 Old 11-22-2011, 05:32 PM   #41
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
It comes out very easily with a jewelers screwdriver. I've pulled mine out before to inspect it.
It's not a normal toroidal O-ring. The edges are flattened, where the cross-section is square not circular.
well then i dont think ill have any orings like that around, but that doesnt mean you couldnt just put a slighter larger reg one and squeeze it in.
Also i dont think measuring the o ring would be that accurate, especially if we think oil is leaking by it. Oil will almost always swell the o ring or atleast deform it slightly.
All this talk makes me want to jump on the band wagon, although i would need to move back home, there is no close stations near memphis
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline
 Old 12-13-2011, 07:40 PM   #42
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
So what specifically do you guys use to clean the spill valve? I didn't see anything mentioned... I like brake cleaner, but I wouldn't use that by the o-ring part.
Also, is the seafoam in the tank only necessary over 50/50?
TIA
EDIT: You guys have 2 maps handy in case you're on a trip and can't plan E85 stations? I plan on have 93 the a mix map. Not sure of mix, maybe E30.
dougefresh_ is offline
 Old 12-13-2011, 07:48 PM   #43
Enki's Avatar
Posts: 7,539   (View Stats)
Groans: 189
Seafoam doesn't do a fucking thing. Trust me.
Use 91 pump gas and a toothbrush/lint free cloth to wipe the sticky off of everything and you'll be good.
Enki is offline
 Old 12-13-2011, 07:58 PM   #44
Eth Fiend
phate's Avatar
Posts: 6,931   (View Stats)
TIA
I use brake cleaner, but gas works, as well.
I have a 93 octane map, a 50/50 shitty map, an E70 (winter) map, and my E85 (summer) map
I picked up a can of seafoam last time I was in town. I'm going to get a gunk specimen and see what the seafoam does to it, directly.
-06 MS6
-Corn fed 07 MS3 - Sold
phate is offline
 Old 12-13-2011, 08:18 PM   #45
Cool, thanks. What's a 50/50 shitty map? lol Something like my current 93 shitty map?
 Old 12-14-2011, 01:56 AM   #46
jroc's Avatar
Posts: 1,482   (View Stats)
jroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the worldjroc is the leader of the world
Groaned at 6 Times in 6 Posts
kind of going along with the last sentence, when i had my engine apart, i had put a stock piston in a bowl of seaform and let it sit for a full day. SOME carbon deposits came off, not a whole lot/what i had hoped for.
JDMFresh.com 1990 Mazda Miata
NASA Time Trials/Time Attack, Global Time Attack
A miata may be gay, but its probably faster than your car around a track. That's pretty gay.
jroc is offline
 Old 12-14-2011, 07:03 AM   #47
I use gasoline and Qtips to clean my spill valve, and I keep a 93 Octane pump tune on my AP just in case I'm stuck in an area without an E85 pump.
silvapain is offline
 Old 04-08-2012, 10:33 PM   #48
lulz @Raider
burn813's Avatar
Posts: 3,171   (View Stats)
subbed... for reference... thank you @silvapain !!!!
2008 MS3 gt
470hp/463tq on GT35r at 29psi
HKS CBE/ Koni Yellows and H&R springs/ HTP Whale Penis Intake/ PTP Fuel internals/SteedSpeed Mani/CP-E SafeSeals/E85 Hypnotic Tuned
burn813 is offline
 Old 05-06-2012, 02:33 PM   #49
Vinnie's Avatar
Posts: 713   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
you're the best!
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline
 Old 09-19-2012, 02:03 PM   #50
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
HOW TO: Remove & Disassemble HPFP Spill Valve
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f633/how-remove-disassemble-hpfp-spill-valve-125098/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-07-2014 06:54 PM
HTML code is On
HOW TO: Remove & Disassemble HPFP Spill Valve silvapain MazdaSpeed 3/6 - E85 Fueling 139 04-09-2018 04:02 AM
Resolving HPFP corn woes (black death/sticking spill valve) Enki MazdaSpeed 3/6 - E85 Fueling 467 10-26-2014 03:50 AM
Spill valve spring mod Enki MazdaSpeed 3/6 - E85 Fueling 15 02-02-2014 11:01 AM
Symptom of spill valve? speed31982 MazdaSpeed 3/6 - ECU Computer Tuning 1 08-16-2012 06:12 PM
HOWTO: Spill Valve SST Enki MazdaSpeed 3/6 - E85 Fueling 9 02-17-2012 09:07 AM
Page generated in 0.50152 seconds with 28 queries
