![]() | | #1 | ![]() |
![]() Join Date: Nov 2011 Location: Bluffdale, UT
Rep Power: 22 ![]() ![]() ![]() ![]() Thanks: 6
(Thread Starter) | Not Ranked : 0 score My current mods are: Downpipe, test pipe, turbo inlet hose, cai and autotech cdfp internals. |
Rep Power: 11896 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 42,832
Groans: 235
The highest amount of retard is 1.75, and occured @ low load. This is very common, especially on the gen1 cars.
So, when I did my fine tune though, I hit a retard of 4.0, as well, when I get home from work I could post a log of that, but what is excepted for retard I know you want values below 2.0, but if they're above 2.0 aren't they bad?
![]() | | #4 | ![]() |
| Unicorn Farts ![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 1073 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,312
Groans: 96
Groaned at 35 Times in 28 Posts
Yes a log of the large knock would be good. also what are your mods?
__________________ Cobb AP - HTP 3.5" Intake -Cobb DP - Cobb CBE - Sure Track RMM - Mazdaspeed Coilovers - CorkSport Endlinks -CorkSport RSB -SPC Camber arms |
![]() | | #5 | ![]() |
I will post it when I get home, but my current mods are: catless downpipe, test pipe, cai and autotech cdfp internals
![]() | | #6 | ![]() |
Groans: 235
Thread here: KR explained
__________________ CPE ATMOSPHERE KIT / (GTX3071 w/ .82 hotside A/R) ● CPE HPFP ● CPE RMM ● CPE FMIC ● CPE TOW PLATE ● CPE TRITON CBE ● HTP 3" TIP ● HTP BATTERY RELOCATE● COBB AP ● GRIMMSPEED 3 PORT BCS ● COOLING MIST / DEVILS OWN METHANOL INJECTION ● DEFI Boost gauge ● TWM FULL REPLACMENT ● TWM M1 ABRAMS ● JBR SSP ● JBR RSB JBR TIG ● H&R COILOVERS● JUMPING JACKSON 3 BAR MAP HARNESS ● STOPTECH STAINLESS LINES ● AKEBONO EURPO 915a ● TANABE STRUT BRACE ● NEXTMOD M'z KIT CORKSPORT UNDERHOOD LED KIT ● GRAM LIGHTS 57 DR ● TOYO PROXES PLUS | |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | smoogs12 (06-14-2012) |
![]() | | #7 | ![]() |
(Thread Starter) | Not Ranked : 0 score Last edited by Anubis450; 06-14-2012 at 07:15 AM. | |
![]() | | #8 | ![]() |
Does anybody, have any idea, why its knocking at those levels, is it mechanical or just engine noise?
![]() | | #9 | ![]() |
| fastest 3-cyl MS3 ![]() Join Date: May 2009 Location: Russellville, AR
Rep Power: 557 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,537
Huge logs are huge. You need to log a WOT log in 4th. If you have access to e85, put 2 gallons of that in and then fill up with 93 octane. And use good gas. If it still knocks it's mechanical noise.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD Dizzy Tuned by Boost_creep in progress hopefully soon: GTX2867R or GTX3076R Last edited by btstarcher; 06-14-2012 at 10:33 AM. Reason: MSF Database - Automerged Doublepost |
| The Following User Says Thank You to btstarcher For This Useful Post: | smoogs12 (06-14-2012) |
![]() | | #10 | ![]() |
(Thread Starter) | Not Ranked : 0 score I'll try that thanks for the input, but if it ends up being mechanical, should I just have a look at everything and is there anything I can do to help it?(assuming nothing is wrong mechanically).
![]() | | #11 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Buena Park, OC, CA
Rep Power: 2394 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 610
Groaned at 22 Times in 20 Posts
Or your couch is fucked.
__________________ ![]() 2007 w/ Cheez // COBB AP // COBB SRI // COBB TIP // CXRacing FMIC // HKS SSQV v1 // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // BC Racing BR Coilovers // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Prosport Elec Boost Gauge // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob | |
![]() | | #12 | ![]() |
| Not Ranked : 0 score I had some knock issues while getting tuned. I put the 2 gallons e85 and still had knock. I took my TMIC off and re-tightened everything, especially the shroud. I also found that the loose end of the band clamp on my SRI was resting lightly against my HPFP, so I rotated that out of the way (it might have been tapping). Just tighten the fuck out of everything. Make sure nothing is loose. Also check your spark plugs, and make sure you're using the right plugs for your mods. Check the gap. Also, always use good fuel! Shell, Exxon, etc. None of that cheap shit.
