Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
Like Tree115Likes
 Old 11-05-2012, 03:15 PM   #161
I'm surprised it's not a photocopy or wax model.
Excellent ideas for next time. I'll have to order a DIY dildo making kit...
The Following 4 Users Say Thank You to silvapain For This Useful Post:
atvfreek (11-05-2012), Easter Bunny (11-05-2012), phate (11-05-2012), TiGraySpeed6 (11-06-2012)
 Old 11-05-2012, 03:17 PM   #162
Posts: 9,484   (View Stats)
What I can't believe is how far out from actual tdc that timing peg leaves us.
And it's likely different on every motor also.
ya know I was wondering this as well...if the block tolerances are good then we should be able to make a custom timing peg to correct the issue...no?
I don't know exactly where it hits the counter balance so perhaps its at an angle and thus hard to get it exact?? I'll def be looking a this in a day or two.
 Old 11-05-2012, 03:17 PM   #163
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
In for hot wax cock moulds.
"Exclusivity" - CP-enis
Demodded.
The Seals
phate (11-05-2012), silvapain (11-05-2012)
 Old 11-05-2012, 03:21 PM   #164
oh god no!
thanks lex!
Good stuff Dan - this should be a nice and documented build! Can't wait to see what you find during teardown.
I mentioned a few posts back about air escaping from #3 and coming out of the VC yet none out of the dip stick tube?? Am I looking at bent/burnt valves and guides there? I know they are both connected [CC and VC] but would think the air would come out of both fairly equally but tis not the case.
anyway when I pull the cams, IM, EM I'll retest and know for sure.
Last edited by Dano; 11-05-2012 at 03:24 PM. Reason: MSF Database - Automerged Doublepost
atvfreek (11-05-2012), djuosnteisn (11-05-2012), MS3-a(sore)ASS-rex (11-06-2012), phate (11-05-2012)
 Old 11-05-2012, 03:24 PM   #165
That peg SST is supposed to hit the crank such that it turns it to #1 TDC and then stops. You're not supposed to be able to continue tightening the SST and rotate the crank further; however, that's exactly what was happening on my engine.
Personally I'd use a degree wheel to set at #1 TDC, and use the crank peg SST or a bolt just to hold the crank at the right spot. Once you've found TDC with the wheel, you can use the factory method just to see how off it would be.
As far as I know my engine is the only one where TDC was independently verified, so I don't know if its common or just due to some manufacturing issue with my crank.
The Following 9 Users Say Thank You to silvapain For This Useful Post:
atvfreek (11-05-2012), BlueStreak (11-05-2012), Ckmazdaspeed3 (04-01-2013), cocoanton (02-11-2013), Dano (11-05-2012), Easter Bunny (11-05-2012), MS3-a(sore)ASS-rex (11-06-2012), phate (11-05-2012), TiGraySpeed6 (11-06-2012)
 Old 11-05-2012, 04:10 PM   #166
Ziggo's Avatar
Posts: 3,843   (View Stats)
+1 on the degree wheel. The tolerance stack up to that peg scares me.
I am very jealous of the cock clock. My garage needs one.
Zigatapatalka
Ask Me About My:
The Following 5 Users Say Thank You to Ziggo For This Useful Post:
amoosenamedhank (11-06-2012), atvfreek (11-05-2012), MS3-a(sore)ASS-rex (11-06-2012), phate (11-05-2012), silvapain (11-05-2012)
 Old 11-05-2012, 04:12 PM   #167
Tokay444's Avatar
Groans: 793
Part of me wants to think that 7 degrees is to compensate for the cam shift when you remove the cam plate.
If Dano measures 7 degrees on his, I'll have even more reason to believe it's built in.
Demodded.
The Seals
The Following 7 Users Say Thank You to Tokay444 For This Useful Post:
atvfreek (11-05-2012), BlueStreak (11-05-2012), Dano (11-05-2012), Easter Bunny (11-05-2012), MS3-a(sore)ASS-rex (11-06-2012), phate (11-05-2012), TiGraySpeed6 (11-06-2012)
 Old 11-05-2012, 04:21 PM   #168
not too sure how well the CCAG will fit into the engine bay but I do have two different angle gauges I can attempt to mount up as pseudo degree wheels. I'll get #1 to TDC before teardown via my dial gauge a la piston height test, and find out what is what with the peg and degree wheel.
edit: I think that 7* is the separation from Kevin Bacon.
