Other Platforms
Ford Focus Ecoboost 2.0 Discussion(ECOBOOSTFORUMS.ORG)
> Ford Focus ST Ecoboost - Turbo Induction
Like Tree14Likes
 Old 01-08-2015, 05:19 PM   #1
4cyl_LOL's Avatar
Posts: 13   (View Stats)
4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future4cyl_LOL has a brilliant future
Default GTX3076R Focus ST - PI-WMI Aquamist - Tuned by Nishan
Hey everyone
This build started as a modest modding money pit, which most of you know to be true on the MS3. My goal is 480whp on 100% methanol and E30. I dont have a bonestock baseline, however I do have a dyno from last month. I did 284.9whp on a DynoDynamics @ Engine Logics in Houston(Modded K03, FMIC, 3" straight TBE, CAI, Denso's, Tuned by Randy@Mountune, Dyno sheet below)
I would like to introduce The Not Fucking Around Build, to the list!
  • JDL Auto Design GTX3076R(Tial .63ar turbine housing) turbo kit
  • Tial MV-S currently with 1bar setup, dumped to atmo
  • Aquamist HFS4-v3, custom port injected with four .4mm check valve jets(140cc), currently spraying 100% water until we move to 100% methanol - Big thanks to Richard Lamb with all of his help ensuring all settings and wiring is correct He also is supporting our platform 100% over on FocusST.org.
  • OE intake
  • 3" Turboback to sideexit
  • Denso ITV24's
  • Spec Stage 2+ and Spec LWA Flywheel
  • Godspeed Type L DIY FMIC Upgrade
  • Kozmic Vented Catch Can
Aquamist setup
Side exit Straight Pipe
Last edited by 4cyl_LOL; 01-20-2015 at 09:04 PM. Reason: used thumbnails instead of full images
4cyl_LOL is offline   Reply With Quote
The Following 11 Users Say Thank You to 4cyl_LOL For This Useful Post:
Cheapspeed (01-27-2015), Code Monkey (01-08-2015), Easter Bunny (01-14-2015), Gr8Speed (03-19-2015), Hush (01-09-2015), impossible (01-26-2015), jseams (01-09-2015), msantana101 (01-20-2015), speed3 britz (01-09-2015), SPEED6 KILLAH (01-18-2015), Vansquish (01-16-2015)
 Old 01-08-2015, 05:25 PM   #2
4cyl_LOL's Avatar
Does this forum not resize images LOL
anyways
https://www.youtube.com/watch?v=ASxRQRRqy10
https://www.youtube.com/watch?v=m-I5l7rSKMw
https://www.youtube.com/watch?v=KEBXkODVYso
Link to build thread
http://www.focusst.org/forum/focus-s...tml#post453177
The Following User Says Thank You to 4cyl_LOL For This Useful Post:
jseams (01-09-2015)
 Old 01-08-2015, 05:56 PM   #3
dale_gribble's Avatar
Posts: 4,720   (View Stats)
FML... First world problems. Really want to see pics, but pics are too big.
MINI H1 6.0 - CAR LED TAILS
Easter Bunny (03-19-2015)
 Old 01-08-2015, 06:24 PM   #4
4cyl_LOL's Avatar
ctrl + minus key
command + minus key.
i will have to resize the damn pictures....or post thumbnails.
Fixed!
UnknownSuperhero (01-09-2015)
 Old 01-09-2015, 12:49 PM   #5
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Really looking forward to the outcome Ryan!
4cyl_LOL likes this.
www.tunedbynishan.com
 Old 01-09-2015, 12:59 PM   #6
Silverdecepticon's Avatar
Posts: 277   (View Stats)
Silverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond reputeSilverdecepticon has a reputation beyond repute
Wicked. Good job, but they're all money pits....
