![]() | | #481 | ![]() |
![]() Join Date: Mar 2010 Location: New Eagle, PA
Rep Power: 2281 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,142
Groans: 324
| Not Ranked : 0 score |
![]() | | #482 | ![]() |
Groans: 324
| Not Ranked : 0 score Well, would the heated oil not, in turn, heat the surrounding air... causing some heated air to rise and, in effect, partially warming the engine if only slightly... ergo heat rising? |
![]() | | #483 | ![]() |
![]() | | #484 | ![]() |
Groans: 324
| Not Ranked : 0 score Yep. |
![]() | | #485 | ![]() |
| Not Ranked : 0 score great! as long as we are on the same page....well...or different page as the case may be.
![]() | | #486 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score do i needa pull out the thermo books lol
__________________ www.tunedbynishan.com |
| The Following User Says Thank You to ms3blackmica For This Useful Post: | Speed_j23 (11-18-2012) |
![]() | | #487 | ![]() |
(Thread Starter) | Not Ranked : 0 score No updates yet. I've been too busy with work to do testing on the car this past week; case in point: I'm posting this reply at work right now. I have leaned out my WOT AFRs to 12.29:1 (0.836 lambda) and will try to get some logs and EGT data today after I get out of work. The rest of you are just jealous of my Thermodynamics skillz. Tapadatass
__________________ |
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | atvfreek (11-18-2012), Dano (11-18-2012), ms3blackmica (11-18-2012), phate (11-18-2012), wolly6973 (11-18-2012) |
![]() | | #488 | ![]() |
Groans: 189
The turbos used in "modern" diesels aren't usually the same as gasoline engine ones; a VGT (for example) turbo won't last terribly long in a gasoline engine unless you monitor/tune for EGT specifically to prevent the shit from burning up. Since diesels are so much more efficient than your standard gas engine, they lose less energy to heat (and thus EGT); this isn't the case for gas engines.
__________________ | |
| The Following 3 Users Say Thank You to Enki For This Useful Post: |
![]() | | #489 | ![]() |
(Thread Starter) | Not Ranked : 0 score More WOT runs, with WOT AFRs leaned out to 12.29:1. EGTs peaked at 1650-1700°F, and still no significant KR with timing advanced to 18-18.5° at Redline. All WOT runs are done in 4th gear BTW. There isn't enough data yet, but it does appear initially that I am suffering from heat soak on pump gas with the stock TMIC. You can see if you VD the attached logs that power reduces as I take more logs.
| The Following 5 Users Say Thank You to silvapain For This Useful Post: | BlueStreak (11-20-2012), Dano (11-20-2012), Nliiitend1 (11-20-2012), phate (11-20-2012), Speed3eak (11-20-2012) |
![]() | | #490 | ![]() |
![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 1975 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,199
Groans: 112
| Not Ranked : 0 score Why you no haz BAT logged?
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, Forge V2 BPV, JBR TIG's, Kozmic EGR delete, Cobb AP, PTP HPFP internals, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Swift springs, Tri Point Engineering RSB, Whiteline Anti Lift Kit, PTP Injector Seals, GenPu transmission, Fidanza flywheel, 3 BAR MAP sensor, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, sleeved block, PTP BSD SnailTune in progress |
| The Following User Says Thank You to btstarcher For This Useful Post: | speedms6 (11-20-2012) |
![]() | | #491 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score I'm scratching my head here as to why your motor isn't freaking out with 10.5:1 compression, K04 bats, 12.2 AFR and 18.5* timing on pump.