The Following 5 Users Say Thank You to Dano For This Useful Post:
djuosnteisn (11-09-2012), Easter Bunny (11-05-2012), MS3-a(sore)ASS-rex (11-06-2012), phate (11-05-2012), Tokay444 (11-05-2012)
 Old 11-06-2012, 05:39 AM   #169
btstarcher's Avatar
Posts: 4,852   (View Stats)
Groans: 112
Wait I thought 6* was the separation from Kevin Bacon....
SnailTune in progress
Dano (11-06-2012)
 Old 11-06-2012, 05:53 AM   #170
Raider is mah Homie
Easter Bunny's Avatar
Posts: 6,460   (View Stats)
Groans: 2,978
whoa guys we have a badass on our hands, he can get there one faster than the rest of us! LOL
I hugged rfinkle2
Dano (11-06-2012)
 Old 11-06-2012, 07:47 AM   #171
ah ha! I caught you...that was a test for the gheys and you failed...or passed depending on how you look at it
j/k lol I knew it was somewhere around there.
ASHMS3 likes this.
 Old 11-06-2012, 08:20 AM   #172
btstarcher's Avatar
Groans: 112
Fuck yeah I'm gay for Kevin Bacon and Will Smith, who isn't?
 Old 11-06-2012, 07:53 PM   #173
so let it be written....
so let it be done....
just about to find out what's what with the timing peg and actual TDC.
The Following 11 Users Say Thank You to Dano For This Useful Post:
802MS3 (11-06-2012), atvfreek (11-06-2012), BlueStreak (11-06-2012), btstarcher (11-06-2012), djuosnteisn (11-09-2012), Easter Bunny (11-06-2012), Lex (11-06-2012), phate (11-06-2012), silvapain (11-06-2012), TiGraySpeed6 (11-07-2012), Tokay444 (11-07-2012)
 Old 11-06-2012, 08:52 PM   #174
TDC vs timing peg results.
So I setup my dial gauge again just like I did when I was looking at piston height. This is #1 at TDC.
I then backed the crank off and installed the timing peg just a little way into the block to see exactly where it was going to land. As it turns out, right on a flat spot on the counter balance.
So I bottomed out the peg by hand into the side of the block, rotated the crank up against it, which turned out like this.
Took a look at my dial gauge and this is the result.
so in the end I can't reproduce the results @silvapain had and it looks like on my motor at least, the peg is dead on.
time to pull the VC and find out where all my compression is going.
silvapain and atvfreek like this.
The Following 13 Users Say Thank You to Dano For This Useful Post:
802MS3 (11-07-2012), atvfreek (11-06-2012), BlueStreak (11-06-2012), charlesfist (11-08-2012), cld12pk2go (11-07-2012), djuosnteisn (11-09-2012), Easter Bunny (11-07-2012), Lex (11-06-2012), phate (11-06-2012), silvapain (11-06-2012), TiGraySpeed6 (11-07-2012), Tokay444 (11-07-2012), Tomas (11-07-2012)
 Old 11-06-2012, 08:58 PM   #175
atvfreek's Avatar
Posts: 7,787   (View Stats)
Damn, that is right on the money. I like it! Waiting patiently for your results (and my pistons and rods )
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following User Says Thank You to atvfreek For This Useful Post:
Dano (11-06-2012)
 Old 11-06-2012, 09:16 PM   #176
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I suppose it's kind've moot now but you could also verify the accuracy of the TDC pin with the slots in the back of the cams.
'07 CWP MS3
Forged.
The Following 2 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (11-07-2012), Dano (11-06-2012)
 Old 11-06-2012, 09:26 PM   #177
Can't wait to see the rods/pistons when you pull them out!
 Old 11-06-2012, 10:27 PM   #178
I can make that happen tomorrow. that cam alignment tool is a tight fit...I put it in tonight just to see how it lines up and it is very tight. the pin was not installed though.
