![]() | | #81 | ![]() |
Rep Power: 14701 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,473
Groans: 79
| Not Ranked : 0 score <---- done way too many things the hard way lol
__________________ 500awhp 440awtq uncorrected ![]() BW8875 ms6, no meth, 50/50 e85, and IDCs in the 90's @ 500+ awhp, with room to grow... fifth port winning. Mounts be popping, and trans be hurting 30r ms3 dd on deck, has fuel... needs top mount turbo lovin' next... Check out the hair Salon: www.permtuning.com |
| The Following User Says Thank You to djuosnteisn For This Useful Post: | phate (09-11-2012) |
![]() | | #82 | ![]() |
| Engineered Tuning ![]() ![]() ![]() Join Date: Jun 2008 Location: Vancouver, Canada
Rep Power: 8363 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,244
The only people that pull the tranny out without the engine or vice versa are mechanics in shops with proper lifts working from under the car with tranny jacks etc. Not us commoners crawling under cars
__________________ We Engineer, and that's better than just tuning! ![]() www.stratifiedauto.com COBB AP and VersaTuner Custom Tuning. Guardian Angel Protection and Boost Control. |
| The Following 5 Users Say Thank You to Lex For This Useful Post: | djuosnteisn (09-11-2012), Downmented (09-17-2012), phate (09-11-2012), Speed_j23 (09-11-2012), TiGraySpeed6 (09-11-2012) |
![]() | | #83 | ![]() |
![]() Join Date: May 2009 Location: Kankakee, IL
Rep Power: 7922 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,622
Groans: 121
__________________ ATP GTX3071 IWG . 10.5:1 pistons . K1 Rods . Balance Shaft Delete . COBB AP . eBay Special Catless DP . Mazdaspeed Accessory CBE . OCC . Autolite XP5364 Spark Plugs . TRZ TMM . TRZ RMM . MDM SSP . JBR Shifter Bushings . JBR EGR Delete . KW V1 Coilovers . SPC Rear Camber Arms . EBC Yellowstuff Pads . Autotech HPFP internals . 3-Bar MAP Sensor . N2MB WOT Box . ACT 6-Puck Sprung Clutch w/ Streetlite Flywheel . Konig Milligrams 18x8.5 et45 with 245/40's . GrimmSpeed EBCS . Self-PnP IM with VTCS removed . TWM full replacement shifter with 3" extension . TS BPV SU Edition . CX Racing FMIC . HTP 3.5" Intake . Lots of ricer mods . Beans Above the Frank Build http://www.mazdaspeedforums.org/forum/f541/beans-above-frank-build-115919/ | |
| The Following 3 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #84 | ![]() |
| Eth Fiend ![]() Join Date: May 2010 Location: Murhpysboro, Illinois
Rep Power: 6798 ![]() Thanks: 10,668
DON'T DO IT. You will hate life if you try it, lol. The front clip is super easy to pull off. In the 6's, though, the refrigerant lines run around the entire bay (all circle like). So, if you happen to have a family member who runs an hvac business (like me), or don't care about letting freon into the air (prob like me, but we didn't lol), or happen to have a system which was already purged (we did!), it's easy! It needs evac'd and filled now, but that's cheap and easy. Once the front clip was off, setting the drivetrain on the mounts takes like 10 minutes. From there, you have way more access to pretty much everything, it's awesome.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold Last edited by phate; 10-01-2012 at 09:26 PM. | ||
| The Following 4 Users Say Thank You to phate For This Useful Post: |
![]() | | #85 | ![]() |
Groans: 121
| The Following 4 Users Say Thank You to silvapain For This Useful Post: |
![]() | | #86 | ![]() |
(Thread Starter) | Not Ranked : 0 score Yeah, on a 3, I believe both of the lines are on the same side of the car.
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold |
| The Following 2 Users Say Thank You to phate For This Useful Post: | djuosnteisn (09-11-2012), silvapain (09-11-2012) |
![]() | | #87 | ![]() |
![]() Join Date: Jul 2011 Location: Aurora, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,394
Groans: 81
that's what i was going to post, glad i read through the posts. You can hook up that light that flashes shows if your getting spark, at least then you will know you are getting readings from the two sensors. When your cranking the car over, does it just constantly try and start in a normal pattern, before when timing was off, the car would try and compensate it self, it would crank crank crank crank, stop, crank crank crank, stop, crank crank crank.
