![]() | | | LinkBack | Thread Tools | Display Modes | ![]() |
![]() | | #1 | ![]() |
![]() ![]() Join Date: Dec 2009 Location: Denver, CO
Rep Power: 726 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,137
| Not Ranked : 0 score
Well I got my EBS from the group buy today and got it installed. I wasn't really sure how the 3 port vs 2 port installation differed, so I followed the direction in the GB thread. Install was ok, was kind of a pain in the ass to get to the nipple on the turbo, but once I got that it was smooth sailing. First impressions ![]() I realize that everyone is saying that a tune is required, I really do understand that. But in my logical thinking before hand, I was only spiking at 14 and dropping down to 11ish. So with this being the 35% more efficient, I was expecting 35% more boost (hence the tune so you don't overboost). Anyways, I'm now spiking at 16psi and it drops down to 14 and holds till about 6k rpm's where it drops off down to 12, sometimes 11! My math kicks ass!!! Spool appears to happen faster (like they said it would) and overall the car pulls harder (obviously...more boost). I'm happy I got in on the GB on this and have it installed now! I hope everyone else's experience will be as good as mine, cause the GB was pretty damn organized and went as smooth as possible. THANKS Grimmspeed and RallySportDirect!!! pics in the GB thread...didn't take any install ones (sorry guys) did it in the parking garage at my apartments with a tiny ass flashlight and only had my iPhone. I would like to point out that based on the install instructions, I do believe I have this hooked up the 3 port way, in case that wasn't clear.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
| The Following 6 Users Say Thank You to tbot For This Useful Post: | -cj- (03-12-2010), Blackspeed (03-11-2010), Fobio (03-11-2010), madvillain (03-15-2010), MPSdriver (03-11-2010), RallySportDirect (03-11-2010) |
| This Space For Rent ![]() Join Date: Jun 2009 Location: Lost Angels, Cali
Rep Power: 1236 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,826
Groans: 66
Groaned at 250 Times in 227 Posts
__________________ Cobb SRI : Cobb TIP : Cobb Shifter Weight : Cobb STS : Cobb DP : Cobb F&R Sway Bars : Cobb AP : AWR F&R Endlinks : SU Shifter Bushings : SU Rear Motor Mount : SU Side Motor Mounts : SU Blackout Emblems : Spin On Oil Filter : O.Z. Racing Ultraleggera Rims : Muteki Lug Nuts : Synchronic BOV : Valentine 1 : CP-E Towplate : Denso ITV-22 : Powerslot F&R Slotted Rotors : Hawk HPS F&R Pads : Goodridge SS Brake Lines : JDM Coin Holder : E4P Heavyweight Shift Knob : Clear Side & Rear Reflectors : Nextmod CF Rear Spoiler Lip : PTP CDFP : AEM UEGO WBO2 & Boost Gauges : Mearcat Double Gauge Pod : Saikou Michi Stage 2 DC3 OCCs : Custom 3" Magnaflow CBE : PG FMIC : PTP Kicker Mount : HID Fogs : Mazdaspeed Coilovers & Camber Links : Devil's Own Meth Injection : ACT Clutch & Lightened Flywheel : HKS Twin Power : Redline Hood Struts : PG v3 Exhaust Manifold : GTSpec Everything To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Saved by Nator! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | |||||||||
| The Following User Says Thank You to hnda etr For This Useful Post: | tbot (03-11-2010) |
So after driving to work today (30 minutes of highway, good time to open it up in higher gears) I noticed a couple of things. I'm still spiking at 16 psi (saw 17 ONCE, but that was it) but its now settling lower. The entire trip I was holding at 13.6-13.8 and dropping down to 11ish after 5600 rpms and at redline I hit 9 (fuckin gay...whatever). So I don't know if this is the ECU learning that this solenoid is more efficient and therefore compensating for it or what. Just wanted to throw that out there too for you guys who are going to be tuning for it. I'll post back in a couple days and see if anything else has changed, but I've put about 50-60 miles on it so far only.