I didn't get to remove the the timing cover and all that entails so I could remove the cams...that will be tomorrow as well as pressurizing the cylinders to confirm where the compression is going.
I guess I will build a custom SST to hold the block from the top so I can easily get to everything from the bottom.
@chimmike;
@Tomas;
what did you guys hold the block up with after you removed the PMM? I don't want to deal with moving something around underneath so I can get to the rods and easily turn the crank.
edit: WTF is up with my mentions?
Last edited by Tokay444; 11-07-2012 at 04:23 AM. Reason: Let me fix those mentions for you.
 Old 11-06-2012, 10:35 PM   #179
just a thought...
looking at this pic again, the OEM balancing relief is right next to the flat spot and so if it were just a tad higher, it might completely FYCN on getting the timing just right.
I'll look again tomorrow to confirm that is in-deed a machining relief and not a casting mark. Either way it looks very close.
 Old 11-07-2012, 04:26 AM   #180
Tokay444's Avatar
Groans: 793
Great results for the timing peg.
@Celestspeed3;
That or you've bottomed out your dial. Lol.
Demodded.
The Seals
Dano (11-07-2012)
 Old 11-07-2012, 04:44 AM   #181
atvfreek's Avatar
To hold the block up when you take the pmm out, I would remove the oil pan and support the back of the block with a jackstand and a block of wood. If you run the block of wood along the back of the block, it will give you plenty if room to work and get the rods disconnected. Here is a pic of Dougs engine from the bottom. Not the best, but you can see the wood.
Freekn tappin
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
BlueStreak (11-07-2012), Dano (11-07-2012), djuosnteisn (11-09-2012), Tokay444 (11-07-2012), Ziggo (11-07-2012)
 Old 11-07-2012, 06:04 AM   #182
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
@chimmike;
@Tomas;
I had a floorjack underneath the transmission. It was a little intrusive for working under there but kept the motor up with the rmm and tmm.
07 MS3
The original Genpoo Hater
The Following 2 Users Say Thank You to Chimmike For This Useful Post:
 Old 11-07-2012, 07:28 AM   #183
@Dano; do you have a cherry picker? The engine can be easily supported by the two lift eyes bolted onto the head.
Dano (11-07-2012)
 Old 11-07-2012, 09:01 AM   #184
@Celestspeed3;
not THAT stupid.
and I see that now we have to put a semicolon after a mention.
@Tokay444;
b but head will be gone
I'll see how I like the block of wood + my extra jack.
thanks for the suggestions guys.
Last edited by Dano; 11-07-2012 at 09:03 AM. Reason: MSF Database - Automerged Doublepost
 Old 11-07-2012, 10:01 AM   #185
Is tonight the piston and rod removal night?
 Old 11-07-2012, 11:34 AM   #186
quite possibly....work is interfering with my fun today.
Hey, lets talk about break in and break in oils. Lets start out with the oil.
I think everyone will agree an oil with high Zinc content is preferred for first startup, short duration breakin [20 miles] as well as long duration break-in [150 additional miles]. Then switch to any dino oil up to say 1K miles before going to syn.
agree, disagree, don't give two cents?
Where I believe things start to differ is with what weight oil one is going to use for each of these periods if different.
My plan was to use the 30wt Lucas Break-in oil for the first startup, 20 mile hard break in, change, and 150 mile changes. If it was still the dead of summer I would stick to that plan but silvapain made a good point about getting a new motor lubricated fast possibly being more critical than having a thicker weight oil during break in. He indicated using a 5-40 breakin oil but Lucas only has a 20-50 and 30wt available. As the days get colder using a multi grade makes more and more since.
sooooooo
I would like to get some thoughts on my below plan for oil usage.
1) Assemble the motor with Lucas assembly lube
2) Fill up with Lucas 20-50 and pour it over the cams/tappets before installing the VC
3) Run this up to 20 miles or so of Motoman's break in procedure
4) Change oil and switch to Lucas 30wt for the next 100-150 miles
5) Change again and go with some cheap multi grade dino oil up to 1200 or so miles.
6) Switch to syn
Note: if I am going to douse the cams with oil, does this negate the need for a multi grade?