__________________ JBR 3.5" whale penis intake, HTP polished battery tray, PnP stock intake manifold w/VCTS delete (by Kmac), Corksport TMIC, HKS BPV, SSP OCC, JBR TIG's, JBR EGR delete, Cobb AP, Kenne Bell BAS, PTP HPFP internals, Steedspeed turbo manifold, stock TBE w/gutted cats, JBR RMM, SU PMM and TMM, Koni Yellow Sport struts, Cobb RSB, Whiteline Anti Lift Kit, Posifab 10.5:1 CR 88mm sexy pistons, Molnar rods, PTP BSD Dizzy Tuned by Boost_creep in progress hopefully soon: GTX2867R or GTX3076R |
| The Following User Says Thank You to btstarcher For This Useful Post: | Boost_creep (06-14-2012) |
![]() | | #13 | ![]() |
![]() Join Date: Feb 2011 Location: Waterford,CT
Rep Power: 1189 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,974
Groans: 153
^^This post is rather confusing. If you put a couple gallon of e85 in your tank and you still knock, chances are it is something hitting against the block. If you put e85 in and your knock goes away, this means that your knock is most likely real, and you should get better gas and or run e85. Otherwise you could always pull timing or reduce boost in the areas that you are knocking. You need to take WOT logs though (3rd or 4th gear from 2500-6000rpm), because as was stated before low load knock is not something to be concerned about. WOT knock on the other hand is something to look into. | |
![]() | | #14 | ![]() |
Sorry, I should have been more clear. When I said "mechanical" I meant "mechanical noise," like a loose IC shroud, heatshield, etc.
![]() | | #15 | ![]() |
![]() Join Date: Nov 2009 Location: Dallas, Texas
Rep Power: 7054 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,745
Groans: 412
Groaned at 105 Times in 61 Posts
| Not Ranked : 0 score couch fucking is mechanical, isn't it? mechanical can be bad injector seals as well as a loose TMIC shield.
__________________ it's fun to do bad things Last edited by jack_hammer; 06-14-2012 at 01:38 PM. Reason: MSF Database - Automerged Doublepost |
![]() | | #16 | ![]() |
Thank you for clearing that up, I'm trying to not be a total noob, when it comes to this stuff. | ||
![]() | | #17 | ![]() |
| Not Ranked : 0 score I meant worst case hurt rods.
![]() | | #18 | ![]() |
It seems to only knock high when I shift between first and second gear, I checked my ic, its tight, I don't have the IC shroud on my car anymore(stupid bolt broke), the only loose thing I can see in my engine is my CAI which I'm not sure if that could be the issue or not, when I installed my downpipe I had to loosen the lower and upper engine mount to raise my engine, I checked both the upper and lower mount bolts, they're good and torqued to the correct specs as well. On my way home from class I took two logs, from 3rd gear WOT and 4th gear WOT. I haven't tried the e85 gas yet, because I live in Utah and the closest station to me is in Orem,( I plan on doing that this weekend).