06 MS6
GTX3076R, Xs power exhaust manifold(suxs), ebay dp(sux), 3" catless exhaust, 4" HTP TIP, Sure shortshift & counterbalance, COBB V3, Autotech HPFP internals, Grimmspeed EBCS, CP-e RMM, Perm PCV plate, JBR EGR delete, JBR BSD, JBR Oil pan baffle plate, Kozmic OCC, rebuilt fuel injectors, safeseal injector seals, Bosch 3 bar MAP, new gaskets(valve cover, throttle body, intake manifold, exhaust manifold, dp), cleaned valves and chambers, CP-E motor mount & rear-diff mount, ATP-INT-003 FMIC, Stratified Guardian Angel set to 24psi, Stoptech rotors, Hawk HPS pads, Forge BPV, home-made strut mounted tower bar, badgeless, special edition 19" anniversary rims. Battery finally relocated to trunk with custom box. New VVT stuff, BC coilovers, new OEM Clutch, fidenza lightweight flywheel, replaced driveshaft again, replaced power steering pump again, busted rear diff side bolts again....FML
Silverdecepticon is offline   Reply With Quote
 Old 01-09-2015, 01:00 PM   #7
ASHMS3's Avatar
Posts: 1,358   (View Stats)
ASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the worldASHMS3 is the leader of the world
Groans: 126
Will stock focus internals hold that kind of power? Either way good luck with the build, sounds like fun.
Using bad grammar from my cell phone.
'09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE
ASHMS3 is offline   Reply With Quote
 Old 01-09-2015, 01:13 PM   #8
jseams's Avatar
Posts: 1,413   (View Stats)
@4cyl_LOL; see you made it over....
LOL MS3 and 4cyl_LOL like this.
MNBlue 2012 S4 Prestige... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
 Old 01-09-2015, 06:57 PM   #9
4cyl_LOL's Avatar
Don't know. I am the only person to document a build that will push the limit of the stock block and stock head.
we have found that the head flows less than the intake manifold, a PI supplemental solution is the best way to make big power, and that e30 is about the max ethanol blend that will work on our car.
Pistons that are failing are doing so because of excessive heat and upon inspection the injectors are cleaner in the failed clyinders than the good ones.
I stand firm on using a methanol/water mixture to keep the engine alive. Currently 100% water injection is what I am using until @ms3blackmica wants to switch over for the big power.
The Following 2 Users Say Thank You to 4cyl_LOL For This Useful Post:
ASHMS3 (01-12-2015), chaser27 (01-21-2015)
 Old 01-09-2015, 10:05 PM   #10
4cyl_LOL's Avatar
I heard corn is good for the soul
jseams likes this.
 Old 01-14-2015, 04:22 AM   #11
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Awesome! Really looking forward to seeing the results. I would think the EB could hold as much power as our cars, stock for stock, but who knows.
2007 Mazdaspeed3 GT
 Old 01-16-2015, 11:15 AM   #12
Nishan
Here is a link back to Ryan's build thread on focusst.org
JDL Auto Design GTX3076R powered ST - The kit is real!!!! Fueling details coming soon
 Old 01-17-2015, 09:57 AM   #13
dterry5's Avatar
Posts: 40   (View Stats)
dterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond reputedterry5 has a reputation beyond repute
Welcome to the dark side can't wait
-2013 Ford ST
GTX2867r, Freek'd
dterry5 is offline   Reply With Quote
 Old 01-20-2015, 04:00 PM   #14
4cyl_LOL's Avatar
I get all warm and fuzzy here....i mean that from the bottom of my cock
jseams likes this.
dterry5 (01-20-2015)
 Old 01-20-2015, 04:29 PM   #15
dterry5's Avatar
You know...I'm kicking myself in the penis not going with a 3076 now. Oh well, guess it will be easier the second go around. #fucksavingmoney
-2013 Ford ST
GTX2867r, Freek'd
 Old 01-20-2015, 05:00 PM   #16
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,162   (View Stats)
Groans: 793
Is @kmac; still making the most power?
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 01-20-2015, 07:52 PM   #17
4cyl_LOL's Avatar
who?
never heard of him lol. I have never seen a baseline or final numbers dynosheet. Also his car has been silent for so long there is no telling what has been done to it or if he even still has it. Not to mention some of his mods were done for no reason, i.e. the intake manifold "upgrade" wont hep unless you mod the head. In which case he no longer is stock block/head, which is what I am after.
