Notices
 Old 09-19-2012, 07:49 PM   #1
Icon's Avatar
Posts: 38   (View Stats)
Icon has disabled reputation
Default Boost Leak? Stage 2 16psi...
Hey guys,
I just got an AP and have a 2008 with a CPE nano and catted dp.
I'm not sure what exact mods I have on my car due to buying from a dealer :/, but I know I have those.
Cobb told me to run the safe mode map, then try Stg 2 if the fuel pressure was fine.
I found that I was only hitting 13psi briefly on both maps. I then discovered that one of the ends of the intercooler in hose wasn't clamped down - I clamped it and safe mode hit 13psi and stage 2 hit 16psi - tightened every other hose in the system, and still 16psi.
I attached a datalog I did from 3rd to 4th. Before/after WOT and the shift are highlighted in the csv. I have no idea if I'm "hitting my load targets" or not. A/F, fuel pressure, and knock all seem to be fine, but I don't know why I'm not hitting my boost targets in each map (15psi and 17.5psi).
Can anyone look at this and tell me what they think is going on? BPV leak? Normal? Thanks!!
Icon is offline   Reply With Quote
 Old 09-19-2012, 07:59 PM   #2
Blackedout1978's Avatar
Posts: 314   (View Stats)
Blackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the worldBlackedout1978 is the leader of the world
DOnate and the Gods will bestow there knowledge....and also look into this. I would say get an E-tune from one of the pros but you need internals and VIP status for that.
File Type: pdf Abilor's Tuning Guide_V1.0_6_21_2011.pdf (8.91 MB, 29 views)
//CS SRI+TIP// //CS DP// //COBB Piping kit Treadstone tr8 core// //CS CBE// //CS Race pipe// //CS Mid chassis brace// //Forge Recirculating valve// //Auto Tech Internals// //COBB AP Stage 2// //NGK IX one step colder// //JBR EGR Delete, JBR SSB, JBR TBG & coolant bypass// //CPE RMM// //MD OCC// //CS Stub Antenna// //CS Lightweight Lug nut set Black// //CS LED Interior Light Kit// //DDM HID kit 6000k// //CS Fog Lights 7000k//
//Custom
DIZZY TUNE//
CORN FED DIZZY TuNED
Blackedout1978 is offline   Reply With Quote
 Old 09-20-2012, 11:24 AM   #3
Icon's Avatar
Done!
Thanks for the guide!
Anyone mind taking a look at my datalog to see if anything is off?
 Old 09-20-2012, 11:30 AM   #4
ZZB Club Member
6Y MAZDA's Avatar
Posts: 808   (View Stats)
6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world6Y MAZDA is the leader of the world
FWIW I've heard that you don't hit the target boost of 17.5 lbs on the OTS map. The notes on the map say 17.5 +/- 1.5 lbs...which would put you at either 16 or 19 lbs based on the error. I am on a stage 2 OTS map and i only see 16lbs of boost.
2006 Black Cherry Mica MS6 Grand Touring #00584
CP-E 3" Straight Pipe Exhaust. CP-E TMIC. StreetUnit TP. Street Unit RMM. CorkSport SRI/TIP. PTP HPFP Internals. Cobb AP. RichTuned. Denso ITV22. Forge V1 BPV. Blox Shift Knob. VEI Boost Gauge. GenPu MS3 Wheels. Megan Racing Springs.
SOLD: 2009 Mazda 6i GT. 6-Speed MT.
6Y MAZDA is offline   Reply With Quote
 Old 09-20-2012, 11:34 AM   #5
Icon's Avatar
Thanks for the reply!
If that's true, that's kind of makes me uneasy knowing that my car could be tuned better after putting all that money into the AP.
 Old 09-20-2012, 11:37 AM   #6
fivefingerdeathpunch's Avatar
Posts: 160   (View Stats)
fivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond reputefivefingerdeathpunch has a reputation beyond repute
Originally Posted by Icon View Post
Done!
whats your elevation? if you live in a place with high elevation you wont boost as high..
i would still venture to guess that you have a leak... you are pushing a WGDC of 99 up top just trying to push 16psi i feel like it shouldnt be THAT bad. i know the k04 dies up top but i didnt think you would need the 99wgdc to hold 16psi. maybe thats just how it is but anyway...
check your clamps and shit. then do your maf cal... closed and open loop. then try again. then try upping your WGDC as necessary to hit boost targets. see if that is any better.
oh and get fuel pump internals
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
BNR S3 currently being tuned
SURE RMM - VG Sharkfin - HTP 3" TIP - SSP BigMAF SRI - GS EBCS - M2 Catless DP - Autotech HPFP Internals - Fiberglass Badgeless front grill - 20% tint - CAR LED tails - Smoked side markers - Pdipped emblems - Cobb AP - CS LED Interiors/DRL - Sub Preamp - HD lip - NGK Iridium 1step colder - Custom 2.5" FMIC w/ TR8 - Prosport Mechanical Boost Gauge w/ Block8head's Single 52mm VentPod - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV -
fivefingerdeathpunch is offline   Reply With Quote
 Old 09-20-2012, 11:37 AM   #7
Shut The Fuck Up Donny
jman46's Avatar
Posts: 3,104   (View Stats)
jman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the worldjman46 is the leader of the world
Groans: 48
Groaned at 25 Times in 19 Posts
If you get an etune you will love your car even more. That is my 2 cents.