__________________ 2004 mazda 3-Daily 2008 mazda 6-Wife 2008.5 Mazdaspeed 3 totaled 1983- FB Rx-7 Soon to be boosted Carb epicness Exedy Clutch/Tokico shocks/racing beat Springs/2.5 Custom exhaust/Short shifter/Solid Motor Mounts/custom 3 point harness bar/Full MSD ignition/T2 Oil cooler ]
![]() | | #88 | ![]() |
She's running!!! Just put the first 20 miles on it ![]() And it was something simple, and I feel dumb hahaha. Story time later.
| The Following 12 Users Say Thank You to phate For This Useful Post: | Boosten Ya(josh) (09-12-2012), btstarcher (09-11-2012), djuosnteisn (09-12-2012), Don06speed6 (09-11-2012), J-Liss (09-12-2012), Lex (09-11-2012), lilred (09-12-2012), Micha (09-18-2012), silvapain (09-12-2012), Speed_j23 (09-11-2012), TiGraySpeed6 (09-11-2012), wolly6973 (09-12-2012) |
![]() | | #89 | ![]() |
| psn boostenya ![]() Join Date: Jun 2009 Location: Riverside, CA
Rep Power: 1293 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,831
Groans: 38
Groaned at 15 Times in 13 Posts
I call it was a ground wire. Out connector wasn't plugged in.
__________________ 08 Mazdaspeed 3 Fucking FREEK TUNED and shit |
| The Following User Says Thank You to Boosten Ya(josh) For This Useful Post: | phate (09-12-2012) |
![]() | | #90 | ![]() |
Alright, so, last night I checked the sensors and found voltage at the cam and crank with my multimeter. Just watched the voltage bounce around, so I thought they were ok. During that, the car popped a P0335 - crank sensor something or other. This led me to think it might be a bad sensor, so we were going to pull the one off of my car and put it on this one. My friend Aaron was like "you have a different sensor on your car". Of course we don't -.- It looked like a different sensor, because the one on the gray 6 was backwards, lolol. When I assembled the engine on the stand, I put the crank sensor on after I timed it. Before we put the engine in, we pulled it so it wouldn't break on anything. At whatever point I put it back on, I did it backwards, knowing it was out of adjustment upwards, so I just put it back to the 'top' portion and tightened it up. After realizing that, I put it on the right way and all was well, haha. The ground DEFINITELY needs redone. With the battery relocated to the back, grounded to the spare tire well, the car barely turns over. I grabbed some 2 gauge wire yesterday and ran a ground from the front at the harness, directly to the battery to test things out. Huge help. I'm also going to get rid of the stupid fuse block at the front for the power wire and run a circuit breaker. After getting it fired up, we let it warm up and topped off the coolant and power steering, and made sure there weren't any leaks. After that, we took it out and immediately realized there was a vac leak. So I put the BCS-TIP line back on and the car runs really, really well. There is a TON of throttle response. We cruised it for 20 miles with lots of long 3rd and 4th gear pulls with just a couple pounds of boost. Each time letting it engine brake down to 2-3k rpm. We changed the oil right after that, and it looked good.
| The Following 19 Users Say Thank You to phate For This Useful Post: | 802MS3 (09-13-2012), amoosenamedhank (09-12-2012), Boosten Ya(josh) (09-12-2012), Boost_creep (09-12-2012), btstarcher (09-12-2012), CosmicArkie (09-12-2012), DingoDave (10-01-2012), djuosnteisn (09-12-2012), Downmented (09-12-2012), J-Liss (09-12-2012), JacksonMS30 (09-12-2012), lilred (09-12-2012), Micha (09-18-2012), naoandlater (09-12-2012), silvapain (09-12-2012), Speed_j23 (09-12-2012), TiGraySpeed6 (09-12-2012), vtekken (09-12-2012), wolly6973 (09-12-2012) |
![]() | | #91 | ![]() |
Let's hope this ends the fail in this car's life. Good stuff!
| The Following 5 Users Say Thank You to Lex For This Useful Post: | Boost Addict (09-12-2012), djuosnteisn (09-12-2012), jracer (09-12-2012), phate (09-12-2012), Speed_j23 (09-12-2012) |
![]() | | #92 | ![]() |
| Unicorn Farts ![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 1073 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,314
Groans: 96
Groaned at 35 Times in 28 Posts
| Not Ranked : 0 score phate did you get those crazy pistons for your car yet?
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms |
| The Following User Says Thank You to Deldran For This Useful Post: | phate (09-12-2012) |
![]() | | #93 | ![]() |
__________________ -06 MS6 - Tuning the high compression forged mill -Corn fed 07 MS3 - Sold | |
| The Following User Says Thank You to phate For This Useful Post: | Speed_j23 (09-12-2012) |
![]() | | #94 | ![]() |
Groans: 96
| Not Ranked : 0 score man they sure take there time, i am sure they will be great once you get them. Cant wait to see a high comp DISI should be interesting
![]() | | #95 | ![]() |
![]() Join Date: May 2011 Location: Sykesville, MD
Rep Power: 788 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 519
Groaned at 49 Times in 20 Posts
Glad to see you got it running!