 Old 01-20-2015, 08:36 PM   #18
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
fivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the world
Isn't that a small turbine housing AR for the gtx3076? Guess it'll spool well and should still be enough for the power levels you are aiming for I'd think. I'm just used to .82 AR I guess. I just picked up a .82 tial turbine housing for the hta3076 I'm trying to throw into my car.
Awesome build! Glad to see people being bold and pushing boundaries
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA
DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan
Old: BNR S3 370/380 VD 91 + Meth
BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforums.org/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/
fivefingerdeathpunch is offline   Reply With Quote
 Old 01-20-2015, 08:56 PM   #19
4cyl_LOL's Avatar
it is small but im in the 72% eff island with this housing. if I were shooting for 650whp I would have gone .82 like you.
Based on my logging I enjoy full spool at a consistent 4033rpms. Nishan believes we can improve that a bit, if so I would love to see full spool around 3700 instead!
 Old 01-20-2015, 11:39 PM   #20
Tokay444's Avatar
Groans: 793
Originally Posted by 4cyl_LOL View Post
who?
How are you deducing an intake manifold, "won't hep unless you mod the head"?
Demodded.
The Seals
 Old 01-21-2015, 04:37 AM   #21
4cyl_LOL's Avatar
Speed Perf6rmanc3 flow tested the Turbo Tech Intake Manifold, OE manifold, and OE head. Given their expertise on the MZR L3 and the level of respect they command here on MSF, I trust that their testing is valid and honest.
The OE manifold out flowed the head, however it has no runners. Using an intake spacer adds short runners and has shown to shift the torque curve slightly but more importantly allows for a PI system of your choice.
a member(Ocysp) over on FocusST.org dyno'd his car with tuning and without showing before and after using an after market intake manifold. there was literally no gain that could be quantified. The manifold he used was the TTR which has a 6.0L plenum.
Also the only two intake manifolds available weigh more than the OE. Turbo Tech Racing(which I have owned) and the Breedt CNC'd. Both companies did NO research prior to making these manifolds(such as dyno or flow testing, they relied on members to provide that data). The Manifold that kmac supposedly tested was the Breedt but Breedt never released the results, for unknown reasons. They also dodge questions regard performance. The biggest elephant in the room is the weight of the Breedt, a whooping 25lbs+. I flew to Seattle on business and dropped by their shop to see and help test(which never happened after talking to Speed Perf6rmanc3) the manifold and I was shocked at the weight of the multi-piece unit. It is very nice but but for me engine bay eye candy is low on the list.
LOL MS3 likes this.
The Following 6 Users Say Thank You to 4cyl_LOL For This Useful Post:
chaser27 (01-21-2015), HawkeyeGeoff (01-21-2015), impossible (01-26-2015), jseams (01-26-2015), LOL MS3 (06-19-2015), Vader (01-21-2015)
 Old 01-26-2015, 10:30 PM   #22
impossible's Avatar
Posts: 732   (View Stats)
Groans: 30
I'll never forget seeing your ST at TeaWorks, I'm sure it was still K03 back in 2013. What kinda power do you think the stock motor will be good for? Nice build regardless!
2009 Mazdaspeed 3 w/ Manley bottom end, keyed and lightened crank, CNC ported head, 2018 JMF v2 port injection fueled, CM twin disk clutch and Precision 6466 turbo, Kozmic built gen2 transmission with final drive swap. Tuning by PD Tuning
 Old 01-26-2015, 11:36 PM   #23
4cyl_LOL's Avatar
No Idea. With @ms3blackmica's expertise and my well thought out build we may see numbers as high as 490whp but that will only be for the sake of setting a record. TBH no knows what the stock block will handle since I will be the first to push it this far
We will dial it back to 450whp and leave it there
 Old 02-19-2015, 10:00 PM   #24
4cyl_LOL's Avatar
Welp motor is toast at 390
SP63 is gonna fap some magic into a new build.
