 Old 02-17-2009, 11:28 AM   #1
smakdown61's Avatar
Posts: 1,069   (View Stats)
smakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the worldsmakdown61 is the leader of the world
Groaned at 37 Times in 23 Posts
Default Can't log with the AP
Tried doing some AP logs today. It says "initializing" then just has dash marks where the info should be like its not getting anything, then kicks me back to the logging directions screen. I have the latest beta firmware and whatnot. Any ideas?
smakdown61 is offline   Reply With Quote
 Old 02-17-2009, 11:46 AM   #2
bova's Avatar
Posts: 3,815   (View Stats)
Groans: 45
you have to reset both your live list and data log list then it should work.
 Old 02-17-2009, 11:57 AM   #3
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
well smak i got the newest updates today went to the car and i log fine... what happened was i selected rpm, it said not logging. i then hit the enter thing. it said initalizing with dash for like 2 seconds, then started showing the rpm again with logging under. so try the update and hope you get this fixed.
"Go find your own enterprise, and get the fuck off my bridge!"
2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard"
1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action"
skeeter149 is offline   Reply With Quote
 Old 02-17-2009, 04:51 PM   #4
SharkDiver's Avatar
Posts: 969   (View Stats)
SharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the worldSharkDiver is the leader of the world
Groaned at 7 Times in 6 Posts
Mine is doing the same thing.I reset the datalogs and live list and it still will not log.I have a small thread on it in the Cobb section..
Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more
http://videos.streetfire.net/profile/SharkDiver.htm
http://www.youtube.com/user/sharkdiverjohn
SharkDiver is offline   Reply With Quote
 Old 02-24-2009, 07:24 PM   #5
94jedi's Avatar
Posts: 2,200   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
yep, mine did the same thing today. I'll try it again w/ your suggestion.
BONE STOCK.
94jedi is offline   Reply With Quote
 Old 03-09-2009, 06:29 AM   #6
Arrowpoint's Avatar
Posts: 364   (View Stats)
Arrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the worldArrowpoint is the leader of the world
Mine is doing the same thing. I have it set to take beta updates. I updated it again last night and removed most of the maps and old logs etc. thinking maybe it is a memory issue. I will try to log again today. I wish that they could make it so that the log dates and times are correct.
Arrowpoint is offline   Reply With Quote
 Old 03-09-2009, 09:12 AM   #7
smakdown61's Avatar
fyi mine was fixed with the latest beta firmware
 Old 03-09-2009, 10:42 AM   #8
SharkDiver's Avatar
THey cant make the times and logs correct because the AP does not have a on board battery to store that info.When the Ap is un-plugged from the OBD it resets everything.What I dont understand is why they added date and time to the logs knowing that it will not be correct.
 Old 03-10-2009, 02:41 AM   #9
Arrowpoint's Avatar
Mine is working again. I guess updating fixed it.
 Old 03-10-2009, 06:21 PM   #10
06turbospeed's Avatar
Posts: 10   (View Stats)
06turbospeed will become famous soon enough
hmm thats weird
Mazdaspeed CAI/ Turbo xs bov/ WOT Box/ CPE rear mount/ DSD-SLM II Boost gauge/ 20% tint (much more this spring)
06turbospeed is offline   Reply With Quote
Page generated in 0.29585 seconds with 25 queries