'07 F250 S-Cab Powerstroke 4x4 - MBRP 4" turbo back no cat or muffler, SCT X3 with Innovative Diesel tow and street tune/SPE X-Race tune, Ford blue spring upgrade, Sinister Diesel coolant filter kit
Fuck Toronto.
'07 MS3 - 313hp/323tq - sold - the FIRST EVER FREEKPerm.
'06 F150 SCrew 4x4 5.4l - sold
'03 Marauder - Vortech on only 8psi 485rwhp/435rwtq - sold
'95 Mustang GT - sold
'95 SHO MTX - sold
jman46 is online now   Reply With Quote
 Old 09-20-2012, 11:38 AM   #8
snailD's Avatar
Posts: 2,036   (View Stats)
but hey you get a sweet monitoring device and the power to make more power. the ots maps are something to start with, they need to make the maps safe for all speeds in all conditions
GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22
EBAY DP wCAT/ CP-E RMM 75D/ HKS BPV/CP-E FP
COBB EBCS/ PG FMIC/ TR8 CORE
13.2 @113.6 @ 4500ft ASL [443/409]SAE CORRECTED
snailD is online now   Reply With Quote
 Old 09-20-2012, 11:45 AM   #9
Harvestor of PU
Harvey PU's Avatar
Posts: 1,798   (View Stats)
Harvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the worldHarvey PU is the leader of the world
Groans: 170
Groaned at 25 Times in 20 Posts
Icon can you post up the map you are using?
2012 BM MS3 w/ tech. No bolt ons. self tuned.
Harvey PU is online now   Reply With Quote
 Old 09-20-2012, 01:15 PM   #10
Icon's Avatar
Thanks for all of the replies! You guys are great.
I should have mentioned the map before:
Stage2+cpCAI 93
And I live in Nashville (597ft)
I will upload the safe map datalog when I get home tonight.
 Old 09-21-2012, 12:22 PM   #11
Icon's Avatar
Well, I forgot to upload the safe mode datalog, but I ordered some charge tubes to see if that will help.
I also noticed that safe mode was only putting the wastegate to ~55% when I was monitoring it this morning on the way to work.
 Old 09-21-2012, 12:34 PM   #12
Whiteboy's Avatar
Posts: 1,916   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 128
Groaned at 34 Times in 22 Posts
Bucker rfinkle2
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is online now   Reply With Quote
 Old 09-21-2012, 12:40 PM   #13
smoogs12's Avatar
Posts: 3,281   (View Stats)
Groans: 153
Not sure if you're hitting the load targets without looking at the map, but it doesn't seem to be a leak.
How are your fuel trims?
Also. Just for laughs, you should take your intake/inlet off and just have a look at the compressor wheel. See if anything looks out of the ordinary.
Tapa
-Pat
NATOR CT Lives!!!
2008 True Red MS3
GT3071R 'n Stuff
 Old 09-21-2012, 07:28 PM   #14
Icon's Avatar
I'm not sure about the fuel trims, and it looks like I can't look at the map because I'm running Mac OSX and can't download ATR.
 Old 09-21-2012, 07:32 PM   #15
ms3rick's Avatar
Posts: 2,364   (View Stats)
Groaned at 9 Times in 7 Posts
Get an etune! unlock that power!!!! Stratified! Or another one of our many amazing tuners
2010 MS3 siLver.
Next: TMIC(WTB PM me); meow DP
Official 60-100mph Times
Official Youtube Channels
 Old 10-13-2012, 06:43 PM   #16
Icon's Avatar
So I've been talking with Braden over at Cobb and it seems like I definitely have a leak somewhere, and it's not in the boost tubes.
(https://forums.cobbtuning.com/forums...k-Stg-2-16-psi)
Anyone else have any thoughts on what it could be? I'm really trying to figure out how to tell if it's the BPV. What are the signs of a leaking BPV? I can't find anywhere that talks about this. I've searched and read threads for hours.
 Old 10-21-2012, 07:31 AM   #17
MS6_Newb's Avatar
Posts: 68   (View Stats)
MS6_Newb is just really niceMS6_Newb is just really niceMS6_Newb is just really niceMS6_Newb is just really niceMS6_Newb is just really nice
Groaned at 5 Times in 2 Posts
I have the same "issue", however I check the tune in AccessTuner and its commanding 16psi. It's nothing to worry about, your car is fine just e-tune. Also make sure you have a upgraded CDFP. I personally like autotech.
PS I have the MSCAI tune not the cpCAI. Same $h!t different pile.
Mods: AEM CAI, Cobb AP, AT internals, Juggernaut, Dreadnaught, R6, Ebay DP
MS6_Newb is offline   Reply With Quote
Not hitting Stage 2 boost targets (boost leak?) Bubba Ho-Tep 2010 MS3 - ECU Computer Tuning 15 04-26-2012 07:25 PM
Help! MS6 Boost Fading In/Out. Boost Cut? Leak? MS600RR MazdaSpeed 3/6 - Troubleshoot/Diagnostics 10 02-28-2012 07:48 AM
3076r Boost Spike when set over 16psi frivolous_rob MazdaSpeed 3/6 - Turbo Induction 15 10-04-2011 06:39 PM
Gen 1 MS3 AP Stage II vs Rage-Tek 16psi tune svtswimmer MazdaSpeed 3/6 - Dyno Sheets/Discussions 4 07-29-2011 07:28 PM
Vacuum leak, but no boost leak? vbt101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 23 04-18-2010 12:06 PM
Page generated in 0.37382 seconds with 31 queries
