Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Notices
Like Tree97Likes
 Old 10-16-2012, 08:08 AM   #281
Unicorn Farts
Deldran's Avatar
Posts: 2,145   (View Stats)
Groans: 96
Groaned at 35 Times in 28 Posts
Yea thats nuts, need some fat sticky tires to get that to the ground
Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms
Deldran is online now   Reply With Quote
 Old 10-16-2012, 08:09 AM   #282
Eth Fiend
phate's Avatar
Posts: 4,276   (View Stats)
phate has disabled reputation
For the blowout - I always had trouble with full e85 when it got cold. Running a hotter plug helped, as did gapping them down a bit. I was running .024" gap at one point. Leaning the car out also helps, and it seemed to make the car run smoother. With the K04 and full E85, you should still have plenty of headroom to lean out without seeing knock. EGT's are the only worry.
I'd have to think the higher compression is only compounding the blowout issue. I have a boost-a-spark on my list of potential purchases.
-06 MS6 - Tuning the high compression forged mill
-Corn fed 07 MS3 - Sold
phate is online now   Reply With Quote
rfinkle2 (10-16-2012), silvapain (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 08:25 AM   #283
Posts: 5,629   (View Stats)
Groans: 121
I'm running NGK stock heat range plugs gapped to 0.026", and my AFR targets at WOT are 0.86 lambda (12.63 on the pump gas scale). I'll drop the gap down to 0.024" and see if that helps.
Oh, and an EGT gauge will be replacing the beard length gauge eventually.
silvapain is online now   Reply With Quote
J-Liss (10-16-2012), rfinkle2 (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 08:39 AM   #284
Captain
djuosnteisn's Avatar
Posts: 11,192   (View Stats)
Groans: 79
I would pull even more timing based on those logs, and really vet each increase in spark advance, either by lots of v-dyno on the same road, or even a real dyno at some point.
500awhp 440awtq uncorrected
BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning.
Mounts be popping, and trans be hurting
Check out the hair Salon:
www.permtuning.com
The Following 5 Users Say Thank You to djuosnteisn For This Useful Post:
charlesfist (10-19-2012), rfinkle2 (10-16-2012), silvapain (10-16-2012), SPEED6 KILLAH (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 09:00 AM   #285
Eth Fiend
phate's Avatar
Agreed. I just looked at the logs more thoroughly. That's taking a huge risk running that much timing on this new hardware setup without dyno time. My feeling is that it might be OK, but it's not worth risking when you have dyno time scheduled less than two weeks from now.
charlesfist (10-19-2012), djuosnteisn (10-16-2012), Nliiitend1 (10-16-2012), Rokusek (10-16-2012), silvapain (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 09:05 AM   #286
Groans: 121
I have retarded WOT timing 2 degrees across the board since those runs. I'm open to your expert opinions on if that's sufficient to start with.
djuosnteisn (10-16-2012), Nliiitend1 (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 09:09 AM   #287
rfinkle2's Avatar
Posts: 12,564   (View Stats)
Groans: 235
I can't explain why, but I've seen blowout on these cars cause the afr's to lean out (vs. traditionally rich PI blowout), much like your logs where you describe possible blowout.
CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R)CPE HPFP CPE RMMCPE FMICCPE TOW PLATE CPE TRITON CBE HTP 3" TIP HTP BATTERY RELOCATECOBB APGRIMMSPEED 3 PORT BCSCOOLING MIST / DEVILS OWN METHANOL INJECTIONDEFI Boost gauge TWM FULL REPLACMENT TWM M1 ABRAMSJBR SSP JBR RSB JBR TIG H&R COILOVERSJUMPING JACKSON 3 BAR MAP HARNESSSTOPTECH STAINLESS LINESAKEBONO EURPO 915aTANABE STRUT BRACENEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KITGRAM LIGHTS 57 DRTOYO PROXES PLUS
The Following 7 Users Say Thank You to rfinkle2 For This Useful Post:
charlesfist (10-19-2012), Dano (10-16-2012), djuosnteisn (10-16-2012), phate (10-16-2012), Rokusek (10-16-2012), silvapain (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 09:28 AM   #288
Captain
Groans: 79
Blow out = no combustion... = unburnt fuel and oxygen going into the exhaust... and that unburnt oxygen will register on the AFR sensor as lean.
www.permtuning.com
The Following 12 Users Say Thank You to djuosnteisn For This Useful Post:
06Speed6 (10-16-2012), charlesfist (10-19-2012), Dano (10-16-2012), Easter Bunny (10-16-2012), J-Liss (10-16-2012), ms3blackmica (10-16-2012), Realgib3 (10-16-2012), rfinkle2 (10-16-2012), Rokusek (10-16-2012), silvapain (10-16-2012), SPEED6 KILLAH (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 10:08 AM   #289
Posts: 8,038   (View Stats)
Groans: 34
I sure hope when I grow up I'll be 1/2 as smart as Dustin...
just 1/2 is all I need....well that and a larger cock...so 1/2 as smart and a larger cock is all I need.....and this lamp....this lamp, a larger cock and 1/2 his smarts is all I need.
silvapain and Rokusek like this.
