Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Notices
Like Tree97Likes
 Old 10-02-2012, 02:20 PM   #121
Realgib3's Avatar
Posts: 1,427   (View Stats)
Groaned at 14 Times in 7 Posts
Here's my take on that: I never removed the gear from the exhaust cam, so as long as the intake cam timing is correct and the chain slack is good the exhaust cam should be timed.
I know it's an assumption and not as good as a proper visual inspection, but it should serve as a good gross check.
I would def check the cams/slots/and chain tension just to be safe because keeping the exhaust cam sprocket loose until everything is in alignment is what allows everything to kinda fall into place. If you were lining things up with the sprocket already tight, then put the chain on, I'm not sure you'll get the proper timing. Just a thought as I'm running out of work.
good luck!
Built Motor
PTE 6466 BIG Turbo
Tuned by me
4 cylinders... 6 injectors... Because Racecar
The Following User Says Thank You to Realgib3 For This Useful Post:
djuosnteisn (10-02-2012)
 Old 10-02-2012, 02:32 PM   #122
helmetface's Avatar
Posts: 4,584   (View Stats)
Groans: 142
#10 - drink a fucking beer
The Following 6 Users Say Thank You to helmetface For This Useful Post:
atvfreek (10-02-2012), djuosnteisn (10-02-2012), Easter Bunny (10-02-2012), phate (10-02-2012), Realgib3 (10-02-2012), silvapain (10-02-2012)
 Old 10-02-2012, 02:45 PM   #123
Eth Fiend
phate's Avatar
Posts: 4,336   (View Stats)
phate has disabled reputation
As long as two of the three sprockets are loose during the timing procedure, everything will be fine. Having all 3 loose isn't necessary, since the loose two will allow the slack to be taken out.
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
djuosnteisn (10-02-2012), silvapain (10-02-2012), Tomas (10-02-2012)
 Old 10-02-2012, 02:45 PM   #124
Posts: 5,718   (View Stats)
Groans: 121
good luck!
When timing the engine, the cams were locked in place with the VVT actuator and crank timing gear both loose. Tensioner pin was pulled which tautened the timing chain, then the VVT actuator was tightened down. This locked the cam gears correctly. Tightening the crank bolt down after the timing cover was put on then locked the crank gear in time.
You can have one of the three timing chain gears locked down and still mechanically time the engine properly. Just not two gears (or three ). l left the exhaust cam gear alone as there was no need to remove it (and therefore have to replace the friction washer).
EDIT: beaten to the punch by phate
silvapain is online now   Reply With Quote
The Following 6 Users Say Thank You to silvapain For This Useful Post:
Dano (10-02-2012), djuosnteisn (10-02-2012), Easter Bunny (10-02-2012), phate (10-02-2012), Realgib3 (10-02-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 03:00 PM   #125
Captain
djuosnteisn's Avatar
Posts: 11,272   (View Stats)
Groans: 79
I think mark was under the impression you didn't loosen the VVT gear. When i assemble motors, i typically don't touch the VVT, and instead loosen the exh sprocket to allow things to fall in place.
It was a good suggestion though, on the off chance you timed the motor with a droop between the cam sprockets.
I'm excited to see fresh gas in the tank. Go home now and doooo eeeet.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
The Following 6 Users Say Thank You to djuosnteisn For This Useful Post:
Easter Bunny (10-02-2012), phate (10-02-2012), Realgib3 (10-02-2012), silvapain (10-02-2012), superskaterxes (10-02-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 03:04 PM   #126
Groans: 121
Ahh. Yeah, I pulled my VVT actuator and sent it out to DCR for the 'upgrade'. The chain was quite taut between the cam gears after pulling the tensioner pin.
Almost time to leave work...
The Following 10 Users Say Thank You to silvapain For This Useful Post:
Boosten Ya(josh) (10-02-2012), Dano (10-02-2012), djuosnteisn (10-02-2012), GLORIFIEDBOZO (10-02-2012), J-Liss (10-02-2012), NJSPEED3 (10-04-2012), Nliiitend1 (10-02-2012), phate (10-02-2012), Realgib3 (10-02-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 04:48 PM   #127
Posts: 10,186   (View Stats)
Groans: 98
dont forget to flush some of that fresh 93 though the system.
a tank of 93 wont help if you have E85 all through your lines, atleast purge it to the fuel pump area and let the car run as much as possible to flush out the rail before you make a determination.
