Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree109Likes
 Old 11-07-2012, 08:14 PM   #441
Snotrocket's Avatar
Posts: 900   (View Stats)
Snotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the worldSnotrocket is the leader of the world
I must have missed that thread. If I didn't blow up myself I'd donate to this cause lol. Glad it worked out.
TappaFak
2010 MS3 Black
395whp/386wtq
| Molnar Rods | CP-e Stage 2 Pistons | Much Head Work | ATP GTX3076 | Tial 38mm EWG | HTP 4 Inch Intake | BSD | Passenger and Rear MM | Denso ITV22's | OCC | Ultimate Racing TBE | Tredstone TR8C FMIC | Tial BPV | Autotech Internals | Grimmspeed ECBS 3 port | Te37 Volks| 245/45/17 Dunlop zzi tires| Cobb AP Self Street Tuned | Sonic Tuning Coilovers | Stoptech breaks and slotted roters
Snotrocket is offline   Reply With Quote
 Old 11-07-2012, 10:59 PM   #442
GODspeed7's Avatar
Posts: 3,456   (View Stats)
Originally Posted by eric@edgeautosport View Post
@silvapain; it's going out today courtesy of Edge
Fuck yeah! There's my name!
Tapatalk LIKE A BOSS!
2012 Mazdaspeed3 Black Mica
ms3blackmica (11-08-2012)
 Old 11-08-2012, 01:39 AM   #443
Enki's Avatar
Posts: 7,541   (View Stats)
Enki has disabled reputation
Groans: 189
Originally Posted by x09MS3GT View Post
Im not tuning guru like these guys are, but ive been following your post since your car blew up.
Ive gone over these logs, and I'm wondering why your making peak hp before you even touch 4900 rpm in most of these logs ? Especially with such cool BATs ? On top of that, it almost looks like the same in every log, as soon as your VVT hits 0 at or around 4800, you stop making anymore power. With the exception of the few logs where it jumps around sporatically at the end of the rpm band, where you gained peak hp at almsot 6400 rpm....
Seems wierd. Maybe im just an idiot. But it does still look wierd, or im not seeing something. 20lbs so low should be getting a bit more torque no ? Your timing table matches my 95 octane mixed gas tune, and im making over 345 consistantly on 1.01 VD's.
2 reasons:
1. K04; boost falling off (as you can see in the graph) leads to torque falling off rapidly up top (no matter what you do aside from nitrous). In fact, it looks alot like every other K04 dyno; 20 pounds down low, taper up top.
2. Possible changes to VVT; it seems that he's hitting 15 deg VVT advance @ 3k, which is half of what is on the stock map. This could account for his drop in torque; people with stock pumps and an AP have seen increases in pressure up to and higher than 2 PSI down low at the same airflow rates and load levels (his 20 PSI might only be equivalent to 17-18 psi with stock VVT).
 Old 11-08-2012, 02:52 AM   #444
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
@silvapain;
Y NOT ENOUGH POWA ??
www.tunedbynishan.com
 Old 11-08-2012, 05:37 AM   #445
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
I always made more power when I targeted less boost and didn't taper as much toward redline. My turbo could hit 21psi up until around 4500 or so, and then would drop to around 17psi by redline; however if I stayed around 19psi it would hold more at redline. Obviously not as much torgue, but my power was up.
Your first runs had much more power; are you sure there isn't something wrong?
SnailTune in progress
 Old 11-08-2012, 08:20 AM   #446
Posts: 9,484   (View Stats)
IIRC he did, in-fact, pull VVT when he was getting all the KR on Corn. if so he just needs to put it back and get the cylinder flow thru and spent fuel scavenging going again.
btstarcher (11-08-2012), silvapain (11-08-2012)
 Old 11-08-2012, 08:24 AM   #447
I pulled VVT advance on my 93 map v145 in an attempt to reduce spoolup KR.
