How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02
Bookmark and Share LinkBack Thread Tools Display Modes
 Old 05-14-2008, 09:26 AM   #1
More air More fuel
94jedi's Avatar
Posts: 2,190   (View Stats)
94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world94jedi is the leader of the world
Groaned at 7 Times in 5 Posts
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss2190
Default How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02
Taken from a post on the other forum by Christian @ Cobb
[quote author=Christian/COBB Tuning link=topic=111760.msg2313621#msg2313621 date=1210781737]
[size=14pt]How ECUs Use Closed-Loop Controls to Make Fueling Corrections v1.02[/size]
This document has been created to explain how the factory Engine Control Unit (ECU) uses its closed-loop control systems to make fueling corrections for aftermarket intake systems. This document will also go into specific details to explain the consequences of operating your vehicle with these aftermarket intake systems. These consequences are based on operating your vehicle without proper ECU calibrations or while running a stock calibrations with these aftermarket intake systems. We will first explain what goals have be programmed in the ECU code, what components are used in the closed-loop control system, and what authority the ECU has to make corrections and report system failures.
For an introduction, we feel it would be best to review how the fuel system operates. This information has been taken from COBB Tuning's EFI 102 class material. We also offer a Free online EFI 101 class that can be found on this link.
The input triggers for most modern EFI fuel systems usually come from the Camshaft Position Sensor (CMP) and Crankshaft Position Sensor (CKP). These input triggers are set-up to let the ECU know when it should open and close the fuel injectors for each cylinder. Inputs from the Main Load Sensor (Mass Air Flow or MAF) are used by the ECU to generate an initial output for the fuel injector pulse width and Camshaft Driven Fuel Pump (CDFP) duty cycles, this output us usually measured in milliseconds. The ECM will then make compensatory adjustments based on additional sensor inputs including: Engine Coolant Temperature (ECT), Throttle Position Sensor (TPS), Knock (KNK), System Voltage, Torque Demand, Heated Exhaust Gas Oxygen (HEGO), etc. The ECU will modify the fuel injector pulse width and CDFP duty cycles based on the look-up values in these compensatory tables then final adjustments are made according to learned information stored inside the ECM; Short Term Fuel Trim (STFT) and Long Term Fuel Trims (LTFT). These final adjustments are usually made by the ECU in order to achieve emissions targets.
All ECUs are simply programmed to understand the engine hardware it is trying to control and the sensors that are being used to control the engine. The hardware being controlled includes the engine long-block, turbochargers, CDFP, electronic throttle bodies, various control solenoids, and engine sensors including the critical MAF sensor. In order to meet ideal emission standards, the ECU is programmed to achieve 1 Lambda (or an Air/Fuel ratio of 14.68:1 for petrol fuel) during idle and light cruising conditions. To achieve this, OEM calibration engineers will spend extensive time working with sensor manufacturers, testing, and analyzing data in order to establish proper ECU calibrations. A major component of these calibrations includes the calibration for the MAF sensor. The MAF calibration is programmed to correlate the ratio of the MASS of fuel being injected in the engine with the MASS of air entering the engine. This information is then used by the ECU to achieve the fuel targets dictated in the fuel table(s). Once the ECU has been properly calibrated, it will then be able to calculate accurate Lambda (or Air/Fuel) values.
The ECU will use the MAF sensor readings to make initial fueling calculations. The ECU will then use the HEGO sensor, which is located in the sealed exhaust system, to measure the actual Lambda (or Air/Fuel ratio) achieved by the engine. This sensor's measurements are then used to make corrections to the fueling of the engine in order for the engine to achieve it's fueling and emissions goals. An example of a modern fuel look-up table can be seen below. This table is only accurate if all other components used for making fueling calculations have been properly calibrated within the ECU.
The ECU is programmed to make more than one correction for fueling, it can actually make several STFT and LTFT corrections across the MAF sensor range. Some ECUs can learn corrections for idle, part throttle, medium throttle, and Wide Open Throttle (WOT) conditions, and some simply apply corrections over various MAF ranges. How the ECU applies LTFT corrections depends on how it has been programmed. The objective of applying these corrections is to allow the ECU to make accurate fueling calculations for the varying fuel mixtures (100% petrol, E10, E15, etc.) that are available at the petrol pump, to account for minor intake system leaks, and to compensate for mechanical variances that may occur from vehicle to vehicle or due to engine component wear. Ideally, LTFT that are within a +/- 6% range, across the entire MAF, are acceptable.