__________________ '07 CWP MS3 Forged. |
| The Following 5 Users Say Thank You to BlueStreak For This Useful Post: | atvfreek (11-20-2012), btstarcher (11-20-2012), phate (11-20-2012), silvapain (11-20-2012), Speed3eak (11-20-2012) |
![]() | | #492 | ![]() |
![]() Join Date: Nov 2009 Location: Westchester NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 566
| Not Ranked : 0 score been thinking the same thing since i saw this earlier this morning
__________________ 2007 Mazdaspeed 6 - Ptp SST, Cobb AP, SSP 3.5" Intake, SURE Sidewinder, Autotech HPFP Internals, PTP 2150 psi HPRV, Cp-e Injector Seals, PTP Injector Studs, Jbarone TIG's, VTCS Delete, ETS 3.25" TMIC, M2 Catless Downpipe, Magnaflow Catback Exhaust, MD OCC, Denso ITV 22, H & R springs, Energy Suspension Rear Sway Bar Bushings, Dashhawk, Hawk HPs Pads, Centric Rotors, Street Unit Rear Motor Mount, TWM Stage II Shifter with Solid Bushings and Weighted Shift Knob, Autometer Mechanical Boost Gauge |
![]() | | #493 | ![]() |
| Not Ranked : 0 score super duper atomization and combustion due to angry piston design?? no hotspots generated like on a dished genwan piston?? Also, brand new pistons with zero carbon buildup is likely better for reducing/eliminating hotspots?? just seeing what sticks...lol
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #494 | ![]() |
| Not Ranked : 0 score Looking at the datalog, I was expecting the car to be ripping the tires off. Then I dropped it into VD and the power output wasn't congruent with expectations given no KR on what appears to be a very aggressive tune on pump. Silvapain. Out of curiosity, has the timing method you used been successfully implemented in other motor buillds?
__________________ '07 CWP MS3 Forged. Last edited by BlueStreak; 11-20-2012 at 09:24 AM. |
| The Following User Says Thank You to BlueStreak For This Useful Post: | btstarcher (11-20-2012) |
![]() | | #495 | ![]() |
Groans: 112
| Not Ranked : 0 score They look like my logs plotted on VD whenever I fucked with Jason's tune, trying to get more power by increasing target boost levels. I ended up with plenty of torque down low, but at the expense of power past around 5k rpm's. It happened every time.
![]() | | #496 | ![]() |
Groans: 79
| Not Ranked : 0 score The ideal spark advance for a given motor has a direct relationship with combustion speed inside the chamber. Faster flame fronts require lower ignition advance in order to hit that sweet spot of peak pressure ~14 degrees ATDC for maximum torque. Shoot, in a perfect world... combustion would be instantaneous, and the plug wouldn't even fire til ATDC... but real life isn't that easy. Combustion speed in the chamber has a direct relationship with the air / fuel mix, and actual combustion path within the chamber (these two are related as well). For instance, one of the reasons racers back in the day disliked the "hemi" design, was that the pistons necessary for higher compression builds resulted in an inverted dome shape... which in turn resulted in a longer flame front path and the need for more spark advance. More spark advance generally increases the amount of negative work the motor has to do (compressing combustion), and it also increases the potential for detonation to occur. Poor air / fuel mix can have a similar effect. Think of combustion as throwing a match into the middle of a dry grass field. The fire will expand in a uniform ring away from the ignition point. Same thing happens in an ideal mix inside a combustion chamber. Now imagine the field has a few dry spots without grass... and a few real clumpy spots where the grass is kinda wet. You can imagine that the fire won't expand anywhere near as fast as the ideal dry field example above. Again.... same thing happens in a combustion chamber. This is why manufacturers include things like tumble valves and focus so much on swirl and mix in the chamber. It's a very important part of the combustion process. I have a feeling the dish in these new pistons is resulting in a very rich spot centered around the plug. And the dish on the far side of the piston would then be resulting in a lean spot. It's hard to say for sure, but that would explain the blow out issues Dan was having on e85, as well as how much spark advance he's able to run on pump gas alone (especially with the higher compression pistons). His EGT temps don't look terribly high though, which is a good thing. Generally poor combustion results in higher EGTs, since more of the combustion process occurs out the exhaust valve.