I'll have more on that soon enough
ASHMS3 (02-20-2015), maisonvi (02-22-2015)
 Old 02-19-2015, 11:13 PM   #25
GrumpyMPS's Avatar
Posts: 51   (View Stats)
GrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud ofGrumpyMPS has much to be proud of
What failed?
2012 VR MPS
BNR S3 and E30 fully bolted. Next up CP-E stage 2 pistons, Manley rods, few other bits and bops, extra fuel, GTX3076R to get it to 500whp............
GrumpyMPS is offline   Reply With Quote
The Following User Says Thank You to GrumpyMPS For This Useful Post:
MD1032 (02-21-2015)
 Old 02-21-2015, 09:46 AM   #26
MD1032's Avatar
Groans: 143
Originally Posted by GrumpyMPS View Post
What failed?
I believe this is the thread. In this post he reports low compression in Cyl#4.
JDL Auto Design GTX3076R Kit - Motor and Fueling By Speed Perf6rmanc3 - 550whp+???? - Page 54
I was discussing in shout with others, the thing I don't understand is how you turn a car over to a dealership with a tune on it that can damage the engine. I have a feeling some critical details are not documented in that thread.
hemicouple likes this.
2007 Mazdaspeed3 GT
The Following User Says Thank You to MD1032 For This Useful Post:
GrumpyMPS (02-21-2015)
 Old 03-19-2015, 09:53 AM   #27
HawkeyeGeoff's Avatar
Posts: 3,036   (View Stats)
HawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the worldHawkeyeGeoff is the leader of the world
Hm. Seems like the ST may have the same issue as the Speed has with the intake manifold; IE cylinder 4 is the boom cylinder due to the flow characteristics of the intake mani (Cylinder 4 gets the worst combustion because of this). I think our OEM Manis vary airflow up to ~23% from cylinder to cylinder.
Silver 2007 Speed3 GT
Xona Rotor 6156, Port Injection w/ E85...Bunch of other stuff. I make some power.
Titanium Grey Mazdaspeed6 GTX3071, DD
HawkeyeGeoff is offline   Reply With Quote
 Old 03-19-2015, 11:22 AM   #28
4cyl_LOL's Avatar
Your feelings don't matter, nothing is hidden. Through my own fault I disabled the Aquamist system and rather than flash the ECU to a e30 only tune I changed slots to a zero WG and low spark/fuel slot.
You don't understand how I could hand my car over? I will make it easy for you to understand:
1. Tranny first gear synchro took a shit
2. Knew it wasn't an issue that I contributed to
3. Initiated a Ford Customer Care case through my forum's resident Ford Rep
4. Met with both the Service Manager and Trans tech
5. Had the transmission swapped under warranty.
The minute the engine went under boost and heat was generated the lack of methanol present allowed heat to build up.
Speed Perf6rmanc3 is sponsoring my engine and I couldn't be happier that I inadvertently cracked a piston.
Unlike a lot of members both here and on focusst.org I will admit to my fault and not pursue a free engine.
The Following 4 Users Say Thank You to 4cyl_LOL For This Useful Post:
802MS3 (03-19-2015), Gr8Speed (03-19-2015), HawkeyeGeoff (03-19-2015), SarcasticOne (03-19-2015)
 Old 03-21-2015, 09:45 AM   #29
Tokay444's Avatar
Groans: 793
That goes against everything the fanbois are saying about how awesome the ford mani is and that no one needs to go aftermarket...
Demodded.
The Seals
Justin@Freektune (03-21-2015)
 Old 03-21-2015, 10:54 AM   #30
Tokay444's Avatar
Groans: 793
Suddenly @kmac; running a mani doesn't sound so dumb...
Demodded.
