![]() | | #1041 | ![]() |
| Must Have Teh 10's! ![]() ![]() Join Date: Mar 2008 Location: Columbia, MD
Rep Power: 10779 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,334
| Not Ranked : 0 score
__________________ 2006 Mazdaspeed 6 GT Black Mica #4126 KILLAH Built/SPEED PERF6RMANC3 (SP) 10.6:1 Pistons ~ SP 11mm H11 Head Studs ~ K1 rods ~ SP CNC Head Work ~ Crower 65lb Valve Springs ~ Fully Keyed/Pinned Motor ~ GTX35R w/Tial .82AR Hotside ~ JMF IM w/1000cc PI Injectors ~ SP 75mm TB ~ SP In-Tank FP w/Dual DW300's ~ AEM FPR ~ SP Custom PI Fuel kit ~ CPE 4" MAF ~ CPE SAFEseals ~ TR1035 FMIC ~ CPE Atmosphere DP/Ex Manifold/Oil/Water Lines ~ Tial MV-R EWG VTA'd ~ Denso ITV-24's ~ CPE Dual CBE ~ CPE BT TIP ~ CPE RMM ~ JBR TMM ~ JBR PMM ~ TTFMM ~ CPE RDM ~ Sonic Tuning CO's ~ LED Tails ~ Sonic Tuning HID's ~ Whiteline RSB ~ ACT 6 Puck w/unicorn dust First K04 in the 12's First MS6 in the 11's Certified RichTune E-Tuner | |
| The Following 10 Users Say Thank You to superskaterxes For This Useful Post: | atvfreek (03-12-2013), BlueStreak (03-12-2013), breakfasteatre (03-12-2013), cld12pk2go (03-16-2013), CosmicArkie (03-12-2013), Downmented (03-15-2013), Easter Bunny (03-12-2013), Micha (03-29-2013), phate (03-12-2013), Ziggo (03-12-2013) |
![]() | | #1042 | ![]() |
| The Following 6 Users Say Thank You to Dano For This Useful Post: | ASHMS3 (03-12-2013), atvfreek (03-12-2013), Downmented (03-15-2013), phate (03-12-2013), superskaterxes (03-12-2013), Ziggo (03-12-2013) |
![]() | | #1043 | ![]() |
![]() Join Date: Sep 2008 Location: Toronto, Ontario, Canada
Rep Power: 2202 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,767
| Not Ranked : 0 score There are two bolts on the bottom of the rear main seal that bolt into the back of the girdle. Need to pull transmission and clutch for that.
__________________ '07 CWP MS3 Forged. |
| The Following 4 Users Say Thank You to BlueStreak For This Useful Post: |
![]() | | #1044 | ![]() |
![]() Join Date: May 2011 Location: Valdosta GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,861
Groans: 126
| Not Ranked : 0 score If you've got the money to do a new LB and swap your forged internals in, it sounds like the way to go. Like you said, you may drop another 250+ for new bearings etc. and still be in the same boat. Drop-ins may only work well for low mileage motors. @Dano; @Tomas; @chimmike; how many miles did you guys start off with for your drop-ins? Dan, maybe your fucked up ringland caused more issues than you originally suspected? Known issues: (quick browsing threads, if I missed something please add) Chimmike: oil consumption issues but great compression results and car is running great(oil consumption suspect thirsty turbo is thristy) Tomas: Fried cam bearings, suspected debris in head, oil starvation to cams or excessive oil temps from track duty Dano: Audible rattle accompanied by observed/logged KR(mechanical timing verified 3X), fucked up bearings
__________________ '09 Red MS3 - AP self tuned, CS HPFP, JBR 3.5 WP, CP-e S2 RMM, M2 Catless DP, CX FMIC, CNT CBE |
| The Following User Says Thank You to ASHMS3 For This Useful Post: | atvfreek (03-12-2013) |
![]() | | #1045 | ![]() |
| Raider is mah Homie ![]() Join Date: Jan 2011 Location: Towson, Maryland
Rep Power: 7524 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54,831
Groans: 2,978
| Not Ranked : 0 score @Dano; what weight oil are you running now? since it seems that you have decided to go all new and junk this motor, I would try running a much higher weight oil to try and bandaid getting the oil pressures up and help out the bearings to try and keep it from self destructing in the near term. If the car is still apart i would try to clean out the oil pickup too. EDIT: go 20w50 BECAUZ RACECAR!!!! I think you will end up spending a lot of money on oil if you try to go heavier.