![]() | | #4 | ![]() |
![]() ![]() Join Date: Jun 2008
Rep Power: 1552 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
You don't understand the principles of boost control. The "efficient" solenoid bit is just BS to sell a product. The stock solenoid reacts just fine. There is no need to replace it unless it is broken or it can't flow the required amount of air out to keep the desired pressure on the wastegate. This is not the case. The boost change you are seeing has nothing to do with efficiency, it is just that you installed a different actuator than what the system is calibrated for with different response time and flow characteristics. Not better, just DIFFERENT. You have to understand that a solenoid is simply an electronic device that allows you to divert pressure. The control logic and parameters are what define how the solenoid controls the boost. I am sorry to be so harsh, but unfortunately there is no reason to upgrade the solenoid. If you want more boost, simply calibrate the ECU or just run a different boost control method (electronic or manual stand alone controller). | ||||||||
| The Following 6 Users Say Thank You to Lex For This Useful Post: | builthatch (03-11-2010), cld12pk2go (03-27-2010), Fagwagon (03-11-2010), FORZDA 1 (03-15-2010), FreeFlyFreak (03-14-2010), opt_ms3 (03-14-2010) |
![]() | | #5 | ![]() |
Fair enough...
![]() | | #6 | ![]() |
![]() ![]() Join Date: Jun 2008 Location: misery
Rep Power: 3762 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,439
Groans: 1,421
Groaned at 660 Times in 488 Posts
this might sound retarded, but so does everything i say. have you entertained the idea of some sort of leak?
__________________ oem part numbers - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. donations to the site - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. creating an avatar - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. do you own a miata? post in the miata section - To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
| The Following User Says Thank You to phillyREPOphail For This Useful Post: | RayRayBauder (03-18-2010) |
![]() | | #7 | ![]() |
I have...even to the point I was posting up dashhawk logs and asking input from everyone else, they all said it was normal (granted I still think its bullshit my car is holding at 13-14 when the factory says its 15.5)
![]() | | #8 | ![]() |
| KR....i haz it ![]() Join Date: Apr 2009 Location: Estero, FL
Rep Power: 867 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 918
Groans: 123
Groaned at 48 Times in 33 Posts
what are your mods?
__________________ Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts | CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | HDR Solid Shifter Bushings | PTP cdfp To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
![]() | | #9 | ![]() |
CP-e CAI, PG turbo inlet, ETS 3.5" tmic, SU race pipe, SU RMM, TT FMM, AWR Tranny mount, TWM stage 2 sts w/ bushings, elite engineering OCC, Labonte stage2 water/meth injection, Synapse BPV, Grimmspeed EBS
![]() | | #10 | ![]() |
Groans: 123
wow......and you were only spiking to 14psi? I was spiking to 20 settling at 17 and then drop after 5500rpm. theres a gremlin in your engine bay.
![]() | | #11 | ![]() |
Well now i'm spiking to 16, and once I saw 17. But before...yeah. I've checked everything out, nothing's loose, no holes...I really have no idea, and thats why I posted up those logs earlier (different thread) and everyone said it was normal boost levels, so I gave up trying to find out why after that.
![]() | | #12 | ![]() |
![]() ![]() Join Date: Dec 2009 Location: Fontucky, California
Rep Power: 495 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,050
Groans: 1,354
Groaned at 587 Times in 384 Posts
| Not Ranked : 0 score But you have the Cobb AP, that accounts for a lot dude. I've spiked to 20 psi and hold 15, then drops to 14 nearing redline. Us with no tunes have the worst boost control.
![]() | | #13 | ![]() |
Groans: 123
| Not Ranked : 0 score that was actually before the ap
![]() | | #14 | ![]() |
![]() Join Date: May 2009 Location: Warminster, PA
Rep Power: 153 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 465
How is yours setup? I just tried the 2port with the tip-1 and w/g-2 and im overboosting like a mutha.
__________________ A Kabar is just a paper weight until it's in the hand of a Marine. If a Marine can't fight it, f@#k it, or eat it, he's going to destroy it and burn it to the ground. COBB SRI | COBB TURBO INLET | TURBOSMART BPV | APEXI TT | SAIKOU MICHI STAGE II OCC | DENSO ITV22 PLUGS | MSD DASHHAWK | SU SHIFTER BUSHINGS | JBARONE SSP | SPEEDLINE HEATED CONVEX MIRRORS | CLEAR SIDEMARKERS | 5000K 35W D2S BULBS | 3000K 35W HID FOG LIGHTS | 6000K REVERSE LIGHT HID KIT | RALLY ARMOR URETHANE MUD FLAPS | PROGRESS TECHNOLOGY RSB | TRZ RMM | GRIMMSPEED EBCS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
![]() | | #15 | ![]() |
I did 3 port. I followed the instructions from Grimmspeed to a T. I am boosting more and spiking higher, but nowhere near 24psi ha. Sent from my iPhone using Tapatalk
![]() | | #16 | ![]() |
i thought 3 port is for if you have tuning capabilities?