__________________ 2008.5 BM MS3 // Cobb AP // JBR 3.5" WP Full Intake // CXRacing Piping/Godspeed Core // CNT 3" Catted Downpipe // Custom 3" CBE // KMD v2.1 Fuel Pump Internals // Turbosmart Dual Port BOV // Raceland Coilovers // JBR 88Duro Dogbone RMM // JBR SSP // SURE AGS Knob // Denso ITV22 // Aeroforce Interceptor Scan Gauge // STACK Boost Gauge // DDM 6k Low HID's // CP-e Towplate // CP-e Defrost Vent Pod // 15% Tint // 17x9.5 Work Equip Anhelos FREEK PERM ![]() |
![]() | | #96 | ![]() |
Groans: 81
the circuit breaker from autozone works well on my relocation to trunk, you can use the seat belt bolt from the back seat as a ground to have less wire.
| The Following 3 Users Say Thank You to J-Liss For This Useful Post: |
![]() | | #97 | ![]() |
Ran a 2 gauge ground wire from the front to the back today. Seemed to help with the one time it turned over and fired up. Drove it for a few miles and went back to give it a wash. Now there's nothing, lol, won't turn over. I'm sure the fuse block and connection to the starter need upgraded, so that's the next step. When I jumped it last night, I connected it to the front where the battery would go and it turned over/started like normal. Car runs well, though.
| The Following 5 Users Say Thank You to phate For This Useful Post: | djuosnteisn (09-13-2012), J-Liss (09-13-2012), jracer (09-13-2012), Speed_j23 (09-12-2012), wolly6973 (09-13-2012) |
![]() | | #98 | ![]() |
Groans: 81
hm, what guage power wire are you running, when i relocated to the back, i grabbed some autozone GOLD jumper cables and cut the ends off, and split them, you have red (+) and black now (-) i took the negative terminal and grounded it to the tranny mount. then cut the end off the positive end, put a terminal on it, with nut and bolt, to one end of the new positive cable, and ran that all the way to back of hatch to the battery, to circuit breaker/then circuit breaker to positive batter. and grounded battery to seatbelt bracket under seat. always cranked even dead in winter. Maybe battery is weak?
![]() | | #99 | ![]() |
![]() Join Date: Jun 2012 Location: San Jose, CA
Rep Power: 676 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,510
Groans: 30
Groaned at 42 Times in 26 Posts
| Not Ranked : 0 score That's what I'm thinking. I would try leaving it on a trickle charger or something. It probably got pretty weak from all the no-start cranking you were doing.
__________________ 2006 Mazdaspeed6 Cobb AP | E30 | HTP 3" | JBR 80A | Autotechs 250AWHP | 280AWTQ |
![]() | | #100 | ![]() |
We had the battery on a trickle charger overnight and it would barely turn the car over. I pulled the battery out of my car and it does the exact same (and it turned over my car just fine afterwards). When I jumped it, I connected at the front of the car and it turned over like normal. There's a weak link in the connections somewhere. Right now, there is a ground wire from the battery to the spare tire well, and a ground from the battery to the front, bolted to the body. The main ground from the engine harness is bolted to this same point in the front. The power wire (looks to be 0 gauge) goes from the battery to the front, to a two prong fused distribution block. One side then goes to the starter wire in the main harness, the other goes to the other (smaller) power wire to power everything else. It's the downstream side of this fuse block I connected to when I jumped it. The fuse block gets hot as hell after cranking for just a couple seconds. All the more reason I think it's the weak link.
![]() | | #101 | ![]() |
Groans: 81
yea i would remove the distribution block. on the mazda 3, my line wasnt long enough to reach from front to back, so i bought another guage line and did a soldered bolt and nut connection and continued half way to rest of the car, and car would not crank enough to spin the flywheel hard enough, i removed it, did solid line. car cranked perfect. wait. on the power line do you have a line from the starter, starter to the fuse box, fuse box to the distribution block, distribution block to the battery.
![]() | | #102 | ![]() |
Power wire goes: Battery->fused distribution block in engine bay->starter and other harness power wire. There really needs to be a fuse or circuit breaker at the battery, but that's not how the car came. I'll deal with that once I have it starting reliably.
![]() | | #103 | ![]() |
Groans: 96
Might be helpful. Granted this is with battery still in the front just modify instruction to battery in the back. Did this on my old car man does upgrading the stock wires really help with cranking and everything
![]() | | #104 | ![]() |
Groans: 81
ok, i think i know why this isnt working. you will have to wire it like this for it work, which is how my mazda 3 is now, starting from engine bay: alternator-starter-fuse box main power supply-circuit breaker-battery.
![]() | | #105 | ![]() |
Think I'm going to need some mspaint diagrams.
