 Old 12-26-2008, 11:40 AM   #1
johnac08's Avatar
Posts: 141   (View Stats)
johnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud ofjohnac08 has much to be proud of
Default ecu learning trick?, will this work?
got this from Re-Mapped ECU Learning Trick 10-20hp in 5 seconds - NASIOC
Its for Subaru's not sure if its the same learning method our ECU does.
Just a little trick that has been shown to accelerate the factory ECU's ignition timing learning process.
Background: There is something called "Ignition Advance Multiplier". It represents, by some complicated algorithm, the average learned positive knock correction applied to the ignition maps. It's represented in 1/8th degrees increments. 1 being the lowest and 16 being the highest (1/8 to 2 degrees in absolute terms).
The "happier" (knock free) the car is, the higher the number will be. Conversely, the lower it is, the more knock prone it is. This number, after ECU reset ore ECU swap defaults to 8 and usually creeps up to 16 (if well mapped) through normal driving. Depending on driving characteristics, this can happen within a few hours or a few weeks. Well, here's a way to make it happen in about 5 seconds ....
First: With the car fully warmed up, reset the ECU. This can be done by killing power the ECU or by simply pulling off the neg. battery terminal and pressing the brake pedal for a couple of seconds.
Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower
In an attempt to save a lot of dyno time between reflashes (when the advance multiplier resets itself), I do this little trick after every reflash. In a typical dyno session, it's not unusual to reflash the same car up to 5 times. On the dyno, all I need to do is tell the dyno to hold revs to 2600rpm. Then I just lay on the throttle until I see a few psi of boost... Bingo!
Warning: This little trick artificially speeds up the learning process. This is only a good thing if the re-mapped ECU is mapped properly. If there are trouble-spots where knock is present, this trick will make it even more present. So be careful!
2007 MAZDASPEED6 GT Liquid Platinum Metallic
ENGINE MODS: CPE FMIC, CPE FullControl Flash, ATP Downpipe W/ High Flow Cat, CPE Dual Exhaust, CPE Xcel™ CAI, HKS SSQV BOV, DNP Turbo Manifold, ProSport Ceramic Header Wrap, Speedie6 Inlet Pipe, SU Recirc Tube. CPE Engine Mount, CPE Standback w/ PNP, WOT Box Full Throttle/2Step, HKS Twin Power Ignition System, Denso 2Step Colder Plugs, Redline Tuning Hood QuickLift:Elite, Greddy Catch Can, Spin-On Oil Filter Conversion Kit, Mobil1 5w-30 FullySynthetic, Redline MT-90
INTERIOR MODS: MSD Dashhawk, TWM SS Stage 2 w/ Bushings, 52mm VEI Boost Gauge, 52mm Vent Pod
EXTERIOR MODS: VG Sharkfin Antenna, 18" 5ZIGEN 5ZR Wheels 43+ Offset with 225/40/18 TR1 Toyo Tires
Future Mods: CPE Rear Diff Brace, TT Front Engine Mount, TT Rear Diff Front Mount, BC Coilovers, CPE HPFpump, GT3076r or GT3582r
THIS IS WHERE MY MONEY GOES!>> Mazda6 / Atenza (Powered by Invision Power Board)
johnac08 is offline   Reply With Quote
 Old 12-26-2008, 01:18 PM   #2
motocrosser614's Avatar
Posts: 687   (View Stats)
motocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the world
Groaned at 15 Times in 14 Posts
video of this in action? Dynoes? I cant trust your hear say with the life of my car and i dont think anyone will until proven.
whats that mean i think everyone on this forum has had knock at least once even a blip of .7 or w/e is still knock.
motocrosser614 is offline   Reply With Quote
 Old 12-26-2008, 02:39 PM   #3
toprock's Avatar
Posts: 749   (View Stats)
toprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the worldtoprock is the leader of the world
Groans: 40
This reminds me of video game cheats back in the day...
For Example:
Stand three steps away from the tunnel. Press B and hold it for 20 seconds, then walk forward in the direction of the tree and a magical bunny will pop out and give you a star!
LMFAO I don't know if anyone will get what I'm talking about...
toprock is offline   Reply With Quote
The Following User Says NO Thank You to toprock For This Un-useful Post:
 Old 12-27-2008, 05:39 AM   #4
sk33ny's Avatar
Posts: 26   (View Stats)
sk33ny has a spectacular aura aboutsk33ny has a spectacular aura aboutsk33ny has a spectacular aura about
Im pretty sure this wont work on the MS3s ECU.
sk33ny is offline   Reply With Quote
 Old 12-30-2008, 04:56 AM   #5
Strizzo's Avatar
Posts: 148   (View Stats)
Strizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of lightStrizzo is a glorious beacon of light
i've heard similar instructions for a lot of different cars. some times its to get the ecu to adjust for race gas (after reset, if the ecu doesn't see any knock, it'll keep advancing timing until it runs out of adjustment range or finds some knock)
i'd imagine our ecu's can be persuaded in a similar way, but then the odd throttle behavior at part throttle will probably be more pronounced
Strizzo is offline   Reply With Quote
 Old 12-31-2008, 08:34 PM   #6
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
I think our ecu is wayyyy too smart for that. If it did work it would be temporary. This ecu seems to learn and adjust constantly.
TRU-BOOST is offline   Reply With Quote
 Old 12-31-2008, 08:47 PM   #7
mexicant's Avatar
Posts: 867   (View Stats)
mexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the worldmexicant is the leader of the world
Groans: 147
Groaned at 34 Times in 29 Posts
u have a better chance of blowing up with all that partial throttle boost and shit. boom boom boom
"08, I hate to break it to you, but if it gives kevin a boner, its porn"
NATOR PERFORMANCE
Nylon washer sponsered
mexicant is offline   Reply With Quote
The Following User Says Thank You to mexicant For This Useful Post:
mdogg (01-01-2009)
SEMA 2008: Cheap Trick Dream Police Tactical Vehicle Haltech Automotive News 0 11-07-2008 02:30 PM
Car dealers learning art of viral video Haltech Automotive News 3 09-29-2008 05:54 PM
TORN: Work CR KAI or Work xd9? EvilMonkey MazdaSpeed 3/6 - Wheels & Tires 16 09-26-2008 07:44 AM
Neat trick: Chrysler claims $1.1 billion profit Haltech Automotive News 0 08-08-2008 09:30 AM
VIDEO: The old "cover the Carrera GT with Post-It notes" trick Haltech Automotive News 0 04-14-2008 06:50 PM
Page generated in 0.28975 seconds with 26 queries
