Notices
 Old 10-20-2012, 07:41 PM   #1
MazdaSpeedSix's Avatar
Posts: 48   (View Stats)
MazdaSpeedSix will become famous soon enough
Default Built motor problems
What's up guys, I tried figuring out a few things but haven't had much luck yet. Seeing if you could help. I recently built my motor, it is fully forged, .20+ bore port and polished head, manifolds and throttle body. I assembled everything, put it in and my Air/fuel went to 17.0-19.00 running very rough. Any suggestions? Ill be hooking up my access tuner tonight to see what's up but seeing if you might have an idea. I'm not even driving it due to such a rough condition. No cel lights by the way. Mod list is quite a big one but it has all supporting mods done including CPe pump and halo injector seals. ahead of time!
06 MazdaSpeed6 Stage 3+
Pauter Rods - Wiseco Pistons - CPE Fuel Pump - Cryotreated transmission internals - SU BSD - JB Baffle - ACT Stage 3 clutch system - ARP Head and Main studs - Cometic Head gasket - Dreadnaught Mount - SURE RMM - NGK One step colder plugs - 3.5" Intake - GTX3071r - CXracing custom FMIC - Accessport custom tune - 3 bar MAP sensor - Grimmspeed Boost controller - Prosport Evo digital gauge setup Boost/Voltage/Oil Pressure -
MazdaSpeedSix is offline   Reply With Quote
 Old 10-21-2012, 01:01 PM   #2
ms3blackmica's Avatar
Posts: 3,950   (View Stats)
Assuming that your engine build was assembled properly and all sensors, gauges, etc. are connected properly and working, there is a few things for you to do..
a) Boost leak test it. Vacuum leaks are a huge cause of lean AFR's. The engine sucks in un-metered air that wasn't compensated for. Also pre-turbo leaks can cause lean AFR's such as your tip not being on fully. If you can confirm the system is air tight, move to b.
b) Check your fuel trims. Are they pegged at +25% ? This would indicate the ECU is doing everything in its power to add more fuel and it is not enough to bring the stoich down to 14.7 AFR. Couple things to ask you here...did you upgrade your intake to a larger MAF housing? If so, you would have to scale your MAF curve.
Let us know more info on the car. We need to know more in order to determine if its a tuning issue or something else.
2009 MS3 GT: Stock HID's and an NJSPEED3 Mani
"NJ Nator the home of makeshitfit technology" - voltron
"I didn't build it hoping for your approval...I built it because it meets mine."
ms3blackmica is online now   Reply With Quote
 Old 10-21-2012, 01:03 PM   #3
(Toe-kay)
Tokay444's Avatar
Posts: 9,784   (View Stats)
Groans: 526
.200 overbore? wow.
Demodded.
Mwho?
Tokay444 is online now   Reply With Quote
ms3blackmica (10-21-2012)
 Old 10-21-2012, 01:07 PM   #4
Eatin' Your Tuna
Haltech's Avatar
Groans: 218
.020 over, big mistake without sleeving it.
Have you checked the same copper ground cable that gave silverpain a shitload of problems?
The Following 2 Users Say Thank You to Haltech For This Useful Post:
ms3blackmica (10-21-2012), trf5000 (10-24-2012)
 Old 10-21-2012, 01:08 PM   #5
fastest 3-cyl MS3
btstarcher's Avatar
Posts: 1,781   (View Stats)
Groaned at 25 Times in 12 Posts
A list of mods sure would help....or is it a secret?
JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD
Dizzy Tuned by Boost_creep in progress
hopefully soon: GTX2867R or GTX3076R
 Old 10-21-2012, 01:26 PM   #6
madspd6's Avatar
Posts: 549   (View Stats)
madspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the worldmadspd6 is the leader of the world
Groans: 24
+0.020 i don't think would cause that much of a problem if he is not going for huge power. i remember seeing street unit or someone selling +0.040 pistons, that would be worrying. almost no material left between cylinders.
Velocity Red Mica 06 Speed6 (ricer) #834
madspd6 is offline   Reply With Quote
 Old 10-21-2012, 01:33 PM   #7
fastest 3-cyl MS3
btstarcher's Avatar
I sure hope not, I'm going .020 over...hey I wonder who's doing the headwork?