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following 30 Users Say Thank You to djuosnteisn For This Useful Post: | aggierandy (11-20-2012), Alpha (11-20-2012), alphasaur (12-05-2012), atvfreek (11-20-2012), Axel907 (01-16-2013), Boosted Beluga (11-20-2012), Boost_creep (11-20-2012), btstarcher (11-20-2012), cld12pk2go (11-20-2012), daafisch (11-20-2012), Dano (11-20-2012), Easter Bunny (11-20-2012), J-Liss (11-20-2012), JacksonMS30 (11-20-2012), Keko (11-20-2012), lilred (11-20-2012), magicka (11-22-2012), ms3blackmica (11-20-2012), Nliiitend1 (11-20-2012), phate (11-20-2012), Realgib3 (11-25-2012), SarcasticOne (11-20-2012), silvapain (11-20-2012), Snotrocket (11-20-2012), Speed3eak (11-20-2012), SPEED6 KILLAH (11-20-2012), speedms6 (11-20-2012), Tokay444 (11-20-2012), wolly6973 (11-20-2012), x09MS3GT (11-20-2012) |
![]() | | #497 | ![]() |
| Not Ranked : 0 score talk about an explanation... thanks @djuosnteisn;
| The Following 4 Users Say Thank You to speedms6 For This Useful Post: | aggierandy (11-20-2012), atvfreek (11-20-2012), djuosnteisn (11-20-2012), SPEED6 KILLAH (11-22-2012) |
![]() | | #498 | ![]() |
Groans: 79
Pioneering ain't easy, but if nobody did it, we'd still be romping around like the flinstones, haha.
__________________ 500awhp 440awtq uncorrected ![]() EFR8374 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Count down to head lift.... 3.... 2.... 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com | |
| The Following 15 Users Say Thank You to djuosnteisn For This Useful Post: | atvfreek (11-20-2012), BlueStreak (11-20-2012), Boosted Beluga (11-20-2012), daafisch (11-20-2012), Dano (11-20-2012), JacksonMS30 (11-20-2012), lilred (11-20-2012), ms3blackmica (11-20-2012), phate (11-20-2012), Realgib3 (11-25-2012), silvapain (11-20-2012), Speed3eak (11-20-2012), SPEED6 KILLAH (11-22-2012), Speed_j23 (11-20-2012), wolly6973 (11-20-2012) |
![]() | | #499 | ![]() |
| Not Ranked : 0 score I definitely don't debate that the dished pistons make a difference. The question is "how much?". The GenPu's have dished pistons and all else equal (boost, timing and AFRs, make about the *same* power as Gen1s. In other words, they don't have 20-30hp on us automatically. I plugged silvapain's first datalog into VD and with a Dynojet correction factor, came out to ~280hp and ~344tq (no adjustments made for temp and baro); this is with airflow at 280g/s, AFRs at 12.2 and 18* timing by redline. In my mind, given these inputs, the engine should A) reject the tune because its too aggressive on pump or B) be incredibly quick. Neither A or B have resulted. I think we have enough info on MSF to have certain expectations that x tune with y modifications will make z power. Heck, silvapain himself knows what power he was making given his previous setup; the only material difference being the higher comp dished pistons. Power should at least be on par. Seems like something else is up. EDIT: The power output seems more consistent with a tune running roughly 10-12* timing up top (with a proper ramp up). To say an additional 6* is necessary to make the same power seems like a bit of a stretch. EDIT x2: That being said, I am eager to see this build become a success. I have a bag of popcorn to my left and some crow to my right should I need to eat my words.
__________________ '07 CWP MS3 Forged. Last edited by BlueStreak; 11-20-2012 at 02:08 PM. |
| The Following 5 Users Say Thank You to BlueStreak For This Useful Post: | atvfreek (11-20-2012), djuosnteisn (11-20-2012), phate (11-20-2012), SPEED6 KILLAH (11-22-2012), wolly6973 (11-20-2012) |
![]() | | #500 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,419
Groans: 81
| Not Ranked : 0 score so as of now....HCP are not the way to go with the current design?
