Like Tree6Likes
 Old 09-05-2011, 06:38 PM   #1
ms6ms6's Avatar
Posts: 802   (View Stats)
ms6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond reputems6ms6 has a reputation beyond repute
Groaned at 8 Times in 7 Posts
Default GrimmSpeed 3 Port Boost Control Solenoid ?
Has anyone installed the Grimm Speed 3 port boost control solenoid for 2 ports only? when installing 3 it needs a tune but they say that U can install it for 2 ports only without tunning leaving the 3rd port unplogged. how do I install it - I got a GT 2871. I installed it but it gets overboosting - 25psi. before installation I had a tune but only for the standback - just a little "safe" tune.
Jansi likes this.
ms6ms6 is offline   Reply With Quote
 Old 09-07-2011, 04:09 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,518   (View Stats)
I thought you had to plug the 3rd port. What WGA are you using?
2006 Mazdaspeed 6
rfinkle2 (09-07-2011)
 Old 09-07-2011, 04:12 PM   #3
m4tic's Avatar
Posts: 4,922   (View Stats)
lol you need a tune... you need to lower WGA duty cycle
wait did i read GT28 and grimm with no tune...
get ready for the ZZB club
2007 MS6 w/ Cheez
The Following User Says Thank You to m4tic For This Useful Post:
i8urgti (09-10-2011)
 Old 09-07-2011, 04:19 PM   #4
rfinkle2's Avatar
Posts: 14,536   (View Stats)
Groans: 298
Grimmspeed can be used in 2 port mode this way:
https://www.grimmspeed.com/install_g...MazdaSpeed.pdf
10. Hook up vacuum lines. Port 1 connects to a high pressure boost source. Remove 4mm
vacuum line on wastegate. Connect 4mm vacuum line from this connector to Port 1 on the
GrimmSpeed BCS.
11. Port 2 connects to the turbo inlet. Remove oem and replace with 4mm hose and bring
4mm hose to Port 2 on the BCS. It is recommended that a plastic zip tie is used to secure
vacuum lines.
SLOWHATCH (09-07-2011)
 Old 09-07-2011, 04:29 PM   #5
atvfreek's Avatar
Posts: 7,784   (View Stats)
Do you have an AccessPORT?
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
 Old 09-08-2011, 05:44 AM   #6
ms6ms6's Avatar
Default pic
Im ready fix now 19PSI
The Following User Says Thank You to ms6ms6 For This Useful Post:
rfinkle2 (09-08-2011)
 Old 09-08-2011, 06:16 AM   #7
you might get some bad boost spikes because your still using the stock compressor nipple which has the restrictor in it.
 Old 09-08-2011, 06:31 AM   #8
rfinkle2's Avatar
Groans: 298
This did the trick!
 Old 09-08-2011, 10:21 AM   #9
Speeeeeed
06Speed6's Avatar
I thought I remembered that lol, I run it in 3 port mode so I wasnt sure.
+1 on removing the restrictor, it helps alot.
2006 Mazdaspeed 6
 Old 09-08-2011, 12:14 PM   #10
mdd5148's Avatar
Posts: 303   (View Stats)
mdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the worldmdd5148 is the leader of the world
Anyone running 3 port install using diagram f in instructions: https://www.grimmspeed.com/install_g...MazdaSpeed.pdf
Port 1 to inlet
Port 2 to wastegate
Port 3 to turbo
2005 Porsche 911 - Pure Sex
Staggered 19" HRE P47's
2007 Mazdaspeed6 GT - #10318 - Sold
AWR Passenger Side Mount | AWR Transmission Mount | CPE RMM | CPE Intake | CPE Inlet | CPE Downpipe | CPE Catback | CPE Fuel Pump | CPE Manifold | TIAL 44mm Wastegate | Grimmspeed EBCS | Custom FMIC | HKS BOV | GT3076 | Cobb AP | Labonte Stage 2 meth | TWM Stage 2 Short Shifter | VEI boost gauge | CPE Tow Plate | LED Tail Lights | LED Mirrors | CX7 Antenna | 18x8.5 Rays Gram Light 57F
2006 Miata Sport - She took it...
Stock For Now...
mdd5148 is offline   Reply With Quote
 Old 09-08-2011, 12:20 PM   #11
starscream's Avatar
Posts: 630   (View Stats)
starscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the worldstarscream is the leader of the world
Groans: 44
This also apply to the stock K04? As in the resitrictor pill? If thats the case, where should you take that source instead of the one on the turbo?
starscream is offline   Reply With Quote
 Old 09-08-2011, 12:21 PM   #12
rfinkle2's Avatar
Groans: 298
Port 1 to inlet
Port 2 to wastegate
Port 3 to turbo
@manelscout4life has a thread concerning using the grimmspeed with a newer ewg.