If an aftermarket intake system is installed that does not closely duplicate the performance of the stock intake system, then the ECU will immediately start to make STFT corrections. If the ECU constantly measures that a STFT is being made, then it will move that correction to the LTFT so it can apply this correction on a constant basis. If an aftermarket intake system allows for a 10% additional MASS of airflow into the engine without the MAF sensor being properly calibrated, then the ECU will eventually measure and save a +10% LTFT that is applied for fueling calculations. If an aftermarket intake system allows for a 10% less MASS of airflow into the engine without the MAF sensor being properly calibrated, then the ECU will eventually measure and save a -10% LTFT that is applied for fueling calculations. The objective of the closed-loop fueling system is to allow for accurate fuel calculations.
An ECU will usually have the authority to make STFT corrections of +/- 25% and LTFT corrections of +/-35% (these limits vary by vehicle make and model). If the ECU has to make fueling corrections that are beyond these allowable corrections, then the ECU will find that something is wrong with the vehicle and it will illuminate the Malfunction Indicator Lamp (MIL, or Check Engine Light) to inform the driver that the system is either running too lean (P0171) or too rich (P0172). The sophistication of modern ECU closed-loop control systems allows for many different hardware items (intake, headers, exhausts, turbochargers, etc.) to be installed, and the engines can be driven. Although, changing ANY efficiency characteristic of an engine requires that a proper ECU calibration be developed in order to fully utilize this new hardware. Operating an engine that has ANY efficiency-changing hardware installed without a proper calibrations can lead to premature engine failure, poor gas mileage, increased emissions, and poor driving quality.
What this means to you:
- One of the most important things you will want to do after you install a properly designed aftermarket intake system is to reset the ECU and drive at very light loads for extended periods of time after the installation. Resetting the ECU will erase any STFT and LTFT values which will allow the ECU to start making compensatory corrections to the fueling calculations.
- Immediately after starting your vehicle, the fuel trims are usually not active. The ECU must heat the HEGO sensor and make sure various sensors complete system checks before the system is activated.
- The accuracy of all input triggers is critical. Using piggy-back devices that skew these triggers does not allow the ECU to calculate the proper timing of fuel injection or ignition operations. This is critical when trying to calculate fuel injection windows and ignition timing on a DISI engine!
- Using a MAP clamp actually throws off the load calculations and the car will not properly fuel itself, it will be too lean.
- Using a MAP clamp actually throws off the torque calculations and the car will not properly control the other sub-systems of the engine properly.
- Most ECUs will store LTFT corrections under heavy load conditions and will eventually apply them to WOT conditions under the assumption that these conditions will continue under WOT conditions.
- Engine longevity can be compromised if proper calibrations are not established for any hardware that has changed engine efficiency.
- Reflashing a calibration intended for hardware other other than what is installed on your vehicle may compromise the performance, driving quality, or longevity of the engine.
- Reflashing a calibration that is a “one size fits all” tune may compromise the performance, driving quality, or longevity of the engine.
Please let me know if this information is useful?
Take care,
Christian.
[/quote]
94jedi is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
The Following 4 Users Say Thank You to 94jedi For This Useful Post:
CMESCOOT (05-14-2008), Crossbow (05-14-2008), kramer (05-16-2008), Zeya (12-15-2008)
 Old 05-14-2008, 09:52 AM   #2
Laloosh's Avatar
Posts: 5,099   (View Stats)
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
Send a message via AIM to Laloosh
good read, but ocne again after turning my map clamp voltage up or down, my af didnt change any.
Laloosh is offline
The Following User Says Thank You to Laloosh For This Useful Post:
shucky (05-14-2008)
 Old 05-15-2008, 02:40 PM   #3
ALL PG And NO B.S.
TRU-BOOST's Avatar
Posts: 754   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
Activity Longevity
0/20 20/20
Today Posts
0/7 ssssss754
i can tell you this, no matter what the strokes at cpe told you it does have an effect. i have noticed that if i chang my map clamp voltage it WILL CHANGE THE FUEL TRIMS ! my LTFT was at 16% i adjust my map clamp to allow the ecu to see 15psi up from the11psi i usually keep it at. now that the map is seeing more boost my LTFT has dropped to 9%. it was notieable right away with the STFT too. once i let it see 15psi my stft went to like -7% while under full boost. now that my trims are closer to 0 my cutting seems less frequent. YES i still get it, but not as much.
