 Old 12-26-2017, 08:58 PM   #1
nate montoya's Avatar
Posts: 28   (View Stats)
nate montoya is an unknown quantity at this point
Default Clutch master cylinder leaking
I noticed my clutch master cylinder leajijng the other day so I bought a new one and now it's not leaking anyone ever deal with this issue?
nate montoya is offline   Reply With Quote
 Old 12-27-2017, 09:03 AM   #2
IMASA's Avatar
Posts: 209   (View Stats)
IMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the worldIMASA is the leader of the world
Maybe all your fluid leaked out so it stopped leaking?
Mine had a very slow leak inside the car. Just monitor it over a few days/weeks. Good luck with the install, one of the more difficult things I had to install in my car.
2008 Mazdaspeed3 | Cobb AP | Cobb DP | Cobb FMIC | Cobb RSB | Cobb RSB | SURE 3" MAF full intake | CP-E Stage 2 RMM | CP-E HPFP | H&R Springs | Koni Yellows | TWM FR | MD OCC | Dashhawk | DO Methanol Injection | JBR PMM & TMM | JBR EGR Plate |
IMASA is offline   Reply With Quote
 Old 12-27-2017, 11:43 AM   #3
Haha no I refilled the reservoir but yes I tried installing master but I could only get the three bolts off in the front that higher up one was a pita. How did you end up getting that thing off.
 Old 12-27-2017, 03:03 PM   #4
aackthpt's Avatar
Posts: 1,450   (View Stats)
aackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the worldaackthpt is the leader of the world
I've never had a problem with anything leajijng.
2013 'speed3, silver
Stage Bro
aackthpt is offline   Reply With Quote
 Old 01-06-2018, 12:57 PM   #5
MSMS3's Avatar
Posts: 2,826   (View Stats)
Groans: 157
Might get more responses if master cylinder leaking thread were started elsewhere. This is the ECU computer tuning section. Just saying it might not get seen here.
Clutch master and slave cylinder repacement questions soulefx MazdaSpeed 6 - Engine, Transmission & Driveline 31 09-12-2019 03:04 PM
Clutch Master Cylinder Removal (2010 MS3) bryancregger MazdaSpeed 3 - Engine, Transmission & Driveline 11 03-01-2019 05:01 PM
Oily liquid on the driver floor mat - Clutch master cylinder? mituc MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 01-02-2017 01:47 PM
Master Slave Cylinder and Clutch Master ahahn95 MazdaSpeed 6 - Engine, Transmission & Driveline 1 09-11-2015 03:47 PM
Page generated in 0.27206 seconds with 23 queries