Grimmspeed and EWG
manelscout4life (09-08-2011), mdd5148 (09-08-2011)
 Old 09-08-2011, 01:01 PM   #13
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
bcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the worldbcmurphy87 is the leader of the world
I love my GS, i just hate the ticking i here in the cabin
Vegas_cs likes this.
06 Speed 6- EBtec built, FreekTuned and 5862 powered! 540/493
06 Speed6 GT- Sold
just bang out the tight spots.
bcmurphy87 is offline   Reply With Quote
 Old 09-08-2011, 01:46 PM   #14
rfinkle2's Avatar
Groans: 298
Do you have it installed on the firewall?
I have mine installed pretty far away from the firewall and never hear a peep.
Alpha (09-09-2011)
 Old 09-08-2011, 01:48 PM   #15
bcmurphy87's Avatar
Yea its on the firewall, i guess i could remove it from there
06 Speed6 GT- Sold
 Old 09-09-2011, 04:44 PM   #16
rfinkle2's Avatar
Groans: 298
If you move it, you won't be able to hear the ticking.
I've heard other guys that mounted theirs on the firewall and reported ticking.
Alpha (09-09-2011)
 Old 09-09-2011, 09:53 PM   #17
starscream's Avatar
Groans: 44
so just to go over my last question...
if your using this in 2 port w/ stock k04, is a restrictor pill still needed? the instructions dont say it is required but it wont be the first time that someones instructions were wrong so hence I am asking the gurus here
The Following User Says Thank You to starscream For This Useful Post:
rfinkle2 (09-10-2011)
 Old 09-10-2011, 04:16 PM   #18
rfinkle2's Avatar
Groans: 298
If you have the ko4, the restrictor pill is part of the compressor housing nipple.
I would think grimmspeed says you do not need to tune for the solenoid in 2 port mode because the restrictor pill is assumed to be in tact.
If you have atr, just cut your wgdc in half whichever way you install it, and take it easy the first few times you boost.
If you need a hand tweaking your map, I could certainly help you.
starscream (09-10-2011)
 Old 09-10-2011, 04:23 PM   #19
starscream's Avatar
Groans: 44
Thanks for the help!
I dont quite use ATR right now, I have a...different tuning method. Its not any of the current tuning solutions out there. Its like I am beta testing a new solution...but I'll definately pass along the info. I may later on endup switching, depending on the outcome of how what I am doing works out.
 Old 09-10-2011, 04:26 PM   #20
rfinkle2's Avatar
Groans: 298
fwiw, regardless of the software you are using, I'd cut wgdc down to 50% of what you were previously using.
You can always revert back to, or creep up on your original values if you are drastically underboosting.
 Old 09-10-2011, 08:15 PM   #21
Speeeeeed
06Speed6's Avatar
The pill should be drilled out for either the 2 port or 3 port method, the reason is that the grimmspeed is a larger bcs and reacts faster than the stock unit. It shouldnt be bottle necked by that restrictor pill.
I "drilled" mine out with a ratcheting screwdriver, a 12" flex extension, and a drill bit. Just be carefull not to drill too far.
On the stock turbo, there is also 2 ports on the wga. One will need to be plugged but those rubber plugs are a ticking time bomb of leakage. It would definitely recommend a wga upgrade to one that only has one port.
2006 Mazdaspeed 6
Alpha (09-11-2011), rfinkle2 (09-11-2011)
 Old 11-10-2011, 07:59 AM   #22
ESB Jiu JItsu's Avatar
Posts: 492   (View Stats)
ESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the worldESB Jiu JItsu is the leader of the world
Groaned at 4 Times in 2 Posts
I have reason to beleive that my stock boost controll solenoid is not functioning properly anymore. I have a stock K04 and minor mods(see sig). I have read i can just take out the stock BCS and install the grimmspeed 2 port and run like normal. What other mods would i need to do to make this work as I intend it too.... I see that i may need to drill out my turbo pill...anything else? Also by using the grimmspeed in 2 port can I control the stock boost? And then once I get a cobb AP in the near future i can then run 3 port and tune. Thanks for any clarification anyone can offer. Im trying to research more about MBC/EBC but now that it seems my BCS is crap i need to get something that can both control boost and work in place of the stock system. thanks agian!