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
The Following 5 Users Say Thank You to superskaterxes For This Useful Post:
Boosten Ya(josh) (10-02-2012), djuosnteisn (10-02-2012), Easter Bunny (10-02-2012), Nliiitend1 (10-02-2012), phate (10-02-2012)
 Old 10-02-2012, 06:45 PM   #128
Groans: 121
Update:
Plug #1 was wet, the other three dry. All four plugs were fouled up bad. Fuel in all cylinders. I pulled the valve cover; cam timing is good, and the timing chain is still tighter than an accountant's asshole. I did discover that I put the gasket that goes on the valve cover for the VVT solenoid backwards. D'oh!
The Following 5 Users Say Thank You to silvapain For This Useful Post:
djuosnteisn (10-02-2012), Easter Bunny (10-02-2012), phate (10-02-2012), rfinkle2 (10-03-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 06:48 PM   #129
Groans: 98
wet from gas or oil?
WWW.SONICTUNING.COM
 Old 10-02-2012, 06:50 PM   #130
Eatin' Your Tuna
Haltech's Avatar
Groans: 218
Well, its nice to discover some little odd gremlins. Im excited to see you fire this fucker up with some fresh fuel. We're all waiting for this high compression beast to be the norm.
fire it up focker!
Prob fuel. No way that fucker can have oil in it.
Last edited by Haltech; 10-02-2012 at 06:50 PM. Reason: MSF Database - Automerged Doublepost
Haltech is online now   Reply With Quote
 Old 10-02-2012, 06:56 PM   #131
Groans: 121
I think fuel, but the smell wasn't strong and I'm not confident about my assessment.
The valve seals and guides were all replaced when the head was rebuilt, and the plug wells are all bone-dry.
One other thing I did notice: the annealing marks on the plugs go pretty far down the ground strap, almost to the plug threads. That's a sign that the plugs are too hot. How the hell the plugs can get that hot when they're completely fouled up is beyond me.
I'm going to put the plug gap back at 0.026" before I put them back in.
Last edited by silvapain; 10-02-2012 at 06:57 PM. Reason: MSF Database - Automerged Doublepost
Boosten Ya(josh) (10-02-2012), chimmike (10-03-2012), phate (10-02-2012)
 Old 10-02-2012, 07:19 PM   #132
Captain
Groans: 79
Start the car already.... the anxiety is driving me nuts.
www.permtuning.com
The Following 5 Users Say Thank You to djuosnteisn For This Useful Post:
btstarcher (10-02-2012), chimmike (10-03-2012), phate (10-02-2012), wolly6973 (10-06-2012), xhymer (10-02-2012)
 Old 10-02-2012, 07:37 PM   #133
Eatin' Your Tuna
Haltech's Avatar
Groans: 218
If you have the plugs drenched in fuel, the electrode will start igniting that fuel and you will end up with plug arching.
Close the gap and fire it up. You aren't using densos I hope? If so, chances are the porcelain has already cracked.
 Old 10-02-2012, 07:52 PM   #134
Groans: 121
Stock heat range NGKs. I went with stock heat range because I plan on running E85 or E50 on this engine.
CKP is properly timed.
Still have to drain E85 and put in 93.
Just because of that, I'm gonna have another cigarette...
Last edited by silvapain; 10-02-2012 at 07:52 PM. Reason: MSF Database - Automerged Doublepost
chimmike (10-03-2012), djuosnteisn (10-02-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 07:53 PM   #135
Eatin' Your Tuna
Haltech's Avatar
Groans: 218
Ok.. Get to work ninja.. We're all waiting for this success.
The Following 2 Users Say Thank You to Haltech For This Useful Post:
 Old 10-02-2012, 08:02 PM   #136
Speeeeeed
06Speed6's Avatar
Posts: 5,870   (View Stats)
Groans: 39
Higher compression will give me more mass airflow for a given RPM, but the MAF curve won't change.
Same mass airflow, higher compression.
Can you post a vid of it starting and running?