![]() | | #17 | ![]() |
It is, but I was already not even getting close to even what stock boost should be at, so I figured with the 35% difference, I would be closer to stock boost levels but still under. I think if you're at stock boost levels, then you would have an issue because there would be an even higher overboosting effect.
![]() | | #18 | ![]() |
![]() ![]() Join Date: Nov 2008 Location: MILTON FL
Rep Power: 208 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
Groaned at 29 Times in 19 Posts
i remember back in november when i bought this and said i was over boosting and people told me i was full of shit and needed to tune with it(i was tuning with it). i would over boost more than 30 psi sometimes. so i just diconected it and have been running ewg psi since then. im my opinion waste of money till some one finds out how to use it right. FML i didnt even get a ms3 mount i had to get the subi mount back then.........
__________________ 2008.5 Mazdaspeed 3 Built Engine- CP Pistons 9.5:1/Pauter Rods -- Holset Big Turbo-- DNP Manifold w/ewg -- Tial 44mm EWG -- GrimmSpeed EBCS CP-E Catback Exhaust -- Custon Downpipe-- CUSTOM 3.25 MAF-- CP-E 4 inch Turbo Inlet CP-E STANDBACK w/ FLASHES-- COBB FMIC Fuel Pump Internals -- Devils Own Meth Kit -- Spin-on Oil Filter -- 1 Step Colder Plugs -- TWM Short Shift Custom Center Gauge Pod -- Custom 1 Of A Kind MS3 Gauges -- Halo Lights -- Front Lip -- Emblem Less Grill -- Black Stock Rims FASTEST MAZDASPEED IN MY DRIVEWAY!!!!!! | |||||||||
![]() | | #19 | ![]() |
| Approved Zoom Zoom Boomer ![]() Join Date: May 2009
Rep Power: 228 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 501
seriously, you need to go back to stock boost control, and figure out your problem before you start fooling around with adding a mod. You are just asking for trouble if you leave the 3 port ebc installed with no tuning.
__________________ Mazdaspeed3 {Blowed Up 7/17/09} Mods: MS-CAI2, Cobb DP, Cobb CBE, Tip, Turbosmart BPV, CPE HPFP, CPE RMM, PTP Kicker Mount, Cobb AP or Hypertech - testing now | ||||||||
![]() | | #20 | ![]() |
Not to sound like an ass or anything, but what "trouble" would there be? And what "problem" did I have before? I've never been close to 15psi since day one (ok I didn't check day one, but a week or so after I bought it). And even on here everyone said that my boost looked normal. I don't see how there would be an issue? The only other "strange" thing I've noticed is that the Abs Load according to the dashhawk only gets to about 160% where as everyone else is saying theirs is 180-200. Either way, I don't see any issues right now, I'm not even spiking as high as some people do stock. An AP is next on the purchase list, and should happen in a week or so and I'm sure that if the wg duty cycle is left untouched with a map that is say 18psi, then yes I could very seriously see an issue with that, just not when the highest PSI I've ever seen is 16 lbs and hold at 12-14 depending on the gear.
![]() | | #21 | ![]() |
Not hating just sayin, but your boost being that low is indicating some problem. Now with the 3 port EBC it's higher but this prolly should not be a big problem until you have the AP where you are gonna prolly get real bad over-boost.
![]() | | #22 | ![]() |
Ok, that's what I was thinking, but then I'd be able to tune for it with the AP, so no worries. I did notice today tho, I just started watching STFT and LTFT just for something different and noticed at idle after my 30 minute drive home my STFT was at -17!!! When I first started the car it was normal...around -3ish. LTFT never really changed, stayed at 1.6 save for WOT and both where at 0.00. So not sure about that. Sent from my iPhone using Tapatalk
![]() | | #23 | ![]() |
Groans: 123
Dont even bother looking at STFT
![]() | | #24 | ![]() |
Not to sound like a newb/idiot, but why is that? Sent from my iPhone using Tapatalk
![]() | | #25 | ![]() |
Groans: 123
stft is always swaying back and forth. Its only when there is a certain trend one way or the other that it then saves this as LTFT. So, unless your ltft is outta whack (which i see its 0) then you have nothing to worry about with stft.
| The Following User Says Thank You to Blackspeed For This Useful Post: | tbot (03-16-2010) |
![]() | | #26 | ![]() |
OK, I'll stop worrying about it. My car does run GREAT right now too just from the butt dyno. Just when something changes drastically I get kinda concerned is all. Thanks everyone!
