![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #201 | ![]() |
![]() Join Date: Mar 2008 Location: Perth Amboy, NJ
Rep Power: 138 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 704
Groans: 86
Groaned at 36 Times in 25 Posts
| Not Ranked : 0 score I hope you are kidding.... one of the most documented factors is our closing throttle.... If power really starts dropping off around 5000-5500 on Cobb's dyno graphs, then Cobb doesn't have throttle control and Cobb isn't seeing all of the power that they should.
__________________ L76-powered To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #202 | ![]() |
| Like A Boss ![]() ![]() Join Date: Mar 2008 Location: Panhandle FL
Rep Power: 1532 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,484
Groans: 274
Groaned at 116 Times in 96 Posts
__________________ Buy my stuff! Lots for sale To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Haltech; 05-13-2008 at 11:00 AM. Reason: I fixed the link for ya mate | ||||||||
![]() | | #203 | ![]() |
Groans: 274
this 'custom' tuned stage 2 map is better, but still power up top is just not there. Maybe FMIC (with less pressure drop or something) can help with this
__________________ Buy my stuff! Lots for sale To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #204 | ![]() |
Groans: 86
Actually, Christian's post refers to Peak numbers on the graph, but thanks.... If you see how sharply ALL dyno sheets on the DISI engines fall off after 5500, it's all wasted RPMs at that point. However, that should NOT be the case. If you can keep the throttle open until redline, you should be able to make more power than with it closing during those RPMs. I'm not saying that the Peak numbers will get better at all - they should decrease from the peak points, but not anywhere near as sharply as they do. It should gradually decline, not drop off like a cliff....
| The Following User Says Thank You to mdogg For This Useful Post: | whoosh@Realtune (05-13-2008) |
![]() | | #205 | ![]() |
| Roush noob ![]() Join Date: Mar 2008 Location: Earth
Rep Power: 89 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6
My understanding from reading various posts regarding specifically our turbo is that it can't handle high RPMs for reliable life... Its in some thread in here were is states specifically that the type of turbo we have should not be pushed hard in the upper RPM range... Thats what I'm attributing the power loss at high RPMs...Mazda's way to make the setup reliable with this turbo. Now, if you replace the turbo all bets are off and you probably should be able/want to have the throttle more open... With the stock turbo...I wouldn't push it...in regards of the info I've come across on this and other boards. Am I wrong to assume this...?
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Mazda NA can kiss my ass!!!! 2008 Stage 3 Roush Mustang 430HP/400TQ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #206 | ![]() |
| Websearch +1 ![]() Join Date: Mar 2008 Location: Gaithersburg, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 335
I think you have to take into account the stock intercooler when trying to get additional power in the upper rpm band. With a 4 psi drop, the turbo is actually working more like 19 psi to try and push air through at the upper rpm range...which according to the compressor maps is out of the turbo's efficiency. Of course if you were to swap out to a different TMIC or FMIC, with less of a pressure drop, you'd now move the turbo back over into efficiency. (I'd need to relearn how to read those damn maps to be more specific, but I'm sure someone will help here). So my understanding would be this. 1. Cobb argues that throttle plate opening all the way does nothing, because the turbo is blowing hot air. Thus Cobb does not include it, but promises to release a map later which may include some level of additional control. Cobb also reduces the psi by redline, to avoid having the turbo become a flamethrower. 2. Cobb releases a FMIC, then releases a new FMIC map, which has delayed throttle opening, and delayed psi drop off, so their product shows phenomenal gains and less drop off then the competition. Sounds like business sense to meeeee! | ||||||||
![]() | | #207 | ![]() |
Groans: 86
__________________ L76-powered To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
![]() | | #208 | ![]() |
| smartass ![]() Join Date: Mar 2008 Location: Texas
Rep Power: 1299 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle
![]() | | #209 | ![]() |
| Not Ranked : 0 score Supposedly with no real benefit on the stock setup...?
![]() | | #210 | ![]() |
Ya. According to cobb, there was only a 3-4 hp difference between 100% open and 50% open, on a 91 octane map.
![]() | | #211 | ![]() |
| More air More fuel ![]() Join Date: Mar 2008 Location: MD
Rep Power: 230 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 496
Groaned at 7 Times in 5 Posts
I'm trying to get a few guys together for a track day...I'd be willing to drive to Crapitol to meet some other MS owners. Should make for a fun time. | |||||||||
![]() | | #212 | ![]() |
Groans: 274
| Yeah it made a bit more power with it wide open, but @ 6500 rpm or whatever...whether you're @ 50 or 100 percent theres still virtually no power. They say its the turbo/cam setup more than anything. I'm hoping for a little more power out of the 5000-6000 range..notice it just flatlines (HP) and torque drops pretty rapidly. I'm OK with not having power to redline..I understand that's probably not really possible w/ this turbo etc.
![]() | | #213 | ![]() |
Jedi, We might be doing a trip to VIR in November. Depends on how many miles I get on the car by then. I'm not a big strip guy, I tend to put most of my time and energy into road courses. Strip is like autox's to me...you only get a few seconds of fun, then you gotta wait wait wait...you get 25-35min at the 4.2 mile track for 8-9 sessions =). | ||||||||
| Thread Tools | |
| throttle plate activity > discussion | whoosh@Realtune | MazdaSpeed 3 - Engine, Transmission & Driveline | 38 | 05-28-2008 05:48 AM |
| COBB Access port dyno run on day of release | mazdaspeedjay | Cobb Access Port/Maps | 44 | 05-20-2008 11:35 AM |
| Cobb STS pic | ms3boost | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 05-03-2008 06:26 AM |