2006 Mazdaspeed 6
P&P, flow benched, head with welded EGR and +1mm inconel exhaust valves (260/200cfm @ .500"), Web Cams, Custom crankcase breather with integrated air/oil seperator, Custom 3/4" ID pan vac system, Blow through maf, Port matched IM, CNC AN-12 ORB block oil adapter, CP-e 88mm Stage 2 pistons, Pauter 22.5mm rods, ARP main, head, and crank studs, CP-e injector seals, Injector stud kit, Cometec 88mm 5 layer HG, Deatschworks flow tested matched injectors, DCR VVT, PTP 2250psi RV, Corksport front sway, Whiteline rear sway, AWR front/rear sway links, TT FMM, AWR 70d DMM, SU RMM, TT FRDM, CP-e RRDM, Autotech CDFP, DW65c ITFP, Custom L/A IC with a dual pass 20x25x1.5 heat exchanger, Dual Cobra I/C pumps, 3" ID 700hp I/A intercooler, ATP catless DP, Corksport catback, Corksport exhaust hangers, chrome plated genpu valve cover, chrome plated timing cover, CP-e whale penis, CP-e sri, Spin on oil filter, Fluidyne dual pass AN-12 oil cooler, Hayden oil cooler fan controller, Dual 4.7" SPAL oil cooler fans, Canton Racing 22-480 oil tstat, Custom BMRS AN-12 oil lines, SPC ball joints, 55w/35w headlights and independently switched fogs on custom waterproof harnesses, PIAA Super Plasma driving and interior lights, rear diff cutout switch, 3M clear front cover, Volk 17x7.5 wheels, Custom tcase bearing cap upgrade, 2007 MS6 p/s pump, GS EBC 3 port, Redline SS hood lift, Versatune, Defi gauges, Innovate MTX-L WB gauge, triple center gauge pod, Block8head dual vent pod, Redline shift boot & ebrake cover & arm rest cover, Mazdaspeed CF ebrake handle, Dashawk, ACL rod bearings, King main bearings, Cosworth BSD, Custom windage tray, Holset HX35w, Creative Performance T3 EWG manifold, HKS VTA BOV, A1 H11 head studs, Hylomar HG sealant
 Old 10-02-2012, 08:04 PM   #137
Analog Troll
Easter Bunny's Avatar
Posts: 1,568   (View Stats)
Groans: 1,510
Groaned at 45 Times in 34 Posts
Please don't do both at the same time.
Easter Bunny is online now   Reply With Quote
The Following 4 Users Say Thank You to Easter Bunny For This Useful Post:
djuosnteisn (10-02-2012), Nliiitend1 (10-02-2012), Speed_j23 (10-02-2012), wolly6973 (10-06-2012)
 Old 10-02-2012, 09:02 PM   #138
Groans: 121
Still not starting up yet. I have to get all the E85 out of the rail itself by cranking it.
djuosnteisn (10-03-2012), Speed_j23 (10-02-2012)
 Old 10-02-2012, 10:06 PM   #139
Groans: 121
Here's something interesting: Car hasn't fired up at all tonight, but I just tried starting it while lightly holding the gas pedal. Car fired up twice. As soon as I let off the gas, the car sputters and dies.
djuosnteisn (10-03-2012), phate (10-02-2012), Speed_j23 (10-02-2012)
 Old 10-02-2012, 10:12 PM   #140
Speeeeeed
06Speed6's Avatar
Groans: 39
I wonder if that is because it is still running rich and opening the TB up brings the AFR closer to stoich. Did you unplug the maf?
2006 Mazdaspeed 6
The Following 3 Users Say Thank You to 06Speed6 For This Useful Post:
 Old 10-02-2012, 10:16 PM   #141
Eth Fiend
phate's Avatar
Did it stay running with you holding the pedal a bit? I woulda been driving it if that was the case lolol.
06Speed6 (10-02-2012), djuosnteisn (10-03-2012), kabobulate (10-03-2012), Speed_j23 (10-02-2012)
 Old 10-02-2012, 10:34 PM   #142
Groans: 121
LOL. Yes; as long as I held the pedal the engine stayed running.
Yes. No change - car won't start.
Last edited by silvapain; 10-02-2012 at 10:34 PM. Reason: MSF Database - Automerged Doublepost
06Speed6 (10-02-2012), djuosnteisn (10-03-2012), Speed_j23 (10-02-2012)
 Old 10-02-2012, 10:37 PM   #143
Speeeeeed
06Speed6's Avatar
Groans: 39
Do you have a way to monitor AFR? As long as its rich let it run until it throws a code.
2006 Mazdaspeed 6
 Old 10-02-2012, 10:55 PM   #144
Groans: 121
After it fired up twice it won't start again.
disabled my WOT box to see if that was affecting startup. No change.
 Old 10-02-2012, 11:07 PM   #145
Speeeeeed
06Speed6's Avatar
Groans: 39
Damnit...
Alright so,
Cams are timed
Compression checks
CPS is installed correctly
Fuel has been swapped to 93
Fuel lines have been flushed
New plugs
Passed boost leak test.
All of the sensors are plugged in and the battery is charged?