 Old 10-24-2012, 07:03 AM   #8
Importfan12's Avatar
Posts: 142   (View Stats)
Importfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond reputeImportfan12 has a reputation beyond repute
I just finished doing the same thing with my Speed6 and I am having the same problem
2007 Black Mica MS6-Fiber Images CF Hood, AutoEXE CF Grill and Rear Window Visor, CF Mirrors, CF Pillars, CF Window Visors, Cipher Auto Racing Seats, AutoPower 4-point cage, Sabelt 3" 4 point Harnesses, TWM Stage 1 SS and Base bushings, BNR Stage 3 turbo, Cobb Access Port, Altered Custioms FMIC, Protege Garage Full Length Short Ram Intake, Magnaflow Catback Exhaust, 3" Down Pipe, HKS Special Edition Black BOV, KSport Kontrol Pro Coilovers, SU Rear MM, Sure Dreadnaught, Whiteline Rear 24mm Sway Bar, SU Trunk Brace, GT Spec Trailing Brace, KMD HPFP Internals, Spin-on-Oil Filter Conversion, Hawk HPS pads and Power Slot rotors,VG Sharkfin, 28% Tint, Dual Vent Pod with AEM Digital Boost and Wideband Gauges, Kenwood DVD, Nav, Sst Radio, JL Components and rear door speakers, Custom Sub enclosure, CF Wrapped interior trim
2007 Liquid Platinum Metallic MS6-K&N Filter, SU Rear MM, Spin-on-Oil Filter Conversion, 28% Silver Tint
Importfan12 is offline   Reply With Quote
 Old 10-24-2012, 07:53 AM   #9
Posts: 5,722   (View Stats)
Groans: 121
Could be a vacuum leak, a fuel delivery issue, or a bad WBO2. Places to start:
1. Check for a vacuum leak by doing a boost leak test and visually inspecting all lines in the vacuum system.
2. Check fuel pressure at the rail via the ECU PID.
3. Check for an exhaust leak.
4. Check your plugs for signs of fouling. A misfiring plug can actually make the wideband read lean, not rich.
5. Check all your grounds. There is one on the PMM, a couple on the slave cylinder bracket, and one on the bracket up by the HPFP.
DingoDave (10-27-2012), MazdaSpeedSix (10-25-2012), ms3blackmica (10-24-2012)
 Old 10-25-2012, 04:17 PM   #10
Hey guys I'm sorry it took me a second to post. The mods are:
CPe fuel pump
3" turbo back exhaust
CPe downpipe
Ported/polished head, intake manifold, throttle body, exhaust manifold
Wiesco pistons (9:1 compression, .020 bore)
Pauter rods
Arp main studs/ head studs
All mew gaskets
New timing tensioner
Timing chain
Oil pump strainer
Block
Bs delete
JB oil baffle
One step colder ngk plugs
3 prosport digital gauges (afr boost voltage)
Crankshaft optimized
There are many more but I'm spacing them. If you have any questions let me know. And also another question. When the car starts up it sounds normal once it's warmed up it starts having a loud tick that wasn't there before. Just barely started recently. Car drives fine, flies like a jet!
FMIC sitting in the garage ready to be put on with the gtx3071r.
Last edited by MazdaSpeedSix; 10-25-2012 at 04:17 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-25-2012, 04:31 PM   #11
fastest 3-cyl MS3
btstarcher's Avatar
It's funny because you have a built motor but stock intake...
 Old 10-25-2012, 05:16 PM   #12
aviator79's Avatar
Posts: 1,427   (View Stats)
Still have EGR? did you install TIGs? This was my fail as EGR tube was not tight and had a massive vac leak and would not stay running. Blocked off EGR and was all set.
Black Metal (10-25-2012)
 Old 10-25-2012, 08:03 PM   #13
Intake is a 3" Sri. EGR Is blocked off and code delete with the accessport lol. Now there is that annoying lifter knock/ tick that's very loud once the engine heats up. Any ideas? This just randomly started doing this out of no where.
The Following User Says Thank You to MazdaSpeedSix For This Useful Post:
btstarcher (10-25-2012)
 Old 10-25-2012, 08:56 PM   #14
Veblen Goods
Tomas's Avatar
Posts: 2,333   (View Stats)
hmm. Did anyone check valve clearance for your built motor?
GHEY THUNDER
 Old 10-25-2012, 11:21 PM   #15
Everything was checked. Could it possibly be because I was driving it (no wot) while at 18-19.0 afr? Also on the freeway as I'm in 6th gear while going 75 I'm steady at 3k rpms. I don't know if I just forgot how it was before I blew it or if I'm just being paranoid. But is that normal? Btw there is a stage 3 spec clutch kit on there as well.
 Old 10-26-2012, 12:16 AM   #16
fastest 3-cyl MS3
btstarcher's Avatar
Were there any problems with your MAF calibration?
ms3blackmica (10-26-2012)
 Old 10-26-2012, 12:50 AM   #17
For the sake that you put this into the ECU Computer tuning section, i have to ask...
Is your map scaled for the 3" Intake ???
You said accessport custom tune, who tuned it?
btstarcher (10-26-2012)
 Old 10-26-2012, 03:16 AM   #18
(Toe-kay)
Tokay444's Avatar
Groans: 526
Find the source of the ticking.
I'm betting it's cdfp or injectors.
Demodded.
Mwho?
 Old 10-26-2012, 02:18 PM   #19
It sounds like timing chain slapping up against something. It's coming from the top valve cover and timing cover. And the map is tuned by me to work with all mods.
 Old 10-26-2012, 02:23 PM   #20
Did you scale the MAF curve for the 3" intake?
If so, how ?
Also, what are your fuel trims at idle? Both STFT and LTFT...
 Old 10-27-2012, 07:54 AM   #21
(Toe-kay)
Tokay444's Avatar
Groans: 526
Get a stethoscope and figure out EXACTLY what it is.
