![]() | | #1 | ![]() |
![]() Join Date: Feb 2009 Location: Flanders, NJ
Rep Power: 244 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 205
Groaned at 9 Times in 5 Posts
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//PG FMIC//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//SenSens + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// ![]() ![]() |
![]() Join Date: Nov 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 221
Groaned at 12 Times in 8 Posts
My ap also shows as low as 9 sometimes, its usually between shifts however. From what I understand the injectors shut off when the clutch is pushed, that would make sense then right?
__________________ 2010 Blue Mazdaspeed3 CP-E Nano Intake - JBR Dogbone 88D - Cobb AP - Sure Shortcut - 20% tint - Blox 490g shift knob - Big stereo system (WIP) - Forge V1 BPV - KDM V2 FP Internals - 10k DDM HID's (lows) - 30k HID's (fogs) - UR CBE (no mufflers) - Vibrant Ultra Quiet resonator - CP-E TMIC - UR Resonated Test Pipe - Dano Perm Tune - Blockhead Dual Gauge Vent Pod (painted) - Aeroforce Interceptor x2 |
well yea I know what you're talking about but I was watching the AP as I was flooring it so it couldn't be that. On my commute to work tomorrow I'll try and replicate it and see what happens.
![]() | | #4 | ![]() |
![]() Join Date: Nov 2009 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,041
Groans: 64
Do a datalog and post it up, it will be a lot easier to help out.
![]() | | #5 | ![]() |
![]() Join Date: Jan 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,186
^^ and subbed for results
__________________ T3 GTX 3076R .82 a/r, ATP wide-mouth turbo inlet, CPE FMIC, 3.25" MAF custom intake, HKS BPV, Steedspeed T3 Exh. mani, CPE High Output Fuel Pump, Streetunit MM, CP-E side mounts, Mazdaspeed CBE, v-band custom DP, TiAL 38mm EWG, DO stg 2 meth 75/25 w/ do7, 3.5 bar MAP, Cobb AP, TWM solid shifter base bushings, BC racing 32 way adj. coilovers, Mazdaspeed camber links, 18" Bronze Enkei wheels |
![]() | | #6 | ![]() |
checked my LTFT this morning. Idle was -16, yikes! I reflashed and things don't look much better. Idle currently at -10, -8 during normal acceleration. When I calibrated my MAF 6 months ago it was perfect, so either I have a leak somewhere on the intake side or something else is messed up. I will post a log after work but I still have the old ATR so my boost will show up all weird.
![]() | | #7 | ![]() |
Well I attached a datalog. It is still with the old ATR so my boost is obviously reading wrong, not sure if anything else is affected. My apologies for the horrible log, but my car is definitely acting weird so I didn't want to continue. Definitely worried about my wastegate being at 99 and my AFR dropping to mid 10's with barely any throttle. Only about 10 miles on the reflash so maybe that has something to do with it. Will definitely make some better pulls tomorrow.
![]() | | #8 | ![]() |
| (Toe-kay) ![]() Join Date: Jan 2011 Location: Cambridge Ontario Canada
Rep Power: 8980 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,141
Groans: 523
| Not Ranked : 0 score That would make between shifts lean. Not rich.
__________________ ![]() ![]() Tokay Racing BeCuse Seals. BeCuse you need these. Demodded. Mwho? |
![]() | | #9 | ![]() |
![]() Join Date: Jun 2010 Location: Santa Fe NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,637
Groans: 371
Groaned at 62 Times in 39 Posts
whats up with your boost? looks like you are wot but it looks like the software is of so i have no idea if those are all correct to begin with |
| The Following User Says Thank You to I Love Brownies For This Useful Post: | sallyspeed3 (05-23-2011) |
![]() | | #10 | ![]() |
as far as I know, cobb said it was only boost that wouldn't read correctly if you're map is a 107 and your AP is updated to the new software. I wasn't close to wot, throttle is only in the high 30's. Like I said I could tell my car acting weird so I didn't wanna push it.