Discuss
edit: of course you could get any number of zinc additives to add to any weight oil you wanted so I am not locked in to Lucas' 20-50
helmetface (11-08-2012), silvapain (11-07-2012)
 Old 11-07-2012, 12:00 PM   #187
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
Stock bearing clearances should probably get recommended stock weight oil. I don't think I would run the 20-50, but that's me.
I'm going to run the straight 30 weight Lucas, but I'm going to order an oil heater so it flows better on initial start up.
-06 MS6
-Corn fed 07 MS3 - Sold
BlueStreak (11-07-2012), Dano (11-07-2012), Tokay444 (11-07-2012)
 Old 11-07-2012, 12:05 PM   #188
BlueStreak's Avatar
I used Joe Gibbs 5w 30 for mine. Worked great.
'07 CWP MS3
Forged.
The Following 3 Users Say Thank You to BlueStreak For This Useful Post:
atvfreek (11-07-2012), Dano (11-07-2012), phate (11-07-2012)
 Old 11-07-2012, 12:06 PM   #189
oh yeah didn't think about the OEM clearances as it relates to oil weight...so 30 is the thickest I need to go not 50.
in that case I'll either stick with the 30 and warm up my oil pan or get a 5 or 10-30 and add Lucas additive.
but you are baller...I can't afford that gold!
Last edited by Dano; 11-07-2012 at 12:06 PM. Reason: MSF Database - Automerged Doublepost
BlueStreak (11-07-2012), phate (11-07-2012)
 Old 11-07-2012, 12:08 PM   #190
Will fuck up ur day
Chimmike's Avatar
Groans: 433
frankly I used napa 5w30 dino for mine. The break in oil prices are WAY Too high, IMO.
you can get a lucas additive for new motor break in.
As for the cam lubrication, I spread assembly lube on the cams during reassmbly of the motor.
07 MS3
 Old 11-07-2012, 12:15 PM   #191
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Not that their standards are all that high, but what does Mazda use when starting a car/engine for the first time?
I'm suspecting the same 5/30 that's in it when it hits the dealership floor for sale
340hp / 371tq
The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post:
atvfreek (11-07-2012), Dano (11-07-2012), Easter Bunny (11-07-2012), phate (11-07-2012)
 Old 11-07-2012, 12:18 PM   #192
not too sure about that. I show your Napa 5w30 costing 17 and the additive is 8. You can get Lucas 30 wt break in oil shipped from Jegs for 21. so for the straight 30 wt Lucas is a better option. now if only they made it in 5-30. Looks like I might get some local 5-30 and add the additive.
BTW I will be using Lucas assembly lube on everything.
phate (11-07-2012)
 Old 11-07-2012, 12:19 PM   #193
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I meant in regards to the Joe Gibbs or Royal Purple stuff.
I just used clevite assembly lube on everything. Thick stuff, stuck on really well.
Did a change after 100 miles, then after 500, then 1000.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
BlueStreak (11-07-2012), Dano (11-07-2012), phate (11-07-2012)
 Old 11-07-2012, 12:25 PM   #194
Modern engines don't need much in terms of break-in. A high ZZP content with the OEM weight conventional oil is fine for break in. If it doesn't have high ZZP you can buy a bottle of additive for a few bucks.
As a sidenote, low friction rings such as in the Skyactiv don't need any break-in. The bores are aluminum with sprayed on steel. So no breaking in and the motors are not rebuildable since you can't machine the bores.
The Following 8 Users Say Thank You to Lex For This Useful Post:
atvfreek (11-07-2012), BlueStreak (11-07-2012), Chimmike (11-07-2012), Dano (11-07-2012), DiGi Faggot (11-16-2012), djuosnteisn (11-09-2012), Easter Bunny (11-07-2012), phate (11-07-2012)
 Old 11-07-2012, 12:30 PM   #195
Eth Fiend
phate's Avatar
Honestly, the last two MZR's I've broken in have used WalMart Super Tech 5W-30. Both run beautifully, one has thousands of miles on it, the other has ~1k miles.