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #106 | ![]() |
Groans: 81
![]() | | #107 | ![]() |
Groans: 96
My bad post fail meant to link this video http://m.youtube.com/watch?v=p82xRzC...%3Dp82xRzCr-lc from galaxy Nexus vis CM10
| The Following User Says Thank You to Deldran For This Useful Post: | phate (09-17-2012) |
![]() | | #108 | ![]() |
| SPEED PERF6RMANC3 ![]() ![]() Join Date: Jun 2011 Location: Laurel, Maryland
Rep Power: 2082 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,176
Groans: 273
Groaned at 55 Times in 37 Posts
So i wonder if our alternators crap the bed after sitting with no battery in the car for a significant period of time. My MS6 as well as a friends MS6 both sat for a little while with no battery, we then got everything back to where we could start it again. And with good batteries in the car, it wouldnt turn over and start. It would try to start, just wouldnt actually turn over. With a jump the car would start and run, but it would need a jump again to start again. I dont really have anything to back this theory, just sounds very close to the problem you are having.
__________________ //KILLAH BUILT, SPEED PERF6RMANC3// Steedspeed T4 Twin Scroll // Precision 6265 Single 44mm Wastegate. KILLAH BUILT //FREEKPERM // Nuffsaid
| The Following User Says Thank You to Downmented For This Useful Post: | phate (09-17-2012) |
![]() | | #109 | ![]() |
Groans: 96
Sent from galaxy Nexus vis CM10
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms | |
| The Following 2 Users Say Thank You to Deldran For This Useful Post: | Downmented (09-17-2012), phate (09-17-2012) |
![]() | | #110 | ![]() |
Groans: 273
Just throwing some thoughts out there thats all
![]() | | #111 | ![]() |
Groans: 96
![]() | | #112 | ![]() |
![]() Join Date: Sep 2012 Location: Glen Burnie, Maryland
Rep Power: 30 ![]() Thanks: 8
Wow what a job. Its nice to see someone tear a car down to the bare heart and build it up like that. Good job. Coming from a mechanic.
![]() | | #113 | ![]() |
Groans: 81
issue resolved clint?
| The Following User Says Thank You to J-Liss For This Useful Post: | phate (09-17-2012) |
![]() | | #114 | ![]() |
Didn't get a chance to work on it all weekend :/
![]() | | #115 | ![]() |
![]() Join Date: May 2011 Location: Portage, IN
Rep Power: 454 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,102
Groans: 83
Man you are a true mad scientist when it comes to Speeds. It's really cool to see another members car getting "recycled", and put to a good new home.
__________________ -#1 2007 Mazdaspeed 3 GT Black Mica - BBS RX in Dark Gray, KW V2s, SPC Camber Arms, Cobb AccessPORT w/ JBR mount, Full-Race Prostock Mani, TurboXS FMIC, Grimmspeed EBC, ACT 6 puck & flywheel, TWM STS, PTP Internals, Cobb SRI w/ TIP, Cobb Shift Weight, TurboXS BPV, TurboXS Full TBE, JBR Trilogy, JBR RSB, Cobb FSB...........needs bigger turbo -1970 Chevelle - Needs full resto |
![]() | | #116 | ![]() |
| OG Pu ![]() Join Date: Jun 2010 Location: Wichita, KS
Rep Power: 1276 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 38,312
Groans: 385
More than one member at that. Any parts from my motor make it on this one, or are you saving those for the other build? Sent from my SAMSUNG-SGH-I777 using Tapatalk 2 |
| The Following User Says Thank You to wolly6973 For This Useful Post: | phate (09-17-2012) |
![]() | | #117 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 329 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 600
Groaned at 25 Times in 10 Posts
another reason why MSF is so bad ass and dizzy tune is number one!!!
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 Bolted and getting Dizzy!! |
![]() | | #118 | ![]() |
![]() | | #119 | ![]() |
If anyone would like any part of the process outlined in more detail, I'll be doing my 6 in the next couple months. Just let me know and I'll try my best to get the info as I go along.
![]() | | #120 | ![]() |
Rear diff mount is finally in lol. Rear shocks were blown, so I'm putting in some oe replacements. It's been slow progress recently.
| Report: Fiat to build Alfa Romeo SUV alongside Jeeps in America, build small car in Italy | Haltech | Automotive News | 0 | 09-02-2011 06:20 AM |
| Chrysler prepares to build Dodge small car | Haltech | Automotive News | 0 | 06-29-2011 09:00 PM |
| Chrysler prepares to build Dodge small car | Haltech | Automotive News | 0 | 06-24-2011 09:00 PM |
| GM announces plans to build new small car in U.S. - but which one will it be? | Haltech | Automotive News | 0 | 05-29-2009 12:00 PM |
| Windsor plant may build small Fiats | Haltech | Automotive News | 0 | 04-19-2009 09:10 PM |