@Dano; where did you get your dial gauge you used to verify TDC? I am thinking about testing mine again just to ease my mind about mechanical timing.
djuosnteisn (11-08-2012)
 Old 11-08-2012, 08:33 AM   #448
man I got that thing at a garage sale for $5 10 years ago and just used it for the first time on this project.. lol.... talk about a premature purchase.
I know you prab don't want to wait but I can send it to you when I finish measuring my bearings...I can prab do that over the weekend. I can send the whole "kit" I made with VC mount. You would just need a 3/8" drive 6" extension and a 3/8 to 1/4 adapter to make it a lil longer for a plunger to go into the cylinder...you can rig up some combination I'm sure.
 Old 11-08-2012, 08:37 AM   #449
I'll see if I can find something at Harbor Freight.
 Old 11-08-2012, 08:40 AM   #450
Oh god no. Not HF!!! Lol
Prab accurate enough for piston height. Leak testers another story.
Tappin
silvapain likes this.
The Following 7 Users Say Thank You to Dano For This Useful Post:
BlueStreak (11-08-2012), djuosnteisn (11-08-2012), J-Liss (11-08-2012), ms3blackmica (11-09-2012), phate (11-08-2012), silvapain (11-08-2012), Speed_j23 (11-08-2012)
 Old 11-08-2012, 04:23 PM   #451
x09MS3GT's Avatar
Posts: 409   (View Stats)
x09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the worldx09MS3GT is the leader of the world
Groaned at 92 Times in 11 Posts
2 reasons:
Valid point i see. But the real question to ask is, where is the power on 22 psi on a higher compression engine ? Man this is confusing.
--Cobb Sri--Cobb Tip--Cobb Airbox--Cobb Fmic--Cobb Bpv--Cobb Turbo-back----Cobb V3 Ap--Cobb Rmm--Jbr Pmm--Jbr Tmm--Cobb Sts----6510's--Autotech's--KW V2'S--Jbr Fsb--Jbr Rsb--STOPTECH Sport Kit--E30 FREEKTuned --
x09MS3GT is offline   Reply With Quote
 Old 11-08-2012, 04:32 PM   #452
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
UnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the worldUnknownSuperhero is the leader of the world
Super price on Fowler 72-520-757 at ToolTopia.com
I used somthing similar when in school to check the deflection of warped rotors while still on the car.
*edit for HF goodness
http://www.harborfreight.com/clampin...tor-93051.html
http://www.harborfreight.com/1-inch-...cator-623.html
UnknownSuperhero is offline   Reply With Quote
The Following 2 Users Say Thank You to UnknownSuperhero For This Useful Post:
Easter Bunny (11-08-2012), silvapain (11-08-2012)
 Old 11-09-2012, 12:37 AM   #453
Nishan
Tappin
compression testers as well lol
ask me how i know !
Dano (11-09-2012)
 Old 11-09-2012, 09:24 AM   #454
Enki's Avatar
Groans: 189
Everything else the same, higher. Ultimately, though, it depends entirely upon afr, airflow, timing...same shit as every other car. The mighty beard needs some time to dial it in a bit more and we will be able to tell for sure where it's at.
The Following 6 Users Say Thank You to Enki For This Useful Post:
Easter Bunny (11-09-2012), ms3blackmica (11-09-2012), phate (11-09-2012), silvapain (11-12-2012), Speed_j23 (11-09-2012), x09MS3GT (11-20-2012)
 Old 11-09-2012, 11:36 AM   #455
Nishan
The worst part about tuning your own car is you get lazy lol
*Driving down the highway, perfect time to grab a log*... and you end up saying "ehh ill do it another time" lol
but i'm sure once silva gets thing dialed in again we should see good numbers for even a stock turbo..
at the end of the day, he is still winning. he now has a strong motor.
The Following 4 Users Say Thank You to ms3blackmica For This Useful Post:
J-Liss (11-09-2012), mazdafreak (11-09-2012), silvapain (11-12-2012), Speed_j23 (11-09-2012)
 Old 11-10-2012, 11:53 AM   #456
EGT gauge was hooked up last night, thanks to help from @phate;. We put the thermocouple in the #2 runner as close as we could to the head. We didn't do the collector because we'd get more accurate readings closer to the combustion chamber, and all the cylinders and plugs looked like they were running evenly WRT AFR and temps.