PERM
07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
The hardest part of modding is knowing when you've met your goal
I dunno though; it sounds good in my head but I'm mostly talking out of my ass.
Dano is online now   Reply With Quote
The Following 21 Users Say Thank You to Dano For This Useful Post:
06Speed6 (10-16-2012), 802MS3 (10-19-2012), Alpha (10-16-2012), amoosenamedhank (10-16-2012), btstarcher (10-16-2012), charlesfist (10-19-2012), djuosnteisn (10-16-2012), Easter Bunny (10-16-2012), GLORIFIEDBOZO (10-16-2012), GODspeed7 (10-16-2012), J-Liss (10-16-2012), lilred (10-16-2012), mazdafreak (10-17-2012), phate (10-16-2012), Realgib3 (10-16-2012), rfinkle2 (10-16-2012), Rokusek (10-16-2012), silvapain (10-16-2012), Speed3eak (10-19-2012), wolly6973 (10-16-2012), xI Leveler Ix (10-20-2012)
 Old 10-16-2012, 06:52 PM   #290
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,781   (View Stats)
Exactly what I was thinking...
Personally, I would pull an additional 2° (beyond the 2° already pulled) until you can map out MBT on a dyno.
Guessing on something this critical is silly with your sweet setup...
08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E30 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071)
The Following 8 Users Say Thank You to cld12pk2go For This Useful Post:
charlesfist (10-19-2012), djuosnteisn (10-17-2012), J-Liss (10-17-2012), ms3blackmica (10-16-2012), rfinkle2 (10-17-2012), silvapain (10-16-2012), Speed_j23 (10-16-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 07:59 PM   #291
Groans: 121
Agreed. I did just what you suggest (pulled an extra 2°) after talking with Dustin via PM. Attached is a WOT log in 4th with the 4° retarded timing. I'm confident my timing isn't past MBT now; car felt noticeably slower with the retarded timing.
The Following 8 Users Say Thank You to silvapain For This Useful Post:
atvfreek (10-19-2012), charlesfist (10-19-2012), cld12pk2go (10-17-2012), djuosnteisn (10-17-2012), J-Liss (10-17-2012), ms3blackmica (10-16-2012), rfinkle2 (10-17-2012), wolly6973 (10-16-2012)
 Old 10-16-2012, 09:53 PM   #292
can't take out voltron
ms3blackmica's Avatar
Posts: 3,859   (View Stats)
Your absolutely right DJ.
This is how i knew i was getting spark blowout (besides the apparent popping/stutter). Every time I would log it, id see lean spikes in the AFR.
Great piece of info for anyone to know
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
djuosnteisn (10-17-2012), rfinkle2 (10-17-2012)
 Old 10-18-2012, 09:20 PM   #293
Groans: 121
Finally had time to pull the plugs. They look pretty good to me. Attached are a couple pics of the #1 plug.
The Following 4 Users Say Thank You to silvapain For This Useful Post:
atvfreek (10-19-2012), charlesfist (10-19-2012), rfinkle2 (10-19-2012), wolly6973 (10-19-2012)
 Old 10-18-2012, 11:46 PM   #294
SPEED6 KILLAH's Avatar
Posts: 1,042   (View Stats)
Did you add octane booster in the gas?
SPEED6 KILLAH is offline   Reply With Quote
The Following User Says Thank You to SPEED6 KILLAH For This Useful Post:
 Old 10-18-2012, 11:51 PM   #295
Groans: 121
You referring to the brownish-red color if the insulator? I did add octane booster back when I was first trying to get it running, in an attempt to revitalize the old gas. I have not used any since; I don't trust that crap. There might have been some left in the lines.
Edit: to clarify, I drained the gas with the octane booster before I got the car running, so any octane booster that I ran would've been from what was in the rail and leftover in the tank.
atvfreek (10-19-2012), rfinkle2 (10-19-2012)
 Old 10-19-2012, 06:21 AM   #296
Alpha's Avatar
Posts: 3,426   (View Stats)
Groaned at 66 Times in 49 Posts
Been crunching numbers on a BorgWarner Turbo MatchBot, and the EFR 7670 is looking good to me...
BorgWarner MatchBot
I know Geoff at Full-Race says the bigger B2 frame turbos won't fit in the 3, but I'm not sure exactly why. If you line up the exhaust flanges on the EFR 7670 with the GTX 3076, it looks like there should be enough room for the downpipe; the battery would just have to be removed for added space for the compressor wheel.
