 Old 10-03-2016, 07:23 PM   #1
Boynton speed3's Avatar
Posts: 10   (View Stats)
Boynton speed3 has a little shameless behaviour in the past
Default Boost gauge
So I was on wot on i95 today and my boost gauge said 5-7lbs??? But my ap logged highest boost hit was 19.4psi. So what can be wrong maybe hole in my vacuum line? Or??? Please any feedback will help...
Boynton speed3 is offline   Reply With Quote
The Following User Says NO Thank You to Boynton speed3 For This Un-useful Post:
g00s3y (10-06-2016)
 Old 10-03-2016, 07:32 PM   #2
Police - Grammarhead
Vansquish's Avatar
Groans: 1,827
What tune are you running?
 Old 10-03-2016, 07:34 PM   #3
Stage 3 93 octane. I'm fully bolted ..
 Old 10-03-2016, 08:13 PM   #4
Vansquish's Avatar
Groans: 1,827
Yup...overboosting.
g00s3y (10-06-2016)
 Old 10-06-2016, 03:26 PM   #5
So you think I do have a hole in my vacuum line on boost gauge??
g00s3y (10-06-2016)
 Old 10-06-2016, 05:13 PM   #6
g00s3y's Avatar
Posts: 2,128   (View Stats)
Groans: 439
No, you've got a lot of reading to do.
You need to change up your wgdc so you start hitting your boost targets.
 Old 10-06-2016, 05:20 PM   #7
Also I wanted to ask you what numbers you are seeing on your fuel pump pressure?
 Old 10-06-2016, 05:20 PM   #8
GabbyChaves's Avatar
Posts: 128   (View Stats)
GabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the worldGabbyChaves is the leader of the world
Post up a log
GabbyChaves is offline   Reply With Quote
The Following User Says Thank You to GabbyChaves For This Useful Post:
g00s3y (10-06-2016)
 Old 10-06-2016, 07:50 PM   #9
sheston's Avatar
Posts: 1,844   (View Stats)
In answer to the OP's real question, yes, I assume you have a leak in your boost gage somewhere. Or it's not tapped into the right place.
 Old 10-06-2016, 08:32 PM   #10
Last week I went wot and it was boosting 18 19psi
 Old 10-07-2016, 07:55 PM   #11
sheston's Avatar
Connections can come loose
 Old 10-12-2016, 07:38 AM   #12
MSMS3's Avatar
Posts: 2,327   (View Stats)
Groans: 126
Leak in the vacuum line to the gauge or defective gauge. I use a purely mechanical VDO boost gauge because many of the inexpensive digital or electronic gauges don't last very long. If there is a variance between your logs and the gauge, its the line to the gauge or the gauge.
Page generated in 0.30213 seconds with 25 queries