2006 Mazdaspeed6 GT Liquid Platinum Metallic
"because racecar!" " I love this $%&*ing car"
-Gram Lights 57C 18"x7.5/Cooper SR3-A 2254018/H&R Springs/SURE RMM/Diff Straps
-2.75 Blow Through MAF/Custom CXracing FMIC&BOV/Fujita SRI/AEM dryflow/PG TIP/SLS TP/Exhaust Delete/NGK LTR7IX11 plugs/ TB Coolant BP/Bat->Trunk Relocation/JBR egr delete
-TWM Stage 2 Short Shifter/JBR Weighted Shift Knob/TWM 4in Shifter Extender
-Emil Drilled/Slotted rotors/Hawk HP Pads/Clutch Pedal Mod/Shift Counter Weight Mod
-Custom Vented Hood/Custom Front Bumper/Emblem delete/Prosport Mech. boost gauge
ESB Jiu JItsu is offline   Reply With Quote
 Old 11-10-2011, 10:40 AM   #23
Alpha's Avatar
Posts: 3,709   (View Stats)
Groans: 24
Groaned at 108 Times in 60 Posts
This is correct, and you'll need to plug the unused ports.
 Old 11-10-2011, 12:32 PM   #24
Excellent thank you for that tip as well. Also can I control boost with just the grimmspeed EBCS....with out an AP or a MBC? If so where? Seems like a stupid question lol but I just dont see anywhere to adjust boost in any of the pictures of the devise. thank you again I am excited about this option, and shouldnt have to go long in 2 port because i see a AP in my near future , but right now im stuck in 10 psi mode and dont think its a boost leak. So Im assuming its the factory BCS.
 Old 11-10-2011, 05:18 PM   #25
Speeeeeed
06Speed6's Avatar
You cannot control the boost without a tuner, but it should function like the factory bcs until you do.
2006 Mazdaspeed 6
 Old 03-31-2012, 01:33 AM   #26
Posts: 6,663   (View Stats)
Necroposting like a mofo...
The instruction manual for the GrimmSpeed EBCS does not mention plugging the unused port 3, and they don't provide a plug for it. I just tested out my new GrimmSpeed EBCS with port 3 unplugged and had no trouble hitting my boost targets.
GLORIFIEDBOZO (03-31-2012)
 Old 03-31-2012, 01:44 AM   #27
Jeremy3eb's Avatar
Posts: 359   (View Stats)
Jeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the worldJeremy3eb is the leader of the world
Groans: 29
Mine is run 2-port, as well, without the third port plugged. No issues.
Jeremy3eb is offline   Reply With Quote
 Old 03-31-2012, 02:01 AM   #28
KevMS6's Avatar
Posts: 316   (View Stats)
KevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the worldKevMS6 is the leader of the world
Follow the grimmspeed instructions... Job done
I had 2 port bleed mode before tune without issue
Now running 3 port interrupt mode with VT
Do not mount on firewall on the 6, the ticking noise is very annoying
Seban likes this.
Cpe tmic&sri, 3" HTP tip, 3" ebay downpipe, BNR stage1, Autotech internals, Snow stage 2 meth with Aqaumist jet/parts, GoFastBits Respons BOV, Grimmspeed ebcs 3-port, Turbinetech diff mount, Cpe diff brace, Whiteline rarb, Bilstein B8's, Eibach springs, NGK iridium IX plugs, Corksport Mods, JBR mods... 324whp 361lb/ft
Tuned with by
KevMS6 is offline   Reply With Quote
 Old 03-31-2012, 10:19 AM   #29
MSMS3's Avatar
Posts: 2,111   (View Stats)
Groans: 107
I'm running the GS in two port mode on the stock K04 to replace failed OEM ebcs. I found it necessary to plug the third port on the GS.
The product did come with a short piece of vacuum line and a cap. Putting it on without a clamp was not tight enough. Once I put a clamp on it, I found it easy to hit 18-19 psi boost target with a normal for me WGDC of 70-75%.
Not to disagree too strongly with post above to contrary, but I needed to cap the 3rd port and secure the cap tightly with a clamp.
 Old 04-01-2012, 04:24 AM   #30
keridil's Avatar
Posts: 84   (View Stats)
keridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond reputekeridil has a reputation beyond repute
You're right, quite annoying. Where did you put yours?
Mazda 6 MPS / BPV GFB / RX-8 8x18" Wheels / EBC RedStuff pads / 235x40 Michelin PS4 / Bilstein B8 & Eibach Pro-Kit / Stainless Steel Brake Lines / Autoexe Front Strut Bar / SU Rear Floor Cross Bar / SURE Anchors, CounterShift, Dreadnaught, Torq R6 70a, 621g AGS Shift Knob / CorkSport 3" SRI / Ralco RZ SS Stage 2 / GrimmSpeed EBCS (interrupt) / CorkSport TMIC / CorkSport DP / AutoTech HPFP internals / BNR stage 3 v2 <-Stratified tuned
'07 BMW 335xi / Koni Yellow & HR / UUC SSK / M193 225/40 8"x18" 255/40 8.5"x18" Michelin PS4 / ER chargepipe / 335is clutch / MHD E30 mapped
keridil is offline   Reply With Quote
 Old 04-01-2012, 04:36 AM   #31
KevMS6's Avatar
I just tie wrapped it into position, on the wiring loom closest to tip, not ideal but I'm more than happy with it there... Not caused any issues and more importantly can't hear a thing!!