![]() | | #27 | ![]() |
Well I got around to fixing the install. It was my error. The 3rd port MUST have a cap otherwise you will overboost. I have some logs of before and after but I cant get them to load. Do I have to save them in a special format to load on the forums?
![]() | | #28 | ![]() |
Take a picture of it and copy it into paint then save it as a jpg
![]() | | #29 | ![]() |
Here they are both were taken from a standstill. It was 60* for the stock log and 50* for the new one. Stock is on the left.
![]() | | #30 | ![]() |
![]() Join Date: Mar 2009 Location: St. Paul, MN
There is some confusion on how to install this in 2 port mode and I can see some of you have installed it in 2 port mode incorrectly (that would explain the overboosting). We have revised the install instructions to include 2 port and 3 port installation. They are available here: https://www.grimmspeed.com/install_g...MazdaSpeed.pdf For 3 port mode installation, you will need tuning. We include the connector and plug required for 3 port installation on all new kits. If you got the initial shipment, you should have recieved the plug and connector by now. Hope this clears things up! -Chad | ||||||||
![]() | | #31 | ![]() |
Groans: 66
okthxbye
![]() | | #32 | ![]() |
| Ur a Mook ![]() ![]() Join Date: Apr 2009
Rep Power: 110 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 136
I got the cap and plastic piece today, thanks GS. I dont plan on installing this until I get my BNR turbo back. And once its all setup I will definantly be having a ProTune done. Found a place close to me EFI and they have had experience w/ MS3 and the AP Not looking for Big#'s just a safe tune @ 16-18lbs, nothing crazy
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Coming Soon: TT L/A Intercooler : BNR Stage 2 Hybrid Turbo - Grimmspeed EBCS - Custom Tune : StandBack + Flashes + ProFuel Controller = WIN! | ||||||||
![]() | | #33 | ![]() |
I just got mine today thanks.
![]() | | #34 | ![]() |
| what'll be my next fail? ![]() ![]() Join Date: Aug 2009 Location: Albany, OR
Rep Power: 170 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 26
so i think a few of us were running this backwards as in inlet to 1 wg to 2 before these instructions came out. whats the ramifications of that
![]() | | #35 | ![]() |
got the cap and directions ONLY, NO CONNECTOR !!!! There was a hole in the letter so maybe it fell out. Can ya'll send me the connector so's I can get this unit workin ? Hoping to get into the 12's with this. Thanks
![]() | | #36 | ![]() |
Flyrevs, I Didnt use my connector, pm ur addy and I'll send it out asap for ya, that sucks tho u didnt get it. So far I still like mine, no issues other than the stft, but not worked about that. Sent from my iPhone using Tapatalk
![]() | | #37 | ![]() |
Groans: 66
![]() | | #38 | ![]() |
![]() ![]() Join Date: Dec 2009 Location: Chitown
Rep Power: 103 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 220
![]() | | #39 | ![]() |
Groans: 1,421
anyone running this with bt?
![]() | | #40 | ![]() |
| i burn your RICE ![]() ![]() Join Date: May 2009 Location: Fayetteville, NC
Rep Power: 332 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 296
Groaned at 30 Times in 21 Posts
![]() | Not Ranked : 0 score
me, well soon as i get my car running.
__________________ To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | ||||||||
| The Following User Says Thank You to dizzin9 For This Useful Post: | phillyREPOphail (03-19-2010) |
| Thread Tools | |
| GB: Grimmspeed Boost Solenoids Specific for the MS3 and MS6 Applications! | RallySportDirect | RallySport Direct | 195 | 04-08-2010 04:33 PM |
| Where is the Boost solenoid ??? | camdensms6 | MazdaSpeed 3/6 - Turbo Induction | 2 | 12-13-2009 08:25 AM |
| WTB: MS3 Boost Solenoid | Element | MazdaSpeed 3/6 - For Sale / Trade | 2 | 09-02-2009 07:54 AM |
| WTB: Boost Solenoid | taf0422 | MazdaSpeed 3/6 - For Sale / Trade | 1 | 04-20-2009 06:26 PM |
| MBC in-between wastegate & boost solenoid | LBV | MazdaSpeed 3/6 - Turbo Induction | 12 | 08-29-2008 10:14 AM |