TRU-BOOST is offline
 Old 05-15-2008, 02:47 PM   #4
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
see it doesnt do shit for me, and my car doesnt cut. I will however try it again, hell ill go outside right now. If its insant i shoudl be able to see them change at idle right?
Laloosh is offline
 Old 05-15-2008, 02:52 PM   #5
ALL PG And NO B.S.
TRU-BOOST's Avatar
Activity Longevity
0/20 20/20
Today Posts
0/7 ssssss754
nope not at idle. your map sensor will see the same voltage at idle no matter what you do to the clamp. if you have had the car clamped at a certain voltage for a while your LTFT will be set, and you STFT should stay near zero at all times. if you go ang change your clamp voltage higher or lower it will right away throw your STFT out of whack under heavy throttle boost situations.
 Old 05-15-2008, 02:58 PM   #6
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
just ripped it in 1st gear 3 times, hit 14 psi in my parkin glot, DH read at least 14.5 and my fuel trims are still the same
Laloosh is offline
 Old 05-15-2008, 03:16 PM   #7
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
Ok I set my map clamp to read 14.95psi, went to rip it up in 3rd and under WOT my STFT were at 50.0....lol wtf My LTFT at idle is 11ish wot its 14. I dont recal what it was at wot before i made the change.
Laloosh is offline
 Old 05-15-2008, 06:14 PM   #8
ALL PG And NO B.S.
TRU-BOOST's Avatar
Activity Longevity
0/20 20/20
Today Posts
0/7 ssssss754
50 holy shit !! mine are usually in the 20's when i get cut.
 Old 05-15-2008, 06:29 PM   #9
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
my a/f ratio didnt change one bit though....
Laloosh is offline
 Old 05-16-2008, 05:23 AM   #10
More air More fuel
94jedi's Avatar
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss2190
so you don't have a CDFP upgrade?
94jedi is offline
 Old 05-16-2008, 08:39 AM   #11
cld12pk2go's Avatar
Posts: 845   (View Stats)
Activity Longevity
9/20 20/20
Today Posts
7/7 ssssss845
If I am understanding this correctly, you are not seeing a change in AFR b/c the ECU is adjusting the STFT and LTFT to account for what it is seeing on the WBO2, when its table lookup values does not give it the proper AFR due to incorrect MAP sensor info.
This means that the MAP sensor value matters, but the ECU is smart enough to adjust to save your butt in this case. However, this would seem a far from ideal method of robust operation.
cld12pk2go is online now
 Old 05-16-2008, 09:10 AM   #12
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
ive been runnin the map clamped to even a lower psi for MONTHS and my car doenst knock, doesnt sutter, runs like good.
I still say the map has zero effect on a/f ratios.
Laloosh is offline
 Old 05-16-2008, 10:30 AM   #13
cld12pk2go's Avatar
Activity Longevity
9/20 20/20
Today Posts
7/7 ssssss845
If you are stating that the end result AFR is the same, then I agree. But the car is having to adjust due to the MAP clamp so that the AFR wasn't what the ECU would have been expecting unclamped.
The time you have run it this way does not change this. If it works for you, then great. Just understand that the ECU is compensating, which means that the MAP does matter (just not enough to be outside of the ECU's ability to compensate in your case).
 Old 05-16-2008, 11:12 AM   #14
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
i agree hence i dont think its a big deal at all. It doesnt change the overall a/f ratio so i don't see the big deal with it.
Laloosh is offline
 Old 05-22-2008, 08:50 PM   #15
Hater!
ptperformance's Avatar
ptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the worldptperformance is the leader of the world
Groaned at 74 Times in 46 Posts
Activity Longevity
6/20 20/20
Today Posts
0/7 sssss4046
What clamp do you have?
See guys this PCM may be smarter then we think. I use to see this all the time with the SRT4N and the Caliber is really smart. The PCM will spike the MAP sensor, only for a milisecond but it will spike it to see what gets sent back on the other side. Why? To check wire integrity and for aftermarket devices. I have seen this on both the Caliber and the SRT4N, I have yet to check it on the MS3.
If you have a generic clamp (cheap version with 2 resistors and a pot box) that unit will have little to no effect on over all performance (fuel trims and such) but if you have a good one (dig to annalog converter) then the PCM doesn't see anything and adjusts accordingly when it spikes the sensor. Every sensor gets spiked on a car to check time over the wire, this gives the PCM the health of the vehicles electrical system and makes for adjustments when needed.
I hope this all makes sence and my little plug.... I have map clamps in stock now.
