![]() | | #41 | ![]() |
![]() Join Date: Apr 2011 Location: Bucks county (bristol),pa
Rep Power: 1018 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 626
(Thread Starter) | Not Ranked : 0 score Map Scalar B: 0.24 Map Scalar Offset: -17.06 |
| The Following 3 Users Say Thank You to dturboman For This Useful Post: |
![]() | | #42 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 44517 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,845
Groaned at 26 Times in 22 Posts
__________________ I'm doing it wrong, just ask all the other Mazda DISIs making 700+HP ![]() | |
| The Following User Says Thank You to Erich For This Useful Post: | dturboman (08-21-2012) |
![]() | | #43 | ![]() |
4 bar tune update - Made 470 @5600 rpm on 27 lbs no meth and mild timing but then went lean so the run ended early and now have a misfire, looking like an injector at this point... I will know more tomorrow. if anyone has an injector let me know Last edited by dturboman; 08-23-2012 at 08:46 PM. |
| The Following 5 Users Say Thank You to dturboman For This Useful Post: | 802MS3 (08-23-2012), atvfreek (08-23-2012), Easter Bunny (08-24-2012), jracer (08-24-2012), NJSPEED3 (08-23-2012) |
![]() | | #44 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Rockville, md
Rep Power: 10081 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,769
Groans: 98
are those 4 bar settings confirmed? for the entire measurement range?
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust 510awhp/473awtq ~ 11.30@125.5 1.730 60' 3455 lbs WWW.SONICTUNING.COM Certified RichTune e-Tuner KILLAH BUILT by SPEED PERF6RMANC3 |
![]() | | #45 | ![]() |
![]() | | #46 | ![]() |
| My AP logs approximately matched what the dyno recorded all the way up to 43 PSI.
| The Following 2 Users Say Thank You to Erich For This Useful Post: | dturboman (08-23-2012), Easter Bunny (08-24-2012) |
![]() | | #47 | ![]() |
![]() | | #48 | ![]() |
Dyno sheet update. Correction 28psi... shit went south right around 5500 and that was the end of the run. was on its way to the 500's with only mild timing. Last edited by dturboman; 08-24-2012 at 03:41 PM. |
| The Following 4 Users Say Thank You to dturboman For This Useful Post: |
![]() | | #49 | ![]() |
Cleaning up the tune. 28PSI target, mild timing up top (14.5), meth is now in play, still ending runs about 1k early.. should be an easy 550+ on an aggressive 28psi tune. Full timing and runs will hold strong power in the 7k range. 35psi and 40psi still coming in the next few weeks FYI - low 60's IDC boost is coming on much sooner ![]() lost boost signal in the middle of run 53 all uncorrected smoothing 3 Last edited by dturboman; 09-14-2012 at 06:51 PM. |
| The Following 6 Users Say Thank You to dturboman For This Useful Post: | 802MS3 (09-15-2012), atvfreek (10-03-2012), BlueStreak (09-14-2012), Easter Bunny (09-14-2012), kilik2 (09-15-2012), PapaSmurf (09-15-2012) |
![]() | | #50 | ![]() |
![]() Join Date: May 2010 Location: Albuquerque, NM
Rep Power: 4673 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,494
Groans: 89
Groaned at 56 Times in 30 Posts
cant wait to see this bitch hit the track.
__________________ Twinscroll GT3582R 3M Matte Blue Metallic Wrapped PERM Tuned/Built Genpu Dragon 565whp/543wtq corrected at 5500ft asl 476whp/458wtq uncorrected at 5500ft asl |
| The Following User Says Thank You to PapaSmurf For This Useful Post: | dturboman (09-14-2012) |
![]() | | #51 | ![]() |
| Hair by Voltron ![]() Join Date: Feb 2009 Location: Hillsborough, NJ
Rep Power: 146634 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 51,478
Groans: 1,406
Groaned at 311 Times in 293 Posts
We'll run next to each other
__________________ ![]() 11.91 @ 122.48 1.85 60' - 12/4/11 - Atco Raceway 11.85 @ 119.69 1.75 60' - 4/15/12 - Mason Dixon Dragway For Sale Section Rules UPDATED 5-17-2013! Please read before posting! |
| The Following 2 Users Say Thank You to doubleflusher For This Useful Post: | dturboman (09-14-2012), Monotonous ONE (10-04-2012) |
![]() | | #52 | ![]() |
| The Following 4 Users Say Thank You to dturboman For This Useful Post: | 802MS3 (09-15-2012), doubleflusher (09-14-2012), Downmented (09-15-2012), Monotonous ONE (10-04-2012) |
![]() | | #53 | ![]() |
Groans: 1,406
| The Following 3 Users Say Thank You to doubleflusher For This Useful Post: |
![]() | | #54 | ![]() |
![]() | | #55 | ![]() |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 817 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,556
Holy fuck me man, i just seen this and its insane.