__________________ ![]() I hugged rfinkle2 |
![]() | | #1046 | ![]() |
(Thread Starter) | Not Ranked : 0 score oil pickup tube was soaked in petrol over night and blew out from the pump side to the pickup side [its split down the middle with the screen]...not much if anything came out. didn't drive it today, wont need to tomorrow nor Thursday and don't know about Friday. Short story is, I don't have to drive it much and I really think it will hold together indefinitely. When I did drive it Monday I kept the revs to 1500 while sitting still so pressure stays around 20psi. prab should flash a map with a 1500 idle setting ![]() it is possible my sending unit location could be part of, if not THE cause of my low pressure readings. Anybody have a clue what the thread pitch is on the OEM sending unit? I could try and find an adapter to get from there to the 1/8th NPT of the Prosport unit. It is def much larger than 1/8 and what probably metric?...lol prab not worth the trouble though. running 10-40 PP syn if I haven't already said this I think the trouble with the bearings was due to honing residue so I really wonder what other drop in builds' bearings look like. my ringland came out in one piece so I doubt it caused any other issues with the motor and it was still captured between the rings.
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
![]() | | #1047 | ![]() |
| Not Ranked : 0 score stock is 1/4 NPT
| The Following 2 Users Say Thank You to superskaterxes For This Useful Post: | Dano (03-12-2013), djuosnteisn (03-13-2013) |
![]() | | #1048 | ![]() |
Groans: 2,978
| Not Ranked : 0 score Fix the thread title it should be formerly not formally.
![]() | | #1049 | ![]() |
(Thread Starter) | Not Ranked : 0 score Is that all u got? Title has been that way for 3 mos. Fail is the only new word which IMO is perfectly fitting. Soooo back OT, with a map flash for 1050 idle. Hot temp is running 15 psi. That should hold the POS over for a week or two. Tappin
![]() | | #1050 | ![]() |
![]() Join Date: Nov 2010 Location: Kaunas, Lithuania
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 144
| Not Ranked : 0 score so was something wrong with the way you washed your block? why all the residue? |
![]() | | #1051 | ![]() |
![]() Join Date: Jun 2009 Location: Tally, FL
Rep Power: 3058 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,683
| Not Ranked : 0 score I remember you washing the heck outta your block (post 369 in this thread has the pics) Tough to think there would have been any micro-shrapnel left to contribute to the problem
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq |
![]() | | #1052 | ![]() |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score I don't know, Bunny. Sounds to me like Dano did a pretty fair job of formalizing fail. Just sayin'... Hey, @Dano; I know you're pretty concerned with temps on everything. I've got a Hayden style P/S cooler kit taking up space and collecting dust up here. Got any use for it?
__________________ ![]() "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() | | #1053 | ![]() |
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-15-2013 at 09:40 AM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Dano For This Useful Post: | TiGraySpeed6 (03-15-2013) |
![]() | | #1054 | ![]() |
(Thread Starter) | Not Ranked : 0 score So my decision has been finalized and parts will be sourced today and Monday. the list: New Mazda LB Mazda HG crank washers and bolt conrod bearing set New Wiseco rings oh forgot the plan. crack open brand new LB and put my forged goodies inside before it goes into the car.
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-15-2013 at 10:24 AM. |
| The Following 10 Users Say Thank You to Dano For This Useful Post: | ASHMS3 (03-15-2013), CosmicArkie (03-15-2013), djuosnteisn (03-15-2013), DSIT995 (03-15-2013), Easter Bunny (03-15-2013), magicka (03-15-2013), Micha (03-29-2013), phate (03-15-2013), SLOWHATCH (03-15-2013), TiGraySpeed6 (03-15-2013) |
![]() | | #1055 | ![]() |
Groans: 2,978
| Not Ranked : 0 score argh!!!!!!!!!!!!!! i really wanted the old motor to work out for you. How is it holding up? Did you do anything other that put the old parts back in?
![]() | | #1056 | ![]() |
| Not Ranked : 0 score @Dano; The cooler is like this one: Power Steering Cooler Made by Hayden Coolers 1009 | eBay Doubt you'd want to use it for engine oil unless as a secondary. Which might not be such a bad idea if you've got room.
![]() | | #1057 | ![]() |
__________________ | |
| The Following User Says Thank You to silvapain For This Useful Post: | Dano (03-15-2013) |
![]() | | #1058 | ![]() |
I think this is the correct one. Correcting Engine Timing Belt Tool Kit 4 Ford & Mazda Replacing Timing Belt on eBay!
