Like Tree2Likes
 Old 08-09-2012, 01:47 PM   #41
Jerd2189's Avatar
Posts: 7   (View Stats)
Jerd2189 will become famous soon enough
Figured out lean code, diameter of intake tubing I used is larger than factory so there was unmonitored air. Currently I have switched to a K&N intake short ram instead and it has been running better even though power band seems less responsive than my original intake.
Jerd2189 is offline
 Old 08-30-2012, 09:05 AM   #42
Jasbo's Avatar
Posts: 364   (View Stats)
Jasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the worldJasbo is the leader of the world
Originally Posted by shawn19 View Post
Sorry if this a stupid question but would a walboro 255 be enough fuel pump for full bolt-on through stage 2?
I see what your saying.. If the CDFP is having trouble keeping up, then your thinking its because the supply is dwindling? Perhaps the answer to that isnt about the feed rate to the CDFP as much as it is the amount of fuel the CDFP is taking in per cycle. In this case you wouldnt fix the high pressure problem without upgraded internals.
Jasbo is offline
 Old 09-06-2012, 03:37 PM   #43
Triz187's Avatar
Posts: 2   (View Stats)
Triz187 is an unknown quantity at this point
Default Fuel Pump Failing!
Went to get Dyno'd at Cobb last week. Running stg 2 with Auto Tech internals. Tuner said my FP failed while tuning. He tuned for my intake before the pump gave out so he built me a baseline map and said for me to put the stock internals back in and to investigate the Autotech ones for scoring or defects. I went home took the pump appart and found the Autotech internals ok with No sign of scoring or damage. While I had the pump out I investigated the housing and found a four-digit number on the high pressure line out of the pump. After research I found that the number which was 7215 was the manufacturing date of that pump and there was a service bulletin online from mazda stating that any pump manufactured before march 2007 should be replaced. When opening the pump with the 18mm socket to reinstall the OEM internals the stainless steel cylinder where the piston comes through was loose enough that I didnt have to place the pump in a vice to unscrew the stainless steel cylinder.Went ahead and put the stock internals back in.This time I took my torque wrench and tightened the 18mm stainless steel cylinder to about 35lb/ft, to ensure it would unscrew. Now running that base map, I keep throwing P2187 over and over again. Does this mean I need to purchase a brand new pump. I do have they Autotech internals cleaned and ready to install again. Did my pump fail on the dyno becuase the stainless steel cylinder started to back it self out, or did it fail because it was a faulty pump assembly from the factory( new internals were installed) Knowledgable people please help as I dont want to have to spend 400$ on a brand new pump if I dont have too. I want me car to run good again so I can get it back on the dyno for a protune.
Triz187 is offline
 Old 09-16-2012, 09:37 PM   #44
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
Hey sorry if this has been covered but I searched and didn't find a definitive answer. I understand that ~400 is good for idle and ~1750+ is good for WOT. I'm good on both those counts. I was cruising on the highway today and noticed my FP dropped to 280 while using cruise control and coasting down a hill at about 75mph. Is this acceptable? I've got autotech internals.
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline
 Old 09-19-2012, 01:47 PM   #45
708
Erich's Avatar
Posts: 4,274   (View Stats)
Discuss here:
http://www.mazdaspeedforums.org/foru...thread-105248/
2 years after hitting 700hp and still running strong. Happy to see others joining the club.
Erich is offline
HTML code is On
THE OFFICIAL HPFP CDFP FUEL PUMP THREAD themytb MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 298 06-29-2018 06:29 AM
Page generated in 0.45201 seconds with 24 queries