Demodded.
Mwho?
 Old 10-27-2012, 10:58 AM   #22
I did, it's knocking really bad right underneath the very left of the valve cover, top timing cover more on both sides where the cam gears are.
If so, how ?
I took off my 3" intake for now until I get my old gt30 switched out to the new gtx30 ad until I figure out where all my vac leaks are.
Last edited by MazdaSpeedSix; 10-27-2012 at 01:00 PM. Reason: MSF Database - Automerged Doublepost
 Old 10-27-2012, 02:34 PM   #23
(Toe-kay)
Tokay444's Avatar
Groans: 526
Timing chain slapping valve cover.
Take the valve cover off and look for scaring.
Demodded.
Mwho?
 Old 10-27-2012, 04:40 PM   #24
Groans: 121
With a Speed6, he should be able to tell just by pulling the oil cap off and checking with his finger.
 Old 10-27-2012, 04:46 PM   #25
Do I have to pull my motor again?..... :/ or is there any way to remove the top mount and take the timing cover off that way? Because the last thing I want to do is pull the damn motor again... also how tight should it sit? Should there be any play? The car drives just fine and there is no knock so I know that it hasn't slipped a gear. What do you guys recommend trying?
 Old 10-27-2012, 04:51 PM   #26
(Toe-kay)
Tokay444's Avatar
Groans: 526
Not the timing cover. The valve cover.
Demodded.
Mwho?
 Old 10-27-2012, 05:05 PM   #27
I know the valve cover has to be removed to really see how loose that chain is, it's loose. But to fix/replace all timing components i have to remove the timing cover. can I remove the timing cover without dropping the engine again? That's what I am really worried about.
 Old 10-27-2012, 05:08 PM   #28
(Toe-kay)
Tokay444's Avatar
Groans: 526
Yes. You can.
Follow the tsb to check for a bad vvt. That will show you how much slack should be in or chain also. Just sticking your finger in the oil fill hole and tugging on the chain is no a definitive method of checking.
Demodded.
Mwho?
MazdaSpeedSix (10-27-2012), silvapain (10-28-2012)
 Old 10-27-2012, 07:12 PM   #29
The slack is a good one. It should be nice and tight shouldn't it?
 Old 10-27-2012, 07:14 PM   #30
(Toe-kay)
Tokay444's Avatar
Groans: 526
With cylinder one at tdc it should be.
Donate brownie faggot.
Demodded.
Mwho?
MazdaSpeedSix (10-27-2012), Stangcobra (10-31-2012)
 Old 10-27-2012, 07:41 PM   #31
jm211's Avatar
Posts: 313   (View Stats)
jm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the worldjm211 is the leader of the world
yea, it'll goes from snug-no movement to, idk 2mm?
Black Mica 2006 Speed6 GT | 57,000 Miles
Cobb AP | Stratified Tune | JBR Stage II Intake | cp-e 3'' Straight Exhaust | cp-e RMM | SURE AGS 600 Gram Shift Knob | SURE Anchors | SURE Return | SURE SSP/Weight | All Amsoil Fluids | NKG Step 1 | Autotech Internals | Shell T6 Juice
ms6db.com I'm Registered. Are You?
jm211 is offline   Reply With Quote
 Old 10-27-2012, 07:45 PM   #32
(Toe-kay)
Tokay444's Avatar
Groans: 526
Lol. Try half an inch.
Demodded.
Mwho?
 Old 10-27-2012, 08:55 PM   #33
I will once I get on my computer.
 Old 10-27-2012, 10:06 PM   #34
(Toe-kay)
Tokay444's Avatar
Groans: 526
atta boy.
we have all the shop and service manuals on here in vip.
Demodded.
Mwho?
 Old 10-27-2012, 10:52 PM   #35
Tokay444 knows his shit.
listen to "everything" he says. even if its gheyyy lol
 Old 10-28-2012, 06:05 AM   #36
(Toe-kay)
Tokay444's Avatar
Groans: 526
Isn't it all ghey?
Demodded.
Mwho?
ms3blackmica (10-28-2012)
 Old 10-28-2012, 01:26 PM   #37
Isn't it all ghey?
Always!
 Old 10-28-2012, 04:50 PM   #38
Yes. You can.
Thank you! Found my problem and know exactly what I need to replace. Looks like ima dig into the engine again tomorrow. Any advice while I have the cover off?
 Old 10-28-2012, 05:05 PM   #39
(Toe-kay)
Tokay444's Avatar
Groans: 526
so, what's the problem.
Demodded.
Mwho?
 Old 10-28-2012, 07:23 PM   #40
Yeah for real..
what was the problem? lol
Built motor.....?.? Matx MazdaSpeed 6 - Engine, Transmission & Driveline 17 06-25-2012 05:15 PM
Built Motor is Done..... yoichi MazdaSpeed 6 - Engine, Transmission & Driveline 107 12-14-2009 09:52 AM
built motor ms3boost MazdaSpeed 3 - Engine, Transmission & Driveline 17 05-20-2009 09:22 AM
Page generated in 0.55627 seconds with 30 queries