To make a purchase please go to
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Shop hours are 9am to 7pm Monday-Saturday
Shop number 253-277-3843, Shop cell 253-653-3843
href="showthread.php?p=553626#post553626" rel="nofollow">
Hahahaha...not that this post will stay up because I am sure John will delete it. But the reason people aren't trying these is because they can't stand you. They think your a gimick man who can't make parts worth a damn. Thats why someone else got on this and they are waiting for him. I happen to think you finally made a part that works. 1 out 55 is a pretty decent ratio I guess. These seals actually seem to be working on Tims car and I created the tune to be pretty aggressive (as much as tuning on the street can do). Its just too bad they come from a company who is viewed as a joke on most platforms.
ptperformance is offline
 Old 05-22-2008, 08:52 PM   #16
Hater!
Activity Longevity
6/20 20/20
Today Posts
0/7 sssss4046
This I agree with, no effects in AFR's can be monitored with the MAP clamp on the MS3. I do feel that there are some gains to be had (proper weather) if you set it accrodingly to the boost that the car is running or less then its running. I have felt gains by messing with the MAP clamp on my car and I will be dynoing here very soon to get the results of what a clamp set at 0 vs 14 psi does.
 Old 05-22-2008, 08:58 PM   #17
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
im running a popular srt4 map clamp...somethign dasmopar
Laloosh is offline
ptperformance (05-22-2008)
 Old 05-22-2008, 09:03 PM   #18
Hater!
Activity Longevity
6/20 20/20
Today Posts
0/7 sssss4046
Thats the 2 resistor and pot box. That is the one the PCM can see when it spikes the wire. Not sure if the PCM will adjust for it but we proved it on the SRT4, the PCM didn't like the resistance on the map sence wire.
 Old 05-22-2008, 09:07 PM   #19
Laloosh's Avatar
Groans: 57
Activity Longevity
0/20 20/20
Today Posts
0/7 sssss5099
I havnt had a problem since i installed it
Laloosh is offline
 Old 05-23-2008, 10:11 AM   #20
ALL PG And NO B.S.
TRU-BOOST's Avatar
Activity Longevity
0/20 20/20
Today Posts
0/7 ssssss754
i have a $17 ebay special, also no problems.
laloosh... you wont see a change in your AFR, thats what the fule trims do.
like i said if i let my ecu see more boost my fuel trims get closer to 0. if i turn the clamp down to say 10 psi my STFT will show like a 10% ajdustment rate under boost, and over time my LTFT will go up about 10% higher than it was. the ecu getsa used to seeing that same boost pressure all the time. thats why the LTFT ends up being off. you are clamped at 10psi but running 20psi. the ecu only sees 10 but has to add a shit ton more fule than it would for 10psi, jow it tells you your fuel trims are 10-15-50% off ! if you let it see more of the boost that is actually there is is going to naturally add more fule too. but it never actualy adds more then it did before. it adds the same amount but lowers the fuel trims.
 Old 05-20-2010, 09:52 AM   #21
teamxtaci's Avatar
Posts: 179   (View Stats)
teamxtaci is a name known to allteamxtaci is a name known to allteamxtaci is a name known to allteamxtaci is a name known to allteamxtaci is a name known to allteamxtaci is a name known to all
Activity Longevity
8/20 5/20
Today Posts
2/7 ssssss179
Crap, going back to stock for sure after this read! Gunna just keep a catback on for looks and sound but get my intake back to where it should have stayed...damned Corksport and their lies about OEM longevity and ECU not changing with their SRI...only have 3,500 miles on car since SRI from CS installed....out of 4,600+.....think I am still safe if I go back to stock now?!
teamxtaci is offline
Thread Tools
Marketing 101: Make stuff up, make it visible - BMW's subtle 1-Series shilling Haltech Automotive News 0 04-13-2008 07:51 AM
Webroot Parental Controls Free AR Upgraders, $15AR Others, Free Shipping at Buy.com Haltech Hot Deals Section 0 04-12-2008 02:24 PM
Alfa may buy closed factory from Big 3 for U.S. production Haltech Automotive News 0 03-31-2008 01:10 PM
Expiring Creative HN-700 Closed-Back Circumaural Headphones w/ Active Noise Reduction $24.99AR Haltech Hot Deals Section 0 03-31-2008 12:00 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.1
Advertisement System V2.6 By   Branden
©Copyright 2008 ; 2010 Cymru Internet Services LLC
Page generated in 0.60189 seconds with 71 queries