2006 Mazdaspeed 6
 Old 10-02-2012, 11:18 PM   #146
Groans: 121
Damnit...
Alright so,
Cams are timed
Compression checks
New plugs
Haven't actually done a compression check yet (don't have a tester).
Battery is brand new, but voltage is low due to all the start attempts. I have my wife's car idling and the jumper leads attached to my battery to make sure there is enough charge. I've checked all sensor plugs that I can see.
Attached is a datalog of me trying to start the car.
djuosnteisn (10-03-2012), phate (10-03-2012)
 Old 10-03-2012, 12:14 AM   #147
jracer's Avatar
Posts: 1,678   (View Stats)
Groans: 85
The plug on the throttle body plugged in really good ? I hear it can cause some headaches.
2006 speed6~Cobb AP~COBB custom E-tune~CobbTIP-CobbSRI~CPeHPFP~ATPdp~Magnaflow exhaust~Denzo plugs~Forge bov~Matt Damon's Occ Kit~Treadstone FMIC~PG V1 Ex.Manifold~CPE safe seals~SU EGR block off plate~SURE TIG intake mani gasket~SU lower motor mount~AWR trans. mount/passenger mount~SU shifter bushings~CPE diff mount~H&R springs~Tenzo type M ~235/40/18 Firestone Indy 500 Wide Oval~ipod adapter~HD lip~Prosport boost gauge~ TWM Desert Eagle Shift Knob~JBR shift plate~spin on oil filter~Block8head Vent Pod~ported intake manifold w/ VTCS delete~EBC red pads w/ slotted rotors~4500k HID fogs 2 gal. E85 mix !!!
 Old 10-03-2012, 12:18 AM   #148
Groans: 121
Yes. The red plug lock is engaged.
 Old 10-03-2012, 01:12 AM   #149
ms6ms6's Avatar
Posts: 671   (View Stats)
ms6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond repute
Groaned at 7 Times in 6 Posts
Check all fuses and wotbox wire
ms6ms6 is offline   Reply With Quote
The Following User Says Thank You to ms6ms6 For This Useful Post:
 Old 10-03-2012, 01:49 AM   #150
Speeeeeed
06Speed6's Avatar
Groans: 39
Was the VCTS delete done during or before the build?
2006 Mazdaspeed 6
 Old 10-03-2012, 03:59 AM   #151
GLORIFIEDBOZO's Avatar
Posts: 1,930   (View Stats)
It was but it wasn't. He is using a borrowed manifold that still has it installed while his is being PC'd.
I don't suppose you have tried unplugging the spill valve and starting it? You might want to try swapping the plugs if you still have your old ones, it's a long shot but hey, and you could check compression while doing it, if I had thought there would be a need I would have brought my compression tester up to you.
djuosnteisn I know you had done some stuff with recording IDC, don't suppose you did any during cold cranking?
The Following User Says Thank You to GLORIFIEDBOZO For This Useful Post:
 Old 10-03-2012, 06:41 AM   #152
J-Liss's Avatar
Posts: 1,958   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
Silvapain, you are experieceing the EXACT same thing i was going through with my mazda 3,
1. my first issue, was, the TB was not working at all, take off your intake and put car in ACC mode and see if the plate is opening and closing.
2. was i had a HUGE leak in my intake manifold, once i installed the bolts in the correct order this went away, and now it starts up perfect.
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
The Following 14 Users Say Thank You to J-Liss For This Useful Post:
06Speed6 (10-03-2012), Boosten Ya(josh) (10-03-2012), djuosnteisn (10-03-2012), Easter Bunny (10-03-2012), GLORIFIEDBOZO (10-03-2012), Haltech (10-03-2012), lilred (10-03-2012), NJSPEED3 (10-04-2012), phate (10-03-2012), Pointless (11-16-2012), Realgib3 (10-03-2012), Speed_j23 (10-03-2012), Tomas (10-03-2012), wolly6973 (10-06-2012)
 Old 10-03-2012, 09:00 AM   #153
Eth Fiend
phate's Avatar
If it stays running while holding the pedal slightly, you may be able to alter the APP translation tables to hold the throttle open a bit at 0% APP. It would be a temporary work around, as it may [will] cause higher than normal idle. For break in, though, it would likely be fine so you can get things diagnosed and running properly.
I have a compression tester if you want me to drive up tonight.