The Seals
The Following 4 Users Say Thank You to Tokay444 For This Useful Post:
Easter Bunny (03-21-2015), HawkeyeGeoff (03-22-2015), Justin@Freektune (03-21-2015), kmac (04-10-2015)
 Old 03-21-2015, 11:53 AM   #31
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Gr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the world
Groaned at 123 Times in 84 Posts
You did read the thread and cause of the motor popping didn't you...? What do you think would happen to any engine running a perfectly flow balanced mani and way too much timing at redline on pump gas?
https://www.youtube.com/user/JustinBieberVEVO
Gr8Speed is offline   Reply With Quote
The Following 3 Users Say NO Thank You to Gr8Speed For This Un-useful Post:
Easter Bunny (03-21-2015), mize13 (03-23-2015), Tokay444 (03-21-2015)
 Old 03-21-2015, 05:11 PM   #32
Tokay444's Avatar
Groans: 793
Who the fuck let you back in here?
Demodded.
The Seals
kmac (04-10-2015)
 Old 03-22-2015, 01:59 PM   #33
I think SPE3DPerformance did a flow test and showed it was good in all the characteristics....but there's definitely still some kind of problem with either fuel or air obviously. Whatever. There are a TON of Ford Ford Booms going on.
 Old 03-22-2015, 04:33 PM   #34
Tokay444's Avatar
Groans: 793
Did they flow test it on a head?
Demodded.
The Seals
Easter Bunny (03-22-2015)
 Old 03-22-2015, 04:47 PM   #35
Posts: 12,651   (View Stats)
Cyl 4 runs the hottest and is most knock prone, second to that, cylinder 2. You have to take things with a grain of salt - a good number of these booms are abuse related and many of them are heat and detonation related.
Keep that at bay and the motor is quite reliable just like any turbo motor.
The speeds have their LSPI failures especially with the gen1/ms6 and funny enough a lot of the research with LSPI has come out after 2010 which is well after the speed3 motor was designed even in the gen2.
Gr8Speed (03-22-2015), HawkeyeGeoff (03-22-2015), kmac (04-10-2015)
 Old 03-22-2015, 04:54 PM   #36
This is very true. Do they have a root cause for the cylinders running hotter?
I could imagine you will get more abuse cases with a higher volume vehicle regardless.
 Old 03-22-2015, 05:24 PM   #37
I really am not sure. Obviously there is some fundamental problem with air/fuel when one cylinder runs hotter than the other so regardless there is some issue that hasn't been resolved/ brought to attention of the enthusiasts yet.
The Following 2 Users Say Thank You to HawkeyeGeoff For This Useful Post:
Easter Bunny (03-22-2015), Tokay444 (03-22-2015)
 Old 03-22-2015, 09:06 PM   #38
A lot of people jump to air/fuel as the culprit but there can be more to it especially relating to the cooling circuit. Cyl 4 is the furthest from the water pump.
On v8 engines the rear cylinders often were the first to let go due to not being cooled enough by the cooling system.
Gr8Speed (03-22-2015), HawkeyeGeoff (03-23-2015)
 Old 03-22-2015, 09:49 PM   #39
Gr8Speed's Avatar
Just like 6 being the most knock prown on the 335s (from what I've seen).
 Old 03-23-2015, 07:20 AM   #40
Hm. Well that's a little bit more of an issue. There's not too much you can do with that other than run a bigger radiator, add some water wetter, or run a higher H20/antifreeze mix. If that's the case, I'd expect this to continue until Ford decides to redesign the cooling system in the block or changes the pistons.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f651/gtx3076r-focus-st-pi-wmi-aquamist-tuned-182547/
JDL Auto Design GTX3076R powered ST - The kit is real!!!! Fueling details coming soon - Page 45 This thread Refback 01-12-2015 04:48 PM
HTML code is On
MS3 GTX3076r EWG JCMS07 MazdaSpeed 3/6 - Big Turbo Builds 32 10-09-2016 08:21 PM
GTX3076r tuned by Justin msantana101 FREEKTUNE 16 02-17-2016 04:55 PM
Detroit: Shelby unveils tuned Ford Focus ST, widebody GT500 Super Snake Haltech Automotive News 0 01-15-2013 12:20 PM
Page generated in 0.63310 seconds with 34 queries
