 Old 10-05-2016, 05:22 PM   #1
pastry00's Avatar
Posts: 154   (View Stats)
pastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud ofpastry00 has much to be proud of
Groaned at 5 Times in 1 Post
Default Accessport not reading boost?
I have a custom tune form PD tuning. Just the other day i was driving the car and the boost gauge on the cobb accessport stopped reading the correct psi. It always says either 10.27 or 9.38 with minor fluctuations. Does anyone know what would be causing this. The car still drives the same and i am running the same boost pressures it is just not being read properly by the accessport. Thanks
pastry00 is offline   Reply With Quote
 Old 10-06-2016, 08:30 AM   #2
Thor Hammer's Avatar
Posts: 1,821   (View Stats)
Groans: 205
Call Cobb. I'm sure they can help you out.
 Old 10-06-2016, 08:34 AM   #3
qtrmile beast's Avatar
Posts: 2,417   (View Stats)
Does car still feel like the boost you think you are supposed to be getting? maybe your map sensor is bad.
track weight 3220
street weight 3370
 Old 10-06-2016, 07:08 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
^^^ I would check the connection to your MAP sensor. Maybe with those numbers you got it mixed up with your MAF sensor and you're running rich :-)
 Old 10-07-2016, 10:01 AM   #5
pastry00's Avatar
The feels to be hitting boost properly. I have a 3.5 bar map sensor from corksport and just pulled it and looks to be in tact.
 Old 10-07-2016, 11:17 AM   #6
tegxsi's Avatar
Posts: 1,237   (View Stats)
Groans: 87
Hopefully you are load tuned but your boost cut probably won't work right. What does boost read when your key on and engine off?
If it's not reading close to zero then your MAP sensor probably went bad.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 10-07-2016, 06:51 PM   #7
MRR
MRR's Avatar
Posts: 95   (View Stats)
MRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to beholdMRR is a splendid one to behold
Pretty sure your MAP sensor is on its way to heaven. Do a log and look for abnormal readings such as static or drastic boost changes. Get in touch with CS.
MRR is offline   Reply With Quote
 Old 10-15-2016, 02:52 PM   #8
pastry00's Avatar
So corksport ended up sending me a new map sensor. But when i went to install it the car wont start. I put the old one back in and the car also wont start. It wont even trunover. I already checked the battery and the keys if anyone has suggestions let me know thanks.
 Old 10-15-2016, 06:44 PM   #9
sheston's Avatar
Any dash lights? I set off my anti theft stuff and couldn't start mine, but you will see the light to tell you.
Does it click? Everything else work?
 Old 10-15-2016, 06:57 PM   #10
pastry00's Avatar
The car clicks but no crank. Everything else works. No lights are on either.
 Old 10-16-2016, 06:22 PM   #11
sheston's Avatar
How did you check the battery? I would suggest reseating the connections and make sure they are good. Also, have someone monitor the battery voltage as you crank
Sounds like you may have a weak battery or bad connection
Scangause 2 Boost reading is off? cjanota 2010 MS3 - Car Audio & Electronics 1 05-02-2012 06:26 PM
boost reading dead wrong on AP nick779 2010 MS3 - ECU Computer Tuning 6 03-14-2012 01:04 PM
Help Not Reading Boost Lakespeed6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 06-16-2011 06:17 AM
Boost gauge vs. AP boost reading.. which is correct? Unoriginalusername MazdaSpeed 3/6 - Turbo Induction 13 05-23-2011 04:41 PM
DH boost reading k0m MazdaSpeed 3 - Engine, Transmission & Driveline 4 10-08-2009 05:49 AM
Page generated in 0.29708 seconds with 25 queries
