  • 1 Post By Mistersix
 Old 04-24-2013, 11:17 PM   #1
mrsmith's Avatar
Posts: 85   (View Stats)
mrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud ofmrsmith has much to be proud of
Groaned at 4 Times in 1 Post
Default A couple spicy runs
Hey guys I just did a couple of runs on the ots spicy tune from cobb. look at them and tell me what you guys think. Here is some background as well, the car is fully bolt on, DP, RP, Cobb sri, Sure tip, Fuel pump internals. Jbr rmm 88, Cobb short shifter, CX racing fmic, Hks ssq, and on 110 oct. All of these runs were done at S.R.M.S., country line race way (1/8 mile) all 40 rolls. And all during a race. That said its not just a 4th gear pull its 1,2,all of 3rd WOT, most or 4th. On my last run when I hit 3rd the linkage from my shifter to my tranny popped off did any of you have the same problem and what can I do to prevent it form happing again?
mrsmith is offline   Reply With Quote
 Old 04-25-2013, 12:07 AM   #2
BobbleHead's Avatar
Posts: 2,237   (View Stats)
BobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the worldBobbleHead is the leader of the world
Groans: 186
Groaned at 33 Times in 25 Posts
how did it feel?
2012 BM MS3 w/ tech. Cobb AP V2b: Autotech CDFP internals: JBR 88d RMM: SURE 3" Aeros full intake: Ebay test pipe: Corksport TMIC: Turbosmart BPV: Bridgestone Potenza 235/40 tires: self tuned
BobbleHead is offline   Reply With Quote
 Old 04-25-2013, 12:21 AM   #3
mituc's Avatar
Posts: 3,513   (View Stats)
Groans: 111
It's weird to see the BAT increasing so much under boost with a FMIC... Otherwise everything looks pretty good, there is no trace of any ignition retard which allows you to run a ton of timing which is awesome.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 04-25-2013, 12:53 AM   #4
snailD's Avatar
Posts: 3,037   (View Stats)
what was the intake temp? bats do seem a bit on the high side. also your only running 16psi, when the last i looked the spicy tunes were demanding 20+. running some real high timing with the lack of boost and load, car seems to like it tho
 Old 04-25-2013, 06:25 AM   #5
fivefingerdeathpunch's Avatar
Posts: 437   (View Stats)
fivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the worldfivefingerdeathpunch is the leader of the world
like they said pretty much
you are running ALOT of timing and such little boost. seems odd. any chance you have a boost leak? temps are hot so i imagine that contributes to this but in the first log you are using quite a bit of wgdc to run 16psi. more so than i would imagine...
BATs are higher than expected or desired but maybe it was just hot beyond belief? i wouldve thought it would come down more once boosting.
LTFTs are abs high. -18? -11?? you needs a maf cal.
what is commanded FP? you seem over 1900 alot. i belief most of the tuners say not to command too much so that the relief valve isnt over used and worn out as quickly
luckily you are running really good gas so no knock or anything but you definitely have room for power/improvement in general.
2006 White Water Pearl Mazdaspeed6 Grand Touring #5430
HTA3076 Tial .82 Turbine Housing, CPE tial Mani, Tial MVR 44mm 20psi spring VTA
DO Stage 2 Meth w/ D07 & 100% - NJSPEED3 PnPed IM - HTP 3" TIP - SSP BigMAF SRI w/ AEM Dryflow and filter wrap - GS EBCS - Fabbed M2 Catless DP - Autotech HPFP Internals - Cobb AP - Custom 2.5" w/ TR8 FMIC - GHL Resonated Dual Catback Exhaust - TS/SU DP BOV - SP63 Aux Fan
Old: BNR S3 370/380 VD 91 + Meth
BNR S3 400/410 VD E21 + Meth - Dyno confirmed: http://www.mazdaspeedforums.org/forum/f338/mazdaspeed6-bnr-s3-dyno-400-410-a-180820/
fivefingerdeathpunch is offline   Reply With Quote
The Following User Says Thank You to fivefingerdeathpunch For This Useful Post:
SLOWHATCH (04-25-2013)
 Old 04-25-2013, 09:03 AM   #6
mrsmith's Avatar
The spicy tune commands 22 boost and 12 afr. It might be that its was run after run that's the bats were high I should these where the 4th and 5th runs. car felt good but I thought it should have been more ,then I saw the 15 psi and, I hold 19 psi on my stge 2. I didn't do a maf caf this was ots just wanted to see what it would do. Would the bats make the ecu turn down the boost?
 Old 04-25-2013, 09:22 AM   #7
Posts: 12,651   (View Stats)
Are you pretty much at sea level?
The spicy tune and all current OTS tunes heavily rely on the WGDC table and a very simple form of boost control which is ... well meh. If you have varying flow mods and are at different altitudes you will either see too much or too little boost. The maps are just not flexible enough and there is more left on the table there for sure.
 Old 04-25-2013, 09:28 AM   #8
6 mods and some Kool-Aid
Raider's Avatar
Posts: 28,879   (View Stats)
Groans: 856
South FL is seal level.
 Old 04-25-2013, 11:45 AM   #9
mrsmith's Avatar
Yup im at 0. Im running my stg 2 map and im holding 18 psi ill do some datalogs after work. I still have no idea why it was only hitting 15 maybe I should have uninstalled my map befor doing the spicy tune.
