Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Notices
Like Tree97Likes
 Old 06-09-2012, 12:52 PM   #1
Posts: 5,613   (View Stats)
Groans: 121
Default Beans Above the Frank Build
Most people would go big turbo on stock block. I'm going forged block under stock turbo.
My plan is to go higher compression to compliment E85; 10.5 or 11.0:1. I will be using the stock valvetrain, with only very minor combustion chamber work and no port work. I plan on going PI, and I want to keep the intake ports rough to help atomization.
Right now I'm looking for info on a windage tray. PTP sells one, but I don't care for its design. I remember seeing another design out there, but I can't for the life of me find it anywhere now.
I'll be adding a parts & prices list and photos as they come.
The Following 27 Users Say Thank You to silvapain For This Useful Post:
86azms3 (06-09-2012), ABSpeed3 (06-09-2012), AZSPEED3 (08-08-2012), Boosten Ya(josh) (08-08-2012), Boost_creep (06-09-2012), btstarcher (08-25-2012), Dash08 (06-09-2012), Easter Bunny (06-11-2012), EdgeAutosport.com (08-07-2012), ESB Jiu JItsu (08-07-2012), gearhead750 (08-08-2012), h.h.sk1nny (06-09-2012), helmetface (06-11-2012), J-Liss (08-26-2012), Jay@posifab.com (08-08-2012), josurr (08-13-2012), lilred (06-11-2012), Micha (02-20-2013), Ms3_Miami (11-07-2012), phate (10-17-2012), psychophyr (08-07-2012), snailD (08-07-2012), Speed3eak (09-23-2012), tddvrrn (06-09-2012), Tomas (10-24-2012), xI Leveler Ix (10-20-2012), Zimmo (11-20-2012)
 Old 06-09-2012, 12:58 PM   #2
JLee1469's Avatar
Posts: 1,169   (View Stats)
JLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the worldJLee1469 is the leader of the world
Is the k04 at least going to be upgraded? Subbed for progress.
JLee1469 is offline   Reply With Quote
 Old 06-09-2012, 01:00 PM   #3
CJM
CJM's Avatar
Posts: 175   (View Stats)
CJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the worldCJM is the leader of the world
Groaned at 5 Times in 2 Posts
Good luck dude! Sounds like a very interesting build.
Four Wheels:
2010 LSM Mazdaspeed 3 + Tech Package
-Cobb AP, K&N SRI, SURE Motorsports TIH, Forge BPV V1, AutoTechs, NATOR'd TP,
JBR 88 Duro RMM
-CJTuned - VD Numbers: 309whp/358wtq @22 psi tapering to 17psi (CF = 1.01, Smoothing 3)
-Tune with corn in progress!
-Personal 1/8 mile best: 8.515@82.76 mph; 2.087 60' on Eagle GT's. Plan on cracking 7's soon.
Two Wheels:
2009 Husqvarna WR300 - 2 Stroke Power!
-Bone Stock, already way too fast
GT3071 waiting to be rebuilt and installed
CJM is offline   Reply With Quote
 Old 06-09-2012, 05:55 PM   #4
Amnesiac's Avatar
Posts: 85   (View Stats)
Amnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond reputeAmnesiac has a reputation beyond repute
F2 used to make a windage tray. I think they aren't around anymore and are now GP Werks? You might check there
Amnesiac is offline   Reply With Quote
The Following 2 Users Say Thank You to Amnesiac For This Useful Post:
Coaststarlight (03-27-2013), silvapain (06-10-2012)
 Old 06-09-2012, 06:17 PM   #5
h.h.sk1nny's Avatar
Posts: 968   (View Stats)
h.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the worldh.h.sk1nny is the leader of the world
You aren't gonna get any better atomization of fuel with rough runners; it's direct injection
- Stock OEM k04 - Cobb AP - 3" ATP MAF w/9" Amsoil Filter - Grimmspeed EBCS - cryo'd Act 6 Puck w/Streetlite FW - HTP 3" Inlet - Bosch 3 Bar w/PNP Harness - Forge BPV V1 - CP-E 3" Single SS Exhaust - M2 Dp - Custom FMIC - PTP BSD - EGR Delete - Sonic Tuning S3 CO's - Enkei PF01 - 235/45/17 Toyo T1 Sport - Sure Dreadnaught - Sure Torq - AWR Pass. MM - PTP RV - KMD Internals - 50/50 e85 - Sure Countershift - Blox 490 LE - PNP'd IM/Head - VG Sharkfin Antenna - Car_Led Tails - Speedline CF Grill -
12.301 @ 113.20, stock turbo, stock ex. manifold, stock clutch
Awaiting: The first 11 sec STOCK k04 powered Mazdaspeed!!!!
h.h.sk1nny is offline   Reply With Quote
The Following User Says NO Thank You to h.h.sk1nny For This Un-useful Post:
Mizzle (08-08-2012)
 Old 06-09-2012, 06:30 PM   #6
Groans: 121
THAT WAS IT!! Thanks, that's been driving me nuts.