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler ] |
![]() | | #501 | ![]() |
![]() Join Date: Feb 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,452
Groans: 82
| Not Ranked : 0 score Haha damn I thought I got away with deleting that post before anyone saw it - after re-reading your explanation it was a little more clear in my mind. Thanks though for clarifying - I'm wearing out my mouse buttons hitting refresh on this page, love the concept of a high compression build. Partly because I haven't seen any before and partly because when I dream about high compression motors and medium frame turbos I wake up with white sticky stuff all over me. edit: Higher compression definitely makes more power given two otherwise identical engines - especially in N/A applications. I imagine the same would hold true for turbos. Just because he isn't making more power yet on this setup doesn't mean that he won't. This is still a preliminary tune as far as I know - we still have to figure out other things. For example, the injection timing is the same as it was on his stock 9.5:1 CR pistons. His piston is however taller than it was before - does this mean fuel is hitting the top of the piston? Does it mean that the air flow in the combustion chamber is all funky monkey? He could be making the same power on a wacked out fuel mixture. We don't know yet. I don't want to presume that this is as much power as he can make at WOT at this early of a stage. |
| The Following 3 Users Say Thank You to Speed3eak For This Useful Post: |
![]() | | #502 | ![]() |
Groans: 112
| Not Ranked : 0 score Hell I'm just surprised he can run that much timing and still not experience significant KR on pump gas.
![]() | | #503 | ![]() |
Dustin just splained all of that. those mountains and valleys on the piston are greatly reducing flame front travel thus requiring more advance to make all things equal. More specifically, the mountains and valleys are causing rich and lean spots in the fuel mix. at least that is one theory and personally the one I subscribe to ATM. This is all a very new piston design so time will prove out its merit.
| The Following 5 Users Say Thank You to Dano For This Useful Post: | btstarcher (11-20-2012), djuosnteisn (11-20-2012), JacksonMS30 (11-20-2012), Speed3eak (11-20-2012), wolly6973 (11-20-2012) |
![]() | | #504 | ![]() |
| Not Ranked : 0 score Eh, my theory is much less complex. The motor is timed funky causing the dynamic compression ratio to be lower than it otherwise would be and/or causing a discrepancy between what the ECU reads TDC as and actual TDC. This isn't an assault against you or your engine building skills, I just like to start with the easiest explanation. All things being equal theory says a 10.5 CR motor is only about 2% more thermally efficient than a 9.5 CR motor. Ideal Thermal efficiency (gasoline engines). = 1 - (1/CR^.4) Zigatapatalka
| The Following 7 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (11-20-2012), BlueStreak (11-20-2012), djuosnteisn (11-20-2012), J-Liss (11-20-2012), phate (11-20-2012), Speed3eak (11-20-2012), wolly6973 (11-20-2012) |
![]() | | #505 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
Freekn tappin
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following 6 Users Say Thank You to atvfreek For This Useful Post: | BlueStreak (11-20-2012), Dano (11-20-2012), djuosnteisn (11-20-2012), phate (11-20-2012), silvapain (11-20-2012), wolly6973 (11-20-2012) |
![]() | | #506 | ![]() |
| Not Ranked : 0 score hahaha that is LESS complex? BTW he did readjust TDC by what 7* according to the CCAG? so he may be 7* retarded when the ECU records 0*. I can't remember for sure but I think he wanted to put a dial indicator on and measure piston height...not sure he has done that yet. Edit: Justin beat me to it! oh and this is now my new theory since I just recalled his timing shift.
| The Following 7 Users Say Thank You to Dano For This Useful Post: | atvfreek (11-20-2012), BlueStreak (11-20-2012), djuosnteisn (11-20-2012), phate (11-20-2012), silvapain (11-20-2012), wolly6973 (11-20-2012), Ziggo (11-20-2012) |
![]() | | #507 | ![]() |
Don't worry about making me butthurt. This process is all about expanding on the already large amount of great technical information on MSF.
| The Following 14 Users Say Thank You to silvapain For This Useful Post: | atvfreek (11-20-2012), BlueStreak (11-20-2012), daafisch (11-20-2012), Dano (11-20-2012), djuosnteisn (11-20-2012), Easter Bunny (11-20-2012), J-Liss (11-20-2012), Nliiitend1 (11-20-2012), phate (11-20-2012), Realgib3 (11-25-2012), Speed3eak (11-20-2012), speedms6 (11-20-2012), wolly6973 (11-20-2012), Ziggo (11-20-2012) |
![]() | | #508 | ![]() |
Groans: 81
| Not Ranked : 0 score things are starting to come together.