-06 MS6
atvfreek (11-07-2012), BlueStreak (11-07-2012), Dano (11-07-2012), djuosnteisn (11-09-2012), helmetface (11-08-2012)
 Old 11-07-2012, 02:33 PM   #196
lol...here is an article I found and this guy used Super Tech oil and filters for the 1st two oil change cycles.
Run any good quality API rated oil...Valvoline, Shell, and Wal-Mart Super Tech are fine. For the initial run use a Super Tech filter...I'm a believer in the "Hard & Fast" break-in method. You want to make several hard runs to ~4000 rpm...you want to get to that rpm as quickly as possible then let the car coast back down to 10 mph or so (at idle, in gear) to create a good vacuum on the engine. Then do the same thing again...3-4 times should be enough. Take the car home and change the oil/filter before running it again using the same 30W...a Super Tech filter is fine for this too. Run to the 100-200 mile point or so and change the oil again...use the same 30W or a 10W-30 dino oil and a PureOne or Wix filter. Run to the 1500 mile point and switch to a good syn oil...stick with the Wix or PureOne filters from then on.
if the Plateau finish is done correctly you are right and there is very little break in required. Probably over thinking the oil part for sure.
 Old 11-07-2012, 05:36 PM   #197
Bob Ross Fanclub
Tomas's Avatar
Posts: 3,811   (View Stats)
are you going to prime the engine before start up?
 Old 11-07-2012, 08:10 PM   #198
BlueStreak's Avatar
^^^This! Amazing stuff for the initial start up. Its thick as hell and doesn't run off like oil does.
I put that sh!t on everything.
'07 CWP MS3
Forged.
Chimmike (11-08-2012), phate (11-07-2012)
 Old 11-07-2012, 08:11 PM   #199
mrmonk7663's Avatar
Posts: 2,997   (View Stats)
Not sure of the inside of the mazda oil filter, but make sure that if it has an oil drain back valve on the stock filter that your aftermarket filter has one as well. Using a non oil drain back filter on my mustang did my engine in.
2011 Speed3-BT and shit
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
 Old 11-08-2012, 08:10 AM   #200
Well made some progress last night but didn't get the head off due to my 12mm 12pt 1/2 drive socket snapping in half trying to remove the head bolts. Will try to source an impact 12pt but they are hard to come by IIRC. It was a Craftsman so they will give me a new one either way.
So to add to fail #2 above I had a 1st fail when I pulled the injectors/rail I found this.
Some of you may remember a few k miles ago I installed the Toyota injector seals and something definitely went wrong with that #2 injector seal...god!
To me there are two points of interest.
1) obviously the seal was not doing its job.
2) besides that even the tip of the injector is covered in black gunk so why is that? Poor cylinder seal leading to poor combustion and soaking the injector with carbon?
Needless to say I'll be ordering me some SafeSeals today.
The Following 6 Users Say Thank You to Dano For This Useful Post:
atvfreek (11-08-2012), BlueStreak (11-08-2012), charlesfist (11-08-2012), djuosnteisn (11-09-2012), Easter Bunny (11-08-2012), silvapain (11-08-2012)
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f658/fail-formerly-known-dano-s-drop-build-127709/
The Antique Outboard Motor Club Forums - 1960 evinrude 10hp parts swap? This thread Refback 11-01-2013 05:11 AM
Tuoreimmat viestit This thread Refback 12-09-2012 11:00 AM
Mazda 3 MPS This thread Refback 12-09-2012 10:46 AM
Dano's Koni FSD install Dano MazdaSpeed 3 - How-To's 64 03-03-2015 12:49 PM
My Pop 'n drop build Chimmike Mazda MZR DISI Engine Builds (2006-2013) 381 11-10-2013 06:51 PM
Dano's Boost Tuning 101 + Cool Stuff Dano MSF KB - Mazdaspeed 3/6 - ECU Computer Tuning 1512 09-20-2012 06:47 AM
2010 MS3 Build, please drop your 2 cents in! randino69 2010 MS3 - Build Diaries 17 03-26-2012 10:19 PM
Dano's SS Exmani install Dano MazdaSpeed 3 - How-To's 18 11-12-2010 10:38 PM
Page generated in 0.60732 seconds with 34 queries
