MSF Wikispeedia
Wiki General Discussion
Like Tree7Likes
 Old 03-20-2014, 09:42 AM   #41
Gr8Speed's Avatar
Posts: 5,702   (View Stats)
Gr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the worldGr8Speed is the leader of the world
Groaned at 123 Times in 84 Posts
It helps that everything can (should) have references as well, though I do agree that someone at least knowledgeable (preferably a subject matter expert) should be in charge of editing their specific section.
And having one person in charge of each section would relieve the workload.
https://www.youtube.com/user/JustinBieberVEVO
Gr8Speed is offline   Reply With Quote
 Old 03-20-2014, 12:12 PM   #42
Gr8Speed's Avatar
@Enki; If you want I could get started on the build paths. I think that section should be split into two sections: Power and Handling. Or should things like RSB, Motor Mounts, etc. just be left out? Or possibly added in with notation that they are optional?
You will have your typical build path of Intake, TIP, HPFP, AP, TP/DP, IC. But there are also some others that could be added as suggestions. Also, I think it would be worthwhile to include information on available parts and link to respective reviews of said parts.
The Following User Says Thank You to Gr8Speed For This Useful Post:
Enki (03-20-2014)
 Old 03-20-2014, 01:31 PM   #43
Eth Fiend
phate's Avatar
Posts: 6,932   (View Stats)
Once you guys have the structure finished, I'll start adding. I feel it's a bit premature right now.
-06 MS6
-Corn fed 07 MS3 - Sold
Enki (03-20-2014), Neverlift (03-20-2014), Nliiitend1 (03-20-2014)
 Old 03-20-2014, 02:27 PM   #44
Enki's Avatar
Posts: 7,540   (View Stats)
Groans: 189
There should be a list of mods every car should have regardless of goals like intake, rear motor mount, hpfp internals, AP/Tune, etc and then we can go to optional power/suspension mods like downpipe, catback, side/trans mounts, etc. This can be all on the same page with variations for the model years; I.E. Pu TMIC are pretty damn good I hear, and HPFP internals should be one of the first mods done, whereas this isn't as stringent a requirement on a Won, and Sixes have more mounts required. Stuff like that.
ItsNox (04-01-2014)
 Old 03-20-2014, 02:30 PM   #45
Neverlift's Avatar
Posts: 4,699   (View Stats)
Groans: 1,143
I have some info I could fill in for the MS6... I guess I should create an account.
Past Mazdas & Speeds
The Following User Says Thank You to Neverlift For This Useful Post:
Enki (03-20-2014)
 Old 03-20-2014, 02:37 PM   #46
Gr8Speed's Avatar
Alright. I started and got like 1 sentence done and had something come up. I'll get a start on it this weekend.
Enki (03-20-2014)
 Old 03-21-2014, 08:45 AM   #47
Police - Grammarhead
Vansquish's Avatar
Groans: 1,863
I tweaked your wording a bit. I'm a little concerned about having a bunch of canned advertising material on the Wiki. It makes the whole thing seem a lot less neutral. If you're dead-set on it, we can leave it though.
The mod path page is a perfectly reasonable way to go, but perhaps the information that's there so far really belongs in the intake page, no?
 Old 03-21-2014, 08:47 AM   #48
Gr8Speed's Avatar
That's true. Maybe I should leave out the options on the market and just go over what the mod does, and some options as far as specs (ex. 3" and 3.5" intake)
 Old 03-21-2014, 08:59 AM   #49
Vansquish's Avatar
Groans: 1,863
I think it's perfectly reasonable to have the options out there, but the information should probably get ported over to the "Intakes" page. I've added a bunch (I'm bored at work). Take a look and see what you think thus far.
 Old 03-21-2014, 09:01 AM   #50
Gr8Speed's Avatar
I'm liking it so far. I agree though that that info should get moved to the intakes page. Leave this for a description of each mod.
Vansquish (03-21-2014)
 Old 03-21-2014, 09:09 AM   #51
Vansquish's Avatar
Groans: 1,863
SURE thing...har har. I'll port it over and leave some intro material.
Gr8Speed (03-21-2014)
 Old 03-21-2014, 10:08 AM   #52
Gr8Speed's Avatar
Added a bunch to the build path section. What am I forgetting?
 Old 03-24-2014, 04:34 PM   #53
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
Is it possible to show the content links on the main page under the section title? Rather than clicking "The Cars" and then getting that list up at the top. Maybe make it hidden by default with an expand button. Like this:
The Cars
_________________________
A description of the vehicles covered by this Wiki
Contents [+]
The Cars
Contents [hide]
1 The Five Mazdaspeeds
1.1 Protege
1.2 Miata
1.3 First Generation MZR DISI
1.4 Second Generation MZR DISI
2006 Mazdaspeed6
 Old 03-24-2014, 05:15 PM   #54
Enki's Avatar
Groans: 189
Probably, but you might have to look it up in the cheat sheet.
 Old 03-27-2014, 06:45 AM   #55
Vansquish's Avatar
Groans: 1,863
Have you guys noticed that under "recent changes" we're getting a ludicrous number of spam-bots?
 Old 03-27-2014, 09:34 AM   #56
someguy's Avatar
Posts: 914   (View Stats)
someguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the worldsomeguy is the leader of the world
Groans: 24
Groaned at 166 Times in 32 Posts
@Haltech;
Ya, serious spammer problem...creating pages all over.
- 2010 Mazdaspeed 3 Black Mica -
- Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 -
- SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace -
- CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint -
someguy is offline   Reply With Quote
 Old 03-27-2014, 11:53 AM   #57
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
I disabled new accounts. I saw it happen yest. Had over 1500 email for account confirmation stuck in the email que. Thats when i put two and two together.