Trust me, the production 7163 will dominate the 7670 on the street. No sense in losing spool and bottom/midrange torque when you're not gonna make over 600HP. The production 7163 will also flow 15% more than my prototype... And my turbo's no slouch.
They basically designed the 7163 for us... Space limited engine bays that want B2 flow.
You'll love it.
PERM Tuned - EFR 7163 Street Sleeper
Alpha is online now   Reply With Quote
The Following User Says Thank You to Alpha For This Useful Post:
Jh8909 (10-19-2012)
 Old 10-19-2012, 06:26 AM   #297
Eth Fiend
phate's Avatar
You'll love it.
The beauty of high compression is that we can run the bigger turbos without losing much spool time. One of my main reasons for going that route.
aggierandy (10-19-2012), rfinkle2 (10-19-2012), Rokusek (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 06:28 AM   #298
Alpha's Avatar
Right, but the 7670 won't fit.
You'd need a custom mounted 8374 to outperform this turbo... If you want to stick with an EFR
 Old 10-19-2012, 06:35 AM   #299
Eth Fiend
phate's Avatar
Everything I'm doing will be custom, not sure about silva.
I considered the 8374, but after seeing comparisons to the other 'new age' turbos, I decided they really aren't for me. No one races at 2000 or 3000 rpm, so it's not a legitimate argument for what I do. No sense in spending the money on something I won't utilize.
The Following 8 Users Say Thank You to phate For This Useful Post:
aggierandy (10-19-2012), Alpha (10-19-2012), charlesfist (10-19-2012), Easter Bunny (10-19-2012), J-Liss (10-19-2012), Realgib3 (10-19-2012), rfinkle2 (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 06:38 AM   #300
Alpha's Avatar
Absolutely. They really shine on street cars that are daily driven.
All out racing/ET I'm sure levels the field.
 Old 10-19-2012, 06:43 AM   #301
Eth Fiend
phate's Avatar
We shall see. I believe we still have a little WWP competition for next year? lol
Alpha (10-19-2012), silvapain (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 06:43 AM   #302
Groans: 121
I see every traffic light as a Christmas Tree.
I vacillate back and forth on what turbo I want to run.
Nliiitend1 (10-19-2012), phate (10-19-2012), rfinkle2 (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 07:01 AM   #303
rfinkle2's Avatar
Groans: 235
I feel your silvapain.
silvapain likes this.
The Following 5 Users Say Thank You to rfinkle2 For This Useful Post:
Dano (10-19-2012), J-Liss (10-19-2012), Micha (02-21-2013), Nliiitend1 (10-19-2012), silvapain (10-19-2012)
 Old 10-19-2012, 07:22 AM   #304
BigjohnB20's Avatar
Posts: 685   (View Stats)
BigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the worldBigjohnB20 is the leader of the world
LOL finkle you are the worst.
2006 BCM MS6 GT
CS SRI/TIP
Jbarone SSP/bushings
cp-e RMM, TMIC, Stiff Diff
AP
KMD V2.whatever
Ebay Catless DP
Grom Ipod
BigjohnB20 is offline   Reply With Quote
The Following 3 Users Say Thank You to BigjohnB20 For This Useful Post:
J-Liss (10-19-2012), rfinkle2 (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 07:35 AM   #305
Alpha's Avatar
I'm down
You gonna be on AUX fueling? I'm gonna rockin stock injectors for a little while.
 Old 10-19-2012, 07:38 AM   #306
psn boostenya
Boosten Ya(josh)'s Avatar
Posts: 3,953   (View Stats)
Boosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the worldBoosten Ya(josh) is the leader of the world
Groans: 40
Groaned at 15 Times in 13 Posts
08 Mazdaspeed 3
Fucking FREEK TUNED and shit
Boosten Ya(josh) is offline   Reply With Quote
The Following 13 Users Say Thank You to Boosten Ya(josh) For This Useful Post:
802MS3 (10-19-2012), atvfreek (10-19-2012), Dano (10-19-2012), Easter Bunny (10-19-2012), J-Liss (10-19-2012), Nliiitend1 (10-19-2012), Pendarus (10-19-2012), phate (10-19-2012), psychophyr (10-19-2012), rfinkle2 (10-19-2012), Rokusek (10-19-2012), silvapain (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 09:08 AM   #307
GODspeed7's Avatar
Posts: 2,632   (View Stats)
Groaned at 46 Times in 31 Posts
I had to do a double take and re-read that but I see what you did there. Your pretty witty there Rob...
Tapatalk LIKE A BOSS!
Originally Posted by Boosten Ya(josh) View Post
My wife gets pissed when I am not the first one off the line at a red light. It's almost like a sign of automobile dominance and superiority. "My masculinity has been challenged. Challenge accepted!"
2012 Mazdaspeed3 Black Mica
HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete.