__________________ 2010 MS3 SOLD 2006 MS6 WWP fully loaded Eagle rods, Wiseco pistons .020, cast topmount mani, catless dp, 4in intake, custom fmic, treadstone tr1035, pte 6262, turbosmart 38mm wastegate, 3.5bar map, egr delete, occ, e cutout, turbosmart vta bov, autotech hpfp, full awr motor mount 88duro, cpe rear diff, turbine tech diff mount, denso itv24, ported stock mani, 06speed6 clutch/flywheel, turbosmart boost t, aux fan controller, motor craft tranny jiz, neo liquid gold |
![]() | | #56 | ![]() |
Groans: 89
| The Following User Says Thank You to PapaSmurf For This Useful Post: | dturboman (09-15-2012) |
![]() | | #57 | ![]() |
hmm started to compare the logs to the runfiles. run 53 and 58 were lifted around 5100rpm right where boost dropped... I guess the dyno keep reading. 59 was lifted around 6200. looking like 32-34psi will get us to 600 and hopefully 40ish gets us close to 700 run 53 and 59 |
| The Following 2 Users Say Thank You to dturboman For This Useful Post: | atvfreek (10-03-2012), Easter Bunny (09-15-2012) |
![]() | | #58 | ![]() |
| rabble rabble ![]() Join Date: Aug 2008 Location: Burlington, VT
Rep Power: 2525 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,549
Groans: 189
Groaned at 102 Times in 55 Posts
so you got the dnp mani, atp iwg hotside? and 4 nozzles in the IM, and a D10 in the cold pipe? how big is your meth tank lol
__________________ '08 White MS3 w/ ported ATP 3071r, fat tires, and other sheit. No Meth or E. hit up NJSPEED3 so he can port yo intake mani! |
![]() | | #59 | ![]() |
looking to add a 2nd wastegate now. dual d07 in cold pipe, 4 D04 in the manifold. 1 gallon tank. it actually lasts longer than I expected. it wont see much street time so I"m not worried about meth tank size. | |
| The Following 2 Users Say Thank You to dturboman For This Useful Post: | 802MS3 (09-15-2012), Easter Bunny (09-15-2012) |
![]() | | #60 | ![]() |
| Veblen Goods ![]() Join Date: Jan 2009 Location: Dania Beach, FL
Rep Power: 2255 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,474
| Not Ranked : 0 score As in parallel to the current one? If so why? Boost creep? Or as in twin scroll where one is on cyl 1/4 and and the other on 2/3?
__________________ ![]() GHEY THUNDER |
![]() | | #61 | ![]() |
| The Following User Says Thank You to dturboman For This Useful Post: | Tomas (09-15-2012) |
![]() | | #62 | ![]() |
Shit dude. Could have gone twin scroll if you are gonna have 2 wgs. What size is the current one? Can't u use a Tial 60? BTW 160K on stock rods and 30+ psi is epic. How did the old pistons look like? any pitting? I am planning on only doing eagle rods and using Pu pistons. There have been a few piston failures but they are uncommon and probably due to failure of the system somewhere. Not lack of material aptitude.
| The Following User Says Thank You to Tomas For This Useful Post: | dturboman (09-15-2012) |
![]() | | #63 | ![]() |
the stock pistons looked good, no pitting but 2 were cracked very minor. | |
![]() | | #64 | ![]() |
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4
Groaned at 19 Times in 12 Posts
| The Following User Says Thank You to greg08 For This Useful Post: | dturboman (09-15-2012) |
![]() | | #65 | ![]() |
| SPEED PERF6RMANC3 ![]() ![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 2138 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,463
Groans: 288
Groaned at 59 Times in 40 Posts
Hold the Fucking phone, you are doing all this on stock internals? Or am I missing something?
__________________ //KILLAH BUILT, SPEED PERF6RMANC3// Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate. KILLAH BUILT //Richtune by Skater // Nuffsaid
| The Following 2 Users Say Thank You to Downmented For This Useful Post: | dturboman (09-15-2012), NoLeftTurn (09-15-2012) |
![]() | | #66 | ![]() |
| Utahmazdas.com ![]() Join Date: Feb 2009 Location: Utah
Rep Power: 219 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 241
You're missing something, did you read the op's first post? built motor more powa.
__________________ |
| The Following User Says Thank You to Snyeed For This Useful Post: | dturboman (09-15-2012) |
![]() | | #67 | ![]() |
![]() | | #68 | ![]() |
Little tease of a new run file ![]() and this |
| The Following 15 Users Say Thank You to dturboman For This Useful Post: | atvfreek (10-03-2012), Black Metal (10-03-2012), bwspeed (10-03-2012), Dano (10-05-2012), Easter Bunny (10-03-2012), EdgeAutosport.com (10-03-2012), Harvey PU (10-11-2012), jracer (10-04-2012), lilred (10-03-2012), Manny (10-04-2012), Monotonous ONE (10-03-2012), PapaSmurf (10-04-2012), rfinkle2 (10-03-2012), Seatime3 (10-03-2012), Voltwings (10-03-2012) |
![]() | | #69 | ![]() |
Rep Power: 12121 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43,322
Groans: 235
LOL!
| The Following User Says Thank You to rfinkle2 For This Useful Post: | atvfreek (10-03-2012) |
![]() | | #70 | ![]() |
Rep Power: 8691 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 20,458
Groans: 31
Groaned at 19 Times in 16 Posts
Oh damn! That mani looks bad ass! Looks like you will be good to go for the dyno too.