We can copy what we need and wipe it out, then start over or edit what was done.
I had no idea this shit would become an invasion for them.
The Following 3 Users Say Thank You to Haltech For This Useful Post:
Enki (03-27-2014), sidekick (03-27-2014), someguy (03-27-2014)
 Old 03-27-2014, 02:11 PM   #58
Enki's Avatar
Groans: 189
I'll take a full text source backup of what we have now a bit later today and let you know so you can wipe it out, Hal.
 Old 03-27-2014, 07:02 PM   #59
sidekick's Avatar
Groans: 47
Damn lol why would spam bots even attack a random wiki?
2006 Mazdaspeed6
 Old 03-27-2014, 07:13 PM   #60
dale_gribble's Avatar
Posts: 4,720   (View Stats)
I think bots are pretty much going after anything all the time. Just IP/port scanning and looking for opportunities anywhere.
MINI H1 6.0 - CAR LED TAILS
 Old 03-28-2014, 10:25 PM   #61
Enki's Avatar
Groans: 189
OK CUNTS
Wiki is back up and cleaned up/restored. I've not restored the pages which only had 1-2 words and I've also not restored the pages "tires" and "struts" since they appeared to be orphaned (I have manual backups though).
PM me for user account creation; ONLY FOR PEOPLE THAT WILL ACTIVELY CONTRIBUTE!
If you only want an account to fuck around with the wiki, this is NOT FOR YOU!
someguy (03-29-2014)
 Old 04-01-2014, 01:55 PM   #62
sidekick's Avatar
Groans: 47
Apparently wikispeedia is already used as a name for other shit, not that it really matters.
https://www.google.com/search?q=wikispeedia
Also, @Haltech;, can you add a link to wikispeedia somewhere on the main forum page?
2006 Mazdaspeed6
The Following User Says Thank You to sidekick For This Useful Post:
dale_gribble (04-01-2014)
 Old 04-01-2014, 05:14 PM   #63
sidekick's Avatar
Groans: 47
@Haltech; @Enki;
Can you possibly add this extension so that we can use collapsible lists?
Module:Collapsible_list Module:Collapsible_list
2006 Mazdaspeed6
Enki (04-01-2014)
 Old 04-02-2014, 11:00 AM   #64
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
ill see what i can do with the module. It requires a template modification it looks like and ill have to hunt down some documentation on installation. Some of it is very vague.
sidekick likes this.
 Old 04-02-2014, 11:08 AM   #65
Enki's Avatar
Groans: 189
Lemme know if you run into issues, Hal; I can help get it figured out.
 Old 04-02-2014, 01:12 PM   #66
sidekick's Avatar
Groans: 47
It's not really a big deal, I just think it will make navigation a little easier. If someone is looking for a specific page, they can just get straight there from the main page.
2006 Mazdaspeed6
 Old 04-13-2014, 03:20 PM   #67
sidekick's Avatar
Groans: 47
@Haltech; @Enki;
Were you able to get that module setup?
2006 Mazdaspeed6
 Old 04-13-2014, 03:25 PM   #68
Enki's Avatar
Groans: 189
I don't have direct access to the source. I'm just a wiki admin until everything is updated/running how it should be and then I'm getting removed as admin.
Truth is we need more people entering data...been almost two weeks since anyone's done anything.
Last edited by Enki; 04-13-2014 at 03:25 PM. Reason: MSF Database - Automerged Doublepost
 Old 04-23-2014, 08:05 AM   #69
sidekick's Avatar
Groans: 47
I've been pretty busy with work/school lately, but I will try to get some info added on my days off. I don't want this to die, because it's already come in handy for me personally. I searched for something on google and the wiki popped up with an answer. Lol.
2006 Mazdaspeed6
Enki (04-23-2014)
 Old 04-23-2014, 09:46 AM   #70
Enki's Avatar
Groans: 189
I'm personally working on what I guess would be Albior's V2... Hopefully I'll get some time today to start putting in the first section or even further.
86AmishMs3 (04-28-2014), WetzMS3 (04-23-2014)
 Old 10-04-2014, 01:50 PM   #71
Bords's Avatar
Posts: 1   (View Stats)
Bords is an unknown quantity at this point
Default Im a newby
I'm 73. I've had British sports cars all my life: MG's, Triumphs, and A-Hs. I'm thinking of buying a 2008 MazdaSpeed3. I was blown away by the quickness and handling of the car on my test drive. Is there a place on this forum where I can read an introduction to this car? What is the difference between Gen 1 and Gen 2?
Bords is offline   Reply With Quote
 Old 10-06-2014, 07:12 AM   #72
Mattyhawk1's Avatar
Posts: 739   (View Stats)
Mattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the worldMattyhawk1 is the leader of the world
Hi Bords
You want to start here:
http://www.mazdaspeedforums.org/foru...st-read-99499/
Mattyhawk1 is offline   Reply With Quote
It's time for Abilors Tooning guide to become a WIKI page dale_gribble
85 06-01-2014 09:52 AM
Format's MS3 Format 2010 MS3 - Build Diaries 17 10-11-2013 03:08 PM
Wiki Section on the forum. Constantin Website Help/Feedback 32 08-06-2012 08:04 PM
MotoGP to return to 1000cc format, MotoCzysz back in the mix? Haltech Automotive News 0 12-17-2009 05:10 AM
Dead format rises from the grave Haltech Computers & Technology News 0 04-11-2008 07:30 AM
Page generated in 0.50327 seconds with 31 queries