![]() | | #19 | ![]() |
![]() Join Date: Feb 2010 Location: Salt Lake City, UT
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,355
as far as your knock is concerned it was hot as fuck in ur wot logs. and for knocking 1 degree with bats at 135 id say ur fine with the wot part of your tune, however, no offense, ur car is prob slow as shit at 14psi lol. as far as your pt knock is concerned, this seems to really only be an issue with gen1's. maybe it has to do with the piston design change for gen 2's but it seems like there is no way around it and just has to be accepted for the most part
__________________ ![]() GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22 EBAY DP wCAT/ CP-E RMM 75D/ HKS BPV/CP-E FP COBB EBCS/ PG FMIC/ TR8 CORE 13.2 @113.6 @ 4500ft ASL [443/409]SAE CORRECTED Last edited by snailD; 06-14-2012 at 09:43 PM. | |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
get us a wot log from 2700rpms to redline. i want to see your boost and wgdc. if its stage 2 log you should be trying to hit 18psi or so and i only see 14psi, which is spring pressure, my stage 1 cobb map in utah held a solid 15.5 psi to redline. you could have something going on that you missed
__________________ ![]() GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22 EBAY DP wCAT/ CP-E RMM 75D/ HKS BPV/CP-E FP COBB EBCS/ PG FMIC/ TR8 CORE 13.2 @113.6 @ 4500ft ASL [443/409]SAE CORRECTED |
![]() | | #22 | ![]() |
Rep Power: 271 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 337
| Not Ranked : 0 score Mechanical. GO retighten the bolts in your engine bay, motor mounts, TMIC/TMIC shroud, hooses. I was getting KR up to like 2.3 because of the TMIC shroud which was rattling against the IM (there the knock sensor is), however, you don't seem to have an aftermarket TMIC so the issue may be a bit different, but I'm just saying.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B14 PSS, SSR Type-F, Michelin PSS 225/40/R18 US Spec, CS RMM Inserts, AutoExe Street Pads Cobb SRI, SU TMIC, Cobb XLE, NGK LTR7IX, Corksport CAI Box, UR catted DP and res TP, GS EBCS, Autotech internals, GTX3071, Bosch 3BAR MAP Sensor StratiVersaTuned |
| The Following 2 Users Say Thank You to mituc For This Useful Post: | btstarcher (06-15-2012), snailD (06-14-2012) |
![]() | | #23 | ![]() |
Yeah the IC shroud is definitely a usual suspect when it comes to knock. In my case I was missing a washer, and the bolt holding it down wasn't tight enough. I'm on the stock TMIC. Your knock doesn't seem bad at all in those two logs you posted, especially considering the heat. Between shifts you will probably see knock. Nothing to be concerned about. I would definitely check out why your boost is so low. If I were you, I would definitely consider getting tuned by someone more knowledgeable here on the forums. Best money I ever spent. I was trying to do it myself, but it's alot to take in, and so much can go wrong. Some of these guides were written a long time ago. The information is good as a reference/learning tool, but some of it no longer applies, or has changed. The experts know what they're doing.
![]() | | #24 | ![]() |
![]() | | #25 | ![]() |
Groans: 412
did you ever add any octane booster or e85? if it only happens between shift, it's probably something hitting in the engine compartment, instead of being loose. the engine moves around in there. do you have any upgraded mounts? what kind of car is this? miles on it? how long have you had it?
__________________ it's fun to do bad things |
| The Following User Says Thank You to jack_hammer For This Useful Post: | rfinkle2 (06-18-2012) |
![]() | | #26 | ![]() |
![]() | | #27 | ![]() |
Groans: 412
i'm not going to comment on your logs b/c i am not into tuning... but here is the troubleshooting formula flow chart you have knock it is either mechanical or tune related to determine if it is mechanical or tune related: increase octane of fuel by either adding e85 or octane booster if it still knocks, that would indicate mechanical problems if it goes away, that would indicate tune related problems another way you could do it, is to run a milder tune if it still knocks, that would indicate mechanical problems if it goes away, that would indicate tune related problems during this entire process, you are only concerning yourself with WOT knock. also, if it really only knocks at shifts, i would look at it being something related to your engine literally moving within the engine compartment. i would, at least, inspect the RMM, take pics of it, and post.
| The Following User Says Thank You to jack_hammer For This Useful Post: | smoogs12 (06-18-2012) |
![]() | | #28 | ![]() |
I just took 5 more logs of me in WOT, which seemed to have some pretty high knock ratings, but I noticed even as I'd accerelate the knock values would still go up, until I completly let off of the gas, any know whats going on? I know my BAT"s are high still, I'm waiting for my tigs to come in, to help with that, along with I'm waiting for my colder plugs to come in as well to help with knock, but I seemed to loose all knock this week until today(it has been hotter today, so I wonder if thats one issue as well).
![]() | | #29 | ![]() |
That's some pretty high part-throttle knock...also in the 2nd log, it looks like you trimmed the beginning, unless you immediately jumped on the throttle at 3941 rpm. Which is weird, because the log should be from around 3k to redline. However it looks pretty lean to me at the beginning of that log. You really should just get someone to tune it before you blow your shit up.