 Old 04-25-2013, 12:09 PM   #10
Voltwings's Avatar
Posts: 3,713   (View Stats)
Most cars need a lot of wastegate from 4500 rpms up and the spicy tune only seems to be comanding 80%. Even maxed out most cars will struggle to hold 17-18 towards redline so 16 psi at 5500-6000 rpms seems about right to me.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 04-25-2013, 12:10 PM   #11
himurax13's Avatar
Posts: 4,582   (View Stats)
Groans: 255
Well the initial High BATs could be due to the fact that you were in boost before you hit 4th gear. They didn't climb too much during the run but it is surprising that they didn't go down I guess the CX Core does not work as well as the Treadstone cores.
Why arent you logging the Injector Duty Cycle, Intake Valve Adjustment? You can ditch the STFT column.
You could try putting some grease on the shifter linkage.
Pickles Tune in progress
 Old 04-25-2013, 11:14 PM   #12
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
He has High BAT's because of that CX Racing FMIC Core.
BAT's are worse than a TMIC with that core.
/BAT Conversation
www.tunedbynishan.com
The Following 2 Users Say Thank You to ms3blackmica For This Useful Post:
ABSpeed3 (04-26-2013), snailD (04-26-2013)
 Old 04-26-2013, 11:24 AM   #13
snailD's Avatar
/BAT Conversation
yea that core fucking sucks. i bought one as my initial fmic core for 30 bucks, and bats went WAY up. why i started running e. this tr8 core is insane in comparison. that core however flows real well
 Old 04-26-2013, 11:29 AM   #14
Raider's Avatar
Groans: 856
Sheesh, and I thought my 100 degree PG FMIC was high.
 Old 04-26-2013, 11:34 AM   #15
Voltwings's Avatar
The reason Cx racing cores are cheap, flow well, and advertise a low pressure drop is because of the design. Most good cores have a staggered fin design, this breaks up the air flow, makes it spend more time in the core and thus dissipates more heat. The CX racing cores have a straight through fin design, basically less resistance (so they can advertise a low pressure drop) but the air blows right through them and doesn't get cooled, theres everal instances on several forums. Now if you buy some of their nicer cores, they actually aren't half bad, was tuning a guys 3071 here not too long ago and with a core of similar size to a TR8L he was running 7-10* over ambient at WOT, its just their ebay ones that suck.
Past:
-Sold-
-Sold-
Current:
The Following 3 Users Say Thank You to Voltwings For This Useful Post:
Mistersix (04-26-2013), ms3blackmica (04-26-2013), snailD (04-26-2013)
 Old 04-26-2013, 02:24 PM   #16
mrsmith's Avatar
Well this ones not from ebay its from cxracing directly, but knowing this ill buy a tr8. I did a run last night wot 3rd and 4th. stg 2 with 93 oct.
 Old 04-26-2013, 04:23 PM   #17
Mistersix's Avatar
Posts: 2,585   (View Stats)
Fwiw, i run the TR-8 and my BAT's are always just above ambient and usually at or lower than IAT. I assumed there was a good reason a treadstone core was 3x the price or a same sized cx racing core.
Ditch the cx and get a treadstone.
Redline143 likes this.
 Old 04-26-2013, 04:26 PM   #18
Nishan
@amggilly305; can attest.
amggilly305 (04-26-2013)
 Old 04-26-2013, 07:18 PM   #19
amggilly305's Avatar
Posts: 899   (View Stats)
amggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the worldamggilly305 is the leader of the world
Groans: 92
wish i went with the tr8 core from day one
KILLAH BUILT
PTE 5862 @29psi
JMF MANI
METH
TUNED BY NISHAN
11.54@123
What does your new map trap
amggilly305 is offline   Reply With Quote
 Old 04-26-2013, 09:46 PM   #20
mrsmith's Avatar
Tr8 or Tr8l? I still don't get why it was only boosting 15 and not at least 18 like my stg 2 does unless I need to upgrade my ebc? and my linkage popped off at the tranny from me slamming it into 3rd, wouldn't greasing it help it pop off? Next s.r.m.s. I'm going to put my maf cals into the spicy tune, first uninstall my stg 2, then reinstall the spicy and see if it does better. I'm going to get a perm tune as soon as I get everything I need, like I just found out I need a new core.
The Following User Says Thank You to mrsmith For This Useful Post:
 Old 04-26-2013, 10:15 PM   #21
Redline143's Avatar
Posts: 930   (View Stats)
Redline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the worldRedline143 is the leader of the world
Me too.... my TR8C with the CX piping is working phenomenally.
Redline143 is offline   Reply With Quote
The Following 2 Users Say Thank You to Redline143 For This Useful Post:
Mistersix (04-27-2013), ms3blackmica (04-26-2013)
 Old 04-27-2013, 02:10 AM   #22
snailD's Avatar
tr8 is what i went with. the L flows more air but has less of a cooling effect. depends how much air you are planning on flowing. most probably wont outdo the tr8. also the boost thing is your wgdc's. you could copy over all of your boost tables from the stage 2 map since they are working for you
Spicy ms6ish thehead MazdaSpeed 3/6 - ECU Computer Tuning 14 03-25-2012 04:48 PM
Cobb spicy tune Zbrit00x Gen2 MS3 General Discussion 4 03-16-2012 08:01 PM
Spicy!!!! Mortose MazdaSpeed 3/6 - ECU Computer Tuning 4 03-16-2012 04:57 PM
Frankfurt 2009: BMW 7 Series Active Hybrid runs (almost) silent, runs deep Haltech Automotive News 0 09-16-2009 12:20 AM
Page generated in 0.54140 seconds with 33 queries