| The Following 3 Users Say Thank You to Dano For This Useful Post: |
![]() | | #1059 | ![]() |
Existing Motor Cons in order of importance to me: 1) car downtime - can't go without a car for another month or two to complete the rest of the below list. This is after all motor building "season" and any good shop around here is booked. 2) honing debris causing conrod bearings to scar up...possible main bearing damage and or oil pump. This means my current motor needs to come out and at least get a full once over at a machine shop..block boil/flush, crank polish, reassembly. can you say FUCK THAT? 3) Valve lash out of spec so I already have to time "A" motor again so it might as well be a brand new motor with forged internals. 4) THE NOISE...FOR GOD SAKE THE FUCKING PHANTOM NOISE, that will likely still be there if I tried to patch this one back together anyways. 5) Possible cam journal damage to the head but I am really hoping a polish will bring any scaring into spec New Motor Pros 1) limited downtime - plan covered below 2) New block and head when finished 3) No bucket swap game 4) Likely an entire spare motor when done that can be built or parted out as is. I think I can get the new block here, tear it down, measure the bores using my saved piston measurements and have it ready to accept the forged parts out of my existing motor. Then over a 4 day weekend pull the old motor, take rods/pistons out and drop into new motor, assemble new motor, drop into car sometime the next week/weekend, profit. Possible snags: bores are not large enough to make .025 P2W clearance. What then? Pull crank and oil pump, hone bores, take to shop for cleanup then reassemble. Still hopefully won't add but a week to the entire project. Still have lots of planning to do but that is the jist.
![]() | | #1060 | ![]() |
| Not Ranked : 0 score That's an outrageous looking kit for $65 Dano- If it's the right one that's a heck of a deal. Should you end up getting it I expect full details on it's actual functionality in the real world....
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | magicka (03-16-2013) |
![]() | | #1061 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah. Shoulda got the SU kit w 2 pieces for 200. Lol Tappin
![]() | | #1062 | ![]() |
| Not Ranked : 0 score ok, so the takeaway from this thread is, whenever you are rebuilding your motor, be sure NOT TO/TO....: a) ?? |
![]() | | #1063 | ![]() |
Groans: 793
| Not Ranked : 0 score There's that missing zero again. Be sure NOT to let Dano get drunk while supervising and shouting commands with his eye looking in two different directions and pointing at a broom handle in the corner of your garage.
__________________ ![]() ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 03-17-2013 at 06:58 AM. Reason: MSF Database - Automerged Doublepost |
![]() | | #1064 | ![]() |
(Thread Starter) | Not Ranked : 0 score I can assure you that my frequent enjoyment of various libations had nothing to do with the fail contained within this thread. the order of occurrence was typically... fail = consume libations...not the other way around lol I have been doing some thinking about the pending 2nd build and maybe I should put a poll together to get some opinions... New motor install options
| The Following User Says Thank You to Dano For This Useful Post: | Tokay444 (03-17-2013) |
![]() | | #1065 | ![]() |
| Not Ranked : 0 score I voted #2 but I'd have to say I'm halfway between 2 & 3. My thinking is, with all you will presumably do as far as temp control in the future, and with your knowledge base up to this point, I don't think you're going to have nearly the fail this time around. Butt, I may be wrong.
![]() | | #1066 | ![]() |
| Will fuck up ur day ![]() Join Date: Feb 2010 Location: Parrish, FL
Rep Power: 4200 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,803
Groans: 433
I'm thinking maybe my quick-n-dirty port job may have caused a valve seal issue resulting in my consumption but I have absolutely no idea yet. Gonna do a leakdown eventually, and will be adding a restrictor to tarby.
__________________ 07 MS3 The original Genpoo Hater PTE 5862cea ball bearing, plus some built stuff. Turismo Vids - Store your car vids and pics here! Blog your builds too! Click here for great deals at The RPM Store! PM me for pricing! I hear that honkey at Protégé Garage is pretty decent too. | |
![]() | | #1067 | ![]() |
(Thread Starter) | Not Ranked : 0 score What have we here? ![]() ![]()
| The Following 16 Users Say Thank You to Dano For This Useful Post: | atvfreek (03-29-2013), BlueStreak (03-29-2013), btstarcher (03-29-2013), cld12pk2go (03-29-2013), CosmicArkie (03-30-2013), djuosnteisn (04-02-2013), Easter Bunny (03-29-2013), EdgeAutosport.com (03-29-2013), KusteLokal (04-02-2013), magicka (03-29-2013), Micha (03-29-2013), phate (03-29-2013), sidekick (03-29-2013), silvapain (03-29-2013), TiGraySpeed6 (03-29-2013), Tokay444 (03-29-2013) |
![]() | | #1068 | ![]() |
Groans: 793
| Not Ranked : 0 score Likes dat!
