 Old 03-24-2008, 10:35 PM   #1
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
Default Datalogs
Ok I did some data logs of the following.
1st to 3rd gear to see if i could see why i would backfire and it appears that when i shift the afrs take a nice turn to the rich side.
then i did a 4th gear pull just to see how everything looks there, at about 4k rpm afr's jump up a bit, i don't know if its because i didn't make a smooth transition with my coupler for the smaller maf housing or what causing turbulence.
then i did a 5th gear pull because when i driving i was hitting fuel cut, or what i perceived to be it so you wil see the spots where i hit some kind of cut.
1st to 3rd
4th gear
5th gear with fuel cut
 Old 03-24-2008, 10:50 PM   #2
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Yea, thats almost VTA rich... i would try to do something about that MAF mod. It has got to be a little bit bigger. Your exhaust system is catching hell for it too!
 Old 03-24-2008, 11:03 PM   #3
bova's Avatar
Groans: 45
ha maybe i should run a vta map.
 Old 03-24-2008, 11:06 PM   #4
Eatin' Your Tuna
Haltech's Avatar
Groans: 244
Try it, see what happens.
 Old 03-25-2008, 06:28 AM   #5
bova's Avatar
Groans: 45
not sure vta did anything, looks like i will be doing some dremeling this evening.
 Old 03-25-2008, 07:11 AM   #6
Laloosh's Avatar
Posts: 5,166   (View Stats)
Groans: 57
hmm strange looking grapsh. What was the outside temp during those runs.
 Old 03-25-2008, 07:25 AM   #7
bova's Avatar
Groans: 45
the ones up above it was about 30, the newest one it was about 25
 Old 03-25-2008, 07:28 AM   #8
Laloosh's Avatar
Groans: 57
i figured...try stretching your springs. What are you using a map clamp or the ATB bcd?
 Old 03-25-2008, 07:32 AM   #9
bova's Avatar
Groans: 45
they were stretched a couple months ago. map clamp was at 13.
i don't think the vta map helped cause doesn't the standback only work in open loop? so those logs of 1 through 3 were probably closed loop and thats where i get the backfire (actually afterfire to be proper)
 Old 03-26-2008, 11:23 AM   #10
bova's Avatar
Groans: 45
here are some more data logs i did. this is after i fixed the coupler in my maf housing. it elimated my backfire. you can see that there is no rich spike after the shift, it does get a bit rich but its a smooth curve rather than a spike and doesn't drop as low as before.
and then here is one where my car got real sluggish in 4th gear and if you notice my fuel pressure basically dropped. think i let my rpm's drop to low before punching it in 4th.
 Old 03-26-2008, 11:38 AM   #11
Laloosh's Avatar
Groans: 57
you are running out of fuel...look at your fuel pressure....
 Old 03-26-2008, 11:46 AM   #12
bova's Avatar
Groans: 45
ha and my only mods are the standback, exhaust, FMIC with intake.
 Old 03-26-2008, 11:53 AM   #13
NYpest's Avatar
Posts: 1,889   (View Stats)
NYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the worldNYpest is the leader of the world
..........insert pump here<---------
NYpest is offline   Reply With Quote
 Old 03-26-2008, 11:54 AM   #14
bova's Avatar
Groans: 45
maybe i'll get one where PT-Performance's come out and are under $300
 Old 03-26-2008, 11:57 AM   #15
Laloosh's Avatar
Groans: 57
according to dadasracecar you have a fualty fuel sytem lmao
 Old 03-26-2008, 11:59 AM   #16
bova's Avatar
Groans: 45
hahaha yeah i'm sure i do. maybe i put sand in my own gas tank.
but honestly i think its cause i bogged the motor down on the highway while trying this. i will do it again later and see what happens.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f9/datalogs-432/
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-26-2008 11:30 AM
Page generated in 0.47811 seconds with 23 queries