DSIT995 (02-11-2013)
 Old 06-09-2012, 06:30 PM   #7
Groans: 121
I said PI = Port Injection. Supplementary to the DI system.
Easter Bunny (06-11-2012), Mizzle (08-08-2012), tddvrrn (06-09-2012)
 Old 06-09-2012, 06:41 PM   #8
86azms3's Avatar
Posts: 2,992   (View Stats)
86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world86azms3 is the leader of the world
Groans: 239
Groaned at 70 Times in 36 Posts
ug...k04...lame. At least upgrade to a s2, s3, or gt28xx. But if you stay with the measly flowing k04, definately at least go 11:1
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP,
Turbosmart Hybrid bpv, SURE TIG's + coolant bypass,
ITV24's, CP-E 75d RMM, Medefail Tranny mount,
DDM 35W 6000K HID's, SURE Counterweight,
18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's
390whp/400wtq
86azms3 is offline   Reply With Quote
 Old 06-09-2012, 06:46 PM   #9
Groans: 121
I have no desire to spend money on any of those turbos. I want an EFR 7163, and I'm not wasting money on any other turbo until that EFR comes out.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
Alpha (10-19-2012), Black Metal (08-07-2012), Code Monkey (07-09-2012), Enki (09-30-2012), h.h.sk1nny (06-09-2012), helmetface (06-11-2012), lilred (06-11-2012), Micha (02-20-2013), tddvrrn (06-09-2012)
 Old 06-09-2012, 06:48 PM   #10
h.h.sk1nny's Avatar
touche' lol, get that bizzatch runnin again
As serious as his beard!!!!!! Badass
Last edited by h.h.sk1nny; 06-09-2012 at 06:48 PM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to h.h.sk1nny For This Useful Post:
Alpha (10-19-2012), silvapain (06-09-2012)
 Old 06-09-2012, 06:58 PM   #11
86azms3's Avatar
Groans: 239
Guess I'm just not thinking high doller enough for you baller!
2009 Mazdaspeed 3:
390whp/400wtq
The Following 2 Users Say Thank You to 86azms3 For This Useful Post:
silvapain (06-10-2012), tddvrrn (06-09-2012)
 Old 06-10-2012, 10:03 AM   #12
Groans: 121
Been crunching numbers on a BorgWarner Turbo MatchBot, and the EFR 7670 is looking good to me...
BorgWarner MatchBot
I know Geoff at Full-Race says the bigger B2 frame turbos won't fit in the 3, but I'm not sure exactly why. If you line up the exhaust flanges on the EFR 7670 with the GTX 3076, it looks like there should be enough room for the downpipe; the battery would just have to be removed for added space for the compressor wheel.
Boosten Ya(josh) (08-08-2012), phate (10-17-2012)
 Old 06-11-2012, 08:12 AM   #13
Groans: 121
Emailed both Darrell and Jennifer at DCR and got no response about an upgraded VVT actuator.
Fucking vendors that don't want to sell their products...
MSFer87 (09-30-2012)
 Old 06-11-2012, 08:21 AM   #14
MAZ
MAZ's Avatar
Posts: 1,088   (View Stats)
MAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the worldMAZ is the leader of the world
interesting......sub'd
What does matter is: length times diameter, plus weight over girth, divided by angle of the tip squared.
"Feel how hot I am through my pants." (Singleflusher, MNM 2013)
MAZ is offline   Reply With Quote
 Old 07-09-2012, 05:33 PM   #15
Groans: 121
My ACT clutch after just 3,000 miles. I'm contacting ACT tomorrow about the amount of wear I'm seeing on the flywheel.
 Old 07-09-2012, 05:36 PM   #16
Groans: 121
My custom 10.5:1 pistons from Positive Fabrications.
GONNA BE BEAST!
The Following 13 Users Say Thank You to silvapain For This Useful Post:
86azms3 (07-11-2012), atvfreek (10-04-2012), AZSPEED3 (07-09-2012), J-Liss (08-26-2012), Jay@posifab.com (08-08-2012), josurr (08-13-2012), jracer (07-09-2012), kritz (09-23-2012), Micha (02-20-2013), Monotonous ONE (07-09-2012), Nliiitend1 (07-09-2012), phate (10-17-2012), uncorked11 (08-07-2012)
 Old 07-09-2012, 05:36 PM   #17
Able
helmetface's Avatar
Posts: 4,421   (View Stats)
Groans: 124
WOW beardman...I'm guessing that's the streetlite?