| The Following User Says Thank You to Tokay444 For This Useful Post: | Dano (03-29-2013) |
![]() | | #1069 | ![]() |
| Not Ranked : 0 score Dano- You are going to have the strongest, most stable, built block here. Simply 'cause you're starting with virgins and training them to do what you want. When it's all said & done please post the real end result cost & part numbers involved to purchase the new block & parts like rods, bearings & the gaskets to reassemble so others can be aware of what's involved with having the bulletproofness
| The Following 5 Users Say Thank You to TiGraySpeed6 For This Useful Post: | btstarcher (03-29-2013), Dano (03-29-2013), magicka (03-29-2013), phate (03-29-2013), sidekick (03-29-2013) |
![]() | | #1070 | ![]() |
(Thread Starter) | Not Ranked : 0 score I wouldn't go that far...still running OEM pistons...more than likely. Haven't decided yet but I'll also likely use OEM head bolts b/c as it stands today, they provide more clamp force than ARPs if you don't re-torque the ARPs and maybe even if you do at 60lb/ft. sooooo consider the cost/PITA of going with ARPs and pulling the cams and re-timing the motor so you can torque them after a heat cycle vs OEM head bolts...anyway that's my current train of thought. I will put up an entire other thread devoted to the new build...don't want the fail to bleed over into the new stuff. And yes I'll provide job costing on build duex. edit: just a lil comparison of the Carrillos vs K1s. Both brought to my by Edgeautosport.com ![]()
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-29-2013 at 04:47 PM. |
| The Following 2 Users Say Thank You to Dano For This Useful Post: | BlueStreak (03-29-2013), TiGraySpeed6 (03-29-2013) |
![]() | | #1071 | ![]() |
Groans: 793
| Not Ranked : 0 score interested how out of round the virgin bores are.
| The Following 5 Users Say Thank You to Tokay444 For This Useful Post: | Dano (03-29-2013), djuosnteisn (04-02-2013), Easter Bunny (03-29-2013), magicka (03-29-2013), phate (03-29-2013) |
![]() | | #1072 | ![]() |
(Thread Starter) | Not Ranked : 0 score we will not know that...no TQ plate and IDGAF....lol actually It would be nice to know if my Wiseco's would go in there but I am not just throwing them in and hoping they are not too tight and I don't have a TQ plate...end of story. now if someone wants to send me a plate I'll throw it on there and measure the bores
![]() | | #1073 | ![]() |
Groans: 793
| Not Ranked : 0 score if the wiseco's measure the same as the oem virgins, toss them in.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Easter Bunny (03-29-2013), phate (03-29-2013) |
![]() | | #1074 | ![]() |
(Thread Starter) | Not Ranked : 0 score don't you mean if they measure LESS than the OEMs
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-29-2013 at 04:50 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #1075 | ![]() |
Groans: 793
| Not Ranked : 0 score oem's are forged as well, so no.
![]() | | #1076 | ![]() |
(Thread Starter) | Not Ranked : 0 score I don't think they are forged?? hydroscopic or some BS cast like that.
![]() | | #1077 | ![]() |
| Not Ranked : 0 score OEM's are hypereteuctic, iirc.
![]() | | #1078 | ![]() |
Groans: 793
| Not Ranked : 0 score not to mention, you got the wiseco's for oem bore anyway.
![]() | | #1079 | ![]() |
(Thread Starter) | Not Ranked : 0 score yes...I do realize that but as a machinist you know that doesn't necessarily mean the P2W will be correct...no? hahahaha I was completely talking out of my ass...and I knew it...and I knew others would know it
__________________ ![]() 07 Red MS3 GT - E40 - Carrillo Rods - Wiseco Pistons - BSD - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - CPE EM - CPE DP - CNT CBE - APv3 - Grim EBC - PERM dual port PCV plate - Dano dual OCC - CPE CDFP - Labonte S2 WMI - ACT Street Kit - SUv2 RMM - SU TM - "Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-01 Last edited by Dano; 03-29-2013 at 04:56 PM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to Dano For This Useful Post: | phate (03-29-2013) |
![]() | | #1080 | ![]() |
Groans: 793
| Not Ranked : 0 score edited to reflect enlightenment
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f658/fail-formerly-known-dano-s-drop-build-127709/ | ||||
| The Antique Outboard Motor Club Forums - 1960 evinrude 10hp parts swap? | This thread | Refback | 11-01-2013 05:11 AM | |
| Tuoreimmat viestit | This thread | Refback | 12-09-2012 11:00 AM | |
| Mazda 3 MPS | This thread | Refback | 12-09-2012 10:46 AM | |
| Dano's Koni FSD install | Dano | MazdaSpeed 3 - How-To's | 64 | 03-03-2015 12:49 PM |
| My Pop 'n drop build | Chimmike | Mazda MZR DISI Engine Builds (2006-2013) | 381 | 11-10-2013 06:51 PM |
| Dano's Boost Tuning 101 + Cool Stuff | Dano | MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning | 1512 | 09-20-2012 06:47 AM |
| 2010 MS3 Build, please drop your 2 cents in! | randino69 | 2010 MS3 - Build Diaries | 17 | 03-26-2012 10:19 PM |
| Dano's SS Exmani install | Dano | MazdaSpeed 3 - How-To's | 18 | 11-12-2010 10:38 PM |
