 Old 09-26-2011, 05:36 PM   #201
well got some bad news guys
David drilled down into the ECU at a deeper level and found a few hundred various references to the HPFP Sensor voltage that is all calculated based off of the expected factory sensor readings. All of these work against anything we've tried to change, and as such are causing the unexplainable behavior you've been seeing. Unfortunately all of this code cannot be simply "adjusted" like a table in ATR and will require rewriting of ECU code to allow use of these aftermarket sensors. This type of coding is very labor intensive and will likely not be completed until resources are available to do so. For the short term, we'll be removing the HPFP Sensor tables from TUNER until these resources are available to continue development. We now have the sensor and pigtail in house, so we will be able to test at a much higher rate once we get back into it.
superskaterxes is offline
 Old 09-26-2011, 06:13 PM   #202
Speeeeeed
06Speed6's Avatar
Posts: 6,526   (View Stats)
Fail
2006 Mazdaspeed 6
06Speed6 is offline
 Old 09-26-2011, 06:21 PM   #203
Eth Fiend
phate's Avatar
Posts: 6,931   (View Stats)
lol, few hundred references. fuck.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 09-26-2011, 06:27 PM   #204
Posts: 9,484   (View Stats)
no shit...I'd say its time for a dedicated piggyback for the fuel sensor...no?
or is there not enough voltage to scale it and you're right back to the SB limitations?
Dano is offline
 Old 09-26-2011, 06:38 PM   #205
how old r you? dont u remember the famous DJCKT?!?!?!
 Old 09-26-2011, 06:40 PM   #206
taf0422's Avatar
Posts: 4,688   (View Stats)
Groans: 192
subbing.
[SIZE="1"]07 MS3 GT..
GTX3076r --- 479/412
S4-460/400
Highest HP BNR S3
BNR-S3 424/397
taf0422 is offline
 Old 09-26-2011, 07:45 PM   #207
yessssss I absolutely do!!!! those things were poised to sell like hotcakes...then cobb up and started back on development for our platform LOL
guess we are back to the DJCKT..
@djuosnteisn...ready to get back into production??
Dano is offline
 Old 09-27-2011, 09:54 AM   #208
SSinstaller's Avatar
Posts: 3,922   (View Stats)
Groans: 56
That sucks, but at least we learned a little from your testing...
Now that we're sure the injector can handle at least 2300~2400psi, can cobb at least remove the cut we get when the OEM sensor hits 4.5v... That would allow us to run a 2350psi RV and just target ~2025psi and not worry about cutting if we overrun that pressure...
Soon to be installed:
SSinstaller is offline
 Old 09-27-2011, 10:56 AM   #209
lol that cut is GOOD sir. i wouldent want to stretch a sensor that is included in HUNDREDS of logic calculations haha
@Erich seems to be just fine running a 2050 RV i think. if u look at his logs he seems to have every consistent pressure just below the OEM sensor limit.
 Old 09-27-2011, 11:09 AM   #210
708
Erich's Avatar
Posts: 4,274   (View Stats)
I am running a 2150 RV, and targeting (with good success) in the 2030-2050 range. I don't seem to get any cut on the rare occasion it spikes to above 2071. Maybe something they changed from the MS6 to MS3 ECU. Has Cobb looked at the MS3 ECU for this as well as the MS6? Do they know if the same hardcoded bullshit is in the MS3 ECU?
Erich is offline
 Old 09-27-2011, 03:29 PM   #211
Groans: 56
Yeah, but my fuel system is on steroids LOL.. I can not target my FP like that. I tried running a 2050psi valve and still spike high enough to get the cut even targeting OEM fuel pressures.. I see 2000psi running the OEM RV and targeting ~1900psi...
I guess I'm stuck waiting for a port injection solution...
 Old 09-27-2011, 03:48 PM   #212
708
Erich's Avatar
Must be those injectors. Pull them off the car and send them to me and I will test to verify.
Erich is offline
 Old 09-27-2011, 04:35 PM   #213
Ziggo's Avatar
Posts: 3,843   (View Stats)
Just when things were looking up...
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 09-27-2011, 05:47 PM   #214
chris,
why dont u ramp up FP so that u dont get a spike?
 Old 09-27-2011, 09:17 PM   #215
Groans: 56
chris,
I've tried every possible FP combination and it still spikes..
I tried targeting 1000psi at WOT and it still pegged the sensor with the 2350 and 2050psi RV's..
IMO, the only reason my car is driveable is the OEM RV opens at 1886psi, and can bypass a shitload of fuel.. I still sometimes see logs where my FP touches 2050psi..