Tuned with by
The Following User Says Thank You to KevMS6 For This Useful Post:
keridil (04-01-2012)
 Old 04-01-2012, 09:22 AM   #32
The cap they provide is 6mm and is for the bottom of the Wastegate Actuator when running in interrupt (3-port) mode. It's not for running in bleed (2-port) mode.
The ports on the EBCS are all 4mm.
KevMS6 (04-11-2012), rfinkle2 (04-11-2012)
 Old 04-01-2012, 09:56 AM   #33
MS3-a(sore)ASS-rex's Avatar
Posts: 7,012   (View Stats)
Groans: 224
Can't wait to get mine on after waiting over 2 month for the thing to show up. Now if only I didn't suck with ATR.....
eat-sleep-speed likes this.
NATOR PA
 Old 04-11-2012, 12:33 PM   #34
exentix's Avatar
Posts: 1,568   (View Stats)
exentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the worldexentix is the leader of the world
Groans: 46
Groaned at 15 Times in 6 Posts
ok im about to install mine, but how do you go about blocking off port 3? like mentioned it doesnt have one, and doesnt state if you really need one or not. i talked to grimmspeed and he wasnt really sure, and an engineer wasnt around to ask.
exentix is offline   Reply With Quote
 Old 04-11-2012, 12:50 PM   #35
KevMS6's Avatar
Instructions: https://www.grimmspeed.com/install_g...MazdaSpeed.pdf
It says to remove factory restrictor pill for external wastegate applications however do you guys think drilling it out for 3-port interrupt mode is best?
If so, is there any info or a how-to on doing this?
Tuned with by
 Old 04-11-2012, 12:52 PM   #36
polysynth's Avatar
Posts: 62   (View Stats)
polysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the worldpolysynth is the leader of the world
^^ Beat me to it.
I still have the pill...runs fine with it in 3port mode.
polysynth is offline   Reply With Quote
 Old 04-11-2012, 02:47 PM   #37
MSMS3's Avatar
Groans: 107
I don't know if capping port 3 when in 2 port mode is necessary or helpful. It just might be coincidence that I seemed to pick up boost and wastegate duty cycle seemed to be closer to expected after I did that. It just might have been the ECU adjusting.
The 6mm cap is installed on the end of a plastic adapter that converts 6mm down to 4mm. That came with the kit. I just used that cap on one end of the adapter, a short 4mm vacuum line on the other end with hose clamps on both ends of the 4mm hose. Even if not necessary or helpful, it deeps dirt and debris out of that port.
 Old 04-11-2012, 08:09 PM   #38
exentix's Avatar
Groans: 46
ok i just got everything back together a few hours ago and drove around a bit. few things i noticed. 1. cobb bpv needs lubed up, its hanging. 2. cant hit boost targets, only 12 psi max, targeting 16 on ots map. 3. according to my ap, im only hitting 75%ish throttle, even wot.
any suggestions? car is slow as hell right now... also, popped a few cels after startup, but they were just tpms codes, whew....
 Old 04-12-2012, 07:19 AM   #39
The throttle plate maxes out at around 75-78%. That's as far as it will physically open.
Lube your BPV and see if it's hitting boost targets. If not, up WGDC.
exentix (04-12-2012)
 Old 04-12-2012, 07:52 AM   #40
exentix's Avatar
Groans: 46
I'll try that today.
LinkBack to this Thread: http://www.mazdaspeedforums.org/forum/f9/grimmspeed-3-port-boost-control-solenoid-90900/
?????-???????? : GrimmSpeed 3 Port Boost Control Solenoid This thread Refback 01-05-2015 03:01 AM
MAC 3-port Boost Solenoid heloboby7 MazdaSpeed 3/6 - ECU Computer Tuning 3 08-12-2011 11:15 AM
the grimmspeed 3 port boost solenoid (EBC) blkspeed6 Mazdaspeed3/6 General Discussion 64 04-07-2011 11:18 PM
3 port boost control solenoid tuning Ckmazdaspeed3 2010 MS3 - ECU Computer Tuning 20 04-05-2011 11:31 AM
Initial Impressions of Grimmspeed Boost Solenoid tbot MazdaSpeed 3/6 - ECU Computer Tuning 44 04-14-2010 04:45 PM
Page generated in 0.58792 seconds with 39 queries
