![]() | | #1 | ![]() |
![]() Join Date: Mar 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
__________________ 2008 Black Mica Cobb SRI // Cobb TIP // Cobb AP // Sure RMM // Autotech Internals H&R Springs // Koni Yellows // Borbet LV5 |
![]() Join Date: Apr 2012 Location: maryland
Rep Power: 35 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| reachin' around ![]() Join Date: Mar 2011 Location: Boca Raton, FL
Rep Power: 4308 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,956
Groans: 565
Groaned at 29 Times in 27 Posts
This guide will give you more detail on how to remove the pump itself. The one above explains the internals part well Fuel Pump internals Install!
__________________ Fast cars are for straight lines. Corners are for fast drivers. Sold: 2011 MS3 Hypnotic Tuned @ 322whp/370tq 2012 Evolution X GSR - 394awhp / 378awtq K&N Intake -|- ETS FMIC + UICP + LICP -|- OBX DP/TP -|- Invidia N1 Sinlge Tip CBE -|- Grimmspeed 3-port EBCS -|- FIC 1100cc Injectors -|- Walbro 255lph FP -|- Forge BPV -|- Innovate Wideband AFR / Boost Gauge -|- GoldenEvo E85 Tune -|- TEIN Monoflex Coilovers -|- Hotchkis 32mm RSB -|- Whiteline Rear Endlinks -|- Cusco Front Strut Bar -|- Hawk HP+ Pads -|- Goodridge SS Brake Lines -|- Motul RPF600 Brake Fluid -|- XXR 527 18x9.75 -|- Hankook Z214 C91 275/35/R18 Racing Slicks |
![]() | | #4 | ![]() |
![]() Join Date: Jul 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 596
__________________ SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB | 286awhp / 346lbs tq @4500 ft ASL [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to redmnsterut For This Useful Post: | Mazdaspeed666 (06-22-2012) |
![]() | | #5 | ![]() |
![]() Join Date: Feb 2010 Location: Kailua
Rep Power: 555 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 208
Not that hard, just make sure you don't break any of the fuel line clips (yellow an blue). Also cross your fingers that your cam won't be in the up position when you pull the pump. Can be a bitch to maintain pressure on that spring when trying to tighten down the three Torx bolts holding it to the engine. Get some brake cleaner and spray down the Entire pump and internals. Be sure to have some engine oil handy to coat the internals prior to install, and the large o-ring on the housing. Good luck! It's really not that hard at all, just be clean and don't drop It in a bucket of sand. |
| The Following 2 Users Say Thank You to Spoofmastafly For This Useful Post: | keridil (09-17-2012), Mazdaspeed666 (06-22-2012) |
| Autotech Internals | PapaSmurf | 2010 MS3 - Fuel, Nitrous & Water Injection | 240 | 07-25-2012 09:59 AM |
| Autotech Internals install help!!!! | Jake_MS3 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 44 | 04-02-2012 04:12 PM |
| Abilor's Autotech Internals Install Adventure | Abilor | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 8 | 03-04-2012 08:56 PM |