At idle I'm around 800F, cruise around 1100F, and WOT is in the 1600F range if I remember correctly. Clint was the one watching the gauge closely while I drove, so he could provide better info.
Next step is to lean it out a bit from the current 12.06:1 and see what happens.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
BlueStreak (11-10-2012), djuosnteisn (11-12-2012), phate (11-10-2012), wolly6973 (11-10-2012)
 Old 11-10-2012, 12:06 PM   #457
GODspeed7's Avatar
Where were you yesterday when I was arguing with this guy that swore up and down that my 11.83 was too lean with my 20psi tune? You are at 12.06 and going leaner. I read that even up to 13.0 is acceptable although risky.
 Old 11-10-2012, 12:43 PM   #458
btstarcher's Avatar
Groans: 112
With the corn it should be fine...I don't know about just gas though...
 Old 11-10-2012, 02:35 PM   #459
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The only reasons to run rich are to combat detonation and reduce egt's. If both are acceptable, you'll be fine.
-06 MS6
-Corn fed 07 MS3 - Sold
atvfreek (11-10-2012), btstarcher (11-10-2012), Dano (11-10-2012), djuosnteisn (11-12-2012), ms3blackmica (11-12-2012), silvapain (11-10-2012), Snotrocket (11-10-2012)
 Old 11-10-2012, 03:17 PM   #460
atvfreek's Avatar
Posts: 7,787   (View Stats)
I had a couple cars on the dyno last week. On two of the cars I gained 4hp every .2 I leaned out the afr. lol Couldn't believe it.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
BlueStreak (11-10-2012), djuosnteisn (11-12-2012), ms3blackmica (11-12-2012), phate (11-10-2012)
 Old 11-10-2012, 03:20 PM   #461
GODspeed7's Avatar
@boost_addict; read the last 10 posts and now you know why I was saying what I was saying.
 Old 11-10-2012, 03:27 PM   #462
Ziggo's Avatar
Posts: 3,843   (View Stats)
What where the effects on IDCs though? I suspect that as long as you are in the right range for your fuel, it doesn't really affect power. Also remember leaner mixtures have a faster flame front speed so by leaning out you are effectively adding timing too.
Zigatapatalka
Ask Me About My:
The Following 5 Users Say Thank You to Ziggo For This Useful Post:
atvfreek (11-10-2012), BlueStreak (11-10-2012), djuosnteisn (11-12-2012), ms3blackmica (11-12-2012), phate (11-10-2012)
 Old 11-10-2012, 03:57 PM   #463
atvfreek's Avatar
Zigatapatalka
Both cars were on meth only so IDC wasn't an issue, so I wasn't paying a whole lot of attention to them.
One of the guys made 385hp corrected and 394 uncorrected in a speed6. With the d10 nozzle he was only in the low 80's for IDC.
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 2 Users Say Thank You to atvfreek For This Useful Post:
 Old 11-10-2012, 07:29 PM   #464
I forgot: we also did a compression check.
1 - 190
2 - 200
3 - 200
4 - 200
No idea why 1 is lower. We tested it twice and got the same value both times. It's only a 5% difference so I'm not too concerned.
The Following 7 Users Say Thank You to silvapain For This Useful Post:
atvfreek (11-10-2012), djuosnteisn (11-12-2012), mazdafreak (11-10-2012), ms3blackmica (11-12-2012), Nliiitend1 (11-11-2012), phate (11-10-2012), Speed3eak (11-10-2012)
 Old 11-10-2012, 09:49 PM   #465
Eth Fiend
phate's Avatar
EGT!!!
