply for a noob.
I installed a hks cat back exhaust on my 2011 mazda3 and ordered a cobb sri. My queston is that putting my car in danger in anyway? Bare with me i amthe first to admit i am a total noob to this lol
rawazchico is offline
 Old 02-16-2011, 07:03 PM   #194
ebnash's Avatar
Read the entire post. You are not going to get any love here if you do not read. Actually, just read the title of this post and you will get your answer. Gen 2 is like a box of chocolates...
ebnash is offline
 Old 02-17-2011, 11:38 AM   #195
surebOOst's Avatar
Posts: 1,795   (View Stats)
surebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the worldsurebOOst is the leader of the world
Groaned at 61 Times in 40 Posts
I just bought a 2010 ms3 used of course with 13k miles on it. To my knowledge the car only has a cobb sf intake but I haven't been able to get under it for a better look. Anyway I was drivin up an onramp the other day and was in 3rd gear very close to WOT and had a very short but very abrupt cut in power then a second later the it spooled back up and was running fine. I drove it hard the past couple days trying to duplicae the issue but haven't so far. Talked to a friend and he said that it sounded like a fuel cut. Im not completely sure what it was but I would appreciate suggestions for data logging systems or software!
surebOOst is offline
 Old 02-17-2011, 01:04 PM   #196
wolly6973's Avatar
Groans: 386
AccessPort.
 Old 02-17-2011, 01:09 PM   #197
MS33SM's Avatar
Groans: 132
You bought a car and are unsure of all the mods?!?!?!?!?!
Sounds like you bought a previously raped car.
MS33SM is offline
 Old 02-17-2011, 04:21 PM   #198
surebOOst's Avatar
Actually i traded a 2004 rx8 with 80k miles and no warranty on a 2010 ms3 with 13k miles and an extended warranty. You may ask why i made such a purchase? i returned from a year deployment in november and found out that verizon is fucking stupid and does not know how to freeze an account so they sent my bill to a collection agency in march and reported bad on my credit until nov when i got it tooken care of....i have bad credit so i got what i could and thankfully it was a ms3. THE CAR MIGHT HAVE BEEN RAPED PREVIOUSLY BUT NOTHING A WARRANTY WONT FIX
Honestly its better than a focus or carolla.....my other options if i didnt get the ms3. It was also inspected and driven plenty before i purchased the vehicle. unsure of the mods cause i have never had a turbo car and dont have a lift to check it out. looks pretty much stock except for intake under the hood.
 Old 02-17-2011, 09:43 PM   #199
rfinkle2's Avatar
Groans: 298
Originally Posted by wolly6973 View Post
AccessPort.
+1^
other datalogging available is incomplete in terms of usable pids AND the Accessport will tune / flash the car if you decide to in the future.
rfinkle2 is offline
 Old 02-18-2011, 05:38 PM   #200
surebOOst's Avatar
seems like the access port is the way to go! Thx....just have to wait on taxes now
HTML code is On
2010+ Mazdaspeed 3, I recommend to monitor your fuel pumps closely Nataphen 2010 MS3 - Fuel, Nitrous & Water Injection 508 07-06-2013 10:44 AM
Fuel Pumps - Gen 1 & Gen 2 MS3&MS6 whitewater 2010 MS3 - Fuel, Nitrous & Water Injection 6 05-24-2012 01:43 AM
recommend me a fuel pump (08ms3) blue_train MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 2 01-05-2012 02:09 PM
If Fuel Pumps are necessary, why no TSB? Silver Ecstasy 2010 MS3 - Fuel, Nitrous & Water Injection 52 09-07-2011 06:19 PM
Cp-e or PTP fuel pumps? manelscout4life MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 99 06-09-2010 04:32 PM
Page generated in 0.58065 seconds with 37 queries