![]() | | #30 | ![]() |
| Utah Mazdas ![]() Join Date: Feb 2011 Location: Utah
Rep Power: 674 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,078
Groans: 76
Groaned at 6 Times in 6 Posts
Stop running your car hard until you get the new plugs in. Its 90+ today the heat definitely isn't helping.
__________________ - 06 Black Mica MS6 - - GT3071R 24PSI - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - E20 - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 Dynojet 301 AWHP 359 AWTQ SAE Corrected on K04 and Corn Dynojet 391 AWHP 387 AWTQ SAE Corrected on 3071 and Corn |
| The Following User Says Thank You to Black Metal For This Useful Post: | Anubis450 (06-21-2012) |
![]() | | #31 | ![]() |
Groans: 153
| Not Ranked : 0 score Anubis450 Do you have access to e85?
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score Black Metal sounds good, I'm assuming that's the majority of the knock due to the past two nice days we have had. smoogs12 yeah. I'm making a trip up to one of the cities this weekend that has e85 in it to pick up a vehicle for my brother so I planned on putting a gallon in when I was down there. |
| The Following User Says Thank You to Anubis450 For This Useful Post: | smoogs12 (06-21-2012) |
![]() | | #33 | ![]() |
Have you did anything to your map since you started this thread? I remember one of the WOT logs had nothing significant except for when you shifted, which is normal. Now there's more.
![]() | | #34 | ![]() |
Groans: 153
I feel like a large part of this knock is due to the bats that you are seeing. Your latest log is definitely a bit more disconcerting but meth/e85/living someplace that isnt so fucking hot should still solve the problem I would think. That being said you should probably stop with the wot runs until you have a possible solution in place. |
![]() | | #35 | ![]() |
![]() Join Date: Nov 2011 Location: Naperville, IL
Rep Power: 2089 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 350
Groaned at 46 Times in 31 Posts
If it isn't high ass BAT's like everyone is saying, I am going to say with the amount of miles on his car it could be leaking injector seals....?
__________________ 2012 Mazdaspeed3 Black Mica HYPNOTIC TUNED, HTP full 3" intake system, HKS SSQV 4 full VTA, Corksport 65mm Racepipe, Cobb AP, Autotech Fuel Pump Internals, JBR 88duro RMM, JBR 88duro TMM, JBR 70duro PMM, JBR cylindrical shift knob, DDM tuning HID's lows and fogs, Resonator Delete. |
| The Following User Says Thank You to GODspeed7 For This Useful Post: | smoogs12 (06-21-2012) |
![]() | | #36 | ![]() |
The BAT's aren't that high. And the advance timing we see in these logs is far from being aggressive. The knock is constantly high under boost (WOT or high PT) so the injector seals may be one of the culprits.
![]() | | #37 | ![]() |
![]() | | #38 | ![]() |
You can't really check them unless you take the intake manifold off of your car and inspect them (you will see a lot of oil near the injectors with bad seals). However, there are some symptoms that are common for this problem: ticking noise when going into boost, hesitation during acceleration, high knock with no explanation (like in your case), or all at the same time depending on how bad your injector seals are now. If you add a gallon or so of E85 to a full tank of gas and the knock is still there most probably it;s something mechanical (and unless you have something loose into the engine bay that hits your IM most probably it's the seals).
| The Following User Says Thank You to mituc For This Useful Post: | Anubis450 (06-22-2012) |
![]() | | #39 | ![]() |
Sounds, good I'll definately make sure to add the e85 tomorrow, to help eliminate what the issue may be, it disappeared for about a week or so, then it got Hotter here in Utah, and the knock issue began to show up again. If it ends up being an Injector seal, its a good thing that I have the EGR delete and TIG's to install which require the same removal. What is IM by the way?
![]() | | #40 | ![]() |
Groans: 153
| New Data Logs | neofandango | 2010 MS3 - ECU Computer Tuning | 11 | 12-01-2011 03:53 PM |
| New Data Logs | neofandango | 2010 MS3 - ECU Computer Tuning | 2 | 11-23-2011 04:38 PM |
| My first data logs | Speedin | 2010 MS3 - ECU Computer Tuning | 4 | 10-16-2011 04:52 PM |
| Three Data Logs | ATAZ | MazdaSpeed 3/6 - ECU Computer Tuning | 1 | 01-02-2010 02:46 PM |
| how do my data logs look ? | jracer | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 01-01-2010 04:38 PM |
