![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #481 | ![]() |
![]() ![]() Join Date: Oct 2008 Location: Alberta
Rep Power: 415 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 746
Groans: 188
Groaned at 51 Times in 30 Posts
| Not Ranked : 0 score Parker - PLC, DIRECT ACTING PRESSURE RELIEF VALVES The PLC series auxiliary valves are direct acting, factory-set pressure relief valves of the cartridge type that can be supplied with or without a threaded plug. They can also be supplied with housings to facilitate in-line installation. PLC valves are intended primarily to act as combined pressure-relief and anticavitation valves - otherwise known as port relief valves - in the service ports of our directional valves. However, they can also be used to advantage in other situations where pressure relief valves in this size range are required. Features * Small dimensions - easy to install * Single unit - facilitates installation * Very tight - no unnecessary leakage losses * Small pressure change between different flows * Low hysteresis - good precision in pressure maintenance * Fast acting - reacts quickly to pressure surges * Setting locked by welding - prevents undesirable changing of pressure setting
__________________ My mission is to go fast. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | ||||||||
| The Following User Says Thank You to phantom3 For This Useful Post: | SilverDemon (01-06-2010) |
![]() | | #482 | ![]() |
![]() Join Date: May 2008
Rep Power: 1976 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,026
Groans: 60
Groaned at 17 Times in 17 Posts
One thing to keep in mind while valve huntin, is that the valve must be gasoline tolerant. Also, some manufacturers cringe when you mention gasoline or automotive, mainly for liability reasons.
__________________ Highest hp stock block ms6 449awhp 527awtq WCF To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. gt3071, SB + flash combo, self tuned and more on the way... | ||||||||
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (01-06-2010) |
![]() | | #483 | ![]() |
![]() ![]() Join Date: Jul 2009
Rep Power: 410 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 754
__________________ I am my own After Market Company. | |||||||||
![]() | | #484 | ![]() |
Groans: 188
The guy at Parker said they have an adapter for it and it will thread right into the old spot. He's gonna look for it while I'm on holidays.
| The Following 3 Users Say Thank You to phantom3 For This Useful Post: |
![]() | | #485 | ![]() |
Cool!!! Thanks for taking the time to look around.
![]() | | #486 | ![]() |
![]() Join Date: Apr 2008 Location: Atlanta, GA
Rep Power: 88 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 125
I don't know how hard it would be but would converting the fuel system to a return style setup eliminate this relief valve? Once the valve is gone then some tuning would be needed to tell the ECU to stop looking for it. Nevertheless this is really interesting to follow and I hope you guys get this figured out.
![]() | | #487 | ![]() |
Groans: 188
EDIT: I think you would still need a relief valve to relieve the pressure in the rail.
__________________ My mission is to go fast. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM Last edited by phantom3; 01-07-2010 at 07:28 AM. | |||||||||
![]() | | #488 | ![]() |
| Not Ranked : 0 score | ||||||||
![]() | | #489 | ![]() |
Groans: 188
*edit: sorry I got valves mixed up.
__________________ My mission is to go fast. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Currently Designing: The golden girdle of the gods The CF "fuck your face" IM | |||||||||
| The Following User Says Thank You to phantom3 For This Useful Post: | djuosnteisn (01-07-2010) |
![]() | | #490 | ![]() |
Groans: 60
Phantom nailed it. Even on my pre-ckt logs i've seen 2100psi during throttle lifts. And 25psi is fucking nuts.
![]() | | #491 | ![]() |
Groans: 188
| Not Ranked : 0 score ![]() CUZ KNOWLEDGE IS POWER!
![]() | | #492 | ![]() |
| i haz grape drank ![]() Join Date: Mar 2008 Location: Buena Park, OC, CA
Rep Power: 497 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
soooo wait for you, or get a ptp relief valve...
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 2007 w/ Cheez Wheels - MSR 045 18x8 +35 | ||||||||
![]() | | #493 | ![]() |
| Approved MSF Vendor Join Date: May 2008 Location: Beltsville, Maryland
Rep Power: 1024 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 157
Groaned at 28 Times in 19 Posts
Not sure what you guys need this for? We aren't modifying the relief pressure at all.