__________________ 2010 Speed3---GTX2867 // SURE 3" Intake // HTP 3" inlet pipe // Ultimate Racing DP/TP // Corksport CBE // KMD v2.1 hpfp internals // Devils Own WMI // COBB FMIC // 3bar map sensor // GFB dual port BPV // JBR 70 duro RMM // MD Dual OCC // Drag DR-34 18x8 // Nitto Neo-gen 235/40 r18 // NJSPEED3 Ported Intake Manifold // JBR TIGS Perm Tune by the Freek ![]() 417hp/395tq 12.903@117.33 Street tires and shitty 2.25 60ft |
![]() | | #71 | ![]() |
| The Following User Says Thank You to dturboman For This Useful Post: | atvfreek (10-03-2012) |
![]() | | #72 | ![]() |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 955 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 686
Groans: 322
Groaned at 44 Times in 29 Posts
Clean up that valve cover man! Don't make that beautiful IM sit by that thing! I wanna see that curve!
__________________ 2007 Sunlight Silver MS3 GT CP-E SRI / CP-E TIP / Cobb AP Stage 1 / JBR 88 RMM, SSP, SSB, Heavy Knob / Turbosmart Dual Port BOV 50/50 / Autotech internals / CNT Racing CBE _______________________________________________ Sitting in my garage: FMIC (CX Racing piping TR8L core) |
![]() | | #73 | ![]() |
![]() | | #74 | ![]() |
![]() Join Date: Nov 2010 Location: Houston
Rep Power: 1211 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,691
Groaned at 34 Times in 14 Posts
is that just a vacuum block you're running your meth through? Im not familiar with the set up, nor those 90* nozzles but its a pretty slick set up man, i'd be interested to see if theres more air or methanol going into your cylinders at any one time haha.
__________________ GTx3576, 93 + Direct Port Meth - Self Tune in progress... Custom 4" intake // TurboXS 3" catless DP -> CS 80mm Race pipe -> UR 3" catback // Custom eBay/Treadstone TR8L FMIC // Superskaters 75mm throttle body // CP-E EWG Manifold - Precision 46mm wastegate // CP-E HPFP // DW ITFP // Grimmspeed 3-port EBC // Custom Vented OCC // NGK Iridium IX // Turbo smart Dual-Port BOV // JBR Manifold - Throttle body TIG's - coolant bypass // TRZ Rmm // JBR Rear Sway Bar. Limitless Performance and Fabrication Built: K1 rods // Stock bore - compression Wiseco pistons // OEM Rod Bearings // Main Bearings // ARP Main - Head Studs // Spec stage 3+ full faced clutch // Ported intake manifold tapped for direct port meth. TEAM LBN BEERS, GET WELL SOON BUDDY -- FYCN |
![]() | | #75 | ![]() |
Each cyl will see about 400cc - 475cc of pure meth ( depending on nozzle at the time) @ 250psi.. which is enough to support a 240-300hp engine purely off the meth. | |
![]() | | #76 | ![]() |
![]() Join Date: Jan 2012 Location: Sutton, Massachusetts
Rep Power: 846 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 29 Times in 11 Posts
| Not Ranked : 0 score I've been mulling this set up for awhile. Obviously the MAP sensor won't pick up the BAT difference correct? The 02 sensors take care of the tuning aspect but meth failure is the scary failure, particularly if only one nozzle fails. Even if you have a pre-throttle body nozzle, would be enough to cover?
__________________ 08.5' MS3 GT www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
![]() | | #77 | ![]() |
true one nozzle could fail from a clog, but with good quality filtered meth it won't be much of a concern, the pump dying would be more my worry if anything. | |
![]() | | #78 | ![]() |
![]() Join Date: Feb 2009 Location: gilbert, az
Rep Power: 1932 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,009
Groans: 256
Groaned at 85 Times in 42 Posts
__________________ 2009 Mazdaspeed 3: GT3076 - Corkey tuned Treadstone 3" MAF, HTP 3" turbo inlet, hallman pro rx bc, MSCBE, Turbo XS FMIC, CNT catted DP, CP-E HPFP, Turbosmart Hybrid bpv, SURE TIG's + coolant bypass, ITV24's, CP-E 75d RMM, Medefail Tranny mount, DDM 35W 6000K HID's, SURE Counterweight, 18x8 245/40 NT-05's up front, R: 225/45 Sport Maxx TT's 390whp/400wtq |
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 06:20 AM |
| New build? | forcedinduktion | Computers & Technology News | 2 | 12-08-2010 08:24 PM |
| Chrysler to build plug-in Ram test fleet, won't build Two Mode hybrid pickup | Haltech | Automotive News | 0 | 03-22-2010 09:10 PM |
| Theory: Build before Build | demonspeed | MazdaSpeed 6 - Engine, Transmission & Driveline | 5 | 02-10-2009 05:52 PM |
| Build-a-Bull: Automobile mag helps build the first production Lambo LP560-4 | Haltech | Automotive News | 0 | 04-01-2008 04:20 PM |