![]() | | #11 | ![]() |
Groans: 523
I see low 9's at wot a bit on a stock tune. But you say you weren't wot?
![]() | | #12 | ![]() |
yeah not even close. after i eat I'm gonna fill up the tank and do a few more pulls and see what happens. will post in about an hour.
![]() | | #13 | ![]() |
Rep Power: 7959 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,115
Groans: 34
your LTFTs are way in the negative so I suspect your MAF cal is way off. This would both support the -9 Logged LTFT and the -16 you posted along with 10AFRs. Maybe your intake had a leak when you calibrated months ago and now it isn't leaking, leaving you way too high on your MAF cal. Also the .7 KR will cause the ECU to inject more fuel so it adds to the richness in the beginning of the log. Looks like the maf is off the most around 3.31 volts. If you see that 9AFR occur multiple times in that range its def the maf.
__________________ ![]() ![]() PERM ![]() 07 Red MS3 GT - E40 - JBR 3.5 WidePath - ATP GTX3071 - Forge BPV - GA - Cobb v2 FMIC - SS Exmani - Cobb DP - CNT CBE - AP w PERMTune - Grim EBC - Dano OCC - CPE CDFP - Labonte S2 WMI/w failsafe - ACT Street Kit - SUv2 RMM -"Stiffy" MM - DG CF wing ext, skirts & front lip - Hotchkis RSB/FSB w PowerGrid Links - Koni FSDs - DBA SX4000 Rotors - Hawk Pads - Silver OZ Ultraleggera - 235/40/18 NT-05
| The Following 4 Users Say Thank You to Dano For This Useful Post: |
![]() | | #14 | ![]() |
Well I changed from my ATR map to the OTS v108 91 Octane SRI + FMIC. LTFTs are much better. -2 normal acceleration, -6 cruising, and close to 0 during hard acceleration(not wot). Car feels much better, noticing AFRs aren't as rich and it pulls much harder, attached a couple datalogs. When I get the time I'll calibrate the MAF using this map as a base.
![]() | | #15 | ![]() |
![]() Join Date: Apr 2009 Location: LOUISIANA!! Football, Guns, Cars, Crawfish, and Beer
Rep Power: 671 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 735
Could weather be a factor? MAF cal in November in NJ vs temps in May? This is why I aim to log at least once a month. Glad you're running better.
__________________ Traded |
| The Following User Says Thank You to Abilor For This Useful Post: | sallyspeed3 (06-07-2011) |
![]() | | #16 | ![]() |
Still tweaking every couple of days with ATR but my ltfts have settled nicely. Attached some datalogs that I did tonight. First one is 3rd barely getting into 4th. I got scared cause I thought I saw a cop behind me on the highway I was getting onto. 2nd datalog I thought I was at wot, but turns out I wasn't. Still, these are the first logs that I've seen my Load go over 2.0 so I guess thats a good thing.
| The Following User Says Thank You to sallyspeed3 For This Useful Post: | Abilor (06-09-2011) |
![]() | | #17 | ![]() |
Good deal. Can you do a full log? 2500 - 6500 RPM at WOT. Cool Fuel Pressure bro! No knock... Looking good. What are your goals again? Sorry, I jump in and out of a lot of threads...
![]() | | #18 | ![]() |
My goals power wise are to finish with bolt ons, just need the CNT catted DP, once i get that I'll get it protuned and I think I'll be done, although it would be nice to get an exhaust manifold. Other than that, get some konis to go with my H&R's that are sitting in my garage and I'll be content.....(I think). I'll try and do a full log tomorrow, what gear should I do it in? 4th?
![]() | | #19 | ![]() |
K, here are 2 logs. Both in 4th gear @ wot. Boost only gets to 15, which I've noticed in 1 gear runs. If I had started in 3rd gear and shifted into 4th then I would have hit higher boost. Is that normal? I feel like I should be getting to full boost in any gear at wot.
![]() | | #20 | ![]() |
![]() Join Date: Apr 2010 Location: Aurora, IL
Rep Power: 214 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 41
How did you get your sample rate so high with so many values logged?
