Notices
 Old 04-20-2010, 06:59 AM   #1
Swearingen's Avatar
Posts: 18   (View Stats)
Swearingen is an unknown quantity at this point
Unhappy knock retard at wot
Hello
I took the plunge and installed ap Stage 2 MSCAI 91 V1.06, mods are colder plugs, OCC, Cobb downpipe with Cat, MSCAI with air Straighteners, HKS CBE exhaust. I Ran the car with little load for a while, and then datalogged some near WOT. Attached is the data log, there is about 3.5 of knock retard. Any ideas where to fix this.
Swearingen is offline   Reply With Quote
 Old 04-20-2010, 07:07 AM   #2
Posts: 9,628   (View Stats)
You have shitty fuel in your area. Either find a different gas station or start pulling timing.
Lex is online now   Reply With Quote
Swearingen (04-20-2010)
 Old 04-20-2010, 07:39 AM   #3
KR....i haz it
Blackspeed's Avatar
Posts: 2,821   (View Stats)
Groans: 166
I had problems w/ KR no matter what gas station I tried (93). I ended up pulling timing. I would start with 1/2 deg from 5000rpm and up and see what happens.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
Originally Posted by Say Chi Sin Lo View Post
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
 Old 04-20-2010, 08:25 AM   #4
Swearingen's Avatar
yeah all i can get is 91 in canada, pulling timing in atr? i am a noob with that. Which table should i look at the knocking table i guess?
thanks
what about octane boost...any body tried that?
 Old 04-20-2010, 09:06 AM   #5
Qtip's Avatar
Posts: 410   (View Stats)
Qtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond reputeQtip has a reputation beyond repute
Isn't there a Sunoco in Canada which has 94 octane?
There are four ignition timing tables in ATR.
Qtip is offline   Reply With Quote
 Old 04-20-2010, 09:41 AM   #6
KR....i haz it
Blackspeed's Avatar
Groans: 166
I personally changed the NO knock high throttle table. Its actually still a mystery as to which tables to change as far as knock vs. no knock, but changeing no knock worked for me
 Old 04-20-2010, 01:50 PM   #7
sean80's Avatar
Posts: 38   (View Stats)
sean80 has a spectacular aura aboutsean80 has a spectacular aura about
thanks
Sunoco 94.... come on you are from the land of Suncor and shitty hockey teams that miss the playoffs! Just like me (Toronto)
I had the same problem when I first flashed my ecu. I switched from Shell 91 to Sunoco 94 and gave the ecu a few more kms to learn and now I have no WOT knock.
2007 MS3 - SU rear MM, Forge BPV, Cobb SRI, RPMC inlet pipe, CP-E catted DP, Cobb AP Stage 2 + SF 93 octane map, Denso IVT 22 spark plugs, PTP Fuel Pump.
sean80 is offline   Reply With Quote
 Old 04-20-2010, 01:55 PM   #8
Swearingen's Avatar
Sunoco is only in Ontario, Alberta seems to only have 91 as there high test. Since i just put the plugs in 300 kms ago i am going to try some race blend octane boost... found that on the cobb forums. We will see...hopefully it is just bad gas. Everything else in the log looks pretty good to me... but i do not know!
 Old 04-20-2010, 02:02 PM   #9
Andrew85's Avatar
Posts: 768   (View Stats)
Andrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the worldAndrew85 is the leader of the world
Groans: 286
Groaned at 273 Times in 222 Posts
Go to Mohawk or Husky dude... 94 octane..... Silly Flames fan :P
Andrew85 is offline   Reply With Quote
 Old 04-20-2010, 02:24 PM   #10
Ethanol blends are best against knock. Chevron although they advertise 94 octane in most cases is shitting than 91 octane in the states. Go figure. And I pay 1.32/litre (thats $5 a gallon folks) for that shit.
 Old 04-20-2010, 06:29 PM   #11
Swearingen's Avatar
thanks for the tip... wife used to work for husky lol was told it was crappy gas... but i will give that a try tomorow. Yeah a flames fan....got to hang my head in shame...we didn't even get a good draft pick. Had no idea ethanol was good against knock.
 Old 04-20-2010, 08:52 PM   #12
Andrew85's Avatar
Groans: 286
Haha, well the most knock I get now is .7 I like husky gas There's a hot chick who always rings me up, she likes my ride :P hahaha
 Old 04-21-2010, 05:27 AM   #13
Qtip's Avatar
Perfect, more reason to get the 93 octane now.
The ATR guide says that as long as your knock is below 1 at WOT then your engine is happy. But knock under 2 at WOT is okay. All taken from the ATR guide.
 Old 04-22-2010, 07:47 AM   #14
Swearingen's Avatar
just an update... thanks for all the tips...put in husky 94 no knock a little bit at 0.7 but running great...pulls like a freight train lol
 Old 04-22-2010, 08:02 AM   #15
Your LTFTs will go up a little with E10 and you will get slightly less mileage on the ethanol blend. But knock will be lower. Ethanol blends have higher octane and ethanol added to the gas is cheaper so it's a win win for Husky/Mohawk. Some car fuel lines etc don't like the ethanol however.
Swearingen (05-10-2010)
WOT Box/AP FFS and Knock Retard Lex MazdaSpeed 3 - Engine, Transmission & Driveline 23 11-10-2009 06:01 PM
knock retard yang_jackson MazdaSpeed 3 - Engine, Transmission & Driveline 26 05-13-2009 03:55 PM
Knock retard.. gone Doc MazdaSpeed 3 - Engine, Transmission & Driveline 5 11-06-2008 10:45 AM
Knock retard Lex MazdaSpeed 3/6 - ECU Computer Tuning 18 09-03-2008 07:24 PM
Knock retard!!! Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 07-12-2008 04:35 AM
Page generated in 0.36037 seconds with 26 queries
