 Old 09-16-2012, 09:06 AM   #401
aviator79's Avatar
Posts: 3,923   (View Stats)
Groans: 67
Originally Posted by mrQQ View Post
is there any way to make your own removal tool somehow? or any other way to remove them if you don't have the tool?
You dont need one. The flange on the injectors that seats on the outside of the head has flat spots on either side that you can use needle nose plyers on to twist the injector. Once you get it to move you should be able to spray some lube, carb cleaner or wd-40 anything should work, you should only need a little bit, and keep working it out by twisting it. Some say you can grab at the top of the injector, which you can, I just wouldn't as you do not want to damage any area where the orings sit as you will have a leak.
I have done it twice. On my ms6 I used a pry bar to pop them up and that was a bad idea but it worked. I nicked an injector, but luckaly not where the oring sits. On cx-7 I beleive I did it the way I stated above with no issues. I dont know Im always drunk when I work on the car so I never remember.
aviator79 is offline
 Old 09-19-2012, 01:49 PM   #402
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
http://www.mazdaspeedforums.org/foru...lution-119326/
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
HTML code is On
Injector seals solution. Version A paveltol MazdaSpeed 6 - Engine, Transmission & Driveline 756 05-23-2017 10:38 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Page generated in 0.25075 seconds with 22 queries
