 Old 12-01-2015, 11:12 PM   #1
BankShot's Avatar
Posts: 77   (View Stats)
BankShot will become famous soon enough
Default DATA LOGS how do they look...
Jus got my AP wondering if anyone with a trained eye could jus give it a look
Turbo inlet pipe
SRI
Test pipe
Fuel pump intenals
I was spinning in 2nd gear so i let off...
BankShot is offline   Reply With Quote
 Old 12-02-2015, 07:14 AM   #2
chaser27's Avatar
Posts: 1,276   (View Stats)
chaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the worldchaser27 is the leader of the world
Groans: 42
Groaned at 16 Times in 12 Posts
You are getting consistently high amounts of knock in each log ~4-5k rpm. You're timing and boost don't seem un-ordinary.
Your AFR seems a little rich to me, but with a MAF cal that seems close enough not to cause that. What are your targets? It's sitting around ~11. Makes me think you may have a boost leak POST-TURBO.
Most people take a single gear log instead of the multiple ones you have. In the future, try getting in 3rd or 4th gear ~3k rpm. Start your log and pin it to redline and stop the log. No need for 30 second logs.
Coming at ya with all 297/359
POWER: HTP 3" intake, Corksport BPV, Treadstone FMIC, Cobb EBCS, Autotech HPFP, CPE full catless DP
ECU: self-tuned
HANDLING: JBR RSB (Middle Setting)
RICE: Stickers and stuff, mudflaps, floormats, Evil M, etc.
RADAR: Passport Escort 9500ci
chaser27 is offline   Reply With Quote
 Old 12-02-2015, 11:44 AM   #3
BankShot's Avatar
First off thanks for looking at it
Goals are prolly nothing more the a cat back exhaust maybe like a corksport turbo considering my turbo burns oil
So prolly not gonna mod anymore, jus looking for what everyone is
Safe boosting and air alphas to be spot on.
BTW what is target vacuum at idle, mine is about 10in according to AP.
POST TURBO leaks would involve..........?
One more thing, yes I will only do single gear logs lol.
 Old 12-02-2015, 11:50 AM   #4
chaser27's Avatar
Groans: 42
If your turbo seals are letting oil past, it could be causing your knock and rich(ish) condition. You need to get that fixed first. No point in doing damage to your engine before you get that turbo replaced.
ECU: self-tuned
 Old 12-03-2015, 07:38 PM   #5
Micha's Avatar
Posts: 3,436   (View Stats)
Micha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the worldMicha is the leader of the world
Groans: 261
Groaned at 73 Times in 60 Posts
Hit me up if you need places to do logs. I have the perfect spot.
Micha is offline   Reply With Quote
First data logs with AP cbmms3 MazdaSpeed 3/6 - ECU Computer Tuning 3 02-18-2015 04:00 AM
First data logs and VD CrawlingMS3 2010 MS3 - ECU Computer Tuning 13 04-04-2013 06:10 AM
New Data Logs neofandango 2010 MS3 - ECU Computer Tuning 11 12-01-2011 03:53 PM
New Data Logs neofandango 2010 MS3 - ECU Computer Tuning 2 11-23-2011 04:38 PM
My first data logs Speedin 2010 MS3 - ECU Computer Tuning 4 10-16-2011 04:52 PM
Page generated in 0.27600 seconds with 23 queries