![]() | | #509 | ![]() |
so you see.... it can expand 10 fold so no pain is felt when attempting to hurt the butt.
| The Following 5 Users Say Thank You to Dano For This Useful Post: | atvfreek (11-20-2012), Boosted Beluga (11-20-2012), phate (11-20-2012), Speed3eak (11-20-2012), Tokay444 (11-20-2012) |
![]() | | #510 | ![]() |
| Not Ranked : 0 score Dano verified timing peg = actual tdc on a good crank. Unless timing slipped on silva's engine, degreeing will give the same tdc result as a dial indicator. Would be good to verify, I suppose. Check things off the list
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #511 | ![]() |
I must be missing something.
| The Following User Says Thank You to Dano For This Useful Post: | phate (11-20-2012) |
![]() | | #512 | ![]() |
| Not Ranked : 0 score Just BeCuase you figured out how to cross quote threads and confuse the shit out of me doesn't give you the right to be stealing my theories! Zigatapatalka
| The Following 5 Users Say Thank You to Ziggo For This Useful Post: | atvfreek (11-20-2012), djuosnteisn (11-20-2012), silvapain (11-20-2012), Speed_j23 (11-20-2012), Tokay444 (11-20-2012) |
![]() | | #513 | ![]() |
| Not Ranked : 0 score went looking for those did you? hahaha you can't steal something the other person still has possession of. jussayin you still have the theory and I subscribe to the same theory...thus we are sharing said theory. oh and I see what you did there...nice
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 11-20-2012 at 04:40 PM. |
| The Following User Says Thank You to Dano For This Useful Post: | atvfreek (11-20-2012) |
![]() | | #514 | ![]() |
So, unless we really fuckered something up or his timing slipped, I'd bet that it's good. EDIT: But, yes, it is odd that his engine is taking so much timing and still picking up power. It could definitely be a mechanical timing issue (I'm just arguing the two methods are near identical), or it could be related to flame speed. Time will tell. Silvapain - if you want a hand this weekend, I'm available.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. Last edited by phate; 11-20-2012 at 04:58 PM. | |
![]() | | #515 | ![]() |
Groans: 793
| Not Ranked : 0 score But the piston is attached to the crank with the rod. So even if timing slipped, before or after the build, the peg should still hit the crank when the piston is at it's highest.
![]() | | #516 | ![]() |
If timing slipped and the reluctor wheel on the crank pulley isn't lined up properly with #1 TDC, my 18.5° of spark advance won't actually be 18.5°. What I need to do is put the car up in the air, pull the #1 spark plug and find TDC using a dial indicator, and then verify that the CKP is lined up with the center of the 20th tooth after the gap on the crank pulley reluctor wheel.
| The Following 6 Users Say Thank You to silvapain For This Useful Post: | Dano (11-20-2012), djuosnteisn (11-21-2012), ms3blackmica (11-21-2012), Nliiitend1 (11-20-2012), phate (11-20-2012), wolly6973 (11-20-2012) |
![]() | | #517 | ![]() |
Groans: 793
| Not Ranked : 0 score Yes.
![]() | | #518 | ![]() |
this...I thought that when the peg was installed in Dan's block and you rolled the crank around until it stopped [on that flat spot that is machined into the crank for this exact purpose] that the piston was not at TDC and that it was either 7* BTDC or 7* ATDC, can't remember which. what say you? edit: asked and answered.
![]() | | #519 | ![]() |
Groans: 81
| Not Ranked : 0 score let me guess you guys used the old extension in cylinder one at its highest point method lol
![]() | | #520 | ![]() |
Groans: 793
| Not Ranked : 0 score Dano used a dial test indicator.
| Official: BMW spills all the beans on new 1 Series | Haltech | Automotive News | 2 | 06-05-2011 12:30 PM |
| Saab spills at least a few beans about its forthcoming 9-5 [w/new pics] | Haltech | Automotive News | 0 | 08-27-2009 08:30 AM |
