Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
 Old 01-11-2018, 08:26 PM   #1
jonj1017's Avatar
Posts: 18   (View Stats)
jonj1017 is a glorious beacon of lightjonj1017 is a glorious beacon of lightjonj1017 is a glorious beacon of lightjonj1017 is a glorious beacon of lightjonj1017 is a glorious beacon of lightjonj1017 is a glorious beacon of light
Default Need help, decisions are hard!
Hi all! My speed3 genjuan has 230K miles, thought I might get to 300K. No dice. I bought it with 167K on it and did all my mods. The turbo has finally failed seals are are leaking oil and coolant. Under the oil cap is nice and frothy with coolant. My compression from cylinder 1-4 is 150, 140, 150, and finally 110. I know I need a new turbo and to build the motor my question is as follows.
What should I do?
1) My local shop found a used motor with 44K miles and will install it for $5200 with a stock turbo.
2) I can get a long block from FJ, EBTEC, or Speedp3f6rmance.
3) Stock long block off edge. Would it be dumb to open it and put forged rods in it?
I don't have the time or space for a full rebuild on my own but can handle the swap of one motor to anther and then sell my motor/block. This is time sensitive to me as this is my daily driver and my plan is to go bnr s4 as the turbo replacement. Please help!
09 MGM MS3
Autotech Internals; Cobb AP; Corksport Intake, TIP, tokay injector seals; UR Test Pipe; JBR SSB, RMM 80a, Air Filter, SSP, heavy shift knob, EGR delete, TIG, IMG; E40 via Statified custom E85 map; <Koni FSD suck> KYB Gas Shocks; CX Racing Piping/Treadstone T8 Intercooler; Damond oil catch can; Drag DR31 17x8, 235/45 17 Potenza S04 Pole Position
jonj1017 is offline   Reply With Quote
 Old 01-11-2018, 08:58 PM   #2
Code Monkey's Avatar
Posts: 7,656   (View Stats)
Search, but I will give you a head start.
2006 Mazdaspeed6
stripped|caged|freektuned
2017 Subaru BRZ
 Old 01-12-2018, 05:29 AM   #3
jonj1017's Avatar
Ok. Would I be ridiculous if I got s remand long block from edge and put upgraded rods in it?
Sent from my Pixel using Tapatalk
09 MGM MS3
 Old 01-12-2018, 06:46 AM   #4
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Well.... you'd have to re-plastigauge and get new bolts at the very least.... I don't like that idea at all, but I have had friends get away with murder when it comes to opening up an engine. (Talking back yard build with used pistons and bearings).
IMHO, I would take it to a machine shop and have them to the work up to snuff.... Or just get a built motor
 Old 01-12-2018, 02:48 PM   #5
jonj1017's Avatar
Going through my body shop going to have them get the motor and turbo with 44k on it and install it for me. They did a leak down on the motor and it was at 90%. I get a 1 year warranty with that. Then bnr s4 in the future. Thanks for the responses.
09 MGM MS3
 Old 01-12-2018, 06:13 PM   #6
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
Groaned at 6 Times in 6 Posts
For 5k and change you can buy a used mazdaspeed 3 :\. Also, s4 too big for stock motor imo.
2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE
2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too.
 Old 01-13-2018, 11:59 AM   #7
mituc's Avatar
Posts: 3,504   (View Stats)
Groans: 111
A GTX3071 is perfect for the stock block, and so will an S4. Add meth on the table and the stock motor will be happy for a pretty long time.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
Hard Mount Hard Wired Radar Detector downs MazdaSpeed 3/6 - Car Audio & Electronics 0 02-11-2017 11:51 AM
decisions cedrek 2010 MS3 - ECU Computer Tuning 5 10-04-2011 08:23 AM
Decisions, Decisions... Need some advice j996tt Mazdaspeed3/6 General Discussion 12 02-02-2011 04:08 PM
Movie Review: The Goods: Live Hard, Sell Hard *Warning: Spoiler Alert* [w/POLL] Haltech Automotive News 0 08-18-2009 02:10 PM
Page generated in 0.27965 seconds with 24 queries