Suckkkz
*edit* saw sig
SUCCCCCKZZZ
 Old 07-09-2012, 05:38 PM   #18
Groans: 121
Suckkkz
*edit* saw sig
SUCCCCCKZZZ
Yep, it's the steel Streetlite. Funny thing is the pressure plate looks fine.
It's really hard to capture in a picture, but I can feel the wear easily with my finger, and it gets more worn the further from the center you go.
 Old 07-09-2012, 05:53 PM   #19
Able
helmetface's Avatar
Groans: 124
The grooves in the first image, towards the center were where my eyes focused.
But for anyone to pull their flywheel after that many miles and to have any response other than, "oh cool" ..especially for the money..is well..you know.
Sickspeed3 likes this.
 Old 07-09-2012, 06:14 PM   #20
Posts: 10,142   (View Stats)
Groans: 98
have you measured the runout on that thing? doesent look abnormal to me.........
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
silvapain (07-09-2012)
 Old 07-09-2012, 06:18 PM   #21
Groans: 121
I don't have a dial indicator to measure face runout. I'll have to see if I can find somebody that has one to borrow.
 Old 07-09-2012, 06:40 PM   #22
Boost_creep's Avatar
Posts: 587   (View Stats)
Boost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the worldBoost_creep is the leader of the world
I found the same exact thing when pulling out my street kit, with only 7k on it. I was very dissapointed to say the least. I posted pics in my thread here:
http://www.mazdaspeedforums.org/foru...77/index2.html
2009 True Red Mazdaspeed 3 GT - 326whp/360wtq
E30, Cobb AccessPort, Cobb SRI/TIH, Sure ID300 Maf
UR v2 Catted Downpipe/Resonated Testpipe, Racing Beat CBE
Corksport TMIC/Tubes, Grimmspeed Ported Throttle Body
KMD v2.1 FP Internals, PTP Seals/Studs, JBR TIG/EGR Delete
Turbosmart BPV, Denso ITV22, Bosch 3 Bar, Optima RedTop
Snow Performance Stage 2 WMI Kit, Sure Torq R3 RMM
SPEC Stage 2+ Clutch, Goodyear Eagle GT, EBC Red Stuff
H&R Coilovers, Corksport RSB
Boost_creep is offline   Reply With Quote
 Old 07-10-2012, 07:22 AM   #23
Groans: 121
I'm picking up a dial indicator today and I'll take some measurements.
Speaking of tools, I bought a Ford & Mazda timing tool set off eBay:
 Old 07-10-2012, 07:23 AM   #24
Groans: 121
Here's my current parts list & retail pricing.
The Following 21 Users Say Thank You to silvapain For This Useful Post:
86azms3 (07-11-2012), Amnesiac (07-10-2012), AZSPEED3 (08-08-2012), Code Monkey (07-10-2012), Dano (08-28-2012), Easter Bunny (07-14-2012), helmetface (09-29-2012), InFeXIoN (07-10-2012), J-Liss (08-26-2012), josurr (08-13-2012), jracer (07-16-2012), JTMS3 (09-05-2012), kritz (09-23-2012), maisonvi (07-10-2012), Monotonous ONE (07-10-2012), Ms3_Miami (11-07-2012), Nliiitend1 (07-10-2012), phate (10-17-2012), psychophyr (08-07-2012), uncorked11 (08-07-2012), xdm88 (08-08-2012)
 Old 07-10-2012, 08:02 AM   #25
maisonvi's Avatar
Posts: 1,223   (View Stats)
maisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the worldmaisonvi is the leader of the world
Groans: 39
I love spread sheets. Nice build and awesome organization.
GT3071R / HTP 3.5” / PG FMIC / M2 Catless DP / JBR BPV Hose / GFB 50-50 BOV / NKG LTR7IX-11 / Cobb AP / Koni Yellows / Cobb Springs / 3-Bar MAP / KDM Internals / Sure Track RMM
DIY Parts: 730g Shift Knob / Short Shift Plate / Rear Sway Bar / Adjustable End-links / 3-Port ECBS
Daily: Stockers w/215-45-18 Hankook V12
Track: TRmotorsport C3 w/245-45-17 Kuhmo XS
maisonvi is online now   Reply With Quote
 Old 07-10-2012, 08:08 AM   #26
Groans: 121
Thanks.
I'm actually thinking of starting to build these engines and have them available to NATOR members, in a Pay It Forward fashion. A parts list spreadsheet like this will really help me make sure I replace everything I need.
SoAgg159 likes this.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
BigjohnB20 (07-10-2012), Black Metal (08-07-2012), kritz (08-08-2012), MAZ (09-01-2012), SoAgg159 (09-28-2012), Speed_j23 (07-10-2012), uncorked11 (08-07-2012)
 Old 07-14-2012, 10:43 AM   #27
Groans: 121
This just arrived, courtesy of burn813:
 Old 07-14-2012, 01:16 PM   #28
Garage Queen
Sid3wayS's Avatar
Posts: 4,314   (View Stats)
Groans: 53
I would most definetly fork over top dollar for an engine built by the bearded one. Few people have more knowledge about this platform then you good sir. Slap a nator price tag on there an Ill buy 1.