![]() | | #494 | ![]() |
Groans: 60
Yup, that's what sean told me. Great news IMO!
![]() | | #495 | ![]() |
![]() Join Date: Jan 2009 Location: Columbus Ohio
Rep Power: 369 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 353
Groaned at 19 Times in 15 Posts
so, is the speed6 different? or does the relief valve just not come into play?? just how far can the stanback scale the fps vs. dj's ckt?
__________________ 08 CB MS3 Sport CPE Nano HKS BOV CPE TBE Cobb Inlet CPE Full Control & Fuel Cut Flashes CPE SB I am looking for used FMIC Piping & CPE CDFP - PM me if you haz..... | ||||||||
![]() | | #496 | ![]() |
DJ's circuit doesnt do what our setup does. It is compeletely differrent. I wish it was that easy but the standback doesn't just scale FP as straight forward as you'd expect. We do a lot of other things behind the scenes as we play with pressure. Simply playin with the pressure with the circuit wont do whats required to make certain things happen.
![]() | | #497 | ![]() |
![]() ![]() Join Date: Aug 2008 Location: NoVA
Rep Power: 29 ![]() ![]() ![]() ![]() ![]() Thanks: 18
Groaned at 19 Times in 3 Posts
It was my understanding that there are several variables to our fueling system. 1. Fuel Pressure 2. Injector Pulse Width 3. Injector Spray Pattern - My understanding, which I am not sure of, is that our fuel injectors are capable of not only controlling length of fueling, but also spray pattern for optimal combustion | ||||||||
![]() | | #498 | ![]() |
![]() ![]() Join Date: Nov 2009
Rep Power: 146 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 120
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Kriebs Speed and Power Development. AIM: KriebsSPD | |||||||||
![]() | | #499 | ![]() |
I wanted to let you guys know that I have not forgot about the pressure relief valve....I talked to the vendor today to get an estimation of delivery for the first set up, he said he was going to contact them and me know. He said in the past that it takes about 2 weeks to get a custom RV from them. It is now been a week.....More to come!!
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | djuosnteisn (01-13-2010), kgb (01-13-2010) |
![]() | | #500 | ![]() |
Groans: 60
Cool. PTP has begun selling their valves. I'm curious how that all pans out, but it's still a real good idea to keep on your guys. Thanks again man!
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (01-13-2010) |
![]() | | #501 | ![]() |
I would like to see a pic of the ptp RV........There was only one company (that I could find) that would completely custom make a valve for our application......
![]() | | #502 | ![]() |
![]() ![]() Join Date: Apr 2009 Location: Ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,389
Groans: 388
Groaned at 277 Times in 140 Posts
but tell him ty anyways =)
__________________ Originally Posted by BrianGT3076 Took a famous quote and edited it a little Phillyb is a dick! A reckless, arrogant, stupid dick. And MSF.org people are pussies. And Lenny is an asshole. Phillyb don't like dicks, because phillyb get fucked by dicks. But Phillyb also fucks assholes: assholes that just want to shit on everything. phillyb may think he can deal with assholes his way. But the only thing that can fuck phillyb's asshole is a dick, with some balls. The problem with phillyb is: he fucks with you too much or fucks with you when it isn't appropriate - and it takes speedsixxx to show him that. But sometimes, phillyb can be so full of shit that he becomes an asshole himself... because phillyb is an inch and half away from his ass hole. I don't know much about this crazy, crazy world, but I do know this: If you don't fuck this asshole phillyb, we're all going to have to deal with this assholes Shit! | |||||||||
![]() | | #503 | ![]() |
| Not Ranked : 0 score yeah because competition DECREASES productivity - RIGHT? Are you kiddin me - ZZP is nasty - take a stole thru their website and look at their accomplishments on the lnf & lsj platforms - not to mention do a little comparing to their staged kits compared to GM's for the lsj It would be sweet to get those guys working on MS3s and give CPE a run for their money...
| The Following 3 Users Say Thank You to cpolly69 For This Useful Post: |
![]() | | #504 | ![]() |
Groans: 388
and pleaseeee can we stop all this MS3 shit and just say MZR or "speeds" not everyone has a speed 3. I hope they take on the 3's and 6's and we have more then a few good companies makin hard parts and tuning solutuons for us. =) love u my gizzard polly C wallE a lizards in tha wizards gizzards and blizzards!