Boosten Ya(josh) (10-03-2012), Easter Bunny (10-03-2012), J-Liss (10-03-2012), Speed_j23 (10-03-2012), Tomas (10-03-2012), wolly6973 (10-06-2012)
 Old 10-03-2012, 10:46 AM   #154
Veblen Goods
Tomas's Avatar
Posts: 2,332   (View Stats)
I don't think timing or fuel is the problem. The fact you have fuel inside all cylinders means you are spraying but for some reason the plugs aren't igniting the fuel. Even slightly fouled plugs have a horrible effect on this car including no starts. I learned that one the hard way after looking for short grounds over 10 hours and then finally just replacing the plugs with stock ones the car fired right up. A boost leak will make you run rich and will foul the plugs.
GHEY THUNDER
The Following 5 Users Say Thank You to Tomas For This Useful Post:
djuosnteisn (10-03-2012), Easter Bunny (10-03-2012), GLORIFIEDBOZO (10-03-2012), phate (10-03-2012), wolly6973 (10-06-2012)
 Old 10-03-2012, 10:52 AM   #155
J-Liss's Avatar
Groans: 81
2004 mazda 3-Daily
2008 mazda 6-Wife
 Old 10-03-2012, 11:03 AM   #156
Captain
Groans: 79
Na, never cared about start up, lol.
+1 on plugs. Maybe even pull plugs and let cylinders air out a bit.
www.permtuning.com
GLORIFIEDBOZO (10-03-2012), Tomas (10-03-2012)
 Old 10-03-2012, 11:10 AM   #157
Posts: 8,163   (View Stats)
Groans: 34
I am also in the replace plugs camp...years ago I put in some shitty octane booster in my car which somehow ruined my plugs....replaced them and car was back to normal.
I think there is such a thing as a perma fouled plug that will never work again and you may be there...just throw in some shitty AZ stock autolight plugs to see if they make a difference. That's what I ran until my Denso's came in.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The grind on was with a chick. Given the amount I had though, I should probably check in with friends to confirm... Her body was pretty tight, could've been a dude with a 6 pack tho...
Originally Posted by djuosnteisn on 5/28/13 View Post
I keep telling my wife that this is the last "mod" on the 6. She doesn't believe me...
I want to tackle the 3 already. The 6 is plenty exotic at this point lol.
Dano is online now   Reply With Quote
djuosnteisn (10-03-2012), GLORIFIEDBOZO (10-03-2012), Tomas (10-03-2012)
 Old 10-03-2012, 11:13 AM   #158
Will fuck up ur day
chimmike's Avatar
chimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the worldchimmike is the leader of the world
Groans: 418
Groaned at 206 Times in 122 Posts
check that intake manifold for a crack! In before massive crack on intake mani from rushed torque procedure?
07 MS3 bone stock?
The original Genpoo Hater
GTX3076r
FenderRollerRental Rent a fender roller, or MZR DISI Timing tools!
Originally Posted by woodfloor View Post
According to Roddiy, A List of Things as funny as fucking with MSF:
  1. Pissing in a bee hive
  2. Bridging the bus bars in an electrical panel with your dick
  3. Running with the bulls
  4. Willingly climbing into the lion habitat at the Zoo
  5. Shooting yourself in the foot on purpose
  6. Jumping up and down on a Fire Ant hill
@kyle undefined loves giving blowjobs to @raider; in truckstop bathrooms
chimmike is offline   Reply With Quote
The Following User Says Thank You to chimmike For This Useful Post:
Tomas (10-03-2012)
 Old 10-03-2012, 11:14 AM   #159
Groans: 121
Yeah, I've been thinking the same thing this morning. I just got back from the store with a set of Autolite XP5263's. Gonna throw those in.
Last night I blew all the fuel out of the cylinders and tried to start it up. Still didn't go.
I just checked the ground strap on the PMM - it was nice and tight, with no corrosion. Are there any other engine to chassis grounds?
GLORIFIEDBOZO (10-03-2012), Speed_j23 (10-03-2012), Tomas (10-03-2012)
 Old 10-03-2012, 11:38 AM   #160
Of course it was, I installed that bitch. Now if had been say, MATT DAMOND, you might have had something to worry about.
The Following 3 Users Say Thank You to GLORIFIEDBOZO For This Useful Post:
Easter Bunny (10-03-2012), silvapain (10-03-2012), Speed_j23 (10-03-2012)
Official: BMW spills all the beans on new 1 Series Haltech Automotive News 2 06-05-2011 11:30 AM
Saab spills at least a few beans about its forthcoming 9-5 [w/new pics] Haltech Automotive News 0 08-27-2009 07:30 AM
Page generated in 0.61943 seconds with 36 queries