Last edited by GODspeed7; 10-19-2012 at 09:08 AM. Reason: MSF Database - Automerged Doublepost
GODspeed7 is online now   Reply With Quote
The Following 2 Users Say Thank You to GODspeed7 For This Useful Post:
lilred (10-19-2012), rfinkle2 (10-19-2012)
 Old 10-19-2012, 09:24 AM   #308
psn boostenya
Groans: 40
launch at 4k Everytime
08 Mazdaspeed 3
The Following 2 Users Say Thank You to Boosten Ya(josh) For This Useful Post:
J-Liss (10-19-2012), Speed_j23 (10-19-2012)
 Old 10-19-2012, 11:08 AM   #309
J-Liss's Avatar
Posts: 1,957   (View Stats)
J-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the worldJ-Liss is the leader of the world
Groans: 81
ahem....
2004 mazda 3-Daily
2008 mazda 6-Wife
2008.5 Mazdaspeed 3 totaled
1983- FB Rx-7 Soon to be boosted Carb epicness
Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler
J-Liss is offline   Reply With Quote
 Old 10-19-2012, 11:37 AM   #310
Eth Fiend
phate's Avatar
Originally Posted by J-Liss View Post
ahem....
no spinning triangles allowed...we'd hate to embarrass anyone.
aggierandy (10-19-2012), GLORIFIEDBOZO (10-22-2012), J-Liss (10-23-2012), Speed_j23 (10-19-2012)
 Old 10-22-2012, 07:03 AM   #311
Groans: 121
I believe I'm getting blowout at higher boost levels. I'm going to buy a set of stock heat range Autolite XP's (XP5364) and swap them in to see if the little bit of octane booster I used ruined my current NGK's. If that doesn't work, I'm open to suggestions.
I looked into the HKS and Kenne Bell BAS units, and all they do is allow the coils to charge quicker. Has anyone used the WeaponX coils with success?
djuosnteisn (10-23-2012), wolly6973 (10-23-2012)
 Old 10-22-2012, 07:23 AM   #312
Posts: 10,145   (View Stats)
Groans: 98
the weaponX coils are garbage and the KB BAP doesent work.
the HKS units work, ive done back to back runs with blowout and was able to eliminate them just plugging in the HKS.
You also need to close your gap more if this doesent help.
KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Web Cams w/Tomas Grind ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ Squash Performance In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust
510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs
WWW.SONICTUNING.COM
Certified RichTune e-Tuner
KILLAH BUILT by SPEED PERF6RMANC3
I could cry right now im so proud of you.
Rokusek (10-22-2012), silvapain (10-22-2012), wolly6973 (10-23-2012)
 Old 10-22-2012, 07:31 AM   #313
Groans: 121
My plug gap is already down to 0.022". Any closer, and the electrode and ground strap may as well be welded together.
djuosnteisn (10-23-2012), superskaterxes (10-22-2012)
 Old 10-22-2012, 07:37 AM   #314
Groans: 98
what turbo is this on? and what boost level?
WWW.SONICTUNING.COM
 Old 10-22-2012, 07:38 AM   #315
Groans: 121
K04 on 23psi.
 Old 10-22-2012, 07:40 AM   #316
Groans: 98
K04 on 23psi.
i would highly doubt its really spark blowout then. what leads u to believe it is?
WWW.SONICTUNING.COM
 Old 10-22-2012, 07:41 AM   #317
Groans: 34
maybe its the angry pistons?
PERM
 Old 10-22-2012, 07:42 AM   #318
Groans: 121
The way the car is shuddering at WOT. I've had spark blowout before when I was running colder plugs on 100% E85.
 Old 10-22-2012, 07:45 AM   #319
fastest 3-cyl MS3
btstarcher's Avatar
Posts: 1,689   (View Stats)
What temp rating plugs are you using again? With higher compression, should we still be using the same guidelines?
JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD
Dizzy Tuned by Boost_creep in progress
hopefully soon: GTX2867R or GTX3076R
 Old 10-22-2012, 07:49 AM   #320
Eth Fiend
phate's Avatar
Full E85 is a completely different animal, even at these pressures.
No, you prob don't want to go by the typical guidelines. As with any performance setup, you want to get actual readings from the plugs and change heat range from there.
Last edited by phate; 10-22-2012 at 07:49 AM. Reason: MSF Database - Automerged Doublepost
btstarcher (10-22-2012), djuosnteisn (10-23-2012), J-Liss (10-23-2012), silvapain (10-22-2012), Speed_j23 (10-22-2012), wolly6973 (10-23-2012)
Official: BMW spills all the beans on new 1 Series Haltech Automotive News 2 06-05-2011 11:30 AM
Saab spills at least a few beans about its forthcoming 9-5 [w/new pics] Haltech Automotive News 0 08-27-2009 07:30 AM
Page generated in 0.59412 seconds with 36 queries