 Old 09-28-2011, 08:24 AM   #216
Ziggo's Avatar
I would not put much stock in the injector duty cycle value. It is known to have issues and doesn't account for the DI rail pressure. With DI it seems the soft fueling limit is found by spark blowout not by running lean so I wouldn't say you are out of fuel till you start seeing blowout.
I bet your MAFCAL cal is spoofed lower than actual to adjust for those injectors. That's the only way we have to account for fueling changes right now. (spoof the MAFCAL low to force smaller injectors pulsewidths for upgraded injectors that flow more, spoof the MAFCAL high to force larger pulsewidths to account for E85....)
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 09-28-2011, 11:02 AM   #217
Groans: 56
Zigatapatalka
The InjDC numbers may be off, but when VD consistently shows my HP start to level off as the DC passes 100% I have to think that the DC is the cause.. It may not be a lack of fuel, but fuel injected too late. All the soot we get is a good indication of incomplete combustion..
I don't know that I agree about the spark blowout issue, I've logged some very high maf g/s numbers and never had blowout issues... Maybe the oem fuel spray pattern is wetting the injectors(and my injectors somehow don't have the same issue), or it could be my lower compression... There are way too many variables to say hitting the fueling limit is causing the blowout.
I really don't know about the MAF cal, I made my adjustments to fix the fuel trims and match my WOT targets, but I haven't seen enough big maf sensor cals to say if mine is skewed any.. IIRC on my cal the 3.25" housing tops out somewhere around 600~650g/s, but I need to rescale it since I installed the MAF straightener.
 Old 09-28-2011, 11:20 AM   #218
Realgib3's Avatar
Posts: 2,443   (View Stats)
Groans: 52
Zigatapatalka
Yeah I've recently found that load plays a huge role in fueling still. I'm actually having a major issue with it right now and I'm completely lost as to why it's happening, but I'm gonna have to run "load cap' like scaling to get it to run right until I figure it out.
Problem: Fuel pressure drops and I go rich at high load. I originally thought this was due to a dying set of pump internals, but it's not. How do I know? I ran 4 MAF's in my car last week trying to find one that worked for me to dyno on.
My stock MAF= FP problem, hitting 2.3x load
Toyato Ech MAF= FP Problem even worse with MAF scaled down a tone, hitting 2.6-2.8x load
Subaru MAF= NO FP Problem with MAF scaled UP 18-20% and hitting only 1.8-2.0 load
Used MS3 MAF= FP Problem, hitting 2.3-2.5x load again...
I'm totally baffled by this, so I'm either throwing the Suby sensor back in, or scaling all my tables to run this sensor, but show lower load.
I'm boost tuning and there aren't any load cuts/targets I could be hitting in the map that are doing this either form what I can tell.
Also... If you didn't catch it... shouldn't I be showing MORE load if the MAF is scaled way UP? and LESS load if it's scaled way DOWN? Cuz I'm seeing exactly the opposite now...
Ugh, my brain is fried right now. HELP!
My 3.25 cal on Mazda sensors are in the 620 range, so yours sounds about right.
My Toyota sensor was all the way down to like 500 and my Suby cal is at 725 peak g/s
Realgib3 is offline
 Old 09-28-2011, 12:29 PM   #219
Groans: 56
The MAFv and IATv are used in the load calculations.. If the IAT is significantly different the load calculated will be different as well..
 Old 09-28-2011, 01:10 PM   #220
Realgib3's Avatar
Groans: 52
Just got a pm back from jacksonms3. I had told him it looked like he may be having some of the same issues I was because of what his logs looked like, but I originally thought hismaf was scaled way up for some reason, but it's not. His maf cal peaks out in the 400snew g/s and he's seeing crazy high loads. Like 2.8-3.0 load...
Am i missing something here or is this strange?
Since when does bringing the MAF cal down make load read way higher? In the load cap days... we scaled it way down to make load read lower... when did this change?
Realgib3 is offline
 Old 09-28-2011, 01:32 PM   #221
this is news to me but I don't have much experience with the larger 30 series and larger turbo cars.
so when you neg scale do your g/s get lower and load still goes up?
also make sure all your TRLS ABS targets are above the cobb 2.5 load range...not sure how that would effect fueling but get them out of the way anyway.
Dano is offline
 Old 09-28-2011, 06:56 PM   #222
Groans: 56
I have no idea how the maf cal correlates with the load, but for me at least 400-450 g/s is 2.5-2.8 load..
 Old 09-28-2011, 07:09 PM   #223
Ziggo's Avatar
I am not saying that its not an issue, I have been harping about the fueling limitations ever since DJ did his investigation a long way back. Even if its inaccurate, fueling towards the spark is a problem like you said you don't get that full power out of the extra flow at that point. I am just saying that based on what I have seen, we hit the HARD limit for fueling when we get spark blowout, not by running lean. It may not be optimal, but you can still gain power by pushing the IDC beyond 100% and making soot. Late shitty combustion of fuel injected late is still better better than less fuel/air.