EGT's were peaking and holding arond 1600° for a multi gear pull through 6th. My suggestion was to richen it up first to see what happens. If the delta wasn't much for a half point or so richer, going a half point leaner (from original) would be a good comparison. Test from there to see what happens
-06 MS6
atvfreek (11-11-2012), silvapain (11-11-2012), snailD (11-10-2012), wolly6973 (11-11-2012)
 Old 11-10-2012, 10:09 PM   #466
Eth Fiend
phate's Avatar
Freekn tappin
Kinda funny you mention this...To reference a bad source: john mentioned seeing gains from going leaner as power increased well beyond what the K04 could produce. I've only tested this on K04 cars, so it may be different as power levels increase.
But, Ziggo is totally correct saying the AFR affects the flame speed, thereby affecting the timing needed. When I did my testing, I held AFR, ran up timing to MBT. Pulled timing, changed AFR, then ran timing back to MBT (different curve). In that case (K04/E85 on my car was most extensive), there was not enough difference to matter.
-06 MS6
atvfreek (11-10-2012), BlueStreak (11-11-2012), djuosnteisn (11-12-2012), Jh8909 (11-10-2012), Speed_j23 (11-11-2012), wolly6973 (11-11-2012)
 Old 11-11-2012, 09:31 AM   #467
Clark954's Avatar
Posts: 9   (View Stats)
Clark954 has a spectacular aura aboutClark954 has a spectacular aura aboutClark954 has a spectacular aura about
PISTONS ARE DONE! They will be shipped out soon.
Many thanks to Positive Fabrications. They will have these available for others to buy as well.
It's like a vagina....only sexier
Clark954 is offline   Reply With Quote
The Following 2 Users Say Thank You to Clark954 For This Useful Post:
mazdafreak (11-11-2012), silvapain (11-12-2012)
 Old 11-12-2012, 12:48 AM   #468
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
So the big question is, what constitutes excessive EGT? If everything is working properly, 1250º to 1300º F. is a safe turbine inlet temperature, even for sustained running, mile after mile.
Banks on turbo diesels.
 Old 11-12-2012, 01:10 AM   #469
Enki's Avatar
Groans: 189
Diesel != gasoline.
1600 is normal/average for gas engines, and with modern materials, reliable as well.
phate (11-12-2012), silvapain (11-12-2012)
 Old 11-12-2012, 01:57 AM   #470
Nishan
whoever this is clearly does not understand DI lol
^^^ this.
 Old 11-12-2012, 11:58 AM   #471
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
Groans: 79
Timing will have a far more substantial effect on EGTs than AFR. If anything, adding fuel can quite possibly increase EGTs, as that added fuel will have more opportunity to burn further into the exhaust. Just like ziggo mentions below, lean AFRs will generally result in a faster flame front, and thus more of the combustion process will occur inside the combustion chamber, rather than into the exhaust stroke.
As always, there are grey areas. But i've even read extreme examples of detonation actually resulting in lower EGTs... simply because the detonation causes uncontrolled combustion, and thus far less combustion in the exhaust.
Zigatapatalka
QFT.
1 - 190
2 - 200
3 - 200
4 - 200
My #3 and #4 cylinders have been 10psi low since the motor went in. I'm not sure if it's just how the rings lined up, or what. I'm not too concerned with it either, as long as they don't drop any further lol.
Those values look great btw!
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
The Following 4 Users Say Thank You to djuosnteisn For This Useful Post:
atvfreek (11-12-2012), phate (11-12-2012), silvapain (11-12-2012), SPEED6 KILLAH (11-16-2012)
 Old 11-12-2012, 12:06 PM   #472
J-Liss's Avatar
Posts: 1,949   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
I got a speed 3 stock manifold sitting in my closet, that i have no use for, you guys need/want it?
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 11-12-2012, 02:04 PM   #473
You want something for it? Shoot me a PM Josh.
 Old 11-12-2012, 02:07 PM   #474
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
I'd still rather run slightly richer. It's a small safety net, in case things go wrong. You'll never feel 5-10WHP in every day driving. You're only putting your engine at more risk for a higher dyno number. Not worth it IMO. I'm not saying that no one should run lean AFRs, they have their place, but I wouldn't suggest it for people new to tuning or cars in general.
