Mazdaspeed 3/6 MZR Gen1/2 Engine Build Forums (2006-2013)
> Mazda MZR DISI Engine Builds (2006-2013)
 Old 01-09-2018, 05:03 AM   #1
AndrewMRZ72's Avatar
Posts: 2   (View Stats)
AndrewMRZ72 is an unknown quantity at this point
Default New MS3 Build Turbo Suggestions
New Build**Turbo opinions from forums**
Hey People, New user would like some thoughts on turbo options for my New motor that was just built.
Looking to run Precision 6262 but builder advised 5858 but there pricey.
Should dyno out in 650 to 750 Depending on Turbo, Want options to make sure I get a fast spool with low lag with out losing HP.
CEA Billeted Wheel? Bigger Turbos are not a large item in my knowledge line so any useful and real world applicable knowledge would be appreciated
Here is what I got,
Speed 3 2010
Built Speed performance Stage 2, just completed
Speed Performance Fuel Setup
Cosworth Intake Manifold
Custom Build Turbo Intake
Front Mount Intercooler with Large Cell
EGR Delete
Large flow racing old pump
Cooling Fan shroud
4 port Solenoid
HKS BOV
Racing CAms
2 step colder Plugs
Race Pipe Into Borla Axle Back (NO cats or res)
3 MAP
Corksport Injector Seals
Weapon Cold Air
Turbo Inlet
Godspeed racing Coilovers
ACT 6 puck twin disc Clutch
Short Shift
In Tank 365 LPH Fuel pump
Cork sport Internals
Cobb Throttle Body
Stiffing (Front, backseat, Hatch and Under side)
Brembo Front Brakes with cross drilled and slotted
AndrewMRZ72 is offline   Reply With Quote
Turbo Suggestions cam1391 MazdaSpeed 3 - How-To's 4 01-19-2015 09:14 AM
Lifeofmusic's build/suggestions? lifeofmusic MazdaSpeed 3/6 - Build Diaries 8 08-17-2014 03:27 PM
Starting a GT3076R build looking for suggestions MurrySpeed MazdaSpeed 3 - How-To's 14 07-11-2012 10:16 AM
Suggestions (ECU, trans, rear end, etc) for MZR build DarkPasseng3r Gen2 MS3 General Discussion 5 06-06-2012 03:54 PM
Page generated in 0.22604 seconds with 20 queries
