 Old 01-16-2012, 08:28 PM   #1
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Default Fuel mix cheat sheets
Seasonal Blends By Region
For 70%, 75%, 80%, 85% seasonal blends of e85 (ethanol content by volume), also factoring in e10 pump gas. Please let me know if you guys want other blends of e85/e10 done up.
E85 beta scalar cheat sheet:
***NOTE*** This cheat sheet is based on the percentage of ethanol in the tank, NOT the percentage of e85 in the tank (ethanol content by volume). See below sheets for actual %E for use in the above table.
E70 mix cheat sheet:
E75 mix cheat sheet:
E80 mix cheat sheet:
E85 mix cheat sheet:
Actual spreadsheet (which can be modified for other seasonal blends and also has the scalar cheat sheet within it) is also attached now.
Enki is offline
 Old 01-16-2012, 08:35 PM   #2
Enki's Avatar
Groans: 189
The XLS for whomever wants more granularity, etc.
Made in OpenOffice, not sure if it will have issues with Excel or whatnot.
Edit: Use the XLS in the OP.
Enki is offline
 Old 01-16-2012, 08:39 PM   #3
GoSpeed3Go's Avatar
Posts: 493   (View Stats)
GoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the worldGoSpeed3Go is the leader of the world
Groaned at 27 Times in 8 Posts
cool man. was wondering where my 2/5 was.
https://www.facebook.com/NorCalTintZone
instagram: sharpdetails
GoSpeed3Go is offline
 Old 01-16-2012, 08:42 PM   #4
Enki's Avatar
Groans: 189
Looks like about 19% on winter blend.
Enki is offline
 Old 01-16-2012, 09:00 PM   #5
Enki's Avatar
Groans: 189
I Just realized I should probably post up my method for filling up; the rule of 3.
MS3 has 14.5 gallon tank, but reads E at about 2 gallons; I figure each quarter tank is 3 gallons, making 50/50 mix 1.5 gallons per quarter tank or .75 gallons per 1/8th, with half a tank obviously being 3 each and 3/4 fill-up being 4.5.
While you may not fill all the way up to the neck with this method, you are less likely to fuck up your mix when doing so.
Enki is offline
 Old 01-17-2012, 09:43 AM   #6
GoSpeed3Go's Avatar
i dont think they switch in cali because of the mild weather.
 Old 02-28-2012, 11:30 AM   #7
Enki's Avatar
Groans: 189
Added E85 beta scalar cheat sheet.
Enki is offline
 Old 02-28-2012, 11:48 AM   #8
Enki's Avatar
Groans: 189
Everything now in the OP for ease of perusal.
Enki is offline
 Old 02-28-2012, 11:51 AM   #9
Boosted Beluga's Avatar
Posts: 4,859   (View Stats)
Groans: 50
Sweet thank you.
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosted Beluga is offline
 Old 02-29-2012, 07:35 AM   #10
Posts: 9,484   (View Stats)
This should be stickied.
thanks Enki!
Dano is offline
 Old 02-29-2012, 07:43 AM   #11
SRTie4k's Avatar
Posts: 1,715   (View Stats)
I might help to change your vocabulary in the first post a little to specify "by volume" as opposed to "by ratio of ethanol to gas".
Otherwise, very helpful, thanks!
SRTie4k is offline
 Old 02-29-2012, 07:49 AM   #12
stuck
superskaterxes is offline
 Old 03-12-2012, 10:35 AM   #13
Enki's Avatar
Groans: 189
Updated OP with link to seasonal blends by region information for more accurate calculation of mixes based on date.
Enki is offline
 Old 07-19-2012, 10:15 AM   #14
Mfinlay04's Avatar
Posts: 826   (View Stats)
Mfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the worldMfinlay04 is the leader of the world
Great thread. This shit is priceless.
2006 MS6 Titanium Grey
BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3
Tuned with
Mfinlay04 is offline
 Old 07-19-2012, 10:35 AM   #15
Enki's Avatar
Groans: 189
Enki is offline
 Old 07-19-2012, 10:38 AM   #16
RichieRichness's Avatar
Posts: 3,314   (View Stats)
Groans: 35
Originally Posted by Mfinlay04 View Post
Great thread. One noob question, just to clarify if one has their MAF tables calibration correctly for pump gas. If we wanted to run some mix of e85 we would just multiple the entire MAF table by X. Whereas X is the value in your tables which relates to the ratio we will be running?
No, the purpose of this thread is to dial in your Injector Control Tables.
RichieRichness is offline
 Old 07-19-2012, 10:50 AM   #17
Mfinlay04's Avatar
As yes after reading the thread on the computer I see there is a FSG and Scalar for the percent of ethanol used.
Tuned with
 Old 08-14-2012, 11:45 AM   #18
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Some people may also find THIS calculator helpful.
2006 Mazdaspeed6
sidekick is offline
 Old 08-14-2012, 12:00 PM   #19
Enki's Avatar
Groans: 189
Unfortunately, that site won't tell you the scalars for the AP, and the mileage shit doesn't apply because we can tune for MUCH better mileage on e85 than a normal, un-tuned flex-fuel vehicle can get (basically close to stock mileage if you keep your foot out of it).
Enki is offline
 Old 08-15-2012, 12:41 PM   #20
sidekick's Avatar
Groans: 47
It's very useful for figuring out your ethanol mix though.
2006 Mazdaspeed6
sidekick is offline
 Old 08-15-2012, 07:45 PM   #21
Enki's Avatar
Groans: 189
Ok...
But the screenshots up top are pretty much laid out so you don't have to type anything into a calculator.
Enki is offline
 Old 09-19-2012, 01:01 PM   #22
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f633/fuel-mix-cheat-sheets-125097/
Is anyone running E10 fuel in a DISI motor? - Page 4 This thread Refback 08-07-2014 10:53 PM
HTML code is On
Fuel mix cheat sheets Enki MazdaSpeed 3/6 - E85 Fueling 53 12-23-2015 04:38 PM
atr cheat sheet 2k4_8 2010 MS3 - ECU Computer Tuning 6 03-08-2012 05:01 AM
Mazda whips the sheets off of MX-5 Miata Miyako for UK market Haltech Automotive News 0 06-30-2010 07:00 AM
18 psi DynoJet Dyno Sheets 18psiWhiteMS3 MazdaSpeed 3/6 - Big Turbo Builds 13 04-08-2010 08:59 AM
New SmartBargains Coupon Codes - Extra 25% Off Select Luxury Sheets at SmartBargains Haltech Hot Deals Section 0 04-14-2008 12:50 PM
Page generated in 0.40184 seconds with 30 queries