MAF correlates to load directly thru RPM.
LOAD*(some constant)*RPM = MAF
RPM being constant, a higher MAF value will result in higher load.
Ask Me About My:
Ziggo is offline
 Old 09-28-2011, 09:00 PM   #224
Groans: 56
At least in my case there seems to be no power to be had much past 115%, and EGT's start getting out of hand.
We don't know how the ECM is actually using the MAF value in the load equation, is it directly off the voltage, or the maf g/s, or the % of the max mafV or MAF g/s.
The calculated load is actually derived from the MAF, IAT, RPM, and BARO--which is why I stated that using a different manufacturers MAF with different scaling on the IAT could throw off the load calculation.
 Old 09-28-2011, 09:04 PM   #225
Eth Fiend
phate's Avatar
But, we don't know how the ECM is actually using the MAF value in the load equation, is it directly off the voltage, or the maf g/s, or the % of the max mafV or MAF g/s.
It is g/s. This is the only way it could work, really. My E85 scaling wouldn't work if the MAF V:g/s conversion didn't happen.
Actually, if you think about it, if it wasn't g/s we couldn't do MAF cal's, run larger diameter intakes, run different fuels at different stoich ratios, etc. g/s has to be the driver.
-06 MS6
phate is offline
 Old 09-28-2011, 09:19 PM   #226
Ziggo's Avatar
Different MAF sensors will certainly screw with things, and i wouldn't expect other manufacturer sensors to be plug and play, but the beauty of hot wire MAF sensors is that you get density for free. MAF voltage is directly proportional to the mass of air flowing past it, its not measuring speed that then has to be corrected for density of the air. That proportion is what we calibrate.
Zigatapatalka
Ask Me About My:
Ziggo is offline
 Old 09-28-2011, 09:20 PM   #227
Realgib3's Avatar
Groans: 52
scaling with my new mazda maf actually worked as it should, not like I experienced with other mafs. So. Neg scaling gave me less calc load and visa versa.
Iats seemed dead on with the other sensors tgough too so I think its something else in the equation causing these oddities.
Realgib3 is offline
 Old 11-18-2011, 11:43 AM   #228
Grab21's Avatar
Posts: 58   (View Stats)
Grab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud ofGrab21 has much to be proud of
Any updates from cobb?
2006 speed6 ... bnr s4 soon- on order... when danger to manifold explodes... 8 port
335i day driver
LSA supercharged Caddy CTS-V stealth gray-sold
Porsche Panamera turbo- sold
Bmw m3-sold
Z4m- sold
Grab21 is offline
 Old 11-18-2011, 12:23 PM   #229
708
Erich's Avatar
Nope, their ATR release yesterday looks like it added some FP monitoring, but nothing to scale the FP Sensor (in fact it looks like they removed the tables to do that on the GenPu)
Erich is offline
 Old 11-18-2011, 12:29 PM   #230
Alpha's Avatar
Posts: 3,711   (View Stats)
Groans: 24
I heard they cut it until they could release the total FP Sensor scaling ability.
Alpha is offline
 Old 11-18-2011, 04:05 PM   #231
^^^^ this is correct
 Old 11-18-2011, 08:36 PM   #232
Speeeeeed
06Speed6's Avatar
Anthony were you the one who bought the sensor upgrade? Steve at versatune was wanting to get his hands on one to help him decipher and test the code.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 11-18-2011, 08:55 PM   #233
if im not mistaken kmac did as well. does he want to purchase/borrow it from me? send me a PM/email if so.
 Old 11-19-2011, 03:39 AM   #234
Speeeeeed
06Speed6's Avatar
0265005303 is that the bosch part number that you have?
Nm I read back in the thread.
2006 Mazdaspeed 6
06Speed6 is offline
 Old 09-19-2012, 01:53 PM   #235
708
Erich's Avatar
Discuss here:
Fuel Rail High Pressure Sensor Upgrade
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
HTML code is On
Fuel Rail High Pressure Sensor Upgrade JumpingJackson MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 234 10-25-2014 01:54 AM
Possible Fuel Rail Pressure sensor failure? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 07-06-2012 04:17 PM
fuel rail pressure sensor Skup1993 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 02-05-2011 09:14 PM
where can i find a mazdaspeed 3 fuel rail pressure sensor? Skup1993 MazdaSpeed 6 - Engine, Transmission & Driveline 8 02-05-2011 08:29 PM
Page generated in 0.54633 seconds with 31 queries