2006 Mazdaspeed6
 Old 11-16-2012, 10:01 PM   #475
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
Any Update
SPEED6 KILLAH is offline   Reply With Quote
The Following 4 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (11-17-2012), Dano (11-17-2012), ms3blackmica (11-17-2012), Speed3eak (11-17-2012)
 Old 11-17-2012, 11:57 PM   #476
hes in the middle of a fierce legal battle with Wolverine Oil Heaters with regard to their totally false claim that;
WHAT IS THE WOLVERINE ENGINE OIL HEATER?
A revolutionary new kind of Engine Preheater designed with aerospace technology to heat the important areas of the auto engine beginning with its oil supply. Remember - Heat Rises."
which we all know that;
Hot AIR rises, due to changes in air density with temperature due to the Ideal Gas Law.
its really a open and shut case but you know how these things go...fight the good fight Dan!
The Following 5 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (11-20-2012), Easter Bunny (11-18-2012), phate (11-18-2012), SPEED6 KILLAH (11-18-2012), wolly6973 (11-18-2012)
 Old 11-18-2012, 12:03 AM   #477
Mizzle's Avatar
Groans: 324
Heat does rise in oil as well.
I feel like I'm missing something... like the joke...
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Dano (11-18-2012), phate (11-18-2012)
 Old 11-18-2012, 12:05 AM   #478
you guys need to get a life....guess I do as well....
god Dan will love this tomorrow!
phate (11-18-2012)
 Old 11-18-2012, 12:09 AM   #479
Mizzle's Avatar
Groans: 324
Diesel != gasoline.
I totally missed this.
So they intentionally use lower-temp parts in a diesel turbo...?
 Old 11-18-2012, 12:23 AM   #480
GODspeed7's Avatar
I think the joke is that "heat" itself doesn't rise. The heat is conducted through the engine. Only hot air rises. So when the advertisement stated their oil pan warmer heated the whole engine because "we all know heat rises" it was more or less false advertising because the heat is transferred from oil pan to block. The "heat" doesn't actually rise like they stated.
The Following 4 Users Say Thank You to GODspeed7 For This Useful Post:
Easter Bunny (11-18-2012), ms3blackmica (11-18-2012), silvapain (11-18-2012), wolly6973 (11-18-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f658/beans-above-frank-build-115919/
Rear wheel slant - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-28-2015 01:06 PM
power steering shut down while driving! - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 09-20-2015 08:41 AM
Oil smells like fuel - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 07-24-2015 06:34 PM
Plastic plate falling off under my engine - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-26-2014 08:37 AM
So I got a Ford Ranger... - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-18-2014 10:18 AM
FMIC ? - Page 3 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 04-16-2014 11:02 AM
MS3 and Mazdaspeed sway bar differences? - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-24-2013 07:38 PM
Options for fixing up a steering wheel - tape it? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 11-17-2013 10:17 AM
Does the gas tank need to be removed to replace fuel pump on '08 Hatchback? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 10-15-2013 05:57 AM
FRONT CAMBER ADJUSTMENT - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-14-2013 11:45 PM
Clear Bra pics - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 08-04-2013 03:39 AM
Driver window not working. Please HELP - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-18-2013 11:14 AM
How To: Change Spark Plugs on your MS3 - Page 2 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-22-2013 10:55 PM
2009 Speed 3 Snow Tire Size and Brand Preferences - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-19-2013 11:49 AM
Free ECU tuning with laptop? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 03-14-2013 06:21 AM
Anyone have the Mazdaspeed sport spring kit on their MS3??? - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 02-28-2013 02:42 AM
My project: Non-boosted DISI motor - Page 4 - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 12-04-2012 03:07 AM
high compression turbo engines? - V6Power Messageboard This thread Refback 11-23-2012 04:41 PM
Official: BMW spills all the beans on new 1 Series Haltech Automotive News 2 06-05-2011 12:30 PM
Saab spills at least a few beans about its forthcoming 9-5 [w/new pics] Haltech Automotive News 0 08-27-2009 08:30 AM
Page generated in 0.63677 seconds with 38 queries