![]() | | #505 | ![]() |
Well, for what it's worth......Here is the pressure relief valve and block. I know the block is huge compared to the factory valve, but I bought the block so I could get the measurements to make one to fit my application.
| The Following 6 Users Say Thank You to SilverDemon For This Useful Post: | cld12pk2go (01-22-2010), djuosnteisn (01-22-2010), evidence (01-22-2010), Realgib3 (01-23-2010), SpeedSixxx (01-22-2010), superskaterxes (02-16-2010) |
![]() | | #506 | ![]() |
Groans: 60
Can't wait to see what you come up with!
| The Following 3 Users Say Thank You to djuosnteisn For This Useful Post: |
![]() | | #507 | ![]() |
![]() Join Date: Mar 2008 Location: Columbus, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 160
__________________ 08 MS3: CP-E CAI, PG Turbo Inlet, PG FMIC piping with CXRacing I0035 core, PG v1 manifold, CP-E catted DP, Alkycontrol Meth injection, Cobb AP (ATR= WIN), KMD v2, and SU MM. (297.3WHP/366.9WTQ) | |||||||||
| The Following User Says Thank You to cld12pk2go For This Useful Post: | SilverDemon (01-22-2010) |
![]() | | #508 | ![]() |
Not a problem man!! I have the weekend off, and hopefully I will get the intake mani off so I can find out what type of adjustments I will need to make to the new valve block.
| The Following User Says Thank You to SilverDemon For This Useful Post: | Realgib3 (01-23-2010) |
![]() | | #509 | ![]() |
Groans: 60
It's gonna be a tight fit with the fuel hardline wrapped around the valve, but i have no doubt in my mind you'll come up with something awesome!
| The Following User Says Thank You to djuosnteisn For This Useful Post: | SilverDemon (01-22-2010) |
![]() | | #510 | ![]() |
Yeah, I figured it would be a bitch, and I hope it will be as easy as just milling off some of the extra material on the block. But, as everyone knows that working on this car is not easy!!
| The Following 2 Users Say Thank You to SilverDemon For This Useful Post: | djuosnteisn (01-23-2010), Realgib3 (01-23-2010) |
![]() | | #511 | ![]() |
ok so what are we doing with this, will this have any bearing on scaling down the load plateau with the AP?
![]() | | #512 | ![]() |
Groans: 60
I'm glad you asked: ![]() Fits inside this box: http://www.hammondmfg.com/pdf/1593S.pdf The battery slider door will be used to access the buttons and leds for programming the unit. And all wires will go in and out the opposite side. I still haven't found oem connectors, but i haven't really tried. I'm sure it'll be easy to find something that will work without too much cutting and stripping wires. I know i dropped the ball for a while. Life has a tendency to catch up with me sometimes. But i'm 99% sure i'm done with the design (not really complicated at all), so i think i'll order some boards today or tomorrow. And then i can whip out some simple firmware and hopefully beta test on my own car at some point. I'll build up 5 at first i guess. We'll see how much they end up costing. Sorry for the lack of updates guys!
| The Following 6 Users Say Thank You to djuosnteisn For This Useful Post: | bmorrisj (02-16-2010), opt_ms3 (02-19-2010), SilverDemon (02-16-2010), SpeedSixxx (02-16-2010), spnkr21 (02-16-2010), superskaterxes (02-16-2010) |
![]() | | #513 | ![]() |
![]() Join Date: Jan 2009 Location: ME
Rep Power: 341 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 185
Groans: 29
Holy shit that's awesome.
| The Following User Says Thank You to spnkr21 For This Useful Post: | SpeedSixxx (02-16-2010) |
![]() | | #514 | ![]() |
Groans: 60
Ordered 2 boards today, just to proof it all out and make sure it works like expected. If it does i'll order quite a few more. We'll cross that bridge when it comes. I ordered through BATCHPCB, for any of you who want cheap pcb boards. They take a lil longer to get (2-3wks typical), but are amazingly cheap. I think they wait til they get enough boards from a bunch of different people and then submit all at once to keep the price low (they have an arrangement with some chinese board house, works for me). Can't argue with $2.50 / sq inch. Once they come in i'll whip up some simple firmware and test it out on the bench. And i'll probably look into a way to hook up to the oem connectors without cutting splicing.
