 Old 01-05-2019, 11:35 AM   #1
Russell141's Avatar
Posts: 4   (View Stats)
Russell141 is an unknown quantity at this point
Default HPFP Data Logs
Right now in my 2013 Mazdaspeed 3, I'm running a Corksport induction system (same MAF size as stock) and a cobb stage 1+ tune. I wanted to check my HPFP's psi through peak boost, and I read on cobbs webpage to do a 2k-6k rpm WOT 3rd gear pull. I did multiple logs and my psi stayed above 1600. I recently logged a WOT 2k-6k rpm 2nd gear pull and saw my fuel pressure dropped to 1450 psi (I then went back and did a 3rd gear log and everything seemed peachy). Should this 2nd gear pull be a cause for concern or is it normal because it's a lower gear?
3rd Gear WOT
3rd Gear WOT.xlsx
2nd GeaR WOT
2nd Gear WOT.csv
Russell141 is offline   Reply With Quote
 Old 01-05-2019, 05:54 PM   #2
Fstrnyou's Avatar
Posts: 2,377   (View Stats)
I've read a lot of threads that Gen2's can't do ANY mods or tune without upgrading the HPFP first.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-05-2019, 05:57 PM   #3
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
That's not entirely true. I'm sure there are many that have done atleast an intake without issues. Gen 2s are just much less friendly than the gen 1.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
First data logs and VD CrawlingMS3 2010 MS3 - ECU Computer Tuning 13 04-04-2013 06:10 AM
Help with data logs XerocX MazdaSpeed 3/6 - ECU Computer Tuning 15 06-13-2012 01:19 AM
New Data Logs neofandango 2010 MS3 - ECU Computer Tuning 2 11-23-2011 04:38 PM
WTF IS UP WITH MY DATA LOGS Fatguy729 MazdaSpeed 3/6 - ECU Computer Tuning 14 05-27-2011 02:46 PM
Page generated in 0.29859 seconds with 23 queries