2010 MS3 W/tech pkg Liquid Silver-Still Slower Then An Asthmatic Snail
Cobb:Ap,Sri,Tip//JBR:Egr,Rsb,IM/TB Tigs,Rmm,Tmm//ATP:Catless long DP
ETS:3.25" TMIC//M/D:OCC//Forge:v.2 BPV//AutoTech:FP Internals//PTP:Seals&studs
Bosch:3-Bar//Grimmspeed:3-port EBCS//Stratified:G.A.//KW:Coilovers//RotaGrids:18x9.5
Meth/E85/Nitrous TUNING BY LEX
Sid3wayS is online now   Reply With Quote
The Following 2 Users Say Thank You to Sid3wayS For This Useful Post:
btstarcher (08-24-2012), silvapain (07-14-2012)
 Old 08-07-2012, 11:15 AM   #29
Eth Fiend
phate's Avatar
Posts: 4,254   (View Stats)
phate has disabled reputation
Figure I better subscribe to this thread...
Are you having Kirk order the bearings?
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
 Old 08-07-2012, 11:17 AM   #30
Groans: 121
Yes, since he's already specing the clearance and assembling the short block for me.
Nliiitend1 (08-07-2012), phate (08-07-2012)
 Old 08-07-2012, 11:53 AM   #31
Groans: 121
PISTONS ARE DONE! They will be shipped out soon.
Many thanks to Positive Fabrications. They will have these available for others to buy as well.
Nliiitend1 and Rokusek like this.
AZSPEED3 (08-08-2012), Black Metal (08-07-2012), Boost_creep (08-07-2012), Jay@posifab.com (08-08-2012), josurr (08-13-2012), kritz (08-08-2012), lilred (08-07-2012), Ms3_Miami (11-07-2012), Nliiitend1 (08-07-2012), phate (08-07-2012), Rokusek (08-24-2012), snailD (08-20-2012), Tomas (08-08-2012)
 Old 08-07-2012, 02:59 PM   #32
Eth Fiend
phate's Avatar
That piston looks ANGRY!!!
silvapain (08-07-2012)
 Old 08-07-2012, 03:08 PM   #33
exentix's Avatar
Posts: 1,143   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 44
Groaned at 14 Times in 5 Posts
subbing to see what comes of this.
exentix is offline   Reply With Quote
 Old 08-08-2012, 05:42 AM   #34
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 410
Groaned at 205 Times in 121 Posts
Question on the pistons...why the design? I thought Pablo mentioned something about that not being proper for our spray pattern?
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
 Old 08-08-2012, 06:08 AM   #35
Groans: 121
These are a different face design than the CP-e smiley face pistons. These are more like the GenPu pistons, but with a notch for the injector (and higher compression ).
chimmike (08-08-2012)
 Old 08-08-2012, 06:24 AM   #36
Tenchix's Avatar
Posts: 369   (View Stats)
Tenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the worldTenchix is the leader of the world
Nice build, i wish i had money so you could build me one.
Tenchix is offline   Reply With Quote
 Old 08-08-2012, 01:01 PM   #37
Groans: 121
Shit, I wish I had the money too. All this cash, and I'll still be slow on the K04 when it's done.
DiGi Faggot (08-13-2012), helmetface (09-29-2012)
 Old 08-08-2012, 01:26 PM   #38
breakfstincluded's Avatar
Posts: 2,685   (View Stats)
Groans: 173
If I look at piston too long I see master chief head
The Following 2 Users Say Thank You to breakfstincluded For This Useful Post:
DiGi Faggot (08-13-2012), silvapain (08-09-2012)
 Old 08-08-2012, 02:01 PM   #39
Veblen Goods
Tomas's Avatar
Posts: 2,293   (View Stats)
How much for pistons?
What alloy?
wrist pin od?
And can they also be had in 9:5 CR?
Nice job having them designed for anyone to buy. Guess they're made by wiseco so they should be 2618?
GHEY THUNDER
 Old 08-08-2012, 02:15 PM   #40
Eth Fiend
phate's Avatar
What alloy?
wrist pin od?
PositiveFabrications will have the pricing info and CR availability. I know we've only discussed this piston as being high(er) compression than stock, so I'm not sure about the 9.5:1. The wrist pins for our builds are 22.5mm.
Official: BMW spills all the beans on new 1 Series Haltech Automotive News 2 06-05-2011 11:30 AM
Saab spills at least a few beans about its forthcoming 9-5 [w/new pics] Haltech Automotive News 0 08-27-2009 07:30 AM
Page generated in 0.52455 seconds with 38 queries