| The Following User Says Thank You to djuosnteisn For This Useful Post: | Realgib3 (02-19-2010) |
![]() | | #515 | ![]() |
Rep Power: 294 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 495
Groaned at 8 Times in 4 Posts
no cutting = I can test tooooo!!!
![]() | | #516 | ![]() |
![]() Join Date: Jul 2009 Location: Boston, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 348
Holy McGuyver on Crystal Meth!! Brilliant work DJ!! ...too bad I was lost in the OP! lol I'm hoping this only necessary for people with larger injectors to communicate fueling properly with the ECU, and not for noobs like myself who just need an upgraded HPFP?! From what I read in ATR the hpfp will affect my FT's, and I thought a simple MAF recal would address that np. Is this just for larger injectors, or am I missing out on something here? Man, you're a lot smarter than you look! haha j/k
__________________ 2006 Mazdaspeed6 GT ---------------------------------------------------------------------- Cobb AP ~Stage 2+, Cobb SF, Cobb TIP, CPE FMIC, CPE Rear Diff Mount, DashHawk, Denzo ITV-22s, 3" GHL CBE +Res, Hitachi HPFP, HKS SSQV BOV, Perrin Pro EBCS, Redline Fluids, Speedy Lite Fin Wheels, SPC BJs, SU MM, 3" SU TP, TWM Stage 2 STS +Bushings, Apexi TT, Badgeless Grill, & 35% tint. Super Nintendo, Sega Genesis, When I was dead broke, man I couldn't picture this... 50 inch screen, money green leather sofa, Got two rides, a limousine with a chauffeur. Phone bill about two G's flat, No need to worry, Dougefresh handles that… To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #517 | ![]() |
no such thing as larger injectors
| The Following User Says Thank You to bmorrisj For This Useful Post: | djuosnteisn (04-06-2010) |
![]() | | #518 | ![]() |
![]() Join Date: Mar 2008 Location: NC
Rep Power: 823 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 525
__________________ My car has issues.... | ||||||||
| The Following 2 Users Say Thank You to SSinstaller For This Useful Post: | djuosnteisn (04-06-2010), SpeedSixxx (04-07-2010) |
![]() | | #519 | ![]() |
Groans: 60
Only one such thing as bigger injectors, and SS has em.. For the rest of us... no such thing... Doug, the advantages are there for stock injectors as well. What this thread basically showed was that the stock injectors would actually flow more fuel with increased rail pressure. To some extent, it shows that fueling isn't quite yet an issue, but as we all know, we are getting fairly close. Many of us agree that the earlier you can get the fuel into the cylinder, the more time it will have to mix with the air and become homogeneous and provide a much better burn. It hasn't been quantified yet, power wise, but at least the fueling benefits have been shown.
| The Following 2 Users Say Thank You to djuosnteisn For This Useful Post: | dougefresh_ (04-07-2010), SpeedSixxx (04-07-2010) |
![]() | | #520 | ![]() |
Groans: 388
| Not Ranked : 0 score may I ask why whoosh or whoever else wont take on the task of doing the injector porting for others.???
| Thread Tools | |
| 2010 Mazdaspeed 3 Weight on Scale - Input | cheez | 2010 MS3 - Engine, Transmission & Driveline | 46 | 12-09-2009 06:19 PM |
| GM Keeps Opel for Scale and Innovation: Analysis | Haltech | Automotive News | 0 | 11-04-2009 12:00 PM |
| P0107 - Barometric pressure sensor low input | vbt101 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 09-14-2009 12:31 PM |
| Spec out your own Maserati - in 1/43 scale | Haltech | Automotive News | 0 | 06-19-2009 04:00 PM |
| Ford sees no large-scale aid for Visteon | Haltech | Automotive News | 0 | 01-29-2009 12:30 PM |